[U-Boot] [Patch V3 1/4] spi: fsl_qspi: fix compile warning for 64-bit platform
This patch fixes the following compile warning: drivers/spi/fsl_qspi.c: In function 'fsl_qspi_probe': drivers/spi/fsl_qspi.c:937:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct fsl_qspi_regs *)plat->reg_base; ^
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V2-V3: - No change.
drivers/spi/fsl_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 542b6cf..eb033bf 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -936,7 +936,7 @@ static int fsl_qspi_probe(struct udevice *bus)
dm_spi_bus->max_hz = plat->speed_hz;
- priv->regs = (struct fsl_qspi_regs *)plat->reg_base; + priv->regs = (struct fsl_qspi_regs *)(unsigned long)plat->reg_base; priv->flags = plat->flags;
priv->speed_hz = plat->speed_hz;
Gong Qianyu
