imx6ull-evk: Hanging with Ethernet enabled
Hi Peng,
Running top of tree U-Boot on an imx6ull evk board causes the board to hang:
U-Boot 2024.10-rc3-00015-g57949a99b7bd (Aug 30 2024 - 13:46:12 -0300)
CPU: Freescale i.MX6ULL rev1.1 900 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C) at 27C Reset cause: POR Model: Freescale i.MX6 UltraLiteLite 14x14 EVK Board Board: MX6ULL 14x14 EVK DRAM: 512 MiB Core: 69 devices, 19 uclasses, devicetree: separate MMC: FSL_SDHC: 0, FSL_SDHC: 1 Loading Environment from MMC... Reading from MMC(1)... *** Warning - bad CRC, using default environment
In: serial@2020000 Out: serial@2020000 Err: serial@2020000 Net:
If I disable Ethernet, U-Boot boots fine.
I haven't had a chance to investigate, but wanted to report it.
Please take a look when you have a chance.
Regards,
Fabio Estevam
On Fri, Aug 30, 2024 at 1:49 PM Fabio Estevam festevam@gmail.com wrote:
Hi Peng,
I was using a imx6ulz, not imx6ull. The imx6ulz does not have Ethernet.
Sorry for the noise.
The imx6ull-evk is booting fine.
Fabio Estevam
