[U-Boot-Users] [PATCH] Memory Functions
did anyone ever used md command? Patch below does following:
# md 400000 00400000: ea000012 .... # md 400000 4 00400000: ea000012 e59ff014 e59ff014 e59ff014 ................ # md .w 40000 00040000: 7b55 U{ # md .w 40000 4 00040000: 7b55 7e24 47b4 67e1 U{$~.G.g
Wrong parameters are handled too :)
Once there, a question comes to mind. Why was this format choosen? md [.b, .w, .l] address [# of objects] First optional parameter makes parsing a bit more difcult. And why is width specifier prefixed with dot? And what is .s specifier good for? Well, more that one question, I know... ;-)
I implemented cmd_get_data_size2, because cmd_get_data_size simply doesn't work and all it's users are broken too (do_pci looks good), just grep for function name and you'll see what needs fixing.
My proposal is to replace cmd_get_data_size with cmd_get_data_size2 and fix all bugs in its users. How should it be done depends on answers to questions above.
Best regars, ladis
--- u-boot/common/cmd_mem.c.orig 2004-09-08 18:43:16.000000000 +0200 +++ u-boot/common/cmd_mem.c 2004-09-08 19:00:18.000000000 +0200 @@ -62,6 +62,33 @@ } return default_size; } + +/* Check for a size specification .b, .w or .l. + * Returns: -1 if arg is not size specifier + * 0 if specifier was recognized (size is set approriately) + * 1 if arg is unknown specifier + */ +int cmd_get_data_size2(char* arg, int *size) +{ + if (!(strlen(arg) > 1 && arg[0] == '.')) + return -1; + switch(arg[1]) { + case 'b': + *size = 1; + break; + case 'w': + *size = 2; + break; + case 'l': + *size = 4; + break; + default: + return 1; + } + return 0; +} + + #endif
#if (CONFIG_COMMANDS & CFG_CMD_MEMORY) @@ -105,27 +132,32 @@ length = dp_last_length;
if (argc < 2) { +error: printf ("Usage:\n%s\n", cmdtp->usage); return 1; }
if ((flag & CMD_FLAG_REPEAT) == 0) { + int idx = 1; /* New command specified. Check for a size specification. * Defaults to long if no or incorrect specification. */ - if ((size = cmd_get_data_size(argv[0], 4)) < 0) - return 1; + size = 4; + if (cmd_get_data_size2(argv[idx], &size) >= 0) + idx++; + if (idx >= argc) + goto error;
- /* Address is specified since argc > 1 - */ - addr = simple_strtoul(argv[1], NULL, 16); + addr = simple_strtoul(argv[idx++], NULL, 16); addr += base_address;
/* If another parameter, it is the length to display. * Length is the number of objects, not number of bytes. */ - if (argc > 2) - length = simple_strtoul(argv[2], NULL, 16); + if (idx < argc) + length = simple_strtoul(argv[idx], NULL, 16); + else + length = 1; }
/* Print the lines. @@ -1128,7 +1160,7 @@ /**************************************************/ #if (CONFIG_COMMANDS & CFG_CMD_MEMORY) U_BOOT_CMD( - md, 3, 1, do_mem_md, + md, 4, 1, do_mem_md, "md - memory display\n", "[.b, .w, .l] address [# of objects]\n - memory display\n" );
Of course, I use it a lot.
Why do you introduce a new command format? At least stick with the existing one!
Also, what exactly is the benefit of this change?
Compatibility to exiting tools. See the BDI2000 for example.
You misunderstand (and mis-implement) the format.
It's "cp" and "cp.b" or "cp.l" or "cp.w". No space inbetween.
I tend to say that the effort (increased memory footprint) is not worth the additional options.
Ahh... It's clear now. (I implemented it a way that help string says, with your additional explanation I have admit it's done right way. I'm sorry for confusion)
Best regards, ladis
Ladislav Michl
