[U-Boot] [PATCH V5] ARM: mx6: Add support for Kosagi Novena
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Sean Cross xobs@kosagi.com Cc: Nikolay Dimitrov picmaster@mail.bg --- arch/arm/Kconfig | 4 + board/kosagi/novena/Kconfig | 23 ++ board/kosagi/novena/Makefile | 11 + board/kosagi/novena/novena.c | 342 +++++++++++++++++++++++ board/kosagi/novena/novena_spl.c | 581 +++++++++++++++++++++++++++++++++++++++ board/kosagi/novena/setup.cfg | 47 ++++ configs/novena_defconfig | 4 + include/configs/imx6_spl.h | 2 +- include/configs/novena.h | 303 ++++++++++++++++++++ 9 files changed, 1316 insertions(+), 1 deletion(-) create mode 100644 board/kosagi/novena/Kconfig create mode 100644 board/kosagi/novena/Makefile create mode 100644 board/kosagi/novena/novena.c create mode 100644 board/kosagi/novena/novena_spl.c create mode 100644 board/kosagi/novena/setup.cfg create mode 100644 configs/novena_defconfig create mode 100644 include/configs/novena.h
V2: - Drop the tegra_keyboard_init() comment altogether - Immediatelly return from the SD controller probe function on failure - Rename PFUZE100_PMIC to just PFUZE100 - Fix the IMX OTP support with CMD_FUSE - Enabling LVDS clock is still in place, since this is coming soon. V3: - Zap rootpath builtin env V4: - Zap the checkpatch issues - Update comments V5: - Don't configure VGEN1 - Set FPGA into reset in SPL - Drop ECSPI1 and add ECSPI3 mux - Drop UART1 and add UART3, UART4 muxes - Add separate mux option for the RGMII pins which doesn't set SPEED field - Move the configuration of RGMII after they were configured in GPIO mode
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 106aed9..4da1923 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -411,6 +411,9 @@ config TARGET_GW_VENTANA config TARGET_HUMMINGBOARD bool "Support hummingboard"
+config TARGET_KOSAGI_NOVENA + bool "Support Kosagi Novena" + config TARGET_TQMA6 bool "TQ Systems TQMa6 board"
@@ -637,6 +640,7 @@ source "board/imx31_phycore/Kconfig" source "board/isee/igep0033/Kconfig" source "board/jornada/Kconfig" source "board/karo/tx25/Kconfig" +source "board/kosagi/novena/Kconfig" source "board/logicpd/imx27lite/Kconfig" source "board/logicpd/imx31_litekit/Kconfig" source "board/mpl/vcma9/Kconfig" diff --git a/board/kosagi/novena/Kconfig b/board/kosagi/novena/Kconfig new file mode 100644 index 0000000..4e52be9 --- /dev/null +++ b/board/kosagi/novena/Kconfig @@ -0,0 +1,23 @@ +if TARGET_KOSAGI_NOVENA + +config SYS_CPU + string + default "armv7" + +config SYS_BOARD + string + default "novena" + +config SYS_VENDOR + string + default "kosagi" + +config SYS_SOC + string + default "mx6" + +config SYS_CONFIG_NAME + string + default "novena" + +endif diff --git a/board/kosagi/novena/Makefile b/board/kosagi/novena/Makefile new file mode 100644 index 0000000..6fba177 --- /dev/null +++ b/board/kosagi/novena/Makefile @@ -0,0 +1,11 @@ +# +# Copyright (C) 2014 Marek Vasut marex@denx.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_SPL_BUILD +obj-y := novena_spl.o +else +obj-y := novena.o +endif diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c new file mode 100644 index 0000000..84aee16 --- /dev/null +++ b/board/kosagi/novena/novena.c @@ -0,0 +1,342 @@ +/* + * Novena board support + * + * Copyright (C) 2014 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/sata.h> +#include <asm/imx-common/video.h> +#include <fsl_esdhc.h> +#include <i2c.h> +#include <input.h> +#include <ipu_pixfmt.h> +#include <linux/fb.h> +#include <linux/input.h> +#include <malloc.h> +#include <micrel.h> +#include <miiphy.h> +#include <mmc.h> +#include <netdev.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> +#include <stdio_dev.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define NOVENA_BUTTON_GPIO IMX_GPIO_NR(4, 14) +#define NOVENA_SD_CD IMX_GPIO_NR(1, 4) +#define NOVENA_USB_HUB_RESET IMX_GPIO_NR(7, 12) + +/* + * GPIO button + */ +#ifdef CONFIG_KEYBOARD +static struct input_config button_input; + +static int novena_gpio_button_read_keys(struct input_config *input) +{ + int key = KEY_ENTER; + if (gpio_get_value(NOVENA_BUTTON_GPIO)) + return 0; + input_send_keycodes(&button_input, &key, 1); + return 1; +} + +static int novena_gpio_button_getc(struct stdio_dev *dev) +{ + return input_getc(&button_input); +} +static int novena_gpio_button_tstc(struct stdio_dev *dev) +{ + return input_tstc(&button_input); +} + +static int novena_gpio_button_init(struct stdio_dev *dev) +{ + gpio_direction_input(NOVENA_BUTTON_GPIO); + input_set_delays(&button_input, 250, 250); + return 0; +} + +int drv_keyboard_init(void) +{ + int error; + struct stdio_dev dev = { + .name = "button", + .flags = DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM, + .start = novena_gpio_button_init, + .getc = novena_gpio_button_getc, + .tstc = novena_gpio_button_tstc, + }; + + error = input_init(&button_input, 0); + if (error) { + debug("%s: Cannot set up input\n", __func__); + return -1; + } + button_input.read_keys = novena_gpio_button_read_keys; + + error = input_stdio_register(&dev); + if (error) + return error; + + return 0; +} +#endif + +/* + * SDHC + */ +#ifdef CONFIG_FSL_ESDHC +static struct fsl_esdhc_cfg usdhc_cfg[] = { + { USDHC3_BASE_ADDR, 0, 4 }, /* Micro SD */ + { USDHC2_BASE_ADDR, 0, 4 }, /* Big SD */ +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + /* There is no CD for a microSD card, assume always present. */ + if (cfg->esdhc_base == USDHC3_BASE_ADDR) + return 1; + else + return !gpio_get_value(NOVENA_SD_CD); +} + +int board_mmc_init(bd_t *bis) +{ + s32 status = 0; + int index; + + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + + for (index = 0; index < ARRAY_SIZE(usdhc_cfg); index++) { + status = fsl_esdhc_initialize(bis, &usdhc_cfg[index]); + if (status) + return status; + } + + return status; +} +#endif + +/* + * USB + */ +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + /* Reset USB hub */ + if (port == 1) { + gpio_set_value(NOVENA_USB_HUB_RESET, 0); + mdelay(2); + gpio_set_value(NOVENA_USB_HUB_RESET, 1); + } + return 0; +} +#endif + +/* + * Video over HDMI + */ +#if defined(CONFIG_VIDEO_IPUV3) +static void enable_hdmi(struct display_info_t const *dev) +{ + imx_enable_hdmi_phy(); +} + +struct display_info_t const displays[] = { + { + /* HDMI Output */ + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = detect_hdmi, + .enable = enable_hdmi, + .mode = { + .name = "HDMI", + .refresh = 60, + .xres = 1024, + .yres = 768, + .pixclock = 15385, + .left_margin = 220, + .right_margin = 40, + .upper_margin = 21, + .lower_margin = 7, + .hsync_len = 60, + .vsync_len = 10, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED + } + } +}; + +size_t display_count = ARRAY_SIZE(displays); + +static void setup_display(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + enable_ipu_clock(); + imx_setup_hdmi(); + + /* Turn on LDB0,IPU,IPU DI0 clocks */ + setbits_le32(&mxc_ccm->CCGR3, MXC_CCM_CCGR3_LDB_DI0_MASK); + + /* set LDB0, LDB1 clk select to 011/011 */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK | + MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK, + (3 << MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) | + (3 << MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET)); + + setbits_le32(&mxc_ccm->cscmr2, MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV); + + setbits_le32(&mxc_ccm->chsccdr, CHSCCDR_CLK_SEL_LDB_DI0 << + MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); + + writel(IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES | + IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH | + IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_LOW | + IOMUXC_GPR2_BIT_MAPPING_CH1_SPWG | + IOMUXC_GPR2_DATA_WIDTH_CH1_18BIT | + IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG | + IOMUXC_GPR2_DATA_WIDTH_CH0_18BIT | + IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED | + IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0, + &iomux->gpr[2]); + + clrsetbits_le32(&iomux->gpr[3], IOMUXC_GPR3_LVDS0_MUX_CTL_MASK, + IOMUXC_GPR3_MUX_SRC_IPU1_DI0 << + IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); +} +#endif + +int board_early_init_f(void) +{ +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + + /* Bring Ethernet PHY out of reset. */ + gpio_set_value(IMX_GPIO_NR(3, 23), 1); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + +#ifdef CONFIG_CMD_SATA + setup_sata(); +#endif + + return 0; +} + +int checkboard(void) +{ + puts("Board: Novena 4x\n"); + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + return 0; +} + +/* setup board specific PMIC */ +int power_init_board(void) +{ + struct pmic *p; + u32 reg; + int ret; + + power_pfuze100_init(1); + p = pmic_get("PFUZE100"); + if (!p) + return -EINVAL; + + ret = pmic_probe(p); + if (ret) + return ret; + + pmic_reg_read(p, PFUZE100_DEVICEID, ®); + printf("PMIC: PFUZE100 ID=0x%02x\n", reg); + + /* Set SWBST to 5.0V and enable (for USB) */ + pmic_reg_read(p, PFUZE100_SWBSTCON1, ®); + reg &= ~(SWBST_MODE_MASK | SWBST_VOL_MASK); + reg |= (SWBST_5_00V | SWBST_MODE_AUTO); + pmic_reg_write(p, PFUZE100_SWBSTCON1, reg); + + return 0; +} + +/* EEPROM configuration data */ +struct novena_eeprom_data { + uint8_t signature[6]; + uint8_t version; + uint8_t reserved; + uint32_t serial; + uint8_t mac[6]; + uint16_t features; +}; + +int misc_init_r(void) +{ + struct novena_eeprom_data data; + uchar *datap = (uchar *)&data; + const char *signature = "Novena"; + int ret; + + /* If 'ethaddr' is already set, do nothing. */ + if (getenv("ethaddr")) + return 0; + + /* EEPROM is at bus 2. */ + ret = i2c_set_bus_num(2); + if (ret) { + puts("Cannot select EEPROM I2C bus.\n"); + return 0; + } + + /* EEPROM is at address 0x56. */ + ret = eeprom_read(0x56, 0, datap, sizeof(data)); + if (ret) { + puts("Cannot read I2C EEPROM.\n"); + return 0; + } + + /* Check EEPROM signature. */ + if (memcmp(data.signature, signature, 6)) { + puts("Invalid I2C EEPROM signature.\n"); + return 0; + } + + /* Set ethernet address from EEPROM. */ + eth_setenv_enetaddr("ethaddr", data.mac); + + return ret; +} diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c new file mode 100644 index 0000000..5e1ada1 --- /dev/null +++ b/board/kosagi/novena/novena_spl.c @@ -0,0 +1,581 @@ +/* + * Novena SPL + * + * Copyright (C) 2014 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/mxc_i2c.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <spl.h> + +#include <asm/arch/mx6-ddr.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_47K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define ENET_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define RGMII_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL \ + (PAD_CTL_HYS | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_240ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE) + +#define BUTTON_PAD_CTRL \ + (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +#define NOVENA_AUDIO_PWRON IMX_GPIO_NR(5, 17) +#define NOVENA_FPGA_RESET_N_GPIO IMX_GPIO_NR(5, 7) +#define NOVENA_HDMI_GHOST_HPD IMX_GPIO_NR(5, 4) +#define NOVENA_PCIE_RESET_GPIO IMX_GPIO_NR(3, 29) +#define NOVENA_PCIE_POWER_ON_GPIO IMX_GPIO_NR(7, 12) +#define NOVENA_PCIE_WAKE_UP_GPIO IMX_GPIO_NR(3, 22) +#define NOVENA_PCIE_DISABLE_GPIO IMX_GPIO_NR(2, 16) + +/* + * Audio + */ +static iomux_v3_cfg_t audio_pads[] = { + /* AUD_PWRON */ + MX6_PAD_DISP0_DAT23__GPIO5_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_audio(void) +{ + imx_iomux_v3_setup_multiple_pads(audio_pads, ARRAY_SIZE(audio_pads)); + gpio_direction_output(NOVENA_AUDIO_PWRON, 1); +} + +/* + * ENET + */ +static iomux_v3_cfg_t enet_pads1[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* pin 35 - 1 (PHY_AD2) on reset */ + MX6_PAD_RGMII_RXC__GPIO6_IO30 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 32 - 1 - (MODE0) all */ + MX6_PAD_RGMII_RD0__GPIO6_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 31 - 1 - (MODE1) all */ + MX6_PAD_RGMII_RD1__GPIO6_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 28 - 1 - (MODE2) all */ + MX6_PAD_RGMII_RD2__GPIO6_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 27 - 1 - (MODE3) all */ + MX6_PAD_RGMII_RD3__GPIO6_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 33 - 1 - (CLK125_EN) 125Mhz clockout enabled */ + MX6_PAD_RGMII_RX_CTL__GPIO6_IO24 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* pin 42 PHY nRST */ + MX6_PAD_EIM_D23__GPIO3_IO23 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t enet_pads2[] = { + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(RGMII_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(RGMII_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads1, ARRAY_SIZE(enet_pads1)); + + gpio_direction_output(IMX_GPIO_NR(3, 23), 0); + gpio_direction_output(IMX_GPIO_NR(6, 30), 1); + gpio_direction_output(IMX_GPIO_NR(6, 25), 1); + gpio_direction_output(IMX_GPIO_NR(6, 27), 1); + gpio_direction_output(IMX_GPIO_NR(6, 28), 1); + gpio_direction_output(IMX_GPIO_NR(6, 29), 1); + gpio_direction_output(IMX_GPIO_NR(6, 24), 1); + + imx_iomux_v3_setup_multiple_pads(enet_pads2, ARRAY_SIZE(enet_pads2)); +} + +/* + * FPGA + */ +static iomux_v3_cfg_t fpga_pads[] = { + /* FPGA_RESET_N */ + MX6_PAD_DISP0_DAT13__GPIO5_IO07 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_fpga(void) +{ + imx_iomux_v3_setup_multiple_pads(fpga_pads, ARRAY_SIZE(fpga_pads)); + gpio_direction_output(NOVENA_FPGA_RESET_N_GPIO, 0); +} + +/* + * GPIO Button + */ +static iomux_v3_cfg_t button_pads[] = { + /* Debug */ + MX6_PAD_KEY_COL4__GPIO4_IO14 | MUX_PAD_CTRL(BUTTON_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_buttons(void) +{ + imx_iomux_v3_setup_multiple_pads(button_pads, ARRAY_SIZE(button_pads)); +} + +/* + * I2C + */ +/* + * I2C1: + * 0x1d ... MMA7455L + * 0x30 ... SO-DIMM temp sensor + * 0x44 ... STMPE610 + * 0x50 ... SO-DIMM ID + */ +struct i2c_pads_info i2c_pad_info0 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D21__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D21__GPIO3_IO21 | PC, + .gp = IMX_GPIO_NR(3, 21) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D28__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D28__GPIO3_IO28 | PC, + .gp = IMX_GPIO_NR(3, 28) + } +}; + +/* + * I2C2: + * 0x08 ... PMIC + * 0x3a ... HDMI DCC + * 0x50 ... HDMI DCC + */ +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_EB2__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | PC, + .gp = IMX_GPIO_NR(2, 30) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D16__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D16__GPIO3_IO16 | PC, + .gp = IMX_GPIO_NR(3, 16) + } +}; + +/* + * I2C3: + * 0x11 ... ES8283 + * 0x50 ... LCD EDID + * 0x56 ... EEPROM + */ +static struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_EIM_D17__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_EIM_D17__GPIO3_IO17 | PC, + .gp = IMX_GPIO_NR(3, 17) + }, + .sda = { + .i2c_mode = MX6_PAD_EIM_D18__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_EIM_D18__GPIO3_IO18 | PC, + .gp = IMX_GPIO_NR(3, 18) + } +}; + +static void novena_spl_setup_iomux_i2c(void) +{ + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info0); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info2); +} + +/* + * PCI express + */ +#ifdef CONFIG_CMD_PCI +static iomux_v3_cfg_t pcie_pads[] = { + /* "Reset" pin */ + MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* "Power on" pin */ + MX6_PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* "Wake up" pin (input) */ + MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* "Disable endpoint" (rfkill) pin */ + MX6_PAD_EIM_A22__GPIO2_IO16 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_pcie(void) +{ + imx_iomux_v3_setup_multiple_pads(pcie_pads, ARRAY_SIZE(pcie_pads)); + + /* Ensure PCIe is powered down */ + gpio_direction_output(NOVENA_PCIE_POWER_ON_GPIO, 0); + + /* Put the card into reset */ + gpio_direction_output(NOVENA_PCIE_RESET_GPIO, 0); + + /* Input signal to wake system from mPCIe card */ + gpio_direction_input(NOVENA_PCIE_WAKE_UP_GPIO); + + /* Drive RFKILL high, to ensure the radio is turned on */ + gpio_direction_output(NOVENA_PCIE_DISABLE_GPIO, 1); +} +#else +static inline void novena_spl_setup_iomux_pcie(void) {} +#endif + +/* + * SDHC + */ +static iomux_v3_cfg_t usdhc2_pads[] = { + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ +}; + +static iomux_v3_cfg_t usdhc3_pads[] = { + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_sdhc(void) +{ + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + + /* Micro SD card detect */ + gpio_direction_input(IMX_GPIO_NR(7, 0)); + + /* Big SD card detect */ + gpio_direction_input(IMX_GPIO_NR(1, 4)); +} + +/* + * SPI + */ +#ifdef CONFIG_MXC_SPI +static iomux_v3_cfg_t ecspi3_pads[] = { + /* SS1 */ + MX6_PAD_DISP0_DAT1__ECSPI3_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT2__ECSPI3_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT0__ECSPI3_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT3__GPIO4_IO24 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT4__GPIO4_IO25 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT5__GPIO4_IO26 | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_DISP0_DAT7__ECSPI3_RDY | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi3_pads, ARRAY_SIZE(ecspi3_pads)); + /* De-assert the nCS */ + gpio_direction_output(MX6_PAD_DISP0_DAT3__GPIO4_IO24, 1); + gpio_direction_output(MX6_PAD_DISP0_DAT4__GPIO4_IO25, 1); + gpio_direction_output(MX6_PAD_DISP0_DAT5__GPIO4_IO26, 1); +} +#else +static void novena_spl_setup_iomux_spi(void) {} +#endif + +/* + * UART + */ +static iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart3_pads[] = { + MX6_PAD_EIM_D24__UART3_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D25__UART3_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart4_pads[] = { + MX6_PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT16__UART4_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT17__UART4_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + +}; + +static void novena_spl_setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); + imx_iomux_v3_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads)); + imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); +} + +/* + * USB + */ +#ifdef CONFIG_USB_EHCI_MX6 +static iomux_v3_cfg_t usb_pads[] = { + MX6_PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_usb(void) +{ + imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); +} +#else +static void novena_spl_setup_iomux_usb(void) {} +#endif + +/* + * Video + */ +#ifdef CONFIG_VIDEO +static iomux_v3_cfg_t hdmi_pads[] = { + /* "Ghost HPD" pin */ + MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void novena_spl_setup_iomux_video(void) +{ + imx_iomux_v3_setup_multiple_pads(hdmi_pads, ARRAY_SIZE(hdmi_pads)); + gpio_direction_input(NOVENA_HDMI_GHOST_HPD); +} +#else +static inline void novena_spl_setup_iomux_video(void) {} +#endif + +/* + * SPL boots from uSDHC card + */ +#ifdef CONFIG_FSL_ESDHC +static struct fsl_esdhc_cfg usdhc_cfg = { + USDHC3_BASE_ADDR, 0, 4 +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + /* There is no CD for a microSD card, assume always present. */ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + return fsl_esdhc_initialize(bis, &usdhc_cfg); +} +#endif + +/* Configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs novena_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = 0x00020038, + .dram_sdclk_1 = 0x00020038, + .dram_cas = 0x00000038, + .dram_ras = 0x00000038, + .dram_reset = 0x00000038, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00000038, + .dram_sdodt1 = 0x00000038, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = 0x00000038, + .dram_sdqs1 = 0x00000038, + .dram_sdqs2 = 0x00000038, + .dram_sdqs3 = 0x00000038, + .dram_sdqs4 = 0x00000038, + .dram_sdqs5 = 0x00000038, + .dram_sdqs6 = 0x00000038, + .dram_sdqs7 = 0x00000038, + + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = 0x00000038, + .dram_dqm1 = 0x00000038, + .dram_dqm2 = 0x00000038, + .dram_dqm3 = 0x00000038, + .dram_dqm4 = 0x00000038, + .dram_dqm5 = 0x00000038, + .dram_dqm6 = 0x00000038, + .dram_dqm7 = 0x00000038, +}; + +/* Configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs novena_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + /* Disable DDR pullups */ + .grp_ddrpke = 0x00000000, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = 0x00000038, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = 0x00000038, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = 0x00020000, + .grp_b0ds = 0x00000038, + .grp_b1ds = 0x00000038, + .grp_b2ds = 0x00000038, + .grp_b3ds = 0x00000038, + .grp_b4ds = 0x00000038, + .grp_b5ds = 0x00000038, + .grp_b6ds = 0x00000038, + .grp_b7ds = 0x00000038, +}; + +static struct mx6_mmdc_calibration novena_mmdc_calib = { + /* write leveling calibration determine */ + .p0_mpwldectrl0 = 0x00420048, + .p0_mpwldectrl1 = 0x006f0059, + .p1_mpwldectrl0 = 0x005a0104, + .p1_mpwldectrl1 = 0x01070113, + /* Read DQS Gating calibration */ + .p0_mpdgctrl0 = 0x437c040b, + .p0_mpdgctrl1 = 0x0413040e, + .p1_mpdgctrl0 = 0x444f0446, + .p1_mpdgctrl1 = 0x044d0422, + /* Read Calibration: DQS delay relative to DQ read access */ + .p0_mprddlctl = 0x4c424249, + .p1_mprddlctl = 0x4e48414f, + /* Write Calibration: DQ/DM delay relative to DQS write access */ + .p0_mpwrdlctl = 0x42414641, + .p1_mpwrdlctl = 0x46374b43, +}; + +static struct mx6_ddr_sysinfo novena_ddr_info = { + /* Width of data bus: 0=16, 1=32, 2=64 */ + .dsize = 2, + /* Config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + /* Single chip select */ + .ncs = 1, + .cs1_mirror = 0, + .rtt_wr = 1, /* RTT_Wr = RZQ/4 */ + .rtt_nom = 2, /* RTT_Nom = RZQ/2 */ + .walat = 3, /* Write additional latency */ + .ralat = 7, /* Read additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ + .bi_on = 1, /* Bank interleaving enabled */ + .sde_to_rst = 0x10, /* 14 cycles, 200us (JEDEC default) */ + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ +}; + +static struct mx6_ddr3_cfg elpida_4gib_1600 = { + .mem_speed = 1600, + .density = 4, + .width = 64, + .banks = 8, + .rowaddr = 16, + .coladdr = 10, + .pagesz = 2, + .trcd = 1300, + .trcmin = 4900, + .trasmin = 3590, +}; + +/* + * called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + /* + * Zero out global data: + * - this should be done by crt0.S + * - failure to zero it will cause i2c_setup to fail + */ + memset((void *)gd, 0, sizeof(struct global_data)); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + /* setup GP timer */ + timer_init(); + +#ifdef CONFIG_BOARD_POSTCLK_INIT + board_postclk_init(); +#endif +#ifdef CONFIG_FSL_ESDHC + get_clocks(); +#endif + + /* Setup IOMUX and configure basics. */ + novena_spl_setup_iomux_audio(); + novena_spl_setup_iomux_buttons(); + novena_spl_setup_iomux_enet(); + novena_spl_setup_iomux_fpga(); + novena_spl_setup_iomux_i2c(); + novena_spl_setup_iomux_pcie(); + novena_spl_setup_iomux_sdhc(); + novena_spl_setup_iomux_spi(); + novena_spl_setup_iomux_uart(); + novena_spl_setup_iomux_usb(); + novena_spl_setup_iomux_video(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* Start the DDR DRAM */ + mx6dq_dram_iocfg(64, &novena_ddr_ioregs, &novena_grp_ioregs); + mx6_dram_cfg(&novena_ddr_info, &novena_mmdc_calib, &elpida_4gib_1600); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + +void reset_cpu(ulong addr) +{ +} diff --git a/board/kosagi/novena/setup.cfg b/board/kosagi/novena/setup.cfg new file mode 100644 index 0000000..18d139c --- /dev/null +++ b/board/kosagi/novena/setup.cfg @@ -0,0 +1,47 @@ +/* + * Copyright (C) 2014 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* Boot Device : sd */ +BOOT_FROM sd + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00C03F3F +DATA 4, CCM_CCGR1, 0x0030FC03 +DATA 4, CCM_CCGR2, 0x0FFFC000 +DATA 4, CCM_CCGR3, 0x3FF00000 +DATA 4, CCM_CCGR4, 0xFFFFF300 /* enable NAND/GPMI/BCH clocks */ +DATA 4, CCM_CCGR5, 0x0F0000C3 +DATA 4, CCM_CCGR6, 0x000003FF + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F + +/* + * Setup CCM_CCOSR register as follows: + * + * cko1_en = 1 --> CKO1 enabled + * cko1_div = 111 --> divide by 8 + * cko1_sel = 1011 --> ahb_clk_root + * + * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz + */ +DATA 4, CCM_CCOSR, 0x000000fb diff --git a/configs/novena_defconfig b/configs/novena_defconfig new file mode 100644 index 0000000..a560afb --- /dev/null +++ b/configs/novena_defconfig @@ -0,0 +1,4 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/kosagi/novena/setup.cfg,MX6Q,SPL" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_KOSAGI_NOVENA=y diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 970460d..52fe9cf 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -27,7 +27,7 @@ #define CONFIG_SYS_THUMB_BUILD #define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/omap-common/u-boot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x00908000 -#define CONFIG_SPL_MAX_SIZE (64 * 1024) +#define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_START_S_PATH "arch/arm/cpu/armv7" #define CONFIG_SPL_STACK 0x0091FFB8 #define CONFIG_SPL_LIBCOMMON_SUPPORT diff --git a/include/configs/novena.h b/include/configs/novena.h new file mode 100644 index 0000000..2d38189 --- /dev/null +++ b/include/configs/novena.h @@ -0,0 +1,303 @@ +/* + * Configuration settings for the Novena U-boot. + * + * Copyright (C) 2014 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* System configurations */ +#define CONFIG_MX6 +#define CONFIG_SYS_MX6_HCLK 24000000 +#define CONFIG_SYS_MX6_CLK32 32768 +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MISC_INIT_R +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_FIT +#define CONFIG_KEYBOARD +#define CONFIG_MXC_GPIO +#define CONFIG_OF_LIBFDT +#define CONFIG_REGEX +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_SYS_NO_FLASH + +#include "configs/mx6_common.h" +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> +#include <config_cmd_default.h> + +/* U-Boot Commands */ +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FAT +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_I2C +#define CONFIG_CMD_FUSE +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_SATA +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_TIME +#define CONFIG_CMD_USB +#define CONFIG_VIDEO + +/* U-Boot general configurations */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O buffer size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + /* Print buffer size */ +#define CONFIG_SYS_MAXARGS 32 /* Max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + /* Boot argument buffer size */ +#define CONFIG_VERSION_VARIABLE /* U-BOOT version */ +#define CONFIG_AUTO_COMPLETE /* Command auto complete */ +#define CONFIG_CMDLINE_EDITING /* Command history etc */ +#define CONFIG_SYS_HUSH_PARSER + +/* U-Boot environment */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_SIZE (16 * 1024) +/* + * Environment is on MMC, starting at offset 64KiB from start of the card. + * Please place first partition at offset 1MiB from the start of the card + * as recommended by GNU/fdisk. See below for details: + * http://homepage.ntlworld.com./jonathan.deboynepollard/FGA/disc-partition-ali... + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_OFFSET (512 * 1024) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET_REDUND \ + (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#else +#define CONFIG_ENV_IS_NOWHERE +#endif + +/* Booting Linux */ +#define CONFIG_BOOTDELAY 5 +#define CONFIG_BOOTFILE "fitImage" +#define CONFIG_BOOTARGS "console=ttymxc1,115200 " +#define CONFIG_BOOTCOMMAND "run net_nfs" +#define CONFIG_LOADADDR 0x18000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_HOSTNAME novena + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define PHYS_SDRAM_SIZE 0xF0000000 + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x20000000 + +#define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) + +/* SPL */ +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#include "imx6_spl.h" /* common IMX6 SPL configuration */ + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Ethernet Configuration */ +#ifdef CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0x7 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9021 +#define CONFIG_ARP_TIMEOUT 200UL +#endif + +/* I2C */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_MXC +#define CONFIG_SYS_I2C_SPEED 100000 + +/* I2C EEPROM */ +#ifdef CONFIG_CMD_EEPROM +#define CONFIG_SYS_I2C_MULTI_EEPROMS +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_SPD_BUS_NUM 2 +#endif + +/* MMC Configs */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#endif + +/* OCOTP Configs */ +#ifdef CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP +#endif + +/* PCI express */ +#undef CONFIG_CMD_PCI /* Disable to prevent Linux from hanging on MX6 */ +#ifdef CONFIG_CMD_PCI +#define CONFIG_PCI +#define CONFIG_PCI_PNP +#define CONFIG_PCI_SCAN_SHOW +#define CONFIG_PCIE_IMX +#define CONFIG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(3, 29) +#define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(7, 12) +#endif + +/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 + +/* SATA Configs */ +#ifdef CONFIG_CMD_SATA +#define CONFIG_DWC_AHSATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_DWC_AHSATA_PORT_ID 0 +#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR +#define CONFIG_LBA48 +#define CONFIG_LIBATA +#endif + +/* UART */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_CONS_INDEX 1 + +/* USB Configs */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_KEYBOARD +#define CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +/* Gadget part */ +#define CONFIG_CI_UDC +#define CONFIG_USBD_HS +#define CONFIG_USB_GADGET_DUALSPEED +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_CDC +#define CONFIG_NETCONSOLE +#endif + +/* Video output */ +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 260000000 +#define CONFIG_CMD_HDMIDETECT +#define CONFIG_CONSOLE_MUX +#define CONFIG_IMX_HDMI +#define CONFIG_IMX_VIDEO_SKIP +#endif + +/* Extra U-Boot environment. */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "consdev=ttymxc1\0" \ + "baudrate=115200\0" \ + "bootdev=/dev/mmcblk0p1\0" \ + "rootdev=/dev/mmcblk0p2\0" \ + "netdev=eth0\0" \ + "rootpath=/opt/eldk-5.5/armv7a-hf/rootfs-qte-sdk\0" \ + "kernel_addr_r=0x18000000\0" \ + "addcons=" \ + "setenv bootargs ${bootargs} " \ + "console=${consdev},${baudrate}\0" \ + "addip=" \ + "setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:" \ + "${netmask}:${hostname}:${netdev}:off\0" \ + "addmisc=" \ + "setenv bootargs ${bootargs} ${miscargs}\0" \ + "addargs=run addcons addmisc\0" \ + "mmcload=" \ + "mmc rescan ; " \ + "ext4load mmc 0:1 ${kernel_addr_r} ${bootfile}\0" \ + "netload=" \ + "tftp ${kernel_addr_r} ${hostname}/${bootfile}\0" \ + "miscargs=nohlt panic=1\0" \ + "mmcargs=setenv bootargs root=${rootdev} rw rootwait\0" \ + "nfsargs=" \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath},v3,tcp\0" \ + "mmc_mmc=" \ + "run mmcload mmcargs addargs ; " \ + "bootm ${kernel_addr_r}\0" \ + "mmc_nfs=" \ + "run mmcload nfsargs addip addargs ; " \ + "bootm ${kernel_addr_r}\0" \ + "net_mmc=" \ + "run netload mmcargs addargs ; " \ + "bootm ${kernel_addr_r}\0" \ + "net_nfs=" \ + "run netload nfsargs addip addargs ; " \ + "bootm ${kernel_addr_r}\0" \ + "update_sd_spl_filename=SPL\0" \ + "update_sd_uboot_filename=u-boot.img\0" \ + "update_sd_firmware=" /* Update the SD firmware partition */ \ + "if mmc rescan ; then " \ + "if dhcp ${update_sd_spl_filename} ; then " \ + "mmc write ${loadaddr} 2 0x200 ; " \ + "fi ; " \ + "if dhcp ${update_sd_uboot_filename} ; then " \ + "fatwrite mmc 0:1 ${loadaddr} u-boot.img ${filesize} ; "\ + "fi ; " \ + "fi\0" \ + +#endif /* __CONFIG_H */
- I2C busses
- FEC Ethernet
- SATA
- USB ports
- USB Ethernet
This patch looks good. It resets the FPGA, muxes the correct UART lines, and detects USB devices. It doesn't have the newer FEC reset sequence, but is the idea for Nikolay to submit that separately in order to get credit for it?
Sean
- I2C busses
- FEC Ethernet
- SATA
- USB ports
- USB Ethernet
I would be happy to do it that way, what do you think ?
Best regards, Marek Vasut
Hi Marek,
I'm marking only the critical issues that are left unfixed from previous conversations, to speed-up the process a little bit. I'll send later patches for the non-critical issues to spare you the extra work (and I'm sure my constructive criticism is already boring :D ).
- USB
- /* Reset USB hub */
- if (port == 1) {
mdelay(2);
+} +#endif
As we previously discussed, this pin definition conflicts with NOVENA_PCIE_POWER_ON_GPIO (GPIO7_IO12 is connected to PCIE_PWRON), so by asserting it, you'll turn-off the wrong sub-system.
Currently the USB hub is reset only by system reset (RESETBMCU asserted by the PMIC). I don't see how the CPU can selectively reset the USB hub via a GPIO, so it would be better to remove the reset code.
@Sean - can you please confirm/reject this finding?
- Audio
- /* AUD_PWRON */
- MX6_PAD_DISP0_DAT23__GPIO5_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL),
The speaker amplifiers will still be disabled, as AUDIO_PWRON is not connected to them (R30A is marked as DNP). You need to add one more GPIO to enable the speaker amplifiers, here's the fix:
#define NOVENA_AUDIO_PWRON IMX_GPIO_NR(5, 17) #define NOVENA_AUDIO_SPK_AMP_ON IMX_GPIO_NR(4, 9)
/* * Audio */ static iomux_v3_cfg_t audio_pads[] = { /* AUD_PWRON */ MX6_PAD_KEY_ROW1__GPIO5_IO17 | MUX_PAD_CTRL(NO_PAD_CTRL),
/* Speakers' amplifiers #SHDWN */ MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), };
static void novena_spl_setup_iomux_audio(void) { imx_iomux_v3_setup_multiple_pads(audio_pads, ARRAY_SIZE(audio_pads));
gpio_direction_output(NOVENA_AUDIO_PWRON, 1); gpio_direction_output(NOVENA_AUDIO_SPK_AMP_ON, 1); }
Side comment: If someone needs to talk to the Audio Codec via I2C3 in U-Boot environment, don't be surprised if the codec doesn't respond to any I2C requests at all (I've had such issues with SGTL5000). The most probable reason is that the codec doesn't receive reference clock from imx6 GPIO0. This is not a critical issues as later the kernel muxes this GPIO0 properly, but keep this in mind if you want to hack the audio-codec at low level.
Reviewed-by: Nikolay Dimitrov picmaster@mail.bg
Kind regards, Nikolay
On 08/10/2014 05:55, Nikolay Dimitrov wrote:
Hi Marek,
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
- Audio
- /* AUD_PWRON */
- Audio
The audio codec ought to answer even when the reference clock isn't active. I actually can't recall, but I think the digital side still works. The audio codec needs to be turned on because otherwise it will pull the SCL and SCK lines low, blocking I2C3 from working at all.
Actually, now that I'm looking at it, we just had to make an ECO to get rid of SPK_AMP_ON. It is now ganged to AUDIO_PWRON, because SPK_AMP_ON was accidentally dual-purposed as a GPIO for the front button on the desktop / laptop. This change was made very recently (last Friday I think), and we'll be switching resistors on the mainboard when they're built in order to make the change. That pin should still be muxed as a GPIO, it's just an input now rather than an output.
Sean
Hi Sean,
----- Цитат от Sean Cross (xobs@kosagi.com), на 08.10.2014 в 10:47 -----
Hi Marek,
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
@Sean: Do you have any comments on USB hub reset stuff? Should we ditch entirely the reset code, or should we modify it somehow to work properly?
- Audio
- /* AUD_PWRON */
- Audio
Well, that would be great if it works out this way. I just shared what happened with another audio codec, to spare some frustration to others.
Agreed.
Well, all I have is the Novena schematic (http://bunniefoo.com/novena/pvt2_release/novena_pvt2.PDF) so all my analysis is based on this PDF. On page 14, R30A is DNP, and R28A is populated, this is why I suggested this modification to enable speaker amps. If there are schematic changes, please publish the new version so we can use the proper schematic and reduce spam.
@Marek: According to this latest update, there's no need for my fix for NOVENA_AUDIO_SPK_AMP_ON, as your original code will work just fine with the planned schematic changes. Please disregard the fix.
On Wednesday, October 08, 2014 at 05:35:44 PM, picmaster@mail.bg wrote:
Hi Sean,
Hi all,
Hi Marek,
:D ).
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
OK, so it's just this USB that remains, right ?
Hi Marek,
Hi Sean,
Hi all,
Hi Marek,
:D ).
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
That's correct.
There are a bunch of non-critical things for fixing also, but we'll negotiate later about them :D.
Regards, Nikolay
On Thursday, October 09, 2014 at 02:13:48 AM, Nikolay Dimitrov wrote:
Hi Marek,
That's correct.
Well what are those ?
Stefano, is there still any chance that a V6 of Novena would go into this release? I guess those chances are slim, right ?
Hi Marek,
Hi Marek,
That's correct.
Stuff like removing GD memset from Novena code, as it's now handled by crt0.S, removing microSD CD pin definition as it's not used at all, improve PHY reset (both timing and signal conflicts), and about 5-6 similar things which I can't remember, need to check again your patch.
As I said, I feel bad for torturing you anyway, and tried to think which are the critical things, which will break stuff if not fixed. The other fixes need another round of more discussions, so can be pushed later.
Regards, Nikolay
On Thursday, October 09, 2014 at 03:04:49 AM, Nikolay Dimitrov wrote:
Hi Marek,
Hi!
Hi Marek,
That's correct.
I fixed those two, thanks!
OK, but don't worry about the discussion. That's really perfectly OK.
Thank you!
Hi Marek,
That's correct.
Right. It looks like that it is better to take the time and fixing the open issues, else having the board just quickly into the release.
Best regards, Stefano Babic
Hi Marek,
That's correct.
Works for me either way, thanks!
Hi Sean,
Hi all,
Hello
Hi Marek,
:D ).
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
This is correct. There is no GPIO-based way to reset the hub.
Sean
Hi Nikolay,
On 08/10/2014 23:35, picmaster@mail.bg wrote:
Hi Sean,
Hi Marek,
- USB
- if (port == 1) {
mdelay(2);
+} +#endif
- Audio
- /* AUD_PWRON */
- Audio
Agreed.
I'll be sure to have Bunnie post a new schematic when he returns tomorrow. For now, the ECO on our wiki is the authoritative source. This is curently the only ECO for the final PVT2 board: http://www.kosagi.com/w/index.php?title=Novena_PVT2_ECO_List#ECO22:_swap_aud...
Sean
Hi Sean,
Thanks for sharing the link to ECO list, it will definitely help (well, shame on me that I didn't find this earler, doh).
Still, if you think it's possible to release at some point an updated PDF schematic that integrates all currently approved ECOs, it will be even better.
Regards, Nikolay
On Tuesday, October 07, 2014 at 11:55:02 PM, Nikolay Dimitrov wrote:
Hi Marek,
It's actually not, I like how multiple eyeballs on the code do spot these issues. On the other hand, I should have probably gone through the schematic one more time and not base this whole thing only on the original code ;-)
Hi Marek,
- I2C busses
- FEC Ethernet
- SATA
- USB ports
- USB Ethernet
- bool "Support Kosagi Novena"
+config SYS_CPU
- string
- default "armv7"
See http://patchwork.ozlabs.org/patch/397186/.
According to Masahiro, "strings" is not required and can be dropped.
On Thursday, October 09, 2014 at 09:36:13 AM, Stefano Babic wrote:
Hi Marek,
- I2C busses
- FEC Ethernet
- SATA
- USB ports
- USB Ethernet
- Update comments
config TARGET_TQMA6
+config SYS_CPU
- string
- default "armv7"
Dropped, thanks!
participants (5)
Nikolay Dimitrov
picmaster@mail.bg
Sean Cross
Stefano Babic
