[PATCH] arm64: imx8mp: Inhibit DTC warning on DH i.MX8MP DHCOM rev.100 DTO
Inhibit DTC warning in imx8mp-dhcom-pdk3-overlay-rev100.dts: " arch/arm/dts/imx8mp-dhcom-pdk3-overlay-rev100.dtbo: Warning (reg_format): /fragment@0/__overlay__:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) arch/arm/dts/imx8mp-dhcom-pdk3-overlay-rev100.dtbo: Warning (avoid_default_addr_size): /fragment@0/__overlay__: Relying on default #address-cells value arch/arm/dts/imx8mp-dhcom-pdk3-overlay-rev100.dtbo: Warning (avoid_default_addr_size): /fragment@0/__overlay__: Relying on default #size-cells value "
The DTO overwrites the 'reg' property of an ethernet PHY and is only used on specific combination of old prototype SoM and old prototype PDK3 carrier board, which had incorrectly placed pull resistor, which made the PHY change its MDIO address in that specific combination and which is already fixed on production hardware.
The DTO is implemented in this simple manner because if it contained a full MDIO bus node reference to define #address-cells and #size-cells, it would also require a full new copy of the PHY node, i.e. ethernet-phy@5 { ... reg = <5>; ... }, to avoid DTC warnings about mismatch between node unit and reg value. The node unit in SoM DT is ethernet-phy@7 { ... }; .
This simpler approach avoids unnecessary duplication without adverse side effects.
Reported-by: Fabio Estevam festevam@denx.de Reported-by: Sean Anderson seanga2@gmail.com Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Andreas Geisreiter ageisreiter@dh-electronics.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Fabio Estevam festevam@gmail.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@dh-electronics.com --- arch/arm/dts/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 66862a70be1..70845c7ac8c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1481,6 +1481,8 @@ targets += $(dtb-y) # Add any required device tree compiler flags here DTC_FLAGS += -a 0x8
+DTC_FLAGS_imx8mp-dhcom-pdk3-overlay-rev100 += -Wno-avoid_default_addr_size -Wno-reg_format + PHONY += dtbs dtbs: $(addprefix $(obj)/, $(dtb-y)) @:
- PHONY += dtbs dtbs: $(addprefix $(obj)/, $(dtb-y)) @:
Tested-by: Sean Anderson seanga2@gmail.com
Reviewed-by: Fabio Estevam festevam@gmail.com
Applied to u-boot-imx master, thanks.
Fabio Estevam
Sean Anderson
