[PATCH 1/1] riscv: reset after crash
If an exception occurs on ARM or x86, we call panic() which will try to reset the board. Do the same on RISC-V.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- arch/riscv/lib/interrupts.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index 8ff40f0f36..f95cb97f92 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -84,7 +84,7 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs)
show_regs(regs); show_efi_loaded_images(epc); - hang(); + panic ("Resetting CPU ...\n"); }
int interrupt_init(void) -- 2.28.0
- hang();
- panic ("Resetting CPU ...\n");
Nits: no space before parentheses.
Do we need a message here? do_panic already prints "resetting...".
--Sean
- hang();
May be I should not have blindly copied from ARM.
With CONFIG_PANIC_HANG=y the next message will be:
### ERROR ### Please RESET the board ###
"resetting..." is printed by the respective implementation of do_reset() depending on the value of CONFIG_SYSRESET=y.
As on all three passways we have a follow up message, passing an empty string "" to panic() should be enough.
Best regards
Heinrich
Sean Anderson
