[U-Boot] Gigabit support in UBOOT
I'm using an ARM 922 based board. It has gigabit ethernet support only. U-Boot Version used : U-Boot 2009.03
Problem faced: Unable to ping from my board.
The terminal ends up with showing the Hardware address only. It's NOT showing if the IP address is alive or not. On debugging I found that it hangs after calling the function "NetSendUDPPacket(NetServerEther, TftpServerIP, TftpServerPort, TftpOurPort, len);" defind in /src/net/tftp.c
If tftpcommand is issued it shows like this in the terminal.
TFTP from server 10.176.18.85; our IP address is 10.176.18.86; sending through gateway 10.176.18.1 Filename 'uImage_er922'.
Load address: 0x11500000 Loading: *
Only the '*' is displayed. I was expecting 'E' or 'T' will be displayed. But nothing is displayed in the terminal.
Also please note that I have connected my board to the PC directly and the the 1000Mbps led lits up after negotiation.
Would like to know the reason for that.
Regards
Sreeju GR
-- View this message in context: http://u-boot.10912.n7.nabble.com/Gigabit-support-in-UBOOT-tp189603.html Sent from the U-Boot mailing list archive at Nabble.com.
sreejugr
