[U-Boot] [PATCH] tools: mxsimage: Fix build with OpenSSL 1.1.x
The EVP_MD_CTX and EVP_CIPHER_CTX are made opaque since 1.1.x , so instead of embedding them directly into struct sb_image_ctx and initializing them using EVP_*_CTX_init(), we use pointers and allocate the crypto contexts using EVP_*_CTX_new().
Signed-off-by: Marek Vasut marex@denx.de Cc: Tom Rini trini@konsulko.com --- tools/mxsimage.c | 74 ++++++++++++++++++++++++++++++-------------------------- 1 file changed, 40 insertions(+), 34 deletions(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 98fc644..6764f9b 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -144,8 +144,8 @@ struct sb_image_ctx { struct sb_dcd_ctx *dcd_head; struct sb_dcd_ctx *dcd_tail;
- EVP_CIPHER_CTX cipher_ctx; - EVP_MD_CTX md_ctx; + EVP_CIPHER_CTX *cipher_ctx; + EVP_MD_CTX *md_ctx; uint8_t digest[32]; struct sb_key_dictionary_key sb_dict_key;
@@ -173,24 +173,26 @@ struct sb_image_ctx { */ static int sb_aes_init(struct sb_image_ctx *ictx, uint8_t *iv, int enc) { - EVP_CIPHER_CTX *ctx = &ictx->cipher_ctx; + EVP_CIPHER_CTX *ctx; int ret;
/* If there is no init vector, init vector is all zeroes. */ if (!iv) iv = ictx->image_key;
- EVP_CIPHER_CTX_init(ctx); + ctx = EVP_CIPHER_CTX_new(); ret = EVP_CipherInit(ctx, EVP_aes_128_cbc(), ictx->image_key, iv, enc); - if (ret == 1) + if (ret == 1) { EVP_CIPHER_CTX_set_padding(ctx, 0); + ictx->cipher_ctx = ctx; + } return ret; }
static int sb_aes_crypt(struct sb_image_ctx *ictx, uint8_t *in_data, uint8_t *out_data, int in_len) { - EVP_CIPHER_CTX *ctx = &ictx->cipher_ctx; + EVP_CIPHER_CTX *ctx = ictx->cipher_ctx; int ret, outlen; uint8_t *outbuf;
@@ -215,13 +217,13 @@ err:
static int sb_aes_deinit(EVP_CIPHER_CTX *ctx) { - return EVP_CIPHER_CTX_cleanup(ctx); + return EVP_CIPHER_CTX_reset(ctx); }
static int sb_aes_reinit(struct sb_image_ctx *ictx, int enc) { int ret; - EVP_CIPHER_CTX *ctx = &ictx->cipher_ctx; + EVP_CIPHER_CTX *ctx = ictx->cipher_ctx; struct sb_boot_image_header *sb_header = &ictx->payload; uint8_t *iv = sb_header->iv;
@@ -276,7 +278,7 @@ static int sb_get_time(time_t time, struct tm *tm)
static void sb_encrypt_sb_header(struct sb_image_ctx *ictx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx; struct sb_boot_image_header *sb_header = &ictx->payload; uint8_t *sb_header_ptr = (uint8_t *)sb_header;
@@ -287,7 +289,7 @@ static void sb_encrypt_sb_header(struct sb_image_ctx *ictx)
static void sb_encrypt_sb_sections_header(struct sb_image_ctx *ictx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx; struct sb_section_ctx *sctx = ictx->sect_head; struct sb_sections_header *shdr; uint8_t *sb_sections_header_ptr; @@ -307,7 +309,7 @@ static void sb_encrypt_sb_sections_header(struct sb_image_ctx *ictx)
static void sb_encrypt_key_dictionary_key(struct sb_image_ctx *ictx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx;
sb_aes_crypt(ictx, ictx->image_key, ictx->sb_dict_key.key, sizeof(ictx->sb_dict_key.key)); @@ -316,7 +318,7 @@ static void sb_encrypt_key_dictionary_key(struct sb_image_ctx *ictx)
static void sb_decrypt_key_dictionary_key(struct sb_image_ctx *ictx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx;
EVP_DigestUpdate(md_ctx, &ictx->sb_dict_key, sizeof(ictx->sb_dict_key)); sb_aes_crypt(ictx, ictx->sb_dict_key.key, ictx->image_key, @@ -326,7 +328,7 @@ static void sb_decrypt_key_dictionary_key(struct sb_image_ctx *ictx) static void sb_encrypt_tag(struct sb_image_ctx *ictx, struct sb_cmd_ctx *cctx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx; struct sb_command *cmd = &cctx->payload;
sb_aes_crypt(ictx, (uint8_t *)cmd, @@ -337,8 +339,8 @@ static void sb_encrypt_tag(struct sb_image_ctx *ictx, static int sb_encrypt_image(struct sb_image_ctx *ictx) { /* Start image-wide crypto. */ - EVP_MD_CTX_init(&ictx->md_ctx); - EVP_DigestInit(&ictx->md_ctx, EVP_sha1()); + ictx->md_ctx = EVP_MD_CTX_new(); + EVP_DigestInit(ictx->md_ctx, EVP_sha1());
/* * SB image header. @@ -379,7 +381,7 @@ static int sb_encrypt_image(struct sb_image_ctx *ictx) } else if (ccmd->header.tag == ROM_LOAD_CMD) { sb_aes_crypt(ictx, cctx->data, cctx->data, cctx->length); - EVP_DigestUpdate(&ictx->md_ctx, cctx->data, + EVP_DigestUpdate(ictx->md_ctx, cctx->data, cctx->length); }
@@ -394,11 +396,12 @@ static int sb_encrypt_image(struct sb_image_ctx *ictx) */ sb_aes_reinit(ictx, 1);
- EVP_DigestFinal(&ictx->md_ctx, ictx->digest, NULL); + EVP_DigestFinal(ictx->md_ctx, ictx->digest, NULL); + EVP_MD_CTX_free(ictx->md_ctx); sb_aes_crypt(ictx, ictx->digest, ictx->digest, sizeof(ictx->digest));
/* Stop the encryption session. */ - sb_aes_deinit(&ictx->cipher_ctx); + sb_aes_deinit(ictx->cipher_ctx);
return 0; } @@ -1322,7 +1325,7 @@ static int sb_postfill_image_header(struct sb_image_ctx *ictx) struct sb_boot_image_header *hdr = &ictx->payload; struct sb_section_ctx *sctx = ictx->sect_head; uint32_t kd_size, sections_blocks; - EVP_MD_CTX md_ctx; + EVP_MD_CTX *md_ctx;
/* The main SB header size in blocks. */ hdr->image_blocks = hdr->header_blocks; @@ -1359,13 +1362,14 @@ static int sb_postfill_image_header(struct sb_image_ctx *ictx) hdr->key_dictionary_block + kd_size / SB_BLOCK_SIZE;
/* Compute header digest. */ - EVP_MD_CTX_init(&md_ctx); + md_ctx = EVP_MD_CTX_new();
- EVP_DigestInit(&md_ctx, EVP_sha1()); - EVP_DigestUpdate(&md_ctx, hdr->signature1, + EVP_DigestInit(md_ctx, EVP_sha1()); + EVP_DigestUpdate(md_ctx, hdr->signature1, sizeof(struct sb_boot_image_header) - sizeof(hdr->digest)); - EVP_DigestFinal(&md_ctx, hdr->digest, NULL); + EVP_DigestFinal(md_ctx, hdr->digest, NULL); + EVP_MD_CTX_free(md_ctx);
return 0; } @@ -1621,12 +1625,12 @@ static int sb_verify_image_header(struct sb_image_ctx *ictx, struct tm tm; int sz, ret = 0; unsigned char digest[20]; - EVP_MD_CTX md_ctx; + EVP_MD_CTX *md_ctx; unsigned long size;
soprintf(ictx, "---------- Verifying SB Image Header ----------\n");
@@ -1637,12 +1641,13 @@ static int sb_verify_image_header(struct sb_image_ctx *ictx, }
/* Compute header digest. */ - EVP_MD_CTX_init(&md_ctx); - EVP_DigestInit(&md_ctx, EVP_sha1()); - EVP_DigestUpdate(&md_ctx, hdr->signature1, + md_ctx = EVP_MD_CTX_new(); + EVP_DigestInit(md_ctx, EVP_sha1()); + EVP_DigestUpdate(md_ctx, hdr->signature1, sizeof(struct sb_boot_image_header) - sizeof(hdr->digest)); - EVP_DigestFinal(&md_ctx, digest, NULL); + EVP_DigestFinal(md_ctx, digest, NULL); + EVP_MD_CTX_free(md_ctx);
sb_aes_init(ictx, NULL, 1); sb_encrypt_sb_header(ictx); @@ -1761,7 +1766,7 @@ static int sb_verify_image_header(struct sb_image_ctx *ictx, static void sb_decrypt_tag(struct sb_image_ctx *ictx, struct sb_cmd_ctx *cctx) { - EVP_MD_CTX *md_ctx = &ictx->md_ctx; + EVP_MD_CTX *md_ctx = ictx->md_ctx; struct sb_command *cmd = &cctx->payload;
sb_aes_crypt(ictx, (uint8_t *)&cctx->c_payload, @@ -1818,7 +1823,7 @@ static int sb_verify_command(struct sb_image_ctx *ictx,
*tsize += size;
- EVP_DigestUpdate(&ictx->md_ctx, cctx->data, asize); + EVP_DigestUpdate(ictx->md_ctx, cctx->data, asize); sb_aes_crypt(ictx, cctx->data, cctx->data, asize);
if (ccmd->load.crc32 != pbl_crc32(0, @@ -2007,7 +2012,8 @@ static int sb_verify_image_end(struct sb_image_ctx *ictx, }
/* Check the image digest. */ - EVP_DigestFinal(&ictx->md_ctx, ictx->digest, NULL); + EVP_DigestFinal(ictx->md_ctx, ictx->digest, NULL); + EVP_MD_CTX_free(ictx->md_ctx);
/* Decrypt the image digest from the input image. */ sb_aes_reinit(ictx, 0); @@ -2083,7 +2089,7 @@ err_verify: soprintf(ictx, "Verification %s\n", ret ? "FAILED" : "PASSED");
fclose(fp); return ret;
