[U-Boot] [PATCH] CPCI750: Fix GCC 4.6 warning in board/esd/cpci750/mv_eth.c
This patch fix the GCC 4.6 warnings in
Signed-off-by: Reinhard Arlt reinhard.arlt@esd.eu
diff --git a/board/esd/cpci750/mv_eth.c b/board/esd/cpci750/mv_eth.c index 781ad23..69b4a91 100644 --- a/board/esd/cpci750/mv_eth.c +++ b/board/esd/cpci750/mv_eth.c @@ -100,6 +100,8 @@ extern void NetReceive (volatile uchar *, int);
extern unsigned int INTERNAL_REG_BASE_ADDR;
+u32 port_status; + /************************************************* *Helper functions - used inside the driver only * *************************************************/ @@ -422,7 +424,7 @@ static int mv64360_eth_real_open (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; unsigned int port_num; - u32 port_status, phy_reg_data; + u32 phy_reg_data;
ethernet_private = (ETH_PORT_INFO *) dev->priv; /* ronen - when we update the MAC env params we only update dev->enetaddr @@ -638,15 +640,6 @@ static int mv64360_eth_free_rx_rings (struct eth_device *dev)
int mv64360_eth_stop (struct eth_device *dev) { - ETH_PORT_INFO *ethernet_private; - struct mv64360_eth_priv *port_private; - unsigned int port_num; - - ethernet_private = (ETH_PORT_INFO *) dev->priv; - port_private = - (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num; - /* Disable all gigE address decoder */ MV_REG_WRITE (MV64360_ETH_BASE_ADDR_ENABLE_REG, 0x3f); DP (printf ("%s Ethernet stop called ... \n", __FUNCTION__)); @@ -716,7 +709,6 @@ int mv64360_eth_xmit (struct eth_device *dev, volatile void *dataPtr, { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num; PKT_INFO pkt_info; ETH_FUNC_RET_STATUS status; struct net_device_stats *stats; @@ -725,7 +717,6 @@ int mv64360_eth_xmit (struct eth_device *dev, volatile void *dataPtr, ethernet_private = (ETH_PORT_INFO *) dev->priv; port_private = (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num;
stats = port_private->stats;
@@ -801,7 +792,6 @@ int mv64360_eth_receive (struct eth_device *dev) { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num; PKT_INFO pkt_info; struct net_device_stats *stats;
@@ -809,7 +799,6 @@ int mv64360_eth_receive (struct eth_device *dev) ethernet_private = (ETH_PORT_INFO *) dev->priv; port_private = (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num; stats = port_private->stats;
while ((eth_port_receive (ethernet_private, ETH_Q0, &pkt_info) == @@ -900,12 +889,10 @@ static struct net_device_stats *mv64360_eth_get_stats (struct eth_device *dev) { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num;
mv64360_eth_update_stat (dev);
@@ -927,24 +914,21 @@ static void mv64360_eth_update_stat (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; struct net_device_stats *stats; - unsigned int port_num; - volatile unsigned int dummy;
/* These are false updates */ stats->rx_packets += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_GOOD_FRAMES_RECEIVED); + eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_GOOD_FRAMES_RECEIVED); stats->tx_packets += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_GOOD_FRAMES_SENT); + eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_GOOD_FRAMES_SENT); stats->rx_bytes += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, + eth_read_mib_counter(ethernet_private->port_num, ETH_MIB_GOOD_OCTETS_RECEIVED_LOW); /* * Ideally this should be as follows - @@ -956,41 +940,41 @@ static void mv64360_eth_update_stat (struct eth_device *dev) * But the unsigned long in PowerPC and MIPS are 32bit. So the next read * is just a dummy read for proper work of the GigE port */ - dummy = eth_read_mib_counter (ethernet_private->port_num, + port_status = eth_read_mib_counter(ethernet_private->port_num, ETH_MIB_GOOD_OCTETS_RECEIVED_HIGH); stats->tx_bytes += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_GOOD_OCTETS_SENT_LOW); - dummy = eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_GOOD_OCTETS_SENT_HIGH); + eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_GOOD_OCTETS_SENT_LOW); + port_status = eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_GOOD_OCTETS_SENT_HIGH); stats->rx_errors += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_MAC_RECEIVE_ERROR); + eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_MAC_RECEIVE_ERROR);
/* Rx dropped is for received packet with CRC error */ stats->rx_dropped += - (unsigned long) eth_read_mib_counter (ethernet_private-> - port_num, - ETH_MIB_BAD_CRC_EVENT); + (unsigned long) eth_read_mib_counter(ethernet_private-> + port_num, + ETH_MIB_BAD_CRC_EVENT); stats->multicast += (unsigned long) - eth_read_mib_counter (ethernet_private->port_num, - ETH_MIB_MULTICAST_FRAMES_RECEIVED); + eth_read_mib_counter(ethernet_private->port_num, + ETH_MIB_MULTICAST_FRAMES_RECEIVED); stats->collisions += - (unsigned long) eth_read_mib_counter (ethernet_private-> - port_num, - ETH_MIB_COLLISION) + - (unsigned long) eth_read_mib_counter (ethernet_private-> - port_num, - ETH_MIB_LATE_COLLISION); + (unsigned long) eth_read_mib_counter(ethernet_private-> + port_num, + ETH_MIB_COLLISION) + + (unsigned long) eth_read_mib_counter(ethernet_private-> + port_num, + ETH_MIB_LATE_COLLISION); /* detailed rx errors */ stats->rx_length_errors += - (unsigned long) eth_read_mib_counter (ethernet_private-> - port_num, - ETH_MIB_UNDERSIZE_RECEIVED) + (unsigned long) eth_read_mib_counter(ethernet_private-> + port_num, + ETH_MIB_UNDERSIZE_RECEIVED) + - (unsigned long) eth_read_mib_counter (ethernet_private-> - port_num, - ETH_MIB_OVERSIZE_RECEIVED); + (unsigned long) eth_read_mib_counter(ethernet_private-> + port_num, + ETH_MIB_OVERSIZE_RECEIVED); /* detailed tx errors */ }
@@ -1009,12 +993,10 @@ static void mv64360_eth_print_stat (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; struct net_device_stats *stats; - unsigned int port_num;
/* These are false updates */ @@ -2066,12 +2048,11 @@ static void eth_port_init_mac_tables (ETH_PORT eth_port_num) static void eth_clear_mib_counters (ETH_PORT eth_port_num) { int i; - unsigned int dummy;
/* Perform dummy reads from MIB counters */ for (i = ETH_MIB_GOOD_OCTETS_RECEIVED_LOW; i < ETH_MIB_LATE_COLLISION; i += 4) - dummy = MV_REG_READ ((MV64360_ETH_MIB_COUNTERS_BASE + port_status = MV_REG_READ((MV64360_ETH_MIB_COUNTERS_BASE (eth_port_num) + i));
return;
Dear Reinhard Arlt,
in what?
and which warnings?
+u32 port_status;
What is this needed for?
I see a port_status locally used in mv64360_eth_print_phy_status(), but except from that it never gets read.
Sorry, but his does not appear to be a good fix.
You may want to have a look at what I did to the same driver for the Marvell boards.
Fix: mv_eth.c: In function 'mv64360_eth_real_open': mv_eth.c:425:6: warning: variable 'port_status' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_stop': mv_eth.c:643:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_xmit': mv_eth.c:719:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_receive': mv_eth.c:804:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_get_stats': mv_eth.c:903:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_update_stat': mv_eth.c:931:24: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] mv_eth.c:930:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'mv64360_eth_print_stat': mv_eth.c:1012:15: warning: variable 'port_num' set but not used [-Wunused-but-set-variable] mv_eth.c: In function 'eth_clear_mib_counters': mv_eth.c:2069:15: warning: variable 'dummy' set but not used [-Wunused-but-set-variable
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Reinhard Arlt reinhard.arlt@esd.eu --- board/esd/cpci750/mv_eth.c | 34 +++++++--------------------------- 1 files changed, 7 insertions(+), 27 deletions(-)
diff --git a/board/esd/cpci750/mv_eth.c b/board/esd/cpci750/mv_eth.c index 781ad23..001c1ad 100644 --- a/board/esd/cpci750/mv_eth.c +++ b/board/esd/cpci750/mv_eth.c @@ -422,7 +422,7 @@ static int mv64360_eth_real_open (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; unsigned int port_num; - u32 port_status, phy_reg_data; + u32 phy_reg_data;
ethernet_private = (ETH_PORT_INFO *) dev->priv; /* ronen - when we update the MAC env params we only update dev->enetaddr @@ -520,7 +520,7 @@ static int mv64360_eth_real_open (struct eth_device *dev) */
MV_REG_WRITE (MV64360_ETH_MAXIMUM_TRANSMIT_UNIT (port_num), 0); - port_status = MV_REG_READ (MV64360_ETH_PORT_STATUS_REG (port_num)); + MV_REG_READ (MV64360_ETH_PORT_STATUS_REG (port_num));
/* Check Link status on phy */ eth_port_read_smi_reg (port_num, 1, &phy_reg_data); @@ -638,15 +638,6 @@ static int mv64360_eth_free_rx_rings (struct eth_device *dev)
int mv64360_eth_stop (struct eth_device *dev) { - ETH_PORT_INFO *ethernet_private; - struct mv64360_eth_priv *port_private; - unsigned int port_num; - - ethernet_private = (ETH_PORT_INFO *) dev->priv; - port_private = - (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num; - /* Disable all gigE address decoder */ MV_REG_WRITE (MV64360_ETH_BASE_ADDR_ENABLE_REG, 0x3f); DP (printf ("%s Ethernet stop called ... \n", __FUNCTION__)); @@ -716,7 +707,6 @@ int mv64360_eth_xmit (struct eth_device *dev, volatile void *dataPtr, { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num; PKT_INFO pkt_info; ETH_FUNC_RET_STATUS status; struct net_device_stats *stats; @@ -725,7 +715,6 @@ int mv64360_eth_xmit (struct eth_device *dev, volatile void *dataPtr, ethernet_private = (ETH_PORT_INFO *) dev->priv; port_private = (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num;
@@ -801,7 +790,6 @@ int mv64360_eth_receive (struct eth_device *dev) { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num; PKT_INFO pkt_info; struct net_device_stats *stats;
@@ -809,7 +797,6 @@ int mv64360_eth_receive (struct eth_device *dev) ethernet_private = (ETH_PORT_INFO *) dev->priv; port_private = (struct mv64360_eth_priv *) ethernet_private->port_private; - port_num = port_private->port_num; stats = port_private->stats;
while ((eth_port_receive (ethernet_private, ETH_Q0, &pkt_info) == @@ -900,12 +887,10 @@ static struct net_device_stats *mv64360_eth_get_stats (struct eth_device *dev) { ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; - unsigned int port_num;
@@ -927,13 +912,10 @@ static void mv64360_eth_update_stat (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; struct net_device_stats *stats; - unsigned int port_num; - volatile unsigned int dummy;
/* These are false updates */ @@ -956,12 +938,12 @@ static void mv64360_eth_update_stat (struct eth_device *dev) * But the unsigned long in PowerPC and MIPS are 32bit. So the next read * is just a dummy read for proper work of the GigE port */ - dummy = eth_read_mib_counter (ethernet_private->port_num, + (void)eth_read_mib_counter (ethernet_private->port_num, ETH_MIB_GOOD_OCTETS_RECEIVED_HIGH); stats->tx_bytes += (unsigned long) eth_read_mib_counter (ethernet_private->port_num, ETH_MIB_GOOD_OCTETS_SENT_LOW); - dummy = eth_read_mib_counter (ethernet_private->port_num, + (void)eth_read_mib_counter (ethernet_private->port_num, ETH_MIB_GOOD_OCTETS_SENT_HIGH); stats->rx_errors += (unsigned long) eth_read_mib_counter (ethernet_private->port_num, @@ -1009,12 +991,10 @@ static void mv64360_eth_print_stat (struct eth_device *dev) ETH_PORT_INFO *ethernet_private; struct mv64360_eth_priv *port_private; struct net_device_stats *stats; - unsigned int port_num;
/* These are false updates */ @@ -2066,13 +2046,13 @@ static void eth_port_init_mac_tables (ETH_PORT eth_port_num) static void eth_clear_mib_counters (ETH_PORT eth_port_num) { int i; - unsigned int dummy;
/* Perform dummy reads from MIB counters */ for (i = ETH_MIB_GOOD_OCTETS_RECEIVED_LOW; i < ETH_MIB_LATE_COLLISION; - i += 4) - dummy = MV_REG_READ ((MV64360_ETH_MIB_COUNTERS_BASE + i += 4) { + (void)MV_REG_READ ((MV64360_ETH_MIB_COUNTERS_BASE (eth_port_num) + i)); + }
return; }
Dear Anatolij Gustschin,
Applied, thanks.
Anatolij Gustschin
Reinhard Arlt
