[U-Boot] Want to burn a u-boot to a customized board
Hi, List
I've just built an u-boot boot-loader based on the configuration of smdk2410. I built this by using buildroot, without additional customizing and modifications.
My problem is, I want to use the boot-loader to boot another s3c2410 board which is a customized board cannot found configurations in the u-boot source tree. I don't have smdk2410 actually, I choose this board just for making a good starting point.
My customized S3C2410 board looks not a strange one, it have common components usually found on other S3C2410 boards, such as Flash, SD Card Socket, Serial Ports and Ethernet interfaces.
My question is, if I download the boot-loader I just built for smdk2410 to my customized board, how much chance I can see it can boot the board with success? At this step, I don't expect I can load a Linux kernel successfully, I just what to see it can boot and give me a prompt on the serial console.
How much is that possible?
Hi Narke,
every board has a specific include/configs/xxyyzz.h configuration file, based on the board-specific memory map (where flash, sdram etc are mapped).
So, if you are not lucky enough that other similar boards use same memory map and similar periferic hardware, you have to arrange new board specific files for this custom board.
Look inside similar boards configuration (include/configs/*.h) files with same cpu, and try to figure out a working mix for the custom board, and read the important README file for help on this.
Start from the memory map, as flash and sdram addresses, it could be a good starting point to have something working briefly.
Best Regards, Angelo Dureghello
On Mon, Nov 12, 2012 at 05:04:41PM +0800, narke wrote:
Hi, List
-- woody I can't go back to yesterday - because I was a different person then.
Angelo,
Many thanks! Looking through the include/configs/mdk2410.h gave me many hints. I will start from here.
-woody
On 11/13/2012 8:33 AM, Angelo Dureghello wrote:
Hi Narke,
Hi, List
On Tue, 13 Nov 2012 01:33:21 +0100, Angelo Dureghello sysamfw@gmail.com wrote:
Hi Narke,
file,
mapped).
memory
files
board,
be a
Hi, List
of
s3c2410
the
common
SD
and
Many thanks to the suggestions!
Angelo Dureghello
narke
woody
