[GIT PULL] Please pull u-boot-amlogic-20220809
Hi Tom,
Here's changes for next release: - fixup error on efuse commands return - add documentation on boot flow
The CI job is at https://source.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/13087
Thanks, Neil
The following changes since commit 2d2c61ff0460740d9ec5a44dbef9255a8c690696:
Merge tag 'efi-2022-07-rc7' of https://source.denx.de/u-boot/custodians/u-boot-efi (2022-07-06 09:17:08 -0400)
https://source.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20220809
for you to fetch changes up to 3145e0d0ff0837647351f2ca261b4cde779f83e0:
ARM: meson: fixup error on efuse commands return (2022-08-08 09:56:38 +0200)
---------------------------------------------------------------- - fixup error on efuse commands return - add documentation on boot flow
---------------------------------------------------------------- Jerome Brunet (1): ARM: meson: fixup error on efuse commands return
Neil Armstrong (1): doc: board: amlogic: add documentation on boot flow
arch/arm/mach-meson/sm.c | 9 +-- doc/board/amlogic/boot-flow.rst | 134 ++++++++++++++++++++++++++++++++++++++++ doc/board/amlogic/index.rst | 1 + 3 files changed, 138 insertions(+), 6 deletions(-) create mode 100644 doc/board/amlogic/boot-flow.rst
On Tue, Aug 09, 2022 at 10:21:42AM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
