[PATCH] log: Allow LOG_DEBUG to always enable log output
At present if CONFIG_LOG enabled, putting LOG_DEBUG at the top of a file (before log.h inclusion) causes _log() to be executed for every log() call, regardless of the build- or run-time logging level.
However there is no guarantee that the log record will actually be displayed. If the current log level is lower than LOGL_DEBUG then it will not be.
Add a way to signal that the log record should always be displayed and update log_passes_filters() to handle this.
common/log.c | 11 ++++++++--- doc/README.log | 10 ++++------ include/log.h | 16 ++++++++++++---- test/log/syslog_test.c | 2 +- 4 files changed, 25 insertions(+), 14 deletions(-)
diff --git a/common/log.c b/common/log.c index 734d26de4a..5ff8245922 100644 --- a/common/log.c +++ b/common/log.c @@ -156,16 +156,20 @@ static bool log_has_file(const char *file_list, const char *file) static bool log_passes_filters(struct log_device *ldev, struct log_rec *rec) { struct log_filter *filt; + int level = rec->level & LOGL_LEVEL_MASK; + + if (rec->force_debug && level <= LOGL_DEBUG) + return true;
/* If there are no filters, filter on the default log level */ if (list_empty(&ldev->filter_head)) { - if (rec->level > gd->default_log_level) + if (level > gd->default_log_level) return false; return true; }
list_for_each_entry(filt, &ldev->filter_head, sibling_node) { - if (rec->level > filt->max_level) + if (level > filt->max_level) continue; if ((filt->flags & LOGFF_HAS_CAT) && !log_has_cat(filt->cat_list, rec->cat)) @@ -208,7 +212,8 @@ int _log(enum log_category_t cat, enum log_level_t level, const char *file, va_list args;
rec.cat = cat; - rec.level = level; + rec.level = level & LOGL_LEVEL_MASK; + rec.force_debug = level & LOGL_FORCE_DEBUG; rec.file = file; rec.line = line; rec.func = func; diff --git a/doc/README.log b/doc/README.log index ba838824a9..554e99ca4c 100644 --- a/doc/README.log +++ b/doc/README.log @@ -77,12 +77,10 @@ Sometimes it is useful to turn on logging just in one file. You can use this:
#define LOG_DEBUG
-to enable building in of all logging statements in a single file. Put it at -the top of the file, before any #includes. - -To actually get U-Boot to output this you need to also set the default logging -level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (LOGL_DEBUG) or more. Otherwise -debug output is suppressed and will not be generated. +to enable building in of all debug logging statements in a single file. Put it +at the top of the file, before any #includes. This overrides any log-level +setting in U-Boot, including CONFIG_LOG_DEFAULT_LEVEL, but just for that file. +All logging statements, up to and including LOGL_DEBUG, will be displayed.
Convenience functions diff --git a/include/log.h b/include/log.h index 2859ce1f2e..63052f74eb 100644 --- a/include/log.h +++ b/include/log.h @@ -33,6 +33,9 @@ enum log_level_t { LOGL_COUNT, LOGL_NONE,
+ LOGL_LEVEL_MASK = 0xf, /* Mask for valid log levels */ + LOGL_FORCE_DEBUG = 0x10, /* Mask to force output due to LOG_DEBUG */ + LOGL_FIRST = LOGL_EMERG, LOGL_MAX = LOGL_DEBUG_IO, }; @@ -133,7 +136,7 @@ static inline int _log_nop(enum log_category_t cat, enum log_level_t level,
#if CONFIG_IS_ENABLED(LOG) #ifdef LOG_DEBUG -#define _LOG_DEBUG 1 +#define _LOG_DEBUG LOGL_FORCE_DEBUG #else #define _LOG_DEBUG 0 #endif @@ -141,9 +144,9 @@ static inline int _log_nop(enum log_category_t cat, enum log_level_t level, /* Emit a log record if the level is less that the maximum */ #define log(_cat, _level, _fmt, _args...) ({ \ int _l = _level; \ - if (CONFIG_IS_ENABLED(LOG) && (_l <= _LOG_MAX_LEVEL || _LOG_DEBUG)) \ - _log((enum log_category_t)(_cat), _l, __FILE__, __LINE__, \ - __func__, \ + if (CONFIG_IS_ENABLED(LOG) && (_LOG_DEBUG || _l <= _LOG_MAX_LEVEL)) \ + _log((enum log_category_t)(_cat), _l | _LOG_DEBUG, __FILE__, \ + __LINE__, __func__, \ pr_fmt(_fmt), ##_args); \ }) #else @@ -279,8 +282,12 @@ void __assert_fail(const char *assertion, const char *file, unsigned int line, * Memebers marked as 'allocated' are allocated (e.g. via strdup()) by the log * system. * + * TODO(sjg@chromium.org): Compress this struct down a bit to reduce space, e.g. + * a single u32 for cat, level, line and force_debug + * * @cat: Category, representing a uclass or part of U-Boot * @level: Severity level, less severe is higher + * @force_debug: Force output of debug * @file: Name of file where the log record was generated (not allocated) * @line: Line number where the log record was generated * @func: Function where the log record was generated (not allocated) @@ -289,6 +296,7 @@ void __assert_fail(const char *assertion, const char *file, unsigned int line, struct log_rec { enum log_category_t cat; enum log_level_t level; + bool force_debug; const char *file; int line; const char *func; diff --git a/test/log/syslog_test.c b/test/log/syslog_test.c index 120a8b2537..df239d1e8d 100644 --- a/test/log/syslog_test.c +++ b/test/log/syslog_test.c @@ -276,7 +276,7 @@ static int log_test_syslog_nodebug(struct unit_test_state *uts) sandbox_eth_set_tx_handler(0, sb_log_tx_handler); /* Used by ut_assert macros in the tx_handler */ sandbox_eth_set_priv(0, &env); - log_debug("testing %s\n", "log_debug"); + log_content("testing %s\n", "log_debug"); sandbox_eth_set_tx_handler(0, NULL); /* Check that the callback function was not called */ ut_assertnonnull(env.expected);
Hello Simon,
we have different debug levels:
LOGL_DEBUG LOGL_DEBUG_CONTENT LOGL_DEBUG_IO
If I understand you right, with your patch putting #define LOG_DEBUG at the top of the file enables all of these. This may be more than I want.
Wouldn't it be more flexible if we could put something like:
#define LOG_DEBUG LOGL_DEBUG
at the top of the file if we want logging up to level 7 in this file.
Best regards
Heinrich
Best regards
return true;
return true; }
if ((filt->flags & LOGFF_HAS_CAT) && !log_has_cat(filt->cat_list, rec->cat))if (level > filt->max_level) continue;
rec.cat = cat;
- rec.level = level & LOGL_LEVEL_MASK;
- rec.force_debug = level & LOGL_FORCE_DEBUG; rec.file = file; rec.line = line; rec.func = func;
#define LOG_DEBUG
- LOGL_LEVEL_MASK = 0xf, /* Mask for valid log levels */
- LOGL_FORCE_DEBUG = 0x10, /* Mask to force output due to LOG_DEBUG */
- LOGL_FIRST = LOGL_EMERG, LOGL_MAX = LOGL_DEBUG_IO,
__func__, \
- if (CONFIG_IS_ENABLED(LOG) && (_LOG_DEBUG || _l <= _LOG_MAX_LEVEL)) \
})__LINE__, __func__, \ pr_fmt(_fmt), ##_args); \
- Memebers marked as 'allocated' are allocated (e.g. via strdup()) by the log
- system.
- TODO(sjg@chromium.org): Compress this struct down a bit to reduce space, e.g.
- a single u32 for cat, level, line and force_debug
- @cat: Category, representing a uclass or part of U-Boot
- @level: Severity level, less severe is higher
- @force_debug: Force output of debug
- @file: Name of file where the log record was generated (not allocated)
- @line: Line number where the log record was generated
- @func: Function where the log record was generated (not allocated)
- bool force_debug; const char *file; int line; const char *func;
- log_content("testing %s\n", "log_debug"); sandbox_eth_set_tx_handler(0, NULL); /* Check that the callback function was not called */ ut_assertnonnull(env.expected);
Hi Heinrich,
Hello Simon,
Actually the way I implemented it, it only enables update LOGL_DEBUG.
Certainly your idea is more flexible. I wonder if we could make the level optional, so:
#define LOG_DEBUG
means
This exposes an underlying problem with LOG and clang I believe: https://gitlab.denx.de/u-boot/u-boot/-/jobs/135789
include/log.h:147:44: note: expanded from macro 'log' if (CONFIG_IS_ENABLED(LOG) && (_LOG_DEBUG || _l <= _LOG_MAX_LEVEL)) \ ^ drivers/misc/p2sb_emul.c:197:10: error: converting the enum constant to a boolean [-Werror,-Wint-in-bool-context]
This seems to be a Clang bug. _LOG_DEBUG is not an enum:
#if CONFIG_IS_ENABLED(LOG) #ifdef LOG_DEBUG #define _LOG_DEBUG 1 #else #define _LOG_DEBUG 0 #endif
So there seems to be a bug in the Clang you used.
Compiling with clang on Debian Bullseye does not show the problem:
make HOSTCC=clang sandbox_defconfig make HOSTCC=clang CC=clang -j8
clang version 9.0.1-13 LLVM version 9.0.1
Which Clang version did you use?
This is the change that added the test: https://reviews.llvm.org/D63082
-Wint-in-bool-context seems to be new in Clang 10.
All over the U-Boot code we assume that a non-zero integer is true. Do we really want to enable -Wint-in-bool-context?
Best regards
Heinrich
I'm using the official Clang 10 stable builds.
Do you really want to forbid using integers as booleans (-Wint-in-bool-context)?
Best regards
Heinrich
So, interesting. The Linux kernel isn't disabling this warning. It's mentioned in two commits, one of which is "clang found a bug here", of which this is not the case. The other is more like ours: commit 968e5170939662341242812b9c82ef51cf140a33 Author: Nathan Chancellor natechancellor@gmail.com Date: Thu Sep 26 09:22:59 2019 -0700
tracing: Fix clang -Wint-in-bool-context warnings in IF_ASSIGN macro
After r372664 in clang, the IF_ASSIGN macro causes a couple hundred warnings along the lines of:
kernel/trace/trace_output.c:1331:2: warning: converting the enum constant to a boolean [-Wint-in-bool-context] kernel/trace/trace.h:409:3: note: expanded from macro 'trace_assign_type' IF_ASSIGN(var, ent, struct ftrace_graph_ret_entry, ^ kernel/trace/trace.h:371:14: note: expanded from macro 'IF_ASSIGN' WARN_ON(id && (entry)->type != id); \ ^ 264 warnings generated.
This warning can catch issues with constructs like:
if (state == A || B)
where the developer really meant:
if (state == A || state == B)
This is currently the only occurrence of the warning in the kernel tree across defconfig, allyesconfig, allmodconfig for arm32, arm64, and x86_64. Add the implicit '!= 0' to the WARN_ON statement to fix the warnings and find potential issues in the future.
Link: https://github.com/llvm/llvm-project/commit/28b38c277a2941e9e891b2db30652cfd... Link: https://github.com/ClangBuiltLinux/linux/issues/686 Link: http://lkml.kernel.org/r/20190926162258.466321-1-natechancellor@gmail.com
Reviewed-by: Nick Desaulniers ndesaulniers@google.com Signed-off-by: Nathan Chancellor natechancellor@gmail.com Signed-off-by: Steven Rostedt (VMware) rostedt@goodmis.org
Which is like our case, and reworking the test to be explicit. I lean towards that.
Hi Tom,
tracing: Fix clang -Wint-in-bool-context warnings in IF_ASSIGN macro After r372664 in clang, the IF_ASSIGN macro causes a couple hundred warnings along the lines of: kernel/trace/trace_output.c:1331:2: warning: converting the enum constant to a boolean [-Wint-in-bool-context] kernel/trace/trace.h:409:3: note: expanded from macro 'trace_assign_type' IF_ASSIGN(var, ent, struct ftrace_graph_ret_entry, ^ kernel/trace/trace.h:371:14: note: expanded from macro 'IF_ASSIGN' WARN_ON(id && (entry)->type != id); \ ^ 264 warnings generated. This warning can catch issues with constructs like: if (state == A || B) where the developer really meant: if (state == A || state == B) This is currently the only occurrence of the warning in the kernel tree across defconfig, allyesconfig, allmodconfig for arm32, arm64, and x86_64. Add the implicit '!= 0' to the WARN_ON statement to fix the warnings and find potential issues in the future. Link: https://github.com/llvm/llvm-project/commit/28b38c277a2941e9e891b2db30652cfd962f070b Link: https://github.com/ClangBuiltLinux/linux/issues/686 Link: http://lkml.kernel.org/r/20190926162258.466321-1-natechancellor@gmail.com Reviewed-by: Nick Desaulniers <ndesaulniers@google.com> Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Oh dear I really want to vote against that.
if (x)
should allow C to consider x to be a boolean. I am hitting this in Zephyr and feels like it is undoing a long-standing C feature, with major disruption, for no benefit I can detect.
Hopefully I am misunderstanding what -Wint-in-bool-context means, and it just applies to enums?
On Wed, Aug 05, 2020 at 12:56:17PM -0600, Simon Glass wrote:
Hi Tom,
> At present if CONFIG_LOG enabled, putting LOG_DEBUG at the top of a file > (before log.h inclusion) causes _log() to be executed for every log() > call, regardless of the build- or run-time logging level. > > However there is no guarantee that the log record will actually be > displayed. If the current log level is lower than LOGL_DEBUG then it will > not be. > > Add a way to signal that the log record should always be displayed and > update log_passes_filters() to handle this. > > Signed-off-by: Simon Glass sjg@chromium.org
if (x)
Yes, it's not the simple case, it's the complex case as noted in the kernel commit message. Our change I believe would be:
diff --git a/include/log.h b/include/log.h index 2859ce1f2e72..91ca2e0523f7 100644 --- a/include/log.h +++ b/include/log.h @@ -141,7 +141,7 @@ static inline int _log_nop(enum log_category_t cat, enum log_level_t level, /* Emit a log record if the level is less that the maximum */ #define log(_cat, _level, _fmt, _args...) ({ \ int _l = _level; \ - if (CONFIG_IS_ENABLED(LOG) && (_l <= _LOG_MAX_LEVEL || _LOG_DEBUG)) \ + if (CONFIG_IS_ENABLED(LOG) && (_l <= _LOG_MAX_LEVEL || _LOG_DEBUG == 1)) \ _log((enum log_category_t)(_cat), _l, __FILE__, __LINE__, \ __func__, \ pr_fmt(_fmt), ##_args); \
It's not a new warning from clang (We've been on LLVM-10 since February), it's only that the logging code is now being run through it via CI.
Am 5. August 2020 21:03:28 MESZ schrieb Tom Rini trini@konsulko.com:
Hi Tom,
wrote:
On 05.08.20 14:18, Tom Rini wrote: > On Sun, Jul 26, 2020 at 08:27:35PM -0600, Simon Glass wrote: > >> At present if CONFIG_LOG enabled, putting LOG_DEBUG at the
top of a file
every log()
>> call, regardless of the build- or run-time logging level. >> >> However there is no guarantee that the log record will
actually be
then it will
>> not be. >> >> Add a way to signal that the log record should always be
displayed and
>> update log_passes_filters() to handle this. >> >> Signed-off-by: Simon Glass sjg@chromium.org > > This exposes an underlying problem with LOG and clang I
believe:
> https://gitlab.denx.de/u-boot/u-boot/-/jobs/135789 >
constant to
problem:
true. Do
It's
of
macro
hundred
enum
'IF_ASSIGN'
kernel
arm64,
fix
lean
towards that.
if (x)
- if (CONFIG_IS_ENABLED(LOG) && (_l <= _LOG_MAX_LEVEL || _LOG_DEBUG ==
1)) \
Why wouldn't we define _LOG_DEBUG as true or false? Shouldn't clang know that true is boolean?
Hi Tom,
wrote:
> On 05.08.20 14:18, Tom Rini wrote: >> On Sun, Jul 26, 2020 at 08:27:35PM -0600, Simon Glass wrote: >> >>> At present if CONFIG_LOG enabled, putting LOG_DEBUG at the
top of a file
every log()
>>> call, regardless of the build- or run-time logging level. >>> >>> However there is no guarantee that the log record will
actually be
then it will
>>> not be. >>> >>> Add a way to signal that the log record should always be
displayed and
>>> update log_passes_filters() to handle this. >>> >>> Signed-off-by: Simon Glass sjg@chromium.org >> >> This exposes an underlying problem with LOG and clang I
believe:
>> https://gitlab.denx.de/u-boot/u-boot/-/jobs/135789 >> > > include/log.h:147:44: note: expanded from macro 'log' > if (CONFIG_IS_ENABLED(LOG) && (_LOG_DEBUG || _l <= > _LOG_MAX_LEVEL)) \ > ^ > drivers/misc/p2sb_emul.c:197:10: error: converting the enum
constant to
> a boolean [-Werror,-Wint-in-bool-context] > > This seems to be a Clang bug. _LOG_DEBUG is not an enum: > > #if CONFIG_IS_ENABLED(LOG) > #ifdef LOG_DEBUG > #define _LOG_DEBUG 1 > #else > #define _LOG_DEBUG 0 > #endif > > So there seems to be a bug in the Clang you used. > > Compiling with clang on Debian Bullseye does not show the
problem:
> > make HOSTCC=clang sandbox_defconfig > make HOSTCC=clang CC=clang -j8 > > clang version 9.0.1-13 > LLVM version 9.0.1 > > Which Clang version did you use? > > This is the change that added the test: > https://reviews.llvm.org/D63082 > > -Wint-in-bool-context seems to be new in Clang 10. > > All over the U-Boot code we assume that a non-zero integer is
true. Do
It's
of
macro
hundred
enum
'IF_ASSIGN'
kernel
arm64,
fix
lean
towards that.
if (x)
1)) \
Because I didn't think of that instead, mainly.
Hi Tom,
wrote:
On 05.08.20 14:56, Tom Rini wrote: > On Wed, Aug 05, 2020 at 02:54:05PM +0200, Heinrich Schuchardt
wrote:
>> On 05.08.20 14:18, Tom Rini wrote: >>> On Sun, Jul 26, 2020 at 08:27:35PM -0600, Simon Glass wrote: >>> >>>> At present if CONFIG_LOG enabled, putting LOG_DEBUG at the
top of a file
every log()
>>>> call, regardless of the build- or run-time logging level. >>>> >>>> However there is no guarantee that the log record will
actually be
then it will
>>>> not be. >>>> >>>> Add a way to signal that the log record should always be
displayed and
>>>> update log_passes_filters() to handle this. >>>> >>>> Signed-off-by: Simon Glass sjg@chromium.org >>> >>> This exposes an underlying problem with LOG and clang I
believe:
>>> https://gitlab.denx.de/u-boot/u-boot/-/jobs/135789 >>> >> >> include/log.h:147:44: note: expanded from macro 'log' >> if (CONFIG_IS_ENABLED(LOG) && (_LOG_DEBUG || _l <= >> _LOG_MAX_LEVEL)) \ >> ^ >> drivers/misc/p2sb_emul.c:197:10: error: converting the enum
constant to
>> a boolean [-Werror,-Wint-in-bool-context] >> >> This seems to be a Clang bug. _LOG_DEBUG is not an enum: >> >> #if CONFIG_IS_ENABLED(LOG) >> #ifdef LOG_DEBUG >> #define _LOG_DEBUG 1 >> #else >> #define _LOG_DEBUG 0 >> #endif >> >> So there seems to be a bug in the Clang you used. >> >> Compiling with clang on Debian Bullseye does not show the
problem:
>> >> make HOSTCC=clang sandbox_defconfig >> make HOSTCC=clang CC=clang -j8 >> >> clang version 9.0.1-13 >> LLVM version 9.0.1 >> >> Which Clang version did you use? >> >> This is the change that added the test: >> https://reviews.llvm.org/D63082 >> >> -Wint-in-bool-context seems to be new in Clang 10. >> >> All over the U-Boot code we assume that a non-zero integer is
true. Do
>> we really want to enable -Wint-in-bool-context? > > I'm using the official Clang 10 stable builds. >
It's
of
macro
hundred
enum
'IF_ASSIGN'
kernel
arm64,
fix
lean
towards that.
if (x)
1)) \
I've resent this patch with just this change to fix clang-10.
