[U-Boot] [POWERPC] muas3001: activate WDT for the muas3001 board.
Signed-off-by: Heiko Schocher hs@denx.de --- include/configs/muas3001.h | 20 +++++++++++++++++--- 1 files changed, 17 insertions(+), 3 deletions(-)
diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index 5d157b6..55f7b1e 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -38,6 +38,9 @@ /* Do boardspecific init */ #define CONFIG_BOARD_EARLY_INIT_R 1
+/* enable Watchdog */ +#define CONFIG_WATCHDOG 1 + /* * Select serial console configuration * @@ -181,8 +184,6 @@ #define CONFIG_BOOTCOMMAND "run net_nfs" #define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */
-#undef CONFIG_WATCHDOG /* disable platform specific watchdog */ - /* * Miscellaneous configurable options */ @@ -277,11 +278,24 @@ #define CFG_HID2 0
#define CFG_SIUMCR 0x00200000 -#define CFG_SYPCR 0xFFFFFFC3 #define CFG_BCR 0x004c0000 #define CFG_SCCR 0x0
/*----------------------------------------------------------------------- + * SYPCR - System Protection Control 4-35 + * SYPCR can only be written once after reset! + *----------------------------------------------------------------------- + * Watchdog & Bus Monitor Timer max, 60x Bus Monitor enable + */ +#if defined(CONFIG_WATCHDOG) +#define CFG_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ + SYPCR_SWRI|SYPCR_SWP|SYPCR_SWE) +#else +#define CFG_SYPCR (SYPCR_SWTC|SYPCR_BMT|SYPCR_PBME|SYPCR_LBME|\ + SYPCR_SWRI|SYPCR_SWP) +#endif /* CONFIG_WATCHDOG */ + +/*----------------------------------------------------------------------- * RMR - Reset Mode Register 5-5 *----------------------------------------------------------------------- * turn on Checkstop Reset Enable
Dear Heiko Schocher,
Applied, thanks.
Heiko Schocher
