[U-Boot] [PATCH 1/2] env: Fix env_load_location
Commit 7d714a24d725 ("env: Support multiple environments") added static variable env_load_location. When saving environmental variables, this variable is presumed to have the value set before. In case the value was set before relocation and U-Boot runs from a NOR flash, this variable wasn't writable. This causes failure when saving the environment. To save this location, global data must be used instead.
Signed-off-by: York Sun york.sun@nxp.com CC: Maxime Ripard maxime.ripard@free-electrons.com --- Limited test on LS1043ARDB.
env/env.c | 8 +++----- include/asm-generic/global_data.h | 1 + include/environment.h | 2 +- 3 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/env/env.c b/env/env.c index 9a89832..edfb575 100644 --- a/env/env.c +++ b/env/env.c @@ -62,8 +62,6 @@ static enum env_location env_locations[] = { #endif };
-static enum env_location env_load_location = ENVL_UNKNOWN; - static bool env_has_inited(enum env_location location) { return gd->env_has_init & BIT(location); @@ -108,11 +106,11 @@ __weak enum env_location env_get_location(enum env_operation op, int prio) if (prio >= ARRAY_SIZE(env_locations)) return ENVL_UNKNOWN;
- env_load_location = env_locations[prio]; - return env_load_location; + gd->env_load_location = env_locations[prio]; + return gd->env_load_location;
case ENVOP_SAVE: - return env_load_location; + return gd->env_load_location; }
return ENVL_UNKNOWN; diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index fd8cd45..10f1441 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -51,6 +51,7 @@ typedef struct global_data { unsigned long env_addr; /* Address of Environment struct */ unsigned long env_valid; /* Environment valid? enum env_valid */ unsigned long env_has_init; /* Bitmask of boolean of struct env_location offsets */ + int env_load_location;
unsigned long ram_top; /* Top address of RAM used by U-Boot */ unsigned long relocaddr; /* Start address of U-Boot in RAM */ diff --git a/include/environment.h b/include/environment.h index a406050..0f339da 100644 --- a/include/environment.h +++ b/include/environment.h @@ -188,6 +188,7 @@ enum env_valid { };
enum env_location { + ENVL_UNKNOWN, ENVL_EEPROM, ENVL_EXT4, ENVL_FAT, @@ -202,7 +203,6 @@ enum env_location { ENVL_NOWHERE,
ENVL_COUNT, - ENVL_UNKNOWN, };
/* value for the various operations we want to perform on the env */
Commit 8a3a7e2270b3 ("env: Pass additional parameters to the env lookup function") dropped the default action if driver doesn't have get_char() defined. This causes failure to get environmental variables from NOR flash. Add back this default action for now.
env/env.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/env/env.c b/env/env.c index edfb575..210bae2 100644 --- a/env/env.c +++ b/env/env.c @@ -159,7 +159,7 @@ int env_get_char(int index) int ret;
if (!drv->get_char) - continue; + return *(uchar *)(gd->env_addr + index);
if (!env_has_inited(drv->location)) continue;
if (!drv->get_char)
continue;
Thinking more about this, I think this would break the case where the first environment in your list has no get_char method, but the second might.
Would something like that work?
------------ 8< -------- diff --git a/env/env.c b/env/env.c index 9a89832c1aaf..391c9c0df2f0 100644 --- a/env/env.c +++ b/env/env.c @@ -152,6 +152,7 @@ static struct env_driver *env_driver_lookup(enum env_operation op, int prio) int env_get_char(int index) { struct env_driver *drv; + bool has_get_char = false; int prio;
if (gd->env_valid == ENV_INVALID) @@ -166,6 +167,7 @@ int env_get_char(int index) if (!env_has_inited(drv->location)) continue;
+ has_get_char = true; ret = drv->get_char(index); if (!ret) return 0; @@ -174,6 +176,9 @@ int env_get_char(int index) drv->name, ret); }
+ if (!has_get_char) + return *(uchar *)(gd->env_addr + index); + return -ENODEV; } ------ 8< -------
Thanks! Maxime
[e-news abonnieren]http://www.pepperl-fuchs.de/e-news [YouTube: Pepperl+Fuchs auf YouTube] http://www.youtube.com/user/PepperlFuchsGmbH [@PepperlFuchsDE folgen] https://twitter.com/PepperlFuchsDE [Pepperl+Fuchs auf XING] https://www.xing.com/companies/pepperl%252bfuchsgmbh
________________________________ [Pepperl+Fuchs GmbH]http://www.pepperl-fuchs.com
Denken Sie bitte an die Umwelt und prüfen Sie, ob diese E-Mail wirklich ausgedruckt werden muss.
SocialMedia2014
Signed-off-by: York Sun york.sun@nxp.commailto:york.sun@nxp.com CC: Maxime Ripard maxime.ripard@free-electrons.commailto:maxime.ripard@free-electrons.com --- Limited test on LS1043ARDB.
How can we decide which way is wanted? With your patch below, we might end up loading chars from a low-prio environment (which is not CRC checked) in the early boot stage. Later, we load the environment from another env driver with higher priority.
That's why I suggested removing the 'get_char' callback from the env drivers :-) Early boot stage environment lookups would still work the old way reading from 'gd->env_addr + index'.
Simon
Thanks! Maxime
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.demailto:U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Sorry for the html mess, I'll resend in a minute.
Simon
Pepperl+Fuchs GmbH, Mannheim Geschaeftsfuehrer/Managing Directors: Dr.-Ing. Gunther Kegel (Vors./CEO), Werner Guthier, Mehmet Hatiboglu Vorsitzender des Aufsichtsrats/Chairman of the supervisory board: Claus Michael Registergericht/Register Court: AG Mannheim HRB 4713 On 08.02.2018 10:42, Simon Goldschmidt wrote:
Wichtiger Hinweis: Diese E-Mail einschliesslich ihrer Anhaenge enthaelt vertrauliche und rechtlich geschuetzte Informationen, die nur fuer den Adressaten bestimmt sind. Sollten Sie nicht der bezeichnete Adressat sein, so teilen Sie dies bitte dem Absender umgehend mit und loeschen Sie diese Nachricht und ihre Anhaenge. Die unbefugte Weitergabe, das Anfertigen von Kopien und jede Veraenderung der E-Mail ist untersagt. Der Absender haftet nicht fuer Inhalte von veraenderten E-Mails.
Important Information: This e-mail message including its attachments contains confidential and legally protected information solely intended for the addressee. If you are not the intended addressee of this message, please contact the addresser immediately and delete this message including its attachments. The unauthorized dissemination, copying and change of this e-mail are strictly forbidden. The addresser shall not be liable for the content of such changed e-mails.
if (!drv->get_char)
continue;
Simon
bool has_get_char = false; int prio; if (gd->env_valid == ENV_INVALID)
if (!has_get_char)
}return -ENODEV;
------ 8< -------
Thanks! Maxime
diff --git a/env/env.c b/env/env.c index edfb575..210bae2 100644 --- a/env/env.c +++ b/env/env.c @@ -159,7 +159,7 @@ int env_get_char(int index) int ret; if (!drv->get_char)
continue;
Ah, right.
If that works on York's board, I'm all in.
Maxime
Maxime, York,
I've just sent a patch that removes 'get_char' callback from the env drivers. This should restore the old behaviour we had before supporting multiple environment drivers (for all but eeprom, of course).
Simon
continue;
Ah, right.
Maxime
Thanks for your patch
case ENVOP_SAVE:
enum env_location {
- ENVL_UNKNOWN, ENVL_EEPROM, ENVL_EXT4, ENVL_FAT,
ENVL_COUNT,
- ENVL_UNKNOWN,
Why did you need to change this? This looks a bit odd.
Thanks! Maxime
Out of curiosity: which linker sections are affected of this issue? I assume only initialized data ('.data') is affected as it is left in place. Also, I assume that uninitialized data ('.bss') is not affected (as your linker can place this into ram)? If so, this issue could be fixed by changing ENVL_UNKNOWN to zero (which you already do in your patch) and leaving 'env_load_location' uninitialized, in which case it is initialized to zero (== ENVL_UNKNOWN) as defined by the C standard.
Another possibility to fix this would be to have your linker script put 'data' into ram but initialize it from rom. Something like this:
.data : { <your section contents here> } >ram AT>rom
To me, both versions would be better than to add members to struct global_dat.
case ENVOP_SAVE:
enum env_location {
ENVL_COUNT,
- ENVL_UNKNOWN,
The global data struct is initialized to zero. I guess this change is meant to ensure 'gd->env_load_location' is initialized to ENV_UNKOWN (see my comments above).
Simon
Thanks! Maxime
Leaving it as ENVL_UNKNOWN doesn't fix the problem. The env_load_location needs to be valid after relocation. Leaving it as unknown doesn't let you write env.
Not everything in initial RAM is copied to final RAM. After relocation, we shouldn't be using initial RAM at all. Actually the initial RAM may be used for other purpose.
case ENVOP_SAVE:
enum env_location {
ENVL_COUNT,
- ENVL_UNKNOWN,
Yes. That was my intention.
York
participants (5)
Goldschmidt Simon
Maxime Ripard
Simon Goldschmidt
York Sun
