[U-Boot] [PATCHv3 01/10] arm: Remove zipitz2 board
Per discussion on the list, drop this board again.
Cc: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 5 -- board/zipitz2/Kconfig | 9 -- board/zipitz2/MAINTAINERS | 6 -- board/zipitz2/Makefile | 8 -- board/zipitz2/zipitz2.c | 219 ---------------------------------------------- configs/zipitz2_defconfig | 34 ------- include/configs/zipitz2.h | 186 --------------------------------------- 7 files changed, 467 deletions(-) delete mode 100644 board/zipitz2/Kconfig delete mode 100644 board/zipitz2/MAINTAINERS delete mode 100644 board/zipitz2/Makefile delete mode 100644 board/zipitz2/zipitz2.c delete mode 100644 configs/zipitz2_defconfig delete mode 100644 include/configs/zipitz2.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01ff57cf1bec..0e82cf1583f7 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1410,10 +1410,6 @@ config TARGET_H2200 bool "Support h2200" select CPU_PXA
-config TARGET_ZIPITZ2 - bool "Support zipitz2" - select CPU_PXA - config TARGET_COLIBRI_PXA270 bool "Support colibri_pxa270" select CPU_PXA @@ -1727,7 +1723,6 @@ source "board/woodburn/Kconfig" source "board/xilinx/Kconfig" source "board/xilinx/zynq/Kconfig" source "board/xilinx/zynqmp/Kconfig" -source "board/zipitz2/Kconfig"
source "arch/arm/Kconfig.debug"
diff --git a/board/zipitz2/Kconfig b/board/zipitz2/Kconfig deleted file mode 100644 index c6635040a37f..000000000000 --- a/board/zipitz2/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_ZIPITZ2 - -config SYS_BOARD - default "zipitz2" - -config SYS_CONFIG_NAME - default "zipitz2" - -endif diff --git a/board/zipitz2/MAINTAINERS b/board/zipitz2/MAINTAINERS deleted file mode 100644 index e027cd361aae..000000000000 --- a/board/zipitz2/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -ZIPITZ2 BOARD -M: Vasily Khoruzhick anarsoul@gmail.com -S: Maintained -F: board/zipitz2/ -F: include/configs/zipitz2.h -F: configs/zipitz2_defconfig diff --git a/board/zipitz2/Makefile b/board/zipitz2/Makefile deleted file mode 100644 index 2bbe4364e8f7..000000000000 --- a/board/zipitz2/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright (C) 2009 -# Marek Vasut marek.vasut@gmail.com -# -# Heavily based on pxa255_idp platform - -obj-y := zipitz2.o diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c deleted file mode 100644 index 9208c882c272..000000000000 --- a/board/zipitz2/zipitz2.c +++ /dev/null @@ -1,219 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2009 - * Marek Vasut marek.vasut@gmail.com - * - * Heavily based on pxa255_idp platform - */ - -#include <common.h> -#include <command.h> -#include <serial.h> -#include <asm/arch/hardware.h> -#include <asm/arch/pxa.h> -#include <asm/arch/regs-mmc.h> -#include <spi.h> -#include <asm/io.h> -#include <usb.h> -#include <asm/mach-types.h> - -DECLARE_GLOBAL_DATA_PTR; - -#ifdef CONFIG_CMD_SPI -void lcd_start(void); -#else -inline void lcd_start(void) {}; -#endif - -/* - * Miscelaneous platform dependent initialisations - */ -int board_init(void) -{ - /* arch number of Z2 */ - gd->bd->bi_arch_number = MACH_TYPE_ZIPIT2; - - /* adress of boot parameters */ - gd->bd->bi_boot_params = 0xa0000100; - - /* Enable LCD */ - lcd_start(); - - return 0; -} - -int dram_init(void) -{ - pxa2xx_dram_init(); - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_USB -int board_usb_init(int index, enum usb_init_type init) -{ - /* enable port 2 */ - writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | - UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); - - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return 0; -} - -void usb_board_stop(void) -{ -} -#endif - -int dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM_1; - gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; - - return 0; -} - -#ifdef CONFIG_CMD_MMC -int board_mmc_init(bd_t *bis) -{ - pxa_mmc_register(0); - return 0; -} -#endif - -#ifdef CONFIG_CMD_SPI - -struct { - unsigned char reg; - unsigned short data; - unsigned char mdelay; -} lcd_data[] = { - { 0x07, 0x0000, 0 }, - { 0x13, 0x0000, 10 }, - { 0x11, 0x3004, 0 }, - { 0x14, 0x200F, 0 }, - { 0x10, 0x1a20, 0 }, - { 0x13, 0x0040, 50 }, - { 0x13, 0x0060, 0 }, - { 0x13, 0x0070, 200 }, - { 0x01, 0x0127, 0 }, - { 0x02, 0x0700, 0 }, - { 0x03, 0x1030, 0 }, - { 0x08, 0x0208, 0 }, - { 0x0B, 0x0620, 0 }, - { 0x0C, 0x0110, 0 }, - { 0x30, 0x0120, 0 }, - { 0x31, 0x0127, 0 }, - { 0x32, 0x0000, 0 }, - { 0x33, 0x0503, 0 }, - { 0x34, 0x0727, 0 }, - { 0x35, 0x0124, 0 }, - { 0x36, 0x0706, 0 }, - { 0x37, 0x0701, 0 }, - { 0x38, 0x0F00, 0 }, - { 0x39, 0x0F00, 0 }, - { 0x40, 0x0000, 0 }, - { 0x41, 0x0000, 0 }, - { 0x42, 0x013f, 0 }, - { 0x43, 0x0000, 0 }, - { 0x44, 0x013f, 0 }, - { 0x45, 0x0000, 0 }, - { 0x46, 0xef00, 0 }, - { 0x47, 0x013f, 0 }, - { 0x48, 0x0000, 0 }, - { 0x07, 0x0015, 30 }, - { 0x07, 0x0017, 0 }, - { 0x20, 0x0000, 0 }, - { 0x21, 0x0000, 0 }, - { 0x22, 0x0000, 0 }, -}; - -void zipitz2_spi_sda(int set) -{ - /* GPIO 13 */ - if (set) - writel((1 << 13), GPSR0); - else - writel((1 << 13), GPCR0); -} - -void zipitz2_spi_scl(int set) -{ - /* GPIO 22 */ - if (set) - writel((1 << 22), GPCR0); - else - writel((1 << 22), GPSR0); -} - -unsigned char zipitz2_spi_read(void) -{ - /* GPIO 40 */ - return !!(readl(GPLR1) & (1 << 8)); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - /* Always valid */ - return 1; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - /* GPIO 88 low */ - writel((1 << 24), GPCR2); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* GPIO 88 high */ - writel((1 << 24), GPSR2); -} - -void lcd_start(void) -{ - int i; - unsigned char reg[3] = { 0x74, 0x00, 0 }; - unsigned char data[3] = { 0x76, 0, 0 }; - unsigned char dummy[3] = { 0, 0, 0 }; - - /* PWM2 AF */ - writel(readl(GAFR0_L) | 0x00800000, GAFR0_L); - /* Enable clock to all PWM */ - writel(readl(CKEN) | 0x3, CKEN); - /* Configure PWM2 */ - writel(0x4f, PWM_CTRL2); - writel(0x2ff, PWM_PWDUTY2); - writel(792, PWM_PERVAL2); - - /* Toggle the reset pin to reset the LCD */ - writel((1 << 19), GPSR0); - udelay(100000); - writel((1 << 19), GPCR0); - udelay(20000); - writel((1 << 19), GPSR0); - udelay(20000); - - /* Program the LCD init sequence */ - for (i = 0; i < sizeof(lcd_data) / sizeof(lcd_data[0]); i++) { - reg[0] = 0x74; - reg[1] = 0x0; - reg[2] = lcd_data[i].reg; - spi_xfer(NULL, 24, reg, dummy, SPI_XFER_BEGIN | SPI_XFER_END); - - data[0] = 0x76; - data[1] = lcd_data[i].data >> 8; - data[2] = lcd_data[i].data & 0xff; - spi_xfer(NULL, 24, data, dummy, SPI_XFER_BEGIN | SPI_XFER_END); - - if (lcd_data[i].mdelay) - udelay(lcd_data[i].mdelay * 1000); - } - - writel((1 << 11), GPSR0); -} -#endif diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig deleted file mode 100644 index 509adcffd9c2..000000000000 --- a/configs/zipitz2_defconfig +++ /dev/null @@ -1,34 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_ZIPITZ2=y -CONFIG_SYS_TEXT_BASE=0x0 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=tty0 console=ttyS2,115200 fbcon=rotate:3" -# CONFIG_CONSOLE_MUX is not set -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y -# CONFIG_CMDLINE_EDITING is not set -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="$ " -CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ENV_IS_IN_FLASH=y -# CONFIG_NET is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_CONS_INDEX=2 -CONFIG_PXA_SERIAL=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_LCD=y -CONFIG_LZMA=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h deleted file mode 100644 index 24fea68a11f0..000000000000 --- a/include/configs/zipitz2.h +++ /dev/null @@ -1,186 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Aeronix Zipit Z2 configuration file - * - * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Board Configuration Options - */ -#define CONFIG_CPU_PXA27X 1 /* Marvell PXA270 CPU */ - -#undef CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_PREBOOT - -/* - * Environment settings - */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_ADDR 0x40000 -#define CONFIG_ENV_SIZE 0x10000 - -#define CONFIG_SYS_MALLOC_LEN (128*1024) -#define CONFIG_ARCH_CPU_INIT - -#define CONFIG_BOOTCOMMAND \ - "if mmc rescan && ext2load mmc 0 0xa0000000 boot/uboot.script ;"\ - "then " \ - "source 0xa0000000; " \ - "else " \ - "bootm 0x50000; " \ - "fi; " -#define CONFIG_TIMESTAMP -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS - -/* - * Serial Console Configuration - * STUART - the lower serial port on Colibri board - */ -#define CONFIG_STUART 1 - -/* - * Bootloader Components Configuration - */ - -/* - * MMC Card Configuration - */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_PXA_MMC_GENERIC -#define CONFIG_SYS_MMC_BASE 0xF0000000 -#endif - -/* - * SPI and LCD - */ -#ifdef CONFIG_CMD_SPI -#define CONFIG_SOFT_SPI -#define CONFIG_LCD_ROTATION -#define CONFIG_PXA_LCD -#define CONFIG_LMS283GF05 - -#define SPI_DELAY udelay(10) -#define SPI_SDA(val) zipitz2_spi_sda(val) -#define SPI_SCL(val) zipitz2_spi_scl(val) -#define SPI_READ zipitz2_spi_read() -#ifndef __ASSEMBLY__ -void zipitz2_spi_sda(int); -void zipitz2_spi_scl(int); -unsigned char zipitz2_spi_read(void); -#endif -#endif - -#define CONFIG_SYS_DEVICE_NULLDEV 1 - -/* - * Clock Configuration - */ -#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ - -/* - * SRAM Map - */ -#define PHYS_SRAM 0x5c000000 /* SRAM Bank #1 */ -#define PHYS_SRAM_SIZE 0x00040000 /* 256k */ - -/* - * DRAM Map - */ -#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ - -#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ -#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ - -#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (GENERATED_GBL_DATA_SIZE + PHYS_SRAM + 2048) - -/* - * NOR FLASH - */ -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ -#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ -#define PHYS_FLASH_SECT_SIZE 0x00010000 /* 64 KB sectors */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT - -#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MONITOR_LEN PHYS_FLASH_SECT_SIZE - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 256 - -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 -#define CONFIG_SYS_FLASH_WRITE_TOUT 240000 -#define CONFIG_SYS_FLASH_LOCK_TOUT 240000 -#define CONFIG_SYS_FLASH_UNLOCK_TOUT 240000 - -/* - * GPIO settings - */ -#define CONFIG_SYS_GAFR0_L_VAL 0x02000140 -#define CONFIG_SYS_GAFR0_U_VAL 0x59188000 -#define CONFIG_SYS_GAFR1_L_VAL 0x63900002 -#define CONFIG_SYS_GAFR1_U_VAL 0xaaa03950 -#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa -#define CONFIG_SYS_GAFR2_U_VAL 0x29000308 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000000 -#define CONFIG_SYS_GAFR3_U_VAL 0x000000d5 -#define CONFIG_SYS_GPCR0_VAL 0x00000000 -#define CONFIG_SYS_GPCR1_VAL 0x00000020 -#define CONFIG_SYS_GPCR2_VAL 0x00000000 -#define CONFIG_SYS_GPCR3_VAL 0x00000000 -#define CONFIG_SYS_GPDR0_VAL 0xdafcee00 -#define CONFIG_SYS_GPDR1_VAL 0xffa3aaab -#define CONFIG_SYS_GPDR2_VAL 0x8fe9ffff -#define CONFIG_SYS_GPDR3_VAL 0x001b1f8a -#define CONFIG_SYS_GPSR0_VAL 0x06080400 -#define CONFIG_SYS_GPSR1_VAL 0x007f0000 -#define CONFIG_SYS_GPSR2_VAL 0x032a0000 -#define CONFIG_SYS_GPSR3_VAL 0x00000180 - -#define CONFIG_SYS_PSSR_VAL 0x30 - -/* - * Clock settings - */ -#define CONFIG_SYS_CKEN 0x00511220 -#define CONFIG_SYS_CCCR 0x00000190 - -/* - * Memory settings - */ -#define CONFIG_SYS_MSC0_VAL 0x2ffc38f8 -#define CONFIG_SYS_MSC1_VAL 0x0000ccd1 -#define CONFIG_SYS_MSC2_VAL 0x0000b884 -#define CONFIG_SYS_MDCNFG_VAL 0x08000ba9 -#define CONFIG_SYS_MDREFR_VAL 0x2011a01e -#define CONFIG_SYS_MDMRS_VAL 0x00000000 -#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 -#define CONFIG_SYS_SXCNFG_VAL 0x40044004 - -/* - * PCMCIA and CF Interfaces - */ -#define CONFIG_SYS_MECR_VAL 0x00000001 -#define CONFIG_SYS_MCMEM0_VAL 0x00014307 -#define CONFIG_SYS_MCMEM1_VAL 0x00014307 -#define CONFIG_SYS_MCATT0_VAL 0x0001c787 -#define CONFIG_SYS_MCATT1_VAL 0x0001c787 -#define CONFIG_SYS_MCIO0_VAL 0x0001430f -#define CONFIG_SYS_MCIO1_VAL 0x0001430f - -#include "pxa-common.h" - -#endif /* __CONFIG_H */
In order to use CMD_SF / CMD_SPI / ENV_IS_IN_SPI_FLASH we need to have the SPI (or SPI_FLASH/DM_SPI_FLASH, for CMD_SF) enabled. Express this in the Kconfigs.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/Kconfig | 2 ++ cmd/Kconfig | 3 +++ env/Kconfig | 2 +- 3 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index e574b0d441b0..28afe3980168 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -101,6 +101,7 @@ config SANDBOX imply CMD_IOTRACE imply CMD_LZMADEC imply CMD_SATA + imply CMD_SF imply CMD_SF_TEST imply CRC32_VERIFY imply FAT_WRITE @@ -147,6 +148,7 @@ config X86 imply CMD_IO imply CMD_IRQ imply CMD_PCI + imply CMD_SF imply CMD_SF_TEST imply CMD_ZBOOT imply DM_ETH diff --git a/cmd/Kconfig b/cmd/Kconfig index 0badcb3fe006..cda7931fe360 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1035,11 +1035,13 @@ config CMD_SDRAM
config CMD_SF bool "sf" + depends on DM_SPI_FLASH || SPI_FLASH help SPI Flash support
config CMD_SF_TEST bool "sf test - Allow testing of SPI flash" + depends on CMD_SF help Provides a way to test that SPI flash is working correctly. The test is destructive, in that an area of SPI flash must be provided @@ -1051,6 +1053,7 @@ config CMD_SF_TEST
config CMD_SPI bool "sspi - Command to access spi device" + depends on SPI help SPI utility command.
diff --git a/env/Kconfig b/env/Kconfig index 1e10c7a4c46b..932081670e9f 100644 --- a/env/Kconfig +++ b/env/Kconfig @@ -293,7 +293,7 @@ config ENV_IS_IN_REMOTE
config ENV_IS_IN_SPI_FLASH bool "Environment is in SPI flash" - depends on !CHAIN_OF_TRUST + depends on !CHAIN_OF_TRUST && SPI default y if ARMADA_XP default y if INTEL_BAYTRAIL default y if INTEL_BRASWELL
Reviewed-by: Jagan Teki jagan@amarulasolutions.com
Add a new option, CONFIG_DEPRECATED, for code that relies on deprecated functionality and has not been converted past the deadline for conversion.
Signed-off-by: Tom Rini trini@konsulko.com --- Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/Kconfig b/Kconfig index a02168690f5b..436308854d0c 100644 --- a/Kconfig +++ b/Kconfig @@ -20,6 +20,13 @@ config BROKEN This option cannot be enabled. It is used as dependency for broken and incomplete features.
+config DEPRECATED + bool + help + This option cannot be enabled. It it used as a dependency for + code that relies on deprecated features that will be removed and + the conversion deadline has passed. + config LOCALVERSION string "Local version - append to U-Boot release" help
+config DEPRECATED
bool
help
then, what would be the exact diff b/w broken vs deprecated? I do see same meaning in terms of code maintenance, though it is working or non-working.
+config DEPRECATED
bool
help
It is a matter of human language. There was objection to using broken as technically the code functions (and thus is not broken) but does use deprecated APIs.
+config DEPRECATED
bool
help
Since broken also refer "incomplete features" in kconfig help, I thought this kind of depreciated meaning will literally look similar to broken. based on my experience with other opensource project like, buildroot does also use broken with same meaning as broken. Giving two options of similar meaning atleast from code maintenance point-of-view leads confusion to developers which is the appropriate one to use. I don't see any problem of marking broken with incomplete code (assuming human can treate legacy code or code would require dm conversion as incomplete), giving space for another config option with similar meaning doesn't worth to hold.
+config DEPRECATED
bool
help
And there is disagreement with that point of view. Given the intention and use of both BROKEN and DEPRECATED, having both and using whichever seems better, given the normal usage of both words in english, seems more productive than having a thread on if "was not converted to DM by deadline" means "broken" or "deprecated". I'd rather we all focus on converting what should get converted or pushing things along to remove the boards/platforms eventually that are functionally useless as they've had most features turned off.
+config DEPRECATED
bool
help
OK. I have no inputs say further.
Will you take this? or shall I send the PR?
If configured target has deprecated configs enabled, trigger a warning about this.
Cc: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com [trini: Change from BROKEN to DEPRECATED] Signed-off-by: Tom Rini trini@konsulko.com --- Makefile | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/Makefile b/Makefile index 07106138e9ff..08deab28cbbb 100644 --- a/Makefile +++ b/Makefile @@ -918,6 +918,9 @@ cmd_cfgcheck = $(srctree)/scripts/check-config.sh $2 \ $(srctree)/scripts/config_whitelist.txt $(srctree)
all: $(ALL-y) +ifeq ($(CONFIG_DEPRECATED),y) + $(warning "You have deprecated configuration options enabled in your .config! Please check your configuration.") +endif ifeq ($(CONFIG_DM_I2C_COMPAT)$(CONFIG_SANDBOX),y) @echo >&2 "===================== WARNING ======================" @echo >&2 "This board uses CONFIG_DM_I2C_COMPAT. Please remove"
We have a warning text for non dm converted spi drivers, but the plan is to mark all these respective drivers with CONFIG_DEPRECATED.
So, trigger a warning saying that these driver configurations and associated code will remove in v2019.07 (earlier plan is to remove it from v2019.04)
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Makefile | 16 +++++----------- 1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index 08deab28cbbb..704e9cefad19 100644 --- a/Makefile +++ b/Makefile @@ -920,6 +920,11 @@ cmd_cfgcheck = $(srctree)/scripts/check-config.sh $2 \ all: $(ALL-y) ifeq ($(CONFIG_DEPRECATED),y) $(warning "You have deprecated configuration options enabled in your .config! Please check your configuration.") +ifeq ($(CONFIG_SPI),y) +ifneq ($(CONFIG_DM_SPI)$(CONFIG_OF_CONTROL),yy) + $(warning "The relevant config item with associated code will remove in v2019.07 release.") +endif +endif endif ifeq ($(CONFIG_DM_I2C_COMPAT)$(CONFIG_SANDBOX),y) @echo >&2 "===================== WARNING ======================" @@ -997,17 +1002,6 @@ ifeq ($(CONFIG_OF_EMBED),y) @echo >&2 "See doc/README.fdt-control for more info." @echo >&2 "====================================================" endif -ifeq ($(CONFIG_SPI),y) -ifneq ($(CONFIG_DM_SPI)$(CONFIG_OF_CONTROL),yy) - @echo >&2 "===================== WARNING ======================" - @echo >&2 "This board does not use CONFIG_DM_SPI. Please update" - @echo >&2 "the board before v2019.04 for no dm conversion" - @echo >&2 "and v2019.07 for partially dm converted drivers." - @echo >&2 "Failure to update can lead to driver/board removal" - @echo >&2 "See doc/driver-model/MIGRATION.txt for more info." - @echo >&2 "====================================================" -endif -endif ifeq ($(CONFIG_SPI_FLASH),y) ifneq ($(CONFIG_DM_SPI_FLASH)$(CONFIG_OF_CONTROL),yy) @echo >&2 "===================== WARNING ======================"
Mark MXS_SPI as DEPRECATED, this so the resulting build shows warning for broken configuration enabled and associated code will remove in v2019.07 release.
Cc: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 7044da35d68e..56194176c514 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -383,6 +383,7 @@ config MXC_SPI
config MXS_SPI bool "MXS SPI Driver" + depends on DEPRECATED help Enable the MXS SPI controller driver. This driver can be used on the i.MX23 and i.MX28 SoCs.
Mark SH_SPI as DEPRECATED, this so the resulting build shows warning for a deprecated configuration enabled and associated code will remove in v2019.07 release.
Acked-by: Marek Vasut marex@denx.de Signed-off-by: Jagan Teki jagan@amarulasolutions.com [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 56194176c514..efceecee5e8f 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -349,6 +349,7 @@ config DAVINCI_SPI
config SH_SPI bool "SuperH SPI driver" + depends on DEPRECATED help Enable the SuperH SPI controller driver. This driver can be used on various SuperH SoCs, such as SH7757.
Mark SOFT_SPI as DEPRECATED, this so the resulting build shows warning for deprecated configuration enabled and associated code will remove in v2019.07 release.
Cc: Vasily Khoruzhick anarsoul@gmail.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index efceecee5e8f..df20f7991fd5 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -309,6 +309,7 @@ endif # if DM_SPI
config SOFT_SPI bool "Soft SPI driver" + depends on DM_SPI || (DEPRECATED && !DM_SPI) help Enable Soft SPI driver. This driver is to use GPIO simulate the SPI protocol.
Mark LPC32XX_SSP as DEPRECATED, this so the resulting build shows warning for deprecated configuration enabled and associated code will remove in v2019.07 release.
Cc: Albert ARIBAUD albert.aribaud@3adev.fr Signed-off-by: Jagan Teki jagan@amarulasolutions.com Acked-by: Vladimir Zapolskiy vz@mleia.com Acked-by: Sylvain Lemieux slemieux@tycoint.com [trini: Switch to DEPRECATED] Signed-off-by: Tom Rini trini@konsulko.com --- drivers/spi/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index df20f7991fd5..b59b4038b5e1 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -369,6 +369,7 @@ config KIRKWOOD_SPI
config LPC32XX_SSP bool "LPC32XX SPI Driver" + depends on DEPRECATED help Enable support for SPI on LPC32xx
Now that various SPI related options depend on CONFIG_DEPRECATED, in order for platforms to build out of the box they need to disable various other options.
Cc: Albert ARIBAUD albert.aribaud@3adev.fr Cc: Marek Vasut marex@denx.de Cc: Vladimir Zapolskiy vz@mleia.com Cc: Fabio Estevam fabio.estevam@nxp.com Signed-off-by: Tom Rini trini@konsulko.com --- board/renesas/sh7752evb/sh7752evb.c | 4 ++++ board/renesas/sh7753evb/sh7753evb.c | 4 ++++ board/renesas/sh7757lcr/sh7757lcr.c | 9 +++++++++ board/work-microwave/work_92105/Makefile | 3 ++- board/work-microwave/work_92105/work_92105.c | 2 ++ configs/bg0900_defconfig | 9 --------- configs/devkit3250_defconfig | 2 -- configs/mx28evk_auart_console_defconfig | 9 --------- configs/mx28evk_defconfig | 9 --------- configs/mx28evk_nand_defconfig | 9 --------- configs/mx28evk_spi_defconfig | 10 ---------- configs/sh7752evb_defconfig | 6 ------ configs/sh7753evb_defconfig | 6 ------ configs/sh7757lcr_defconfig | 5 ----- configs/work_92105_defconfig | 2 -- include/configs/sh7752evb.h | 1 - include/configs/sh7753evb.h | 1 - include/configs/sh7757lcr.h | 1 - 18 files changed, 21 insertions(+), 71 deletions(-)
diff --git a/board/renesas/sh7752evb/sh7752evb.c b/board/renesas/sh7752evb/sh7752evb.c index 480933b3cc96..da33a0bd8a2f 100644 --- a/board/renesas/sh7752evb/sh7752evb.c +++ b/board/renesas/sh7752evb/sh7752evb.c @@ -174,6 +174,7 @@ int board_mmc_init(bd_t *bis)
static int get_sh_eth_mac_raw(unsigned char *buf, int size) { +#ifdef CONFIG_DEPRECATED struct spi_flash *spi; int ret;
@@ -190,6 +191,7 @@ static int get_sh_eth_mac_raw(unsigned char *buf, int size) return 1; } spi_flash_free(spi); +#endif
return 0; } @@ -239,6 +241,7 @@ int board_late_init(void) return 0; }
+#ifdef CONFIG_DEPRECATED int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret; @@ -302,3 +305,4 @@ U_BOOT_CMD( "write MAC address for GETHERC", "[GETHERC ch0] [GETHERC ch1]\n" ); +#endif diff --git a/board/renesas/sh7753evb/sh7753evb.c b/board/renesas/sh7753evb/sh7753evb.c index dfdc6b79b7ae..5ddddb65711d 100644 --- a/board/renesas/sh7753evb/sh7753evb.c +++ b/board/renesas/sh7753evb/sh7753evb.c @@ -190,6 +190,7 @@ int board_mmc_init(bd_t *bis)
@@ -206,6 +207,7 @@ static int get_sh_eth_mac_raw(unsigned char *buf, int size) return 1; } spi_flash_free(spi); +#endif
return 0; } @@ -255,6 +257,7 @@ int board_late_init(void) return 0; }
+#ifdef CONFIG_DEPRECATED int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret; @@ -318,3 +321,4 @@ U_BOOT_CMD( "write MAC address for GETHERC", "[GETHERC ch0] [GETHERC ch1]\n" ); +#endif diff --git a/board/renesas/sh7757lcr/sh7757lcr.c b/board/renesas/sh7757lcr/sh7757lcr.c index 90c5508e439c..3222701ad2db 100644 --- a/board/renesas/sh7757lcr/sh7757lcr.c +++ b/board/renesas/sh7757lcr/sh7757lcr.c @@ -30,6 +30,7 @@ static void init_gctrl(void)
static int init_pcie_bridge_from_spi(void *buf, size_t size) { +#ifdef CONFIG_DEPRECATED struct spi_flash *spi; int ret; unsigned long pcie_addr; @@ -54,6 +55,10 @@ static int init_pcie_bridge_from_spi(void *buf, size_t size) spi_flash_free(spi);
return 0; +#else + printf("No SPI support so no PCIe support\n"); + return 1; +#endif }
static void init_pcie_bridge(void) @@ -231,6 +236,7 @@ int board_mmc_init(bd_t *bis)
@@ -247,6 +253,7 @@ static int get_sh_eth_mac_raw(unsigned char *buf, int size) return 1; } spi_flash_free(spi); +#endif
return 0; } @@ -352,6 +359,7 @@ U_BOOT_CMD( "enable SH-G200 bus (disable PCIe-G200)" );
+#ifdef CONFIG_DEPRECATED int do_write_mac(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { int i, ret; @@ -418,3 +426,4 @@ U_BOOT_CMD( "write MAC address for ETHERC/GETHERC", "[ETHERC ch0] [ETHERC ch1] [GETHERC ch0] [GETHERC ch1]\n" ); +#endif diff --git a/board/work-microwave/work_92105/Makefile b/board/work-microwave/work_92105/Makefile index e3803bb04315..b837e7b0dd8f 100644 --- a/board/work-microwave/work_92105/Makefile +++ b/board/work-microwave/work_92105/Makefile @@ -6,5 +6,6 @@ ifdef CONFIG_SPL_BUILD obj-y += work_92105_spl.o else -obj-y += work_92105.o work_92105_display.o +obj-y += work_92105.o +obj-$(CONFIG_DEPRECATED) += work_92105_display.o endif diff --git a/board/work-microwave/work_92105/work_92105.c b/board/work-microwave/work_92105/work_92105.c index eb2e7d7eb88a..3f23af9ed40c 100644 --- a/board/work-microwave/work_92105/work_92105.c +++ b/board/work-microwave/work_92105/work_92105.c @@ -52,8 +52,10 @@ int board_early_init_r(void) gpio_request(GPO_19, "NAND_nWP"); gpio_direction_output(GPO_19, 1);
+#ifdef CONFIG_DEPRECATED /* initialize display */ work_92105_display_init(); +#endif
return 0; } diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index a71ec2b03e32..353790f44640 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -22,9 +22,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -33,13 +30,7 @@ CONFIG_DOS_PARTITION=y # CONFIG_MMC is not set CONFIG_NAND=y CONFIG_NAND_MXS=y -CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_SF_DEFAULT_SPEED=40000000 -CONFIG_SPI_FLASH_STMICRO=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index c7a7983976ba..a47cf02b8fbd 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_NAND=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -45,7 +44,6 @@ CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ADDR=31 CONFIG_SYS_NS16550=y CONFIG_SPI=y -CONFIG_LPC32XX_SSP=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 9fbe9ea510ac..27c152571a2f 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -22,9 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -44,15 +41,9 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y -CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index 62661eac3131..4cee901d8321 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -22,9 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -44,15 +41,9 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y -CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index f18dbd374984..3875da733adb 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -21,9 +21,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -43,15 +40,9 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y -CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index db3ac7d7a207..37477b35f1cb 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -21,9 +21,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_DEFAULT_SPI_BUS=2 CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -39,19 +36,12 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:3m(bootloader)ro,512k(environment),512k(redundant-environment),4m(kernel),512k(fdt),8m(ramdisk),-(filesystem)" CONFIG_CMD_UBI=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC_MXS=y CONFIG_NAND=y CONFIG_NAND_MXS=y -CONFIG_SPI_FLASH=y -CONFIG_SF_DEFAULT_BUS=2 -CONFIG_SF_DEFAULT_MODE=0 -CONFIG_SF_DEFAULT_SPEED=24000000 -CONFIG_SPI_FLASH_SST=y CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y -CONFIG_MXS_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index b34709d1ea73..d9fa1ca57fc9 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -18,7 +18,6 @@ CONFIG_CMD_MD5SUM=y # CONFIG_CMD_LOADB is not set CONFIG_CMD_MMC=y CONFIG_CMD_SDRAM=y -CONFIG_CMD_SF=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set @@ -29,14 +28,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SH_MMCIF=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_STMICRO=y CONFIG_SH_ETHER=y CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y -CONFIG_SH_SPI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 857e90b86ab2..e5698d802f78 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -17,7 +17,6 @@ CONFIG_CMD_MD5SUM=y # CONFIG_CMD_LOADB is not set CONFIG_CMD_MMC=y CONFIG_CMD_SDRAM=y -CONFIG_CMD_SF=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set @@ -28,14 +27,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SH_MMCIF=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_SPI_FLASH_STMICRO=y CONFIG_SH_ETHER=y CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y -CONFIG_SH_SPI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index 8314435b9384..f9b7379cee75 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -20,7 +20,6 @@ CONFIG_CMD_MD5SUM=y # CONFIG_CMD_LOADB is not set CONFIG_CMD_MMC=y CONFIG_CMD_SDRAM=y -CONFIG_CMD_SF=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set @@ -31,13 +30,9 @@ CONFIG_CMD_PING=y CONFIG_CMD_EXT2=y CONFIG_MAC_PARTITION=y CONFIG_DOS_PARTITION=y -CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MMC=y CONFIG_SH_MMCIF=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y CONFIG_SH_ETHER=y CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y -CONFIG_SH_SPI=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index bbd13e0cd9f3..01c8884f2b77 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_EEPROM=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_NAND=y -CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -41,4 +40,3 @@ CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_SYS_NS16550=y CONFIG_SPI=y -CONFIG_LPC32XX_SSP=y diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index 1f29e3d221e8..c90d8e0e9a52 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -63,7 +63,6 @@ #define CONFIG_SH_MMCIF_CLK 48000000
/* ENV setting */ -#define CONFIG_ENV_IS_EMBEDDED #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_ADDR (0x00080000) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 0693fb5a3c49..83d123f33a78 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -63,7 +63,6 @@ #define CONFIG_SH_MMCIF_CLK 48000000
/* ENV setting */ -#define CONFIG_ENV_IS_EMBEDDED #define CONFIG_ENV_SECT_SIZE (64 * 1024) #define CONFIG_ENV_ADDR (0x00080000) #define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 05b2f01c15ac..f92f06649496 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -75,7 +75,6 @@ #define SH7757LCR_PCIEBRG_SIZE (96 * 1024)
For the SH boards,
Reviewed-by: Marek Vasut marek.vasut@gmail.com
Acked-by: Vasily Khoruzhick anarsoul@gmail.com
Thanks for submitting this patch!
select CPU_PXA
-config SYS_BOARD
default "zipitz2"
default "zipitz2"
- Copyright (C) 2009
- Marek Vasut marek.vasut@gmail.com
- Heavily based on pxa255_idp platform
- Miscelaneous platform dependent initialisations
/* Enable LCD */
lcd_start();
pxa2xx_dram_init();
/* enable port 2 */
-} -#endif
-struct {
unsigned char reg;
-} lcd_data[] = {
/* GPIO 13 */
if (set)
else
/* GPIO 22 */
if (set)
else
/* GPIO 40 */
/* Always valid */
return 1;
/* GPIO 88 low */
/* GPIO 88 high */
int i;
/* PWM2 AF */
udelay(100000);
udelay(20000);
udelay(20000);
reg[0] = 0x74;
reg[1] = 0x0;
data[0] = 0x76;
- Aeronix Zipit Z2 configuration file
- Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com
- High Level Board Configuration Options
- Environment settings
"then " \
"else " \
"bootm 0x50000; " \
"fi; "
- Serial Console Configuration
- STUART - the lower serial port on Colibri board
- Bootloader Components Configuration
- MMC Card Configuration
- SPI and LCD
- Clock Configuration
- SRAM Map
- DRAM Map
- NOR FLASH
- GPIO settings
- Clock settings
- Memory settings
- PCMCIA and CF Interfaces
2.7.4
Applied all to u-boot-spi/master
Jagan Teki
Vasily Khoruzhick
