[U-Boot] [PATCH] gpio: generalize for all generic gpio providers
The Blackfin gpio command isn't terribly Blackfin-specific. So generalize the few pieces into two new optional helpers: name_to_gpio() - turn a string name into a GPIO # gpio_status() - display current pin bindings (think /proc/gpio)
Once these pieces are pulled out, we can relocate the cmd_gpio.c into the common directory.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- arch/blackfin/cpu/Makefile | 1 - arch/blackfin/cpu/cmd_gpio.c | 118 -------------------------------------- arch/blackfin/include/asm/gpio.h | 53 +++++++++++++++++ common/Makefile | 1 + common/cmd_gpio.c | 86 +++++++++++++++++++++++++++ 5 files changed, 140 insertions(+), 119 deletions(-) delete mode 100644 arch/blackfin/cpu/cmd_gpio.c create mode 100644 common/cmd_gpio.c
diff --git a/arch/blackfin/cpu/Makefile b/arch/blackfin/cpu/Makefile index 4a9e577..df10f1b 100644 --- a/arch/blackfin/cpu/Makefile +++ b/arch/blackfin/cpu/Makefile @@ -18,7 +18,6 @@ CEXTRA := initcode.o SEXTRA := start.o SOBJS := interrupt.o cache.o COBJS-$(CONFIG_BOOTCOUNT_LIMIT) += bootcount.o -COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o COBJS-y += cpu.o COBJS-y += gpio.o COBJS-y += interrupts.o diff --git a/arch/blackfin/cpu/cmd_gpio.c b/arch/blackfin/cpu/cmd_gpio.c deleted file mode 100644 index e96413b..0000000 --- a/arch/blackfin/cpu/cmd_gpio.c +++ /dev/null @@ -1,118 +0,0 @@ -/* - * Control GPIO pins on the fly - * - * Copyright (c) 2008-2010 Analog Devices Inc. - * - * Licensed under the GPL-2 or later. - */ - -#include <common.h> -#include <command.h> -#include <linux/ctype.h> - -#include <asm/blackfin.h> -#include <asm/gpio.h> - -enum { - GPIO_INPUT, - GPIO_SET, - GPIO_CLEAR, - GPIO_TOGGLE, -}; - -int do_gpio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) -{ - if (argc == 2 && !strcmp(argv[1], "status")) { - bfin_gpio_labels(); - return 0; - } - - if (argc != 3) - show_usage: - return cmd_usage(cmdtp); - - /* parse the behavior */ - ulong sub_cmd; - switch (argv[1][0]) { - case 'i': sub_cmd = GPIO_INPUT; break; - case 's': sub_cmd = GPIO_SET; break; - case 'c': sub_cmd = GPIO_CLEAR; break; - case 't': sub_cmd = GPIO_TOGGLE; break; - default: goto show_usage; - } - - /* parse the pin with format: [p][port]<#> */ - const char *str_pin = argv[2]; - - /* grab the [p]<port> portion */ - ulong port_base; - if (tolower(*str_pin) == 'p') ++str_pin; - switch (tolower(*str_pin)) { -#ifdef GPIO_PA0 - case 'a': port_base = GPIO_PA0; break; -#endif -#ifdef GPIO_PB0 - case 'b': port_base = GPIO_PB0; break; -#endif -#ifdef GPIO_PC0 - case 'c': port_base = GPIO_PC0; break; -#endif -#ifdef GPIO_PD0 - case 'd': port_base = GPIO_PD0; break; -#endif -#ifdef GPIO_PE0 - case 'e': port_base = GPIO_PE0; break; -#endif -#ifdef GPIO_PF0 - case 'f': port_base = GPIO_PF0; break; -#endif -#ifdef GPIO_PG0 - case 'g': port_base = GPIO_PG0; break; -#endif -#ifdef GPIO_PH0 - case 'h': port_base = GPIO_PH0; break; -#endif -#ifdef GPIO_PI0 - case 'i': port_base = GPIO_PI0; break; -#endif -#ifdef GPIO_PJ - case 'j': port_base = GPIO_PJ0; break; -#endif - default: goto show_usage; - } - - /* grab the <#> portion */ - ulong pin = simple_strtoul(str_pin + 1, NULL, 10); - if (pin > 15) - goto show_usage; - - /* grab the pin before we tweak it */ - ulong gpio = port_base + pin; - gpio_request(gpio, "cmd_gpio"); - - /* finally, let's do it: set direction and exec command */ - ulong value; - if (sub_cmd == GPIO_INPUT) { - gpio_direction_input(gpio); - value = gpio_get_value(gpio); - } else { - switch (sub_cmd) { - case GPIO_SET: value = 1; break; - case GPIO_CLEAR: value = 0; break; - case GPIO_TOGGLE: value = !gpio_get_value(gpio); break; - default: goto show_usage; - } - gpio_direction_output(gpio, value); - } - printf("gpio: pin %lu on port %c (gpio %lu) value is %lu\n", - pin, *str_pin, gpio, value); - - gpio_free(gpio); - - return value; -} - -U_BOOT_CMD(gpio, 3, 0, do_gpio, - "input/set/clear/toggle gpio output pins", - "<input|set|clear|toggle> <port><pin>\n" - " - input/set/clear/toggle the specified pin (e.g. PF10)"); diff --git a/arch/blackfin/include/asm/gpio.h b/arch/blackfin/include/asm/gpio.h index b650ef0..9c0e5d1 100644 --- a/arch/blackfin/include/asm/gpio.h +++ b/arch/blackfin/include/asm/gpio.h @@ -196,6 +196,59 @@ static inline int gpio_is_valid(int number) return number >= 0 && number < MAX_BLACKFIN_GPIOS; }
+#include <linux/ctype.h> + +static inline int name_to_gpio(const char *name) +{ + int port_base; + + if (tolower(*name) == 'p') { + ++name; + + switch (tolower(*name)) { +#ifdef GPIO_PA0 + case 'a': port_base = GPIO_PA0; break; +#endif +#ifdef GPIO_PB0 + case 'b': port_base = GPIO_PB0; break; +#endif +#ifdef GPIO_PC0 + case 'c': port_base = GPIO_PC0; break; +#endif +#ifdef GPIO_PD0 + case 'd': port_base = GPIO_PD0; break; +#endif +#ifdef GPIO_PE0 + case 'e': port_base = GPIO_PE0; break; +#endif +#ifdef GPIO_PF0 + case 'f': port_base = GPIO_PF0; break; +#endif +#ifdef GPIO_PG0 + case 'g': port_base = GPIO_PG0; break; +#endif +#ifdef GPIO_PH0 + case 'h': port_base = GPIO_PH0; break; +#endif +#ifdef GPIO_PI0 + case 'i': port_base = GPIO_PI0; break; +#endif +#ifdef GPIO_PJ + case 'j': port_base = GPIO_PJ0; break; +#endif + default: return -1; + } + + ++name; + } else + port_base = 0; + + return port_base + simple_strtoul(name, NULL, 10); +} +#define name_to_gpio(n) name_to_gpio(n) + +#define gpio_status() bfin_gpio_labels() + #endif /* __ASSEMBLY__ */
#endif /* __ARCH_BLACKFIN_GPIO_H__ */ diff --git a/common/Makefile b/common/Makefile index 167612b..2ea0075 100644 --- a/common/Makefile +++ b/common/Makefile @@ -95,6 +95,7 @@ COBJS-$(CONFIG_CMD_FLASH) += cmd_flash.o ifdef CONFIG_FPGA COBJS-$(CONFIG_CMD_FPGA) += cmd_fpga.o endif +COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o COBJS-$(CONFIG_CMD_I2C) += cmd_i2c.o COBJS-$(CONFIG_CMD_IDE) += cmd_ide.o COBJS-$(CONFIG_CMD_IMMAP) += cmd_immap.o diff --git a/common/cmd_gpio.c b/common/cmd_gpio.c new file mode 100644 index 0000000..9c9de28 --- /dev/null +++ b/common/cmd_gpio.c @@ -0,0 +1,86 @@ +/* + * Control GPIO pins on the fly + * + * Copyright (c) 2008-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <command.h> + +#include <asm/gpio.h> + +#ifndef name_to_gpio +#define name_to_gpio(name) simple_strtoul(name, NULL, 10) +#endif + +enum gpio_cmd { + GPIO_INPUT, + GPIO_SET, + GPIO_CLEAR, + GPIO_TOGGLE, +}; + +static int do_gpio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int gpio; + enum gpio_cmd sub_cmd; + ulong value; + const char *str_cmd, *str_gpio; + +#ifdef gpio_status + if (argc == 2 && !strcmp(argv[1], "status")) { + gpio_status(); + return 0; + } +#endif + + if (argc != 3) + show_usage: + return cmd_usage(cmdtp); + str_cmd = argv[1]; + str_gpio = argv[2]; + + /* parse the behavior */ + switch (*str_cmd) { + case 'i': sub_cmd = GPIO_INPUT; break; + case 's': sub_cmd = GPIO_SET; break; + case 'c': sub_cmd = GPIO_CLEAR; break; + case 't': sub_cmd = GPIO_TOGGLE; break; + default: goto show_usage; + } + + /* turn the gpio name into a gpio number */ + gpio = name_to_gpio(str_gpio); + if (gpio < 0) + goto show_usage; + + /* grab the pin before we tweak it */ + gpio_request(gpio, "cmd_gpio"); + + /* finally, let's do it: set direction and exec command */ + if (sub_cmd == GPIO_INPUT) { + gpio_direction_input(gpio); + value = gpio_get_value(gpio); + } else { + switch (sub_cmd) { + case GPIO_SET: value = 1; break; + case GPIO_CLEAR: value = 0; break; + case GPIO_TOGGLE: value = !gpio_get_value(gpio); break; + default: goto show_usage; + } + gpio_direction_output(gpio, value); + } + printf("gpio: pin %s (gpio %i) value is %lu\n", + str_gpio, gpio, value); + + gpio_free(gpio); + + return value; +} + +U_BOOT_CMD(gpio, 3, 0, do_gpio, + "input/set/clear/toggle gpio pins", + "<input|set|clear|toggle> <pin>\n" + " - input/set/clear/toggle the specified pin");
Am Sonntag, den 03.04.2011, 04:43 -0400 schrieb Mike Frysinger:
Tested-by: Andreas Pretzsch apr@cn-eng.de
Verified on Blackfin BF561 with full port range.
- int port_base;
- if (tolower(*name) == 'p') {
++name;
+#ifdef GPIO_PA0
default: return -1;
++name;
- } else
port_base = 0;
- return port_base + simple_strtoul(name, NULL, 10);
Remark: Leads to an oom access when exceeding the processor number of GPIOs, e.g. PF48 on a BF561. IMHO, no problem but only a cosmetic issue, not worth adding an additional per-cpu check. In the end, no difference to other user errors like an invalid memory address.
err, oom ? i guess you mean oob ?
simple to fix by having the return of gpio_request() get checked ... -mike
Am Montag, den 11.04.2011, 23:14 -0400 schrieb Mike Frysinger:
bfin> gpio input PF0 gpio: pin PF0 (gpio 0) value is 1 bfin> gpio input pf47 gpio: pin pf47 (gpio 47) value is 1 bfin> gpio input pf48 DCPLB exception outside of memory map at 0x33000000 [...] PANIC: Blackfin internal error
Works, thanks. With "[U-Boot] [PATCH] gpio: check request result":
bfin> gpio input PF0 gpio: pin PF0 (gpio 0) value is 1 bfin> gpio input pf47 gpio: pin pf47 (gpio 47) value is 1 bfin> gpio input pf48 gpio: requesting pin 48 failed bfin>
"oom" is usually reserved for "out of memory" as in "memory exhausted" -mike
Make sure the pin request passed before attempting to use it later on.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/cmd_gpio.c | 5 ++++- 1 files changed, 4 insertions(+), 1 deletions(-)
diff --git a/common/cmd_gpio.c b/common/cmd_gpio.c index 9c9de28..9cc790a 100644 --- a/common/cmd_gpio.c +++ b/common/cmd_gpio.c @@ -57,7 +57,10 @@ static int do_gpio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) goto show_usage;
/* grab the pin before we tweak it */ - gpio_request(gpio, "cmd_gpio"); + if (gpio_request(gpio, "cmd_gpio")) { + printf("gpio: requesting pin %u failed\n", gpio); + return -1; + }
/* finally, let's do it: set direction and exec command */ if (sub_cmd == GPIO_INPUT) {
Am Dienstag, den 12.04.2011, 03:03 -0400 schrieb Mike Frysinger:
Andreas Pretzsch
Mike Frysinger
