[U-Boot-Users] [PATCH] sbc8349: Remove board specific ECC code
ECC code is now shared for all 83xx boards, so remove board specific one. See commit daab8c67d2defef73dc26ab07f0c3afd1b05d019 for reference.
Signed-off-by: Paul Gortmaker paul.gortmaker@windriver.com --- board/sbc8349/sbc8349.c | 327 ----------------------------------------------- 1 files changed, 0 insertions(+), 327 deletions(-)
diff --git a/board/sbc8349/sbc8349.c b/board/sbc8349/sbc8349.c index 86166ea..da37714 100644 --- a/board/sbc8349/sbc8349.c +++ b/board/sbc8349/sbc8349.c @@ -32,7 +32,6 @@ #include <i2c.h> #include <spd.h> #include <miiphy.h> -#include <command.h> #if defined(CONFIG_SPD_EEPROM) #include <spd_sdram.h> #endif @@ -235,332 +234,6 @@ void sdram_init(void) } #endif
-#if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) -/* - * ECC user commands - */ -void ecc_print_status(void) -{ - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - - printf("\nECC mode: %s\n\n", (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) ? "ON" : "OFF"); - - /* Interrupts */ - printf("Memory Error Interrupt Enable:\n"); - printf(" Multiple-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MBEE) ? 1 : 0); - printf(" Single-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_SBEE) ? 1 : 0); - printf(" Memory Select Error Interrupt Enable: %d\n\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MSEE) ? 1 : 0); - - /* Error disable */ - printf("Memory Error Disable:\n"); - printf(" Multiple-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MBED) ? 1 : 0); - printf(" Sinle-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_SBED) ? 1 : 0); - printf(" Memory Select Error Disable: %d\n\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MSED) ? 1 : 0); - - /* Error injection */ - printf("Memory Data Path Error Injection Mask High/Low: %08lx %08lx\n", - ddr->data_err_inject_hi, ddr->data_err_inject_lo); - - printf("Memory Data Path Error Injection Mask ECC:\n"); - printf(" ECC Mirror Byte: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EMB) ? 1 : 0); - printf(" ECC Injection Enable: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EIEN) ? 1 : 0); - printf(" ECC Error Injection Mask: 0x%02x\n\n", - ddr->ecc_err_inject & ECC_ERR_INJECT_EEIM); - - /* SBE counter/threshold */ - printf("Memory Single-Bit Error Management (0..255):\n"); - printf(" Single-Bit Error Threshold: %d\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBET) >> ECC_ERROR_MAN_SBET_SHIFT); - printf(" Single-Bit Error Counter: %d\n\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBEC) >> ECC_ERROR_MAN_SBEC_SHIFT); - - /* Error detect */ - printf("Memory Error Detect:\n"); - printf(" Multiple Memory Errors: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MME) ? 1 : 0); - printf(" Multiple-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MBE) ? 1 : 0); - printf(" Single-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_SBE) ? 1 : 0); - printf(" Memory Select Error: %d\n\n", - (ddr->err_detect & ECC_ERROR_DETECT_MSE) ? 1 : 0); - - /* Capture data */ - printf("Memory Error Address Capture: 0x%08lx\n", ddr->capture_address); - printf("Memory Data Path Read Capture High/Low: %08lx %08lx\n", - ddr->capture_data_hi, ddr->capture_data_lo); - printf("Memory Data Path Read Capture ECC: 0x%02x\n\n", - ddr->capture_ecc & CAPTURE_ECC_ECE); - - printf("Memory Error Attributes Capture:\n"); - printf(" Data Beat Number: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_BNUM) >> ECC_CAPT_ATTR_BNUM_SHIFT); - printf(" Transaction Size: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSIZ) >> ECC_CAPT_ATTR_TSIZ_SHIFT); - printf(" Transaction Source: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSRC) >> ECC_CAPT_ATTR_TSRC_SHIFT); - printf(" Transaction Type: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TTYP) >> ECC_CAPT_ATTR_TTYP_SHIFT); - printf(" Error Information Valid: %d\n\n", - ddr->capture_attributes & ECC_CAPT_ATTR_VLD); -} - -int do_ecc ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - volatile u32 val; - u64 *addr, count, val64; - register u64 *i; - - if (argc > 4) { - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; - } - - if (argc == 2) { - if (strcmp(argv[1], "status") == 0) { - ecc_print_status(); - return 0; - } else if (strcmp(argv[1], "captureclear") == 0) { - ddr->capture_address = 0; - ddr->capture_data_hi = 0; - ddr->capture_data_lo = 0; - ddr->capture_ecc = 0; - ddr->capture_attributes = 0; - return 0; - } - } - - if (argc == 3) { - if (strcmp(argv[1], "sbecnt") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBEC_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBET); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "sbethr") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBET_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBEC); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "errdisable") == 0) { - val = ddr->err_disable; - - if (strcmp(argv[2], "+sbe") == 0) { - val |= ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "+mbe") == 0) { - val |= ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "+mse") == 0) { - val |= ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "+all") == 0) { - val |= (ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else if (strcmp(argv[2], "-sbe") == 0) { - val &= ~ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "-mbe") == 0) { - val &= ~ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "-mse") == 0) { - val &= ~ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "-all") == 0) { - val &= ~(ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else { - printf("Incorrect err_disable field\n"); - return 1; - } - - ddr->err_disable = val; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - return 0; - } else if (strcmp(argv[1], "errdetectclr") == 0) { - val = ddr->err_detect; - - if (strcmp(argv[2], "mme") == 0) { - val |= ECC_ERROR_DETECT_MME; - } else if (strcmp(argv[2], "sbe") == 0) { - val |= ECC_ERROR_DETECT_SBE; - } else if (strcmp(argv[2], "mbe") == 0) { - val |= ECC_ERROR_DETECT_MBE; - } else if (strcmp(argv[2], "mse") == 0) { - val |= ECC_ERROR_DETECT_MSE; - } else if (strcmp(argv[2], "all") == 0) { - val |= (ECC_ERROR_DETECT_MME | - ECC_ERROR_DETECT_MBE | - ECC_ERROR_DETECT_SBE | - ECC_ERROR_DETECT_MSE); - } else { - printf("Incorrect err_detect field\n"); - return 1; - } - - ddr->err_detect = val; - return 0; - } else if (strcmp(argv[1], "injectdatahi") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_hi = val; - return 0; - } else if (strcmp(argv[1], "injectdatalo") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_lo = val; - return 0; - } else if (strcmp(argv[1], "injectecc") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - if (val > 0xff) { - printf("Incorrect ECC inject mask, should be 0x00..0xff\n"); - return 1; - } - val |= (ddr->ecc_err_inject & ~ECC_ERR_INJECT_EEIM); - - ddr->ecc_err_inject = val; - return 0; - } else if (strcmp(argv[1], "inject") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EIEN; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EIEN; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - return 0; - } else if (strcmp(argv[1], "mirror") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EMB; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EMB; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - return 0; - } - } - - if (argc == 4) { - if (strcmp(argv[1], "test") == 0) { - addr = (u64 *)simple_strtoul(argv[2], NULL, 16); - count = simple_strtoul(argv[3], NULL, 16); - - if ((u32)addr % 8) { - printf("Address not alligned on double word boundary\n"); - return 1; - } - - disable_interrupts(); - icache_disable(); - - for (i = addr; i < addr + count; i++) { - /* enable injects */ - ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* write memory location injecting errors */ - *i = 0x1122334455667788ULL; - __asm__ __volatile__ ("sync"); - - /* disable injects */ - ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* read data, this generates ECC error */ - val64 = *i; - __asm__ __volatile__ ("sync"); - - /* disable errors for ECC */ - ddr->err_disable |= ~ECC_ERROR_ENABLE; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* re-initialize memory, write the location again - * NOT injecting errors this time */ - *i = 0xcafecafecafecafeULL; - __asm__ __volatile__ ("sync"); - - /* enable errors for ECC */ - ddr->err_disable &= ECC_ERROR_ENABLE; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - } - - icache_enable(); - enable_interrupts(); - - return 0; - } - } - - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; -} - -U_BOOT_CMD( - ecc, 4, 0, do_ecc, - "ecc - support for DDR ECC features\n", - "status - print out status info\n" - "ecc captureclear - clear capture regs data\n" - "ecc sbecnt <val> - set Single-Bit Error counter\n" - "ecc sbethr <val> - set Single-Bit Threshold\n" - "ecc errdisable <flag> - clear/set disable Memory Error Disable, flag:\n" - " [-|+]sbe - Single-Bit Error\n" - " [-|+]mbe - Multiple-Bit Error\n" - " [-|+]mse - Memory Select Error\n" - " [-|+]all - all errors\n" - "ecc errdetectclr <flag> - clear Memory Error Detect, flag:\n" - " mme - Multiple Memory Errors\n" - " sbe - Single-Bit Error\n" - " mbe - Multiple-Bit Error\n" - " mse - Memory Select Error\n" - " all - all errors\n" - "ecc injectdatahi <hi> - set Memory Data Path Error Injection Mask High\n" - "ecc injectdatalo <lo> - set Memory Data Path Error Injection Mask Low\n" - "ecc injectecc <ecc> - set ECC Error Injection Mask\n" - "ecc inject <en|dis> - enable/disable error injection\n" - "ecc mirror <en|dis> - enable/disable mirror byte\n" - "ecc test <addr> <cnt> - test mem region:\n" - " - enables injects\n" - " - writes pattern injecting errors\n" - " - disables injects\n" - " - reads pattern back, generates error\n" - " - re-inits memory" -); -#endif /* if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) */ - #if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd)
Paul Gortmaker
