[PATCH] Convert CFG_SYS_UBOOT_START to Kconfig
Commit 65cc0e2a65d2 ("global: Move remaining CONFIG_SYS_* to CFG_SYS_*") renamed CONFIG_SYS_UBOOT_START to CFG_SYS_UBOOT_START. Unfortunately, this meant that the value was no longer available to the Makefile. This caused imxrt to fail to boot. All the other boards that used this variable were unaffected because they were using the default value which is CONFIG_TEXT_BASE.
This commit converts CFG_SYS_UBOOT_START to Kconfig and sets the default value to CONFIG_TEXT_BASE.
Suggested-by: Marek Vasut marek.vasut+renesas@gmail.com Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Jesse Taube Mr.Bossman075@gmail.com --- Makefile | 16 ++++------------ arch/arm/mach-k3/config_secure.mk | 2 +- arch/arm/mach-omap2/config_secure.mk | 2 +- boot/Kconfig | 16 ++++++++++++++++ common/spl/spl.c | 6 +----- common/spl/spl_fit.c | 2 +- configs/imxrt1020-evk_defconfig | 2 ++ configs/imxrt1050-evk_defconfig | 2 ++ configs/imxrt1170-evk_defconfig | 2 ++ include/configs/gardena-smart-gateway-mt7688.h | 4 ---- include/configs/imxrt1020-evk.h | 6 ------ include/configs/imxrt1050-evk.h | 6 ------ include/configs/imxrt1170-evk.h | 3 --- include/configs/linkit-smart-7688.h | 4 ---- include/configs/mt7620.h | 3 --- include/configs/mt7628.h | 3 --- include/configs/mt8512.h | 2 -- include/configs/vocore2.h | 4 ---- include/spl.h | 2 +- 19 files changed, 31 insertions(+), 56 deletions(-)
diff --git a/Makefile b/Makefile index 9b90204bfe..13d4c63439 100644 --- a/Makefile +++ b/Makefile @@ -1364,14 +1364,6 @@ OBJCOPYFLAGS_u-boot.ldr.srec := -I binary -O srec u-boot.ldr.hex u-boot.ldr.srec: u-boot.ldr FORCE $(call if_changed,objcopy)
-# -# U-Boot entry point, needed for booting of full-blown U-Boot -# from the SPL U-Boot version. -# -ifndef CFG_SYS_UBOOT_START -CFG_SYS_UBOOT_START := $(CONFIG_TEXT_BASE) -endif - # Boards with more complex image requirements can provide an .its source file # or a generator script # NOTE: Please do not use this. We are migrating away from Makefile rules to use @@ -1391,7 +1383,7 @@ endif
ifdef CONFIG_SPL_LOAD_FIT MKIMAGEFLAGS_u-boot.img = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -p $(CONFIG_FIT_EXTERNAL_OFFSET) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" -E \ $(patsubst %,-b arch/$(ARCH)/dts/%.dtb,$(subst ",,$(DEVICE_TREE))) \ @@ -1399,10 +1391,10 @@ MKIMAGEFLAGS_u-boot.img = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ $(patsubst %,-b arch/$(ARCH)/dts/%.dtbo,$(subst ",,$(CONFIG_OF_OVERLAY_LIST))) else MKIMAGEFLAGS_u-boot.img = -A $(ARCH) -T firmware -C none -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" MKIMAGEFLAGS_u-boot-ivt.img = -A $(ARCH) -T firmware_ivt -C none -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" u-boot-ivt.img: MKIMAGEOUTPUT = u-boot-ivt.img.log endif @@ -1433,7 +1425,7 @@ MKIMAGEFLAGS_u-boot.pbl = -n $(srctree)/$(CONFIG_SYS_FSL_PBL_RCW:"%"=%) \ UBOOT_BIN := u-boot.bin
MKIMAGEFLAGS_u-boot-lzma.img = -A $(ARCH) -T standalone -C lzma -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board"
u-boot.bin.lzma: u-boot.bin FORCE diff --git a/arch/arm/mach-k3/config_secure.mk b/arch/arm/mach-k3/config_secure.mk index 7bc8af813a..9cc1f9eb24 100644 --- a/arch/arm/mach-k3/config_secure.mk +++ b/arch/arm/mach-k3/config_secure.mk @@ -30,7 +30,7 @@ tispl.bin_HS: $(obj)/u-boot-spl-nodtb.bin_HS $(patsubst %,$(obj)/dts/%.dtb_HS,$( $(call if_changed,mkfitimage)
MKIMAGEFLAGS_u-boot.img_HS = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" -E \ $(patsubst %,-b arch/$(ARCH)/dts/%.dtb_HS,$(subst ",,$(CONFIG_OF_LIST)))
diff --git a/arch/arm/mach-omap2/config_secure.mk b/arch/arm/mach-omap2/config_secure.mk index 24ddcdb961..f76262bb0c 100644 --- a/arch/arm/mach-omap2/config_secure.mk +++ b/arch/arm/mach-omap2/config_secure.mk @@ -102,7 +102,7 @@ u-boot_HS_XIP_X-LOADER: $(obj)/u-boot.bin FORCE ifdef CONFIG_SPL_LOAD_FIT
MKIMAGEFLAGS_u-boot_HS.img = -f auto -A $(ARCH) -T firmware -C none -O u-boot \ - -a $(CONFIG_TEXT_BASE) -e $(CFG_SYS_UBOOT_START) \ + -a $(CONFIG_TEXT_BASE) -e $(CONFIG_SYS_UBOOT_START) \ -n "U-Boot $(UBOOTRELEASE) for $(BOARD) board" -E \ $(patsubst %,-b arch/$(ARCH)/dts/%.dtb_HS,$(subst ",,$(CONFIG_OF_LIST)))
diff --git a/boot/Kconfig b/boot/Kconfig index 5e2d4286ae..f2f7821cc1 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -737,6 +737,22 @@ config TEXT_BASE default 0x4a000000 if SUNXI_MINIMUM_DRAM_MB >= 256 default 0x42e00000 if SUNXI_MINIMUM_DRAM_MB >= 64 hex "Text Base" + help + The address in memory that U-Boot will be copied from, initially. + +config HAVE_SYS_UBOOT_START + bool + depends on HAVE_TEXT_BASE + prompt "Use custom U-Boot Start" + help + By default, the address in memory that U-Boot will be copied from(TEXT_BASE) and the + entry point are the same. Select this to set a different U-Boot start address. + +config SYS_UBOOT_START + hex + depends on HAVE_TEXT_BASE + default TEXT_BASE + prompt "U-Boot entry" if HAVE_SYS_UBOOT_START help The address in memory that U-Boot will be running from, initially.
diff --git a/common/spl/spl.c b/common/spl/spl.c index 0062f3f45d..f4b30b3cf3 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -45,10 +45,6 @@ DECLARE_GLOBAL_DATA_PTR; DECLARE_BINMAN_MAGIC_SYM;
-#ifndef CFG_SYS_UBOOT_START -#define CFG_SYS_UBOOT_START CONFIG_TEXT_BASE -#endif - u32 *boot_params_ptr = NULL;
#if CONFIG_IS_ENABLED(BINMAN_UBOOT_SYMBOLS) @@ -252,7 +248,7 @@ void spl_set_header_raw_uboot(struct spl_image_info *spl_image) spl_image->entry_point = u_boot_pos; spl_image->load_addr = u_boot_pos; } else { - spl_image->entry_point = CFG_SYS_UBOOT_START; + spl_image->entry_point = CONFIG_SYS_UBOOT_START; spl_image->load_addr = CONFIG_TEXT_BASE; } spl_image->os = IH_OS_U_BOOT; diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 730639f756..3d39e70e65 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -816,7 +816,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, }
/* - * If a platform does not provide CFG_SYS_UBOOT_START, U-Boot's + * If a platform does not provide CONFIG_SYS_UBOOT_START, U-Boot's * Makefile will set it to 0 and it will end up as the entry point * here. What it actually means is: use the load address. */ diff --git a/configs/imxrt1020-evk_defconfig b/configs/imxrt1020-evk_defconfig index 40210a5f0b..6b63b80895 100644 --- a/configs/imxrt1020-evk_defconfig +++ b/configs/imxrt1020-evk_defconfig @@ -19,6 +19,8 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_SIZE_LIMIT=0x20000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x20209000 +CONFIG_HAVE_SYS_UBOOT_START=y +CONFIG_SYS_UBOOT_START=0x800023FD CONFIG_DISTRO_DEFAULTS=y CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index 8f7a36fea7..cbf9469b24 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -21,6 +21,8 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_SIZE_LIMIT=0x20000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x20209000 +CONFIG_HAVE_SYS_UBOOT_START=y +CONFIG_SYS_UBOOT_START=0x800023FD CONFIG_DISTRO_DEFAULTS=y CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/configs/imxrt1170-evk_defconfig b/configs/imxrt1170-evk_defconfig index 8320c091d2..83825da6de 100644 --- a/configs/imxrt1170-evk_defconfig +++ b/configs/imxrt1170-evk_defconfig @@ -21,6 +21,8 @@ CONFIG_SPL_SERIAL=y CONFIG_SPL_SIZE_LIMIT=0x20000 CONFIG_SPL=y CONFIG_SYS_LOAD_ADDR=0x202C0000 +CONFIG_HAVE_SYS_UBOOT_START=y +CONFIG_SYS_UBOOT_START=0x202403FD CONFIG_DISTRO_DEFAULTS=y CONFIG_SD_BOOT=y # CONFIG_USE_BOOTCOMMAND is not set diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index 0ba4efe67a..1b97ae22fc 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -11,10 +11,6 @@
#define CFG_SYS_INIT_SP_OFFSET 0x400000
-/* SPL */ - -#define CFG_SYS_UBOOT_START CONFIG_TEXT_BASE - /* Dummy value */ #define CFG_SYS_UBOOT_BASE 0
diff --git a/include/configs/imxrt1020-evk.h b/include/configs/imxrt1020-evk.h index e180387c68..cd6af93454 100644 --- a/include/configs/imxrt1020-evk.h +++ b/include/configs/imxrt1020-evk.h @@ -18,10 +18,4 @@ #define DMAMEM_BASE (PHYS_SDRAM + PHYS_SDRAM_SIZE - \ DMAMEM_SZ_ALL)
-/* - * Configuration of the external SDRAM memory - */ - -#define CFG_SYS_UBOOT_START 0x800023FD - #endif /* __IMXRT1020_EVK_H */ diff --git a/include/configs/imxrt1050-evk.h b/include/configs/imxrt1050-evk.h index 7688464841..2af2dde2ae 100644 --- a/include/configs/imxrt1050-evk.h +++ b/include/configs/imxrt1050-evk.h @@ -25,10 +25,4 @@ "stderr=serial,vidconsole\0" #endif
-/* - * Configuration of the external SDRAM memory - */ - -#define CFG_SYS_UBOOT_START 0x800023FD - #endif /* __IMXRT1050_EVK_H */ diff --git a/include/configs/imxrt1170-evk.h b/include/configs/imxrt1170-evk.h index f83429082a..1ccaa15bc1 100644 --- a/include/configs/imxrt1170-evk.h +++ b/include/configs/imxrt1170-evk.h @@ -22,8 +22,5 @@ #define DMAMEM_SZ_ALL (1 * 1024 * 1024) #define DMAMEM_BASE (PHYS_SDRAM + PHYS_SDRAM_SIZE - \ DMAMEM_SZ_ALL) -/* For SPL */ -#define CFG_SYS_UBOOT_START 0x202403FD -/* For SPL ends */
#endif /* __IMXRT1170_EVK_H */ diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index f16c7e9122..e8f7a59c40 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -11,10 +11,6 @@
diff --git a/include/configs/mt7620.h b/include/configs/mt7620.h index d69d35fa96..3bc0c18a1e 100644 --- a/include/configs/mt7620.h +++ b/include/configs/mt7620.h @@ -12,9 +12,6 @@
-/* SPL */ -#define CFG_SYS_UBOOT_START CONFIG_TEXT_BASE - /* Dummy value */ #define CFG_SYS_UBOOT_BASE 0
diff --git a/include/configs/mt7628.h b/include/configs/mt7628.h index 0ac376d33c..1df06811d6 100644 --- a/include/configs/mt7628.h +++ b/include/configs/mt7628.h @@ -22,9 +22,6 @@ #define CFG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ 230400, 460800, 921600 }
diff --git a/include/configs/mt8512.h b/include/configs/mt8512.h index c0fc8688ca..4e70291e94 100644 --- a/include/configs/mt8512.h +++ b/include/configs/mt8512.h @@ -10,8 +10,6 @@ #define __MT8512_H
/* Uboot definition */ -#define CFG_SYS_UBOOT_START CONFIG_TEXT_BASE - #define ENV_BOOT_READ_IMAGE \ "boot_rd_img=mmc dev 0" \ ";mmc read ${loadaddr} 0x27000 0x8000" \ diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h index 43050d61c3..eb87633661 100644 --- a/include/configs/vocore2.h +++ b/include/configs/vocore2.h @@ -11,10 +11,6 @@
diff --git a/include/spl.h b/include/spl.h index 92bcaa90a4..57da1484f0 100644 --- a/include/spl.h +++ b/include/spl.h @@ -484,7 +484,7 @@ unsigned long spl_mmc_get_uboot_raw_sector(struct mmc *mmc, * spl_set_header_raw_uboot() - Set up a standard SPL image structure * * This sets up the given spl_image which the standard values obtained from - * config options: CONFIG_SYS_MONITOR_LEN, CFG_SYS_UBOOT_START, + * config options: CONFIG_SYS_MONITOR_LEN, CONFIG_SYS_UBOOT_START, * CONFIG_TEXT_BASE. * * @spl_image: Image description to set up
[snip]
- help
- bool
- depends on HAVE_TEXT_BASE
- prompt "Use custom U-Boot Start"
We should use: bool "Use custom U-Boot start address"
instead of separate bool/prompt.
- help
- hex
- default TEXT_BASE
- prompt "U-Boot entry" if HAVE_SYS_UBOOT_START
This is clever, and can be kept. I didn't catch at first that this will do what I was hoping of setting a default, but then allowing for it to be changed.
This should be slightly different and expand on what's in the help text for HAVE_SYS_UBOOT_START.
Thanks!
Hi Jesse,
help
bool
help
space after 'from'
Also this is a little unclear. START means the start address that U-Boot will run from. If it is different from TEXT_BASE, then something loads it here?
This could do with a bit more detail.
hex
default TEXT_BASE
On Thu, Aug 24, 2023 at 4:01 PM Simon Glass sjg@chromium.org wrote:
Hi Jesse,
help
bool
help
space after 'from'
Yes, it is and why I edited the TEXT_BASE help prompt. I'm not sure how to word that this is where the SPL will start execution after the jump. TEXT_BASE is where the spl will copy the binary to.
hex
default TEXT_BASE
Tom: This is clever, and can be kept. I didn't catch at first that this will do what I was hoping of setting a default, but then allowing for it to be changed.
Was there another way of doing this? I looked at the docs for a while to figure this out.
Thanks, Jesse Taube
Hi Jesse,
help
bool
help
space after 'from'
hex
default TEXT_BASE
This part here is mechanically correct. Just need a slight wording change to the help to better explain what / why one wants to adjust the address. Why are these platforms needing start != text?
Jesse T
Jesse Taube
