I2C on imx8qm - Failed to enable ipg clk
Hello,
I try to get my I2C working on imx8qm. But I run into this issue:
=> i2c bus Bus 3: i2c@5a830000 => i2c dev 3 Setting bus to 3 Failed to enable ipg clk Failure changing bus number (-524)
Some idea how to fix that?
I'am using U-Boot 2020.04
Oliver
Hi Oliver,
On Wed, 5 Aug 2020 15:47:07 +0200 Oliver Graute oliver.graute@gmail.com wrote:
Hello,
I think the clock driver (in drivers/clk/imx/clk-imx8qm.c) does not have support for IMX8QM_I2C*_IPG_CLK clocks yet.
-- Anatolij
On 05/08/20, Anatolij Gustschin wrote:
Hi Oliver,
Hello,
ok, what I have to do to add support for it? just adding IMX8QM_I2C*_IPG_CLK to the imx8_clk_names[]?
Best Regards,
Oliver
Hi Oliver,
Hello,
ok I solved this issue this way:
diff --git a/drivers/clk/imx/clk-imx8qm.c b/drivers/clk/imx/clk-imx8qm.c index 54fb09fda4..7e466d630a 100644 --- a/drivers/clk/imx/clk-imx8qm.c +++ b/drivers/clk/imx/clk-imx8qm.c @@ -53,19 +53,27 @@ ulong imx8_clk_get_rate(struct clk *clk) resource = SC_R_A53; pm_clk = SC_PM_CLK_CPU; break; + case IMX8QM_I2C0_IPG_CLK: case IMX8QM_I2C0_CLK: + case IMX8QM_I2C0_DIV: resource = SC_R_I2C_0; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C1_IPG_CLK: case IMX8QM_I2C1_CLK: + case IMX8QM_I2C1_DIV: resource = SC_R_I2C_1; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C2_IPG_CLK: case IMX8QM_I2C2_CLK: + case IMX8QM_I2C2_DIV: resource = SC_R_I2C_2; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C3_IPG_CLK: case IMX8QM_I2C3_CLK: + case IMX8QM_I2C3_DIV: resource = SC_R_I2C_3; pm_clk = SC_PM_CLK_PER; break; @@ -148,19 +156,27 @@ ulong imx8_clk_set_rate(struct clk *clk, unsigned long rate) debug("%s(#%lu), rate: %lu\n", __func__, clk->id, rate);
switch (clk->id) { + case IMX8QM_I2C0_IPG_CLK: case IMX8QM_I2C0_CLK: + case IMX8QM_I2C0_DIV: resource = SC_R_I2C_0; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C1_IPG_CLK: case IMX8QM_I2C1_CLK: + case IMX8QM_I2C1_DIV: resource = SC_R_I2C_1; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C2_IPG_CLK: case IMX8QM_I2C2_CLK: + case IMX8QM_I2C2_DIV: resource = SC_R_I2C_2; pm_clk = SC_PM_CLK_PER; break; + case IMX8QM_I2C3_IPG_CLK: case IMX8QM_I2C3_CLK: + case IMX8QM_I2C3_DIV: resource = SC_R_I2C_3; pm_clk = SC_PM_CLK_PER; break; @@ -242,19 +258,27 @@ int __imx8_clk_enable(struct clk *clk, bool enable) debug("%s(#%lu)\n", __func__, clk->id);
Oliver
Anatolij Gustschin
Oliver Graute
