[U-Boot] [PATCH 0/2] Rename serial_stm32x7.c to serial_stm32.c
As driver serial_stm32x7.c is used by all STM32 SoCs family (F4/F7 and H7) rename it with the generic name serial_stm32.c
Move also some flags from defconfig to stm32 machine Kconfig
Patrice Chotard (2): serial: stm32: Rename serial_stm32x7.c to serial_stm32.c configs: stm32: move config flag from defconfig to Kconfig
arch/arm/mach-stm32/Kconfig | 24 +++++++++++++++++++++- configs/stm32f429-discovery_defconfig | 11 ---------- configs/stm32f469-discovery_defconfig | 11 ---------- configs/stm32f746-disco_defconfig | 11 ---------- drivers/serial/Kconfig | 2 +- drivers/serial/Makefile | 2 +- .../serial/{serial_stm32x7.c => serial_stm32.c} | 4 ++-- .../serial/{serial_stm32x7.h => serial_stm32.h} | 4 ++-- 8 files changed, 29 insertions(+), 40 deletions(-) rename drivers/serial/{serial_stm32x7.c => serial_stm32.c} (98%) rename drivers/serial/{serial_stm32x7.h => serial_stm32.h} (97%)
Now this driver is used across stm32f4, stm32f7 and stm32h7 SoCs family, give it a generic name.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/mach-stm32/Kconfig | 2 +- configs/stm32f429-discovery_defconfig | 2 +- configs/stm32f469-discovery_defconfig | 2 +- configs/stm32f746-disco_defconfig | 2 +- drivers/serial/Kconfig | 2 +- drivers/serial/Makefile | 2 +- drivers/serial/{serial_stm32x7.c => serial_stm32.c} | 4 ++-- drivers/serial/{serial_stm32x7.h => serial_stm32.h} | 4 ++-- 8 files changed, 10 insertions(+), 10 deletions(-) rename drivers/serial/{serial_stm32x7.c => serial_stm32.c} (98%) rename drivers/serial/{serial_stm32x7.h => serial_stm32.h} (97%)
diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index b618b60..f4c93f1 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -38,7 +38,7 @@ config STM32H7 select STM32_SDRAM select STM32_RCC select STM32_RESET - select STM32X7_SERIAL + select STM32_SERIAL select SYSCON
source "arch/arm/mach-stm32/stm32f4/Kconfig" diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 52bd931..6f7a12f 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -31,4 +31,4 @@ CONFIG_RAM=y CONFIG_STM32_SDRAM=y CONFIG_DM_RESET=y CONFIG_STM32_RESET=y -CONFIG_STM32X7_SERIAL=y +CONFIG_STM32_SERIAL=y diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index afffddf..5b70aa9 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -39,4 +39,4 @@ CONFIG_RAM=y CONFIG_STM32_SDRAM=y CONFIG_DM_RESET=y CONFIG_STM32_RESET=y -CONFIG_STM32X7_SERIAL=y +CONFIG_STM32_SERIAL=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 321321f..69df866 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -60,7 +60,7 @@ CONFIG_RAM=y CONFIG_STM32_SDRAM=y CONFIG_DM_RESET=y CONFIG_STM32_RESET=y -CONFIG_STM32X7_SERIAL=y +CONFIG_STM32_SERIAL=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 122b8e7..7b20b47 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -529,7 +529,7 @@ config STI_ASC_SERIAL on STiH410 SoC. This is a basic implementation, it supports following baudrate 9600, 19200, 38400, 57600 and 115200.
-config STM32X7_SERIAL +config STM32_SERIAL bool "STMicroelectronics STM32 SoCs on-chip UART" depends on DM_SERIAL && (STM32F4 || STM32F7 || STM32H7) help diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 7adcee3..5ef603a 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -44,7 +44,7 @@ obj-$(CONFIG_UNIPHIER_SERIAL) += serial_uniphier.o obj-$(CONFIG_STM32_SERIAL) += serial_stm32.o obj-$(CONFIG_STI_ASC_SERIAL) += serial_sti_asc.o obj-$(CONFIG_PIC32_SERIAL) += serial_pic32.o -obj-$(CONFIG_STM32X7_SERIAL) += serial_stm32x7.o +obj-$(CONFIG_STM32_SERIAL) += serial_stm32.o obj-$(CONFIG_BCM283X_MU_SERIAL) += serial_bcm283x_mu.o obj-$(CONFIG_MSM_SERIAL) += serial_msm.o obj-$(CONFIG_MVEBU_A3700_UART) += serial_mvebu_a3700.o diff --git a/drivers/serial/serial_stm32x7.c b/drivers/serial/serial_stm32.c similarity index 98% rename from drivers/serial/serial_stm32x7.c rename to drivers/serial/serial_stm32.c index d1580e3..286b954 100644 --- a/drivers/serial/serial_stm32x7.c +++ b/drivers/serial/serial_stm32.c @@ -11,7 +11,7 @@ #include <asm/io.h> #include <serial.h> #include <asm/arch/stm32.h> -#include "serial_stm32x7.h" +#include "serial_stm32.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -148,7 +148,7 @@ static const struct dm_serial_ops stm32_serial_ops = { };
U_BOOT_DRIVER(serial_stm32) = { - .name = "serial_stm32x7", + .name = "serial_stm32", .id = UCLASS_SERIAL, .of_match = of_match_ptr(stm32_serial_id), .ofdata_to_platdata = of_match_ptr(stm32_serial_ofdata_to_platdata), diff --git a/drivers/serial/serial_stm32x7.h b/drivers/serial/serial_stm32.h similarity index 97% rename from drivers/serial/serial_stm32x7.h rename to drivers/serial/serial_stm32.h index f7dca39..d08ba1f 100644 --- a/drivers/serial/serial_stm32x7.h +++ b/drivers/serial/serial_stm32.h @@ -5,8 +5,8 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#ifndef _SERIAL_STM32_X7_ -#define _SERIAL_STM32_X7_ +#ifndef _SERIAL_STM32_ +#define _SERIAL_STM32_
#define CR1_OFFSET(x) (x ? 0x0c : 0x00) #define CR3_OFFSET(x) (x ? 0x14 : 0x08)
Reviewed-by: Vikas Manocha vikas.manocha@st.com
Cheers, Vikas
- select STM32_SERIAL select SYSCON
- .name = "serial_stm32", .id = UCLASS_SERIAL, .of_match = of_match_ptr(stm32_serial_id), .ofdata_to_platdata = of_match_ptr(stm32_serial_ofdata_to_platdata),
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Vikas Manocha vikas.manocha@st.com
Move system flags from defconfig to mach-stm32/Kconfig
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/mach-stm32/Kconfig | 22 ++++++++++++++++++++++ configs/stm32f429-discovery_defconfig | 11 ----------- configs/stm32f469-discovery_defconfig | 11 ----------- configs/stm32f746-disco_defconfig | 11 ----------- 4 files changed, 22 insertions(+), 33 deletions(-)
diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index f4c93f1..5f7a2b5 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -2,9 +2,31 @@ if STM32
config STM32F4 bool "stm32f4 family" + select CLK + select DM_GPIO + select DM_RESET + select MISC + select PINCTRL + select PINCTRL_STM32 + select RAM + select STM32_SDRAM + select STM32_RCC + select STM32_RESET + select STM32_SERIAL
config STM32F7 bool "stm32f7 family" + select CLK + select DM_GPIO + select DM_RESET + select MISC + select PINCTRL + select PINCTRL_STM32 + select RAM + select STM32_SDRAM + select STM32_RCC + select STM32_RESET + select STM32_SERIAL select SUPPORT_SPL select SPL select SPL_CLK diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 6f7a12f..ec67aad 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -19,16 +19,5 @@ CONFIG_CMD_TIMER=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_FLASH=y -CONFIG_CLK=y -CONFIG_DM_GPIO=y -CONFIG_MISC=y -CONFIG_STM32_RCC=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_STM32=y -CONFIG_RAM=y -CONFIG_STM32_SDRAM=y -CONFIG_DM_RESET=y -CONFIG_STM32_RESET=y -CONFIG_STM32_SERIAL=y diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index 5b70aa9..8190b82 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -26,17 +26,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y # CONFIG_BLK is not set -CONFIG_CLK=y -CONFIG_DM_GPIO=y -CONFIG_MISC=y -CONFIG_STM32_RCC=y CONFIG_DM_MMC=y CONFIG_ARM_PL180_MMCI=y CONFIG_MTD_NOR_FLASH=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_STM32=y -CONFIG_RAM=y -CONFIG_STM32_SDRAM=y -CONFIG_DM_RESET=y -CONFIG_STM32_RESET=y -CONFIG_STM32_SERIAL=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 69df866..f8fa198 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -39,10 +39,6 @@ CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y # CONFIG_BLK is not set -CONFIG_CLK=y -CONFIG_DM_GPIO=y -CONFIG_MISC=y -CONFIG_STM32_RCC=y CONFIG_DM_MMC=y # CONFIG_SPL_DM_MMC is not set CONFIG_ARM_PL180_MMCI=y @@ -53,14 +49,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y -CONFIG_PINCTRL=y # CONFIG_PINCTRL_FULL is not set -CONFIG_PINCTRL_STM32=y -CONFIG_RAM=y -CONFIG_STM32_SDRAM=y -CONFIG_DM_RESET=y -CONFIG_STM32_RESET=y -CONFIG_STM32_SERIAL=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_OF_LIBFDT_OVERLAY=y
Reviewed-by: Vikas Manocha vikas.manocha@st.com One comment below
- select CLK
- select DM_GPIO
- select DM_RESET
- select MISC
- select PINCTRL
- select PINCTRL_STM32
- select RAM
- select STM32_SDRAM
- select STM32_RCC
- select STM32_RESET
- select CLK
- select DM_GPIO
- select DM_RESET
- select MISC
- select PINCTRL
- select RAM
- select STM32_RCC
Can you have one common selection(like STM32_SERIAL) like under 'if STM32'.
Cheers, Vikas
Vikas Manocha
