[U-Boot] [RFC 0/7] Universal PHY Infrastructure
Or PHY Lib for U-Boot.
This sequence of patches adds infrastructure for universally-available PHY drivers (and MDIO drivers). It piggy-backs on the existing miiphy code, for backwards compatibility, but it also creates a new set of APIs. This was necessary partly to provide cleaner interfaces for more robust driver support, and partly because one goal was to support 10G (802.3 Clause 45) MDIO buses, which has an extra argument for addressing PHY registers.
The first three patches clear the way, and are in this sequence mostly because the tsec changes depend on them.
Special thanks goes to Mingkai Hu, who did a substantial amount of work up front to convert the tsec PHY code into something more usable, which I have mostly copied for the purposes of PHY Lib.
As the subject says, these are submitted here for comment. I hope they will go in for the presumptive June release.
Andy Fleming (5): Remove instances of phy_read/write Create PHY Lib for U-Boot Add mdio command for new PHY infrastructure phylib: Add a bunch of PHY drivers from tsec tsec: Convert tsec to use PHY Lib
Mingkai Hu (2): tsec: use IO accessories to access the register tsec: arrange the code to avoid useless function declaration
arch/powerpc/include/asm/config.h | 7 + arch/powerpc/include/asm/fsl_enet.h | 10 + board/freescale/mpc837xemds/mpc837xemds.c | 7 + board/freescale/mpc8536ds/mpc8536ds.c | 6 + board/freescale/mpc8544ds/mpc8544ds.c | 30 + board/freescale/mpc8572ds/mpc8572ds.c | 6 + board/freescale/p1022ds/p1022ds.c | 6 + board/freescale/p1_p2_rdb/p1_p2_rdb.c | 6 + board/freescale/p2020ds/p2020ds.c | 7 + common/Makefile | 4 + common/cmd_mdio.c | 293 +++++ common/miiphyutil.c | 173 +++- drivers/net/Makefile | 2 +- drivers/net/dm9000x.c | 18 +- drivers/net/enc28j60.c | 24 +- drivers/net/fsl_mdio.c | 117 ++ drivers/net/phy/Makefile | 11 + drivers/net/phy/atheros.c | 37 + drivers/net/phy/broadcom.c | 275 ++++ drivers/net/phy/davicom.c | 86 ++ drivers/net/phy/lxt.c | 76 ++ drivers/net/phy/marvell.c | 357 ++++++ drivers/net/phy/micrel.c | 29 + drivers/net/phy/natsemi.c | 85 ++ drivers/net/phy/phy.c | 733 +++++++++++ drivers/net/phy/realtek.c | 120 ++ drivers/net/phy/teranetics.c | 43 + drivers/net/phy/vitesse.c | 330 +++++ drivers/net/tsec.c | 1966 ++++------------------------- drivers/net/uli526x.c | 24 +- drivers/qe/uec.c | 3 - drivers/qe/uec_phy.c | 145 ++-- include/fsl_mdio.h | 62 + include/miiphy.h | 31 + include/phy.h | 498 ++++++++ include/phylib_all_drivers.h | 25 + include/tsec.h | 302 +---- net/eth.c | 6 + 38 files changed, 3860 insertions(+), 2100 deletions(-) create mode 100644 common/cmd_mdio.c create mode 100644 drivers/net/fsl_mdio.c create mode 100644 drivers/net/phy/atheros.c create mode 100644 drivers/net/phy/broadcom.c create mode 100644 drivers/net/phy/davicom.c create mode 100644 drivers/net/phy/lxt.c create mode 100644 drivers/net/phy/marvell.c create mode 100644 drivers/net/phy/micrel.c create mode 100644 drivers/net/phy/natsemi.c create mode 100644 drivers/net/phy/phy.c create mode 100644 drivers/net/phy/realtek.c create mode 100644 drivers/net/phy/teranetics.c create mode 100644 drivers/net/phy/vitesse.c create mode 100644 include/fsl_mdio.h create mode 100644 include/phy.h create mode 100644 include/phylib_all_drivers.h
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Acked-by: Andy Fleming afleming@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/net/tsec.c | 234 ++++++++++++++++++++++++++------------------------- include/tsec.h | 8 +- 2 files changed, 123 insertions(+), 119 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 9c8fe62..1665174 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -5,7 +5,7 @@ * terms of the GNU Public License, Version 2, incorporated * herein by reference. * - * Copyright 2004-2010 Freescale Semiconductor, Inc. + * Copyright 2004-2011 Freescale Semiconductor, Inc. * (C) Copyright 2003, Motorola, Inc. * author Andy Fleming * @@ -50,7 +50,7 @@ static int tsec_recv(struct eth_device *dev); static int tsec_init(struct eth_device *dev, bd_t * bd); static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info); static void tsec_halt(struct eth_device *dev); -static void init_registers(volatile tsec_t * regs); +static void init_registers(tsec_t * regs); static void startup_tsec(struct eth_device *dev); static int init_phy(struct eth_device *dev); void write_phy_reg(struct tsec_private *priv, uint regnum, uint value); @@ -166,9 +166,9 @@ static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info) eth_register(dev);
/* Reset the MAC */ - priv->regs->maccfg1 |= MACCFG1_SOFT_RESET; + setbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); udelay(2); /* Soft Reset must be asserted for 3 TX clocks */ - priv->regs->maccfg1 &= ~(MACCFG1_SOFT_RESET); + clrbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET);
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ && !defined(BITBANGMII) @@ -190,16 +190,16 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) char tmpbuf[MAC_ADDR_LEN]; int i; struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
/* Make sure the controller is stopped */ tsec_halt(dev);
/* Init MACCFG2. Defaults to GMII */ - regs->maccfg2 = MACCFG2_INIT_SETTINGS; + out_be32(®s->maccfg2, MACCFG2_INIT_SETTINGS);
/* Init ECNTRL */ - regs->ecntrl = ECNTRL_INIT_SETTINGS; + out_be32(®s->ecntrl, ECNTRL_INIT_SETTINGS);
/* Copy the station address into the address registers. * Backwards, because little endian MACS are dumb */ @@ -209,11 +209,11 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) tempval = (tmpbuf[0] << 24) | (tmpbuf[1] << 16) | (tmpbuf[2] << 8) | tmpbuf[3];
- regs->macstnaddr1 = tempval; + out_be32(®s->macstnaddr1, tempval);
tempval = *((uint *) (tmpbuf + 4));
- regs->macstnaddr2 = tempval; + out_be32(®s->macstnaddr2, tempval);
/* reset the indices to zero */ rxIdx = 0; @@ -230,17 +230,17 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) }
/* Writes the given phy's reg with value, using the specified MDIO regs */ -static void tsec_local_mdio_write(volatile tsec_mdio_t *phyregs, uint addr, +static void tsec_local_mdio_write(tsec_mdio_t *phyregs, uint addr, uint reg, uint value) { int timeout = 1000000;
- phyregs->miimadd = (addr << 8) | reg; - phyregs->miimcon = value; + out_be32(&phyregs->miimadd, (addr << 8) | reg); + out_be32(&phyregs->miimcon, value); asm("sync");
timeout = 1000000; - while ((phyregs->miimind & MIIMIND_BUSY) && timeout--) ; + while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--) ; }
@@ -254,28 +254,27 @@ static void tsec_local_mdio_write(volatile tsec_mdio_t *phyregs, uint addr, * notvalid bit cleared), and the bus to cease activity (miimind * busy bit cleared), and then returns the value */ -static uint tsec_local_mdio_read(volatile tsec_mdio_t *phyregs, - uint phyid, uint regnum) +static uint tsec_local_mdio_read(tsec_mdio_t *phyregs, uint phyid, uint regnum) { uint value;
/* Put the address of the phy, and the register * number into MIIMADD */ - phyregs->miimadd = (phyid << 8) | regnum; + out_be32(&phyregs->miimadd, (phyid << 8) | regnum);
/* Clear the command register, and wait */ - phyregs->miimcom = 0; + out_be32(&phyregs->miimcom, 0); asm("sync");
/* Initiate a read command, and wait */ - phyregs->miimcom = MIIM_READ_COMMAND; + out_be32(&phyregs->miimcom, MIIM_READ_COMMAND); asm("sync");
/* Wait for the the indication that the read is done */ - while ((phyregs->miimind & (MIIMIND_NOTVALID | MIIMIND_BUSY))) ; + while ((in_be32(&phyregs->miimind) & (MIIMIND_NOTVALID | MIIMIND_BUSY))) ;
/* Grab the value read from the PHY */ - value = phyregs->miimstat; + value = in_be32(&phyregs->miimstat);
return value; } @@ -321,18 +320,18 @@ static int init_phy(struct eth_device *dev) { struct tsec_private *priv = (struct tsec_private *)dev->priv; struct phy_info *curphy; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
/* Assign a Physical address to the TBI */ - regs->tbipa = CONFIG_SYS_TBIPA_VALUE; + out_be32(®s->tbipa, CONFIG_SYS_TBIPA_VALUE); asm("sync");
/* Reset MII (due to new addresses) */ - priv->phyregs->miimcfg = MIIMCFG_RESET; + out_be32(&priv->phyregs->miimcfg, MIIMCFG_RESET); asm("sync"); - priv->phyregs->miimcfg = MIIMCFG_INIT_VALUE; + out_be32(&priv->phyregs->miimcfg, MIIMCFG_INIT_VALUE); asm("sync"); - while (priv->phyregs->miimind & MIIMIND_BUSY) ; + while (in_be32(&priv->phyregs->miimind) & MIIMIND_BUSY) ;
/* Get the cmd structure corresponding to the attached * PHY */ @@ -345,7 +344,7 @@ static int init_phy(struct eth_device *dev) return 0; }
- if (regs->ecntrl & ECNTRL_SGMII_MODE) + if (in_be32(®s->ecntrl) & ECNTRL_SGMII_MODE) tsec_configure_serdes(priv);
priv->phyinfo = curphy; @@ -838,16 +837,16 @@ static uint mii_parse_dm9161_scsr(uint mii_reg, struct tsec_private * priv) static uint mii_cis8204_fixled(uint mii_reg, struct tsec_private * priv) { uint phyid; - volatile tsec_mdio_t *regbase = priv->phyregs; + tsec_mdio_t *regbase = priv->phyregs; int timeout = 1000000;
for (phyid = 0; phyid < 4; phyid++) { - regbase->miimadd = (phyid << 8) | mii_reg; - regbase->miimcon = MIIM_CIS8204_SLEDCON_INIT; + out_be32(®base->miimadd, (phyid << 8) | mii_reg); + out_be32(®base->miimcon, MIIM_CIS8204_SLEDCON_INIT); asm("sync");
timeout = 1000000; - while ((regbase->miimind & MIIMIND_BUSY) && timeout--) ; + while ((in_be32(®base->miimind) & MIIMIND_BUSY) && timeout--) ; }
return MIIM_CIS8204_SLEDCON_INIT; @@ -874,45 +873,45 @@ static uint mii_m88e1111s_setmode(uint mii_reg, struct tsec_private *priv) * those we don't care about (unless zero is bad, in which case, * choose a more appropriate value) */ -static void init_registers(volatile tsec_t * regs) +static void init_registers(tsec_t * regs) { /* Clear IEVENT */ - regs->ievent = IEVENT_INIT_CLEAR; - - regs->imask = IMASK_INIT_CLEAR; - - regs->hash.iaddr0 = 0; - regs->hash.iaddr1 = 0; - regs->hash.iaddr2 = 0; - regs->hash.iaddr3 = 0; - regs->hash.iaddr4 = 0; - regs->hash.iaddr5 = 0; - regs->hash.iaddr6 = 0; - regs->hash.iaddr7 = 0; - - regs->hash.gaddr0 = 0; - regs->hash.gaddr1 = 0; - regs->hash.gaddr2 = 0; - regs->hash.gaddr3 = 0; - regs->hash.gaddr4 = 0; - regs->hash.gaddr5 = 0; - regs->hash.gaddr6 = 0; - regs->hash.gaddr7 = 0; - - regs->rctrl = 0x00000000; + out_be32(®s->ievent, IEVENT_INIT_CLEAR); + + out_be32(®s->imask, IMASK_INIT_CLEAR); + + out_be32(®s->hash.iaddr0, 0); + out_be32(®s->hash.iaddr1, 0); + out_be32(®s->hash.iaddr2, 0); + out_be32(®s->hash.iaddr3, 0); + out_be32(®s->hash.iaddr4, 0); + out_be32(®s->hash.iaddr5, 0); + out_be32(®s->hash.iaddr6, 0); + out_be32(®s->hash.iaddr7, 0); + + out_be32(®s->hash.gaddr0, 0); + out_be32(®s->hash.gaddr1, 0); + out_be32(®s->hash.gaddr2, 0); + out_be32(®s->hash.gaddr3, 0); + out_be32(®s->hash.gaddr4, 0); + out_be32(®s->hash.gaddr5, 0); + out_be32(®s->hash.gaddr6, 0); + out_be32(®s->hash.gaddr7, 0); + + out_be32(®s->rctrl, 0x00000000);
/* Init RMON mib registers */ memset((void *)&(regs->rmon), 0, sizeof(rmon_mib_t));
- regs->rmon.cam1 = 0xffffffff; - regs->rmon.cam2 = 0xffffffff; + out_be32(®s->rmon.cam1, 0xffffffff); + out_be32(®s->rmon.cam2, 0xffffffff);
- regs->mrblr = MRBLR_INIT_SETTINGS; + out_be32(®s->mrblr, MRBLR_INIT_SETTINGS);
- regs->minflr = MINFLR_INIT_SETTINGS; + out_be32(®s->minflr, MINFLR_INIT_SETTINGS);
- regs->attr = ATTR_INIT_SETTINGS; - regs->attreli = ATTRELI_INIT_SETTINGS; + out_be32(®s->attr, ATTR_INIT_SETTINGS); + out_be32(®s->attreli, ATTRELI_INIT_SETTINGS);
@@ -922,44 +921,49 @@ static void init_registers(volatile tsec_t * regs) static void adjust_link(struct eth_device *dev) { struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs; + u32 ecntrl, maccfg2;
- if (priv->link) { - if (priv->duplexity != 0) - regs->maccfg2 |= MACCFG2_FULL_DUPLEX; - else - regs->maccfg2 &= ~(MACCFG2_FULL_DUPLEX); + if (!priv->link) { + printf("%s: No link.\n", dev->name); + return; + }
- switch (priv->speed) { - case 1000: - regs->maccfg2 = ((regs->maccfg2 & ~(MACCFG2_IF)) - | MACCFG2_GMII); - break; - case 100: - case 10: - regs->maccfg2 = ((regs->maccfg2 & ~(MACCFG2_IF)) - | MACCFG2_MII); + /* clear all bits relative with interface mode */ + ecntrl = in_be32(®s->ecntrl); + ecntrl &= ~ECNTRL_R100;
- /* Set R100 bit in all modes although - * it is only used in RGMII mode - */ - if (priv->speed == 100) - regs->ecntrl |= ECNTRL_R100; - else - regs->ecntrl &= ~(ECNTRL_R100); - break; - default: - printf("%s: Speed was bad\n", dev->name); - break; - } + maccfg2 = in_be32(®s->maccfg2); + maccfg2 &= ~(MACCFG2_IF | MACCFG2_FULL_DUPLEX);
- printf("Speed: %d, %s duplex%s\n", priv->speed, - (priv->duplexity) ? "full" : "half", - (priv->flags & TSEC_FIBER) ? ", fiber mode" : ""); + if (priv->duplexity) + maccfg2 |= MACCFG2_FULL_DUPLEX;
- } else { - printf("%s: No link.\n", dev->name); + switch (priv->speed) { + case 1000: + maccfg2 |= MACCFG2_GMII; + break; + case 100: + case 10: + maccfg2 |= MACCFG2_MII; + + /* Set R100 bit in all modes although + * it is only used in RGMII mode + */ + if (priv->speed == 100) + ecntrl |= ECNTRL_R100; + break; + default: + printf("%s: Speed was bad\n", dev->name); + break; } + + out_be32(®s->ecntrl, ecntrl); + out_be32(®s->maccfg2, maccfg2); + + printf("Speed: %d, %s duplex%s\n", priv->speed, + (priv->duplexity) ? "full" : "half", + (priv->flags & TSEC_FIBER) ? ", fiber mode" : ""); }
/* Set up the buffers and their descriptors, and bring up the @@ -969,11 +973,11 @@ static void startup_tsec(struct eth_device *dev) { int i; struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
/* Point to the buffer descriptors */ - regs->tbase = (unsigned int)(&rtx.txbd[txIdx]); - regs->rbase = (unsigned int)(&rtx.rxbd[rxIdx]); + out_be32(®s->tbase, (unsigned int)(&rtx.txbd[txIdx])); + out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[rxIdx]));
/* Initialize the Rx Buffer descriptors */ for (i = 0; i < PKTBUFSRX; i++) { @@ -998,13 +1002,13 @@ static void startup_tsec(struct eth_device *dev) adjust_link(dev);
/* Enable Transmit and Receive */ - regs->maccfg1 |= (MACCFG1_RX_EN | MACCFG1_TX_EN); + setbits_be32(®s->maccfg1, MACCFG1_RX_EN | MACCFG1_TX_EN);
/* Tell the DMA it is clear to go */ - regs->dmactrl |= DMACTRL_INIT_SETTINGS; - regs->tstat = TSTAT_CLEAR_THALT; - regs->rstat = RSTAT_CLEAR_RHALT; - regs->dmactrl &= ~(DMACTRL_GRS | DMACTRL_GTS); + setbits_be32(®s->dmactrl, DMACTRL_INIT_SETTINGS); + out_be32(®s->tstat, TSTAT_CLEAR_THALT); + out_be32(®s->rstat, RSTAT_CLEAR_RHALT); + clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); }
/* This returns the status bits of the device. The return value @@ -1017,7 +1021,7 @@ static int tsec_send(struct eth_device *dev, volatile void *packet, int length) int i; int result = 0; struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
/* Find an empty buffer descriptor */ for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { @@ -1033,7 +1037,7 @@ static int tsec_send(struct eth_device *dev, volatile void *packet, int length) (TXBD_READY | TXBD_LAST | TXBD_CRC | TXBD_INTERRUPT);
/* Tell the DMA to go */ - regs->tstat = TSTAT_CLEAR_THALT; + out_be32(®s->tstat, TSTAT_CLEAR_THALT);
/* Wait for buffer to be transmitted */ for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { @@ -1053,7 +1057,7 @@ static int tsec_recv(struct eth_device *dev) { int length; struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
while (!(rtx.rxbd[rxIdx].status & RXBD_EMPTY)) {
@@ -1076,9 +1080,9 @@ static int tsec_recv(struct eth_device *dev) rxIdx = (rxIdx + 1) % PKTBUFSRX; }
- if (regs->ievent & IEVENT_BSY) { - regs->ievent = IEVENT_BSY; - regs->rstat = RSTAT_CLEAR_RHALT; + if (in_be32(®s->ievent) & IEVENT_BSY) { + out_be32(®s->ievent, IEVENT_BSY); + out_be32(®s->rstat, RSTAT_CLEAR_RHALT); }
return -1; @@ -1089,15 +1093,15 @@ static int tsec_recv(struct eth_device *dev) static void tsec_halt(struct eth_device *dev) { struct tsec_private *priv = (struct tsec_private *)dev->priv; - volatile tsec_t *regs = priv->regs; + tsec_t *regs = priv->regs;
- regs->dmactrl &= ~(DMACTRL_GRS | DMACTRL_GTS); - regs->dmactrl |= (DMACTRL_GRS | DMACTRL_GTS); + clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); + setbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS);
- while ((regs->ievent & (IEVENT_GRSC | IEVENT_GTSC)) + while ((in_be32(®s->ievent) & (IEVENT_GRSC | IEVENT_GTSC)) != (IEVENT_GRSC | IEVENT_GTSC)) ;
- regs->maccfg1 &= ~(MACCFG1_TX_EN | MACCFG1_RX_EN); + clrbits_be32(®s->maccfg1, MACCFG1_TX_EN | MACCFG1_RX_EN);
/* Shut down the PHY, as needed */ if(priv->phyinfo) @@ -1881,13 +1885,13 @@ static void phy_run_commands(struct tsec_private *priv, struct phy_cmd *cmd) { int i; uint result; - volatile tsec_mdio_t *phyregs = priv->phyregs; + tsec_mdio_t *phyregs = priv->phyregs;
- phyregs->miimcfg = MIIMCFG_RESET; + out_be32(&phyregs->miimcfg, MIIMCFG_RESET);
- phyregs->miimcfg = MIIMCFG_INIT_VALUE; + out_be32(&phyregs->miimcfg, MIIMCFG_INIT_VALUE);
- while (phyregs->miimind & MIIMIND_BUSY) ; + while (in_be32(&phyregs->miimind) & MIIMIND_BUSY) ;
for (i = 0; cmd->mii_reg != miim_end; i++) { if (cmd->mii_data == miim_read) { diff --git a/include/tsec.h b/include/tsec.h index d56ec2c..a066d97 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -7,7 +7,7 @@ * terms of the GNU Public License, Version 2, incorporated * herein by reference. * - * Copyright 2004, 2007, 2009 Freescale Semiconductor, Inc. + * Copyright 2004, 2007, 2009, 2011 Freescale Semiconductor, Inc. * (C) Copyright 2003, Motorola, Inc. * maintained by Xianghua Xiao (x.xiao@motorola.com) * author Andy Fleming @@ -587,9 +587,9 @@ typedef struct tsec #define TSEC_FIBER (1 << 3) /* PHY uses fiber, eg 1000 Base-X */
struct tsec_private { - volatile tsec_t *regs; - volatile tsec_mdio_t *phyregs; - volatile tsec_mdio_t *phyregs_sgmii; + tsec_t *regs; + tsec_mdio_t *phyregs; + tsec_mdio_t *phyregs_sgmii; struct phy_info *phyinfo; uint phyaddr; u32 flags;
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Acked-by: Andy Fleming afleming@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- drivers/net/tsec.c | 857 +++++++++++++++++++++++++--------------------------- 1 files changed, 416 insertions(+), 441 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 1665174..f563d34 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -44,31 +44,6 @@ static RTXBD rtx __attribute__ ((aligned(8))); #error "rtx must be 64-bit aligned" #endif
-static int tsec_send(struct eth_device *dev, - volatile void *packet, int length); -static int tsec_recv(struct eth_device *dev); -static int tsec_init(struct eth_device *dev, bd_t * bd); -static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info); -static void tsec_halt(struct eth_device *dev); -static void init_registers(tsec_t * regs); -static void startup_tsec(struct eth_device *dev); -static int init_phy(struct eth_device *dev); -void write_phy_reg(struct tsec_private *priv, uint regnum, uint value); -uint read_phy_reg(struct tsec_private *priv, uint regnum); -static struct phy_info *get_phy_info(struct eth_device *dev); -static void phy_run_commands(struct tsec_private *priv, struct phy_cmd *cmd); -static void adjust_link(struct eth_device *dev); -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ - && !defined(BITBANGMII) -static int tsec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); -static int tsec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); -#endif -#ifdef CONFIG_MCAST_TFTP -static int tsec_mcast_addr (struct eth_device *dev, u8 mcast_mac, u8 set); -#endif - /* Default initializations for TSEC controllers. */
static struct tsec_info_struct tsec_info[] = { @@ -95,140 +70,6 @@ static struct tsec_info_struct tsec_info[] = { #endif };
-/* - * Initialize all the TSEC devices - * - * Returns the number of TSEC devices that were initialized - */ -int tsec_eth_init(bd_t *bis, struct tsec_info_struct *tsecs, int num) -{ - int i; - int ret, count = 0; - - for (i = 0; i < num; i++) { - ret = tsec_initialize(bis, &tsecs[i]); - if (ret > 0) - count += ret; - } - - return count; -} - -int tsec_standard_init(bd_t *bis) -{ - return tsec_eth_init(bis, tsec_info, ARRAY_SIZE(tsec_info)); -} - -/* Initialize device structure. Returns success if PHY - * initialization succeeded (i.e. if it recognizes the PHY) - */ -static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info) -{ - struct eth_device *dev; - int i; - struct tsec_private *priv; - - dev = (struct eth_device *)malloc(sizeof *dev); - - if (NULL == dev) - return 0; - - memset(dev, 0, sizeof *dev); - - priv = (struct tsec_private *)malloc(sizeof(*priv)); - - if (NULL == priv) - return 0; - - privlist[num_tsecs++] = priv; - priv->regs = tsec_info->regs; - priv->phyregs = tsec_info->miiregs; - priv->phyregs_sgmii = tsec_info->miiregs_sgmii; - - priv->phyaddr = tsec_info->phyaddr; - priv->flags = tsec_info->flags; - - sprintf(dev->name, tsec_info->devname); - dev->iobase = 0; - dev->priv = priv; - dev->init = tsec_init; - dev->halt = tsec_halt; - dev->send = tsec_send; - dev->recv = tsec_recv; -#ifdef CONFIG_MCAST_TFTP - dev->mcast = tsec_mcast_addr; -#endif - - /* Tell u-boot to get the addr from the env */ - for (i = 0; i < 6; i++) - dev->enetaddr[i] = 0; - - eth_register(dev); - - /* Reset the MAC */ - setbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); - udelay(2); /* Soft Reset must be asserted for 3 TX clocks */ - clrbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ - && !defined(BITBANGMII) - miiphy_register(dev->name, tsec_miiphy_read, tsec_miiphy_write); -#endif - - /* Try to initialize PHY here, and return */ - return init_phy(dev); -} - -/* Initializes data structures and registers for the controller, - * and brings the interface up. Returns the link status, meaning - * that it returns success if the link is up, failure otherwise. - * This allows u-boot to find the first active controller. - */ -static int tsec_init(struct eth_device *dev, bd_t * bd) -{ - uint tempval; - char tmpbuf[MAC_ADDR_LEN]; - int i; - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - - /* Make sure the controller is stopped */ - tsec_halt(dev); - - /* Init MACCFG2. Defaults to GMII */ - out_be32(®s->maccfg2, MACCFG2_INIT_SETTINGS); - - /* Init ECNTRL */ - out_be32(®s->ecntrl, ECNTRL_INIT_SETTINGS); - - /* Copy the station address into the address registers. - * Backwards, because little endian MACS are dumb */ - for (i = 0; i < MAC_ADDR_LEN; i++) { - tmpbuf[MAC_ADDR_LEN - 1 - i] = dev->enetaddr[i]; - } - tempval = (tmpbuf[0] << 24) | (tmpbuf[1] << 16) | (tmpbuf[2] << 8) | - tmpbuf[3]; - - out_be32(®s->macstnaddr1, tempval); - - tempval = *((uint *) (tmpbuf + 4)); - - out_be32(®s->macstnaddr2, tempval); - - /* reset the indices to zero */ - rxIdx = 0; - txIdx = 0; - - /* Clear out (for the most part) the other registers */ - init_registers(regs); - - /* Ready the device for tx/rx */ - startup_tsec(dev); - - /* If there's no link, fail */ - return (priv->link ? 0 : -1); -} - /* Writes the given phy's reg with value, using the specified MDIO regs */ static void tsec_local_mdio_write(tsec_mdio_t *phyregs, uint addr, uint reg, uint value) @@ -243,7 +84,6 @@ static void tsec_local_mdio_write(tsec_mdio_t *phyregs, uint addr, while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--) ; }
- /* Provide the default behavior of writing the PHY of this ethernet device */ #define write_phy_reg(priv, regnum, value) \ tsec_local_mdio_write(priv->phyregs,priv->phyaddr,regnum,value) @@ -312,48 +152,6 @@ static void tsec_configure_serdes(struct tsec_private *priv) CONFIG_TSEC_TBICR_SETTINGS); }
-/* Discover which PHY is attached to the device, and configure it - * properly. If the PHY is not recognized, then return 0 - * (failure). Otherwise, return 1 - */ -static int init_phy(struct eth_device *dev) -{ - struct tsec_private *priv = (struct tsec_private *)dev->priv; - struct phy_info *curphy; - tsec_t *regs = priv->regs; - - /* Assign a Physical address to the TBI */ - out_be32(®s->tbipa, CONFIG_SYS_TBIPA_VALUE); - asm("sync"); - - /* Reset MII (due to new addresses) */ - out_be32(&priv->phyregs->miimcfg, MIIMCFG_RESET); - asm("sync"); - out_be32(&priv->phyregs->miimcfg, MIIMCFG_INIT_VALUE); - asm("sync"); - while (in_be32(&priv->phyregs->miimind) & MIIMIND_BUSY) ; - - /* Get the cmd structure corresponding to the attached - * PHY */ - curphy = get_phy_info(dev); - - if (curphy == NULL) { - priv->phyinfo = NULL; - printf("%s: No PHY found\n", dev->name); - - return 0; - } - - if (in_be32(®s->ecntrl) & ECNTRL_SGMII_MODE) - tsec_configure_serdes(priv); - - priv->phyinfo = curphy; - - phy_run_commands(priv, priv->phyinfo->config); - - return 1; -} - /* * Returns which value to write to the control register. * For 10/100, the value is slightly different @@ -869,245 +667,6 @@ static uint mii_m88e1111s_setmode(uint mii_reg, struct tsec_private *priv) return mii_data; }
-/* Initialized required registers to appropriate values, zeroing - * those we don't care about (unless zero is bad, in which case, - * choose a more appropriate value) - */ -static void init_registers(tsec_t * regs) -{ - /* Clear IEVENT */ - out_be32(®s->ievent, IEVENT_INIT_CLEAR); - - out_be32(®s->imask, IMASK_INIT_CLEAR); - - out_be32(®s->hash.iaddr0, 0); - out_be32(®s->hash.iaddr1, 0); - out_be32(®s->hash.iaddr2, 0); - out_be32(®s->hash.iaddr3, 0); - out_be32(®s->hash.iaddr4, 0); - out_be32(®s->hash.iaddr5, 0); - out_be32(®s->hash.iaddr6, 0); - out_be32(®s->hash.iaddr7, 0); - - out_be32(®s->hash.gaddr0, 0); - out_be32(®s->hash.gaddr1, 0); - out_be32(®s->hash.gaddr2, 0); - out_be32(®s->hash.gaddr3, 0); - out_be32(®s->hash.gaddr4, 0); - out_be32(®s->hash.gaddr5, 0); - out_be32(®s->hash.gaddr6, 0); - out_be32(®s->hash.gaddr7, 0); - - out_be32(®s->rctrl, 0x00000000); - - /* Init RMON mib registers */ - memset((void *)&(regs->rmon), 0, sizeof(rmon_mib_t)); - - out_be32(®s->rmon.cam1, 0xffffffff); - out_be32(®s->rmon.cam2, 0xffffffff); - - out_be32(®s->mrblr, MRBLR_INIT_SETTINGS); - - out_be32(®s->minflr, MINFLR_INIT_SETTINGS); - - out_be32(®s->attr, ATTR_INIT_SETTINGS); - out_be32(®s->attreli, ATTRELI_INIT_SETTINGS); - -} - -/* Configure maccfg2 based on negotiated speed and duplex - * reported by PHY handling code - */ -static void adjust_link(struct eth_device *dev) -{ - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - u32 ecntrl, maccfg2; - - if (!priv->link) { - printf("%s: No link.\n", dev->name); - return; - } - - /* clear all bits relative with interface mode */ - ecntrl = in_be32(®s->ecntrl); - ecntrl &= ~ECNTRL_R100; - - maccfg2 = in_be32(®s->maccfg2); - maccfg2 &= ~(MACCFG2_IF | MACCFG2_FULL_DUPLEX); - - if (priv->duplexity) - maccfg2 |= MACCFG2_FULL_DUPLEX; - - switch (priv->speed) { - case 1000: - maccfg2 |= MACCFG2_GMII; - break; - case 100: - case 10: - maccfg2 |= MACCFG2_MII; - - /* Set R100 bit in all modes although - * it is only used in RGMII mode - */ - if (priv->speed == 100) - ecntrl |= ECNTRL_R100; - break; - default: - printf("%s: Speed was bad\n", dev->name); - break; - } - - out_be32(®s->ecntrl, ecntrl); - out_be32(®s->maccfg2, maccfg2); - - printf("Speed: %d, %s duplex%s\n", priv->speed, - (priv->duplexity) ? "full" : "half", - (priv->flags & TSEC_FIBER) ? ", fiber mode" : ""); -} - -/* Set up the buffers and their descriptors, and bring up the - * interface - */ -static void startup_tsec(struct eth_device *dev) -{ - int i; - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - - /* Point to the buffer descriptors */ - out_be32(®s->tbase, (unsigned int)(&rtx.txbd[txIdx])); - out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[rxIdx])); - - /* Initialize the Rx Buffer descriptors */ - for (i = 0; i < PKTBUFSRX; i++) { - rtx.rxbd[i].status = RXBD_EMPTY; - rtx.rxbd[i].length = 0; - rtx.rxbd[i].bufPtr = (uint) NetRxPackets[i]; - } - rtx.rxbd[PKTBUFSRX - 1].status |= RXBD_WRAP; - - /* Initialize the TX Buffer Descriptors */ - for (i = 0; i < TX_BUF_CNT; i++) { - rtx.txbd[i].status = 0; - rtx.txbd[i].length = 0; - rtx.txbd[i].bufPtr = 0; - } - rtx.txbd[TX_BUF_CNT - 1].status |= TXBD_WRAP; - - /* Start up the PHY */ - if(priv->phyinfo) - phy_run_commands(priv, priv->phyinfo->startup); - - adjust_link(dev); - - /* Enable Transmit and Receive */ - setbits_be32(®s->maccfg1, MACCFG1_RX_EN | MACCFG1_TX_EN); - - /* Tell the DMA it is clear to go */ - setbits_be32(®s->dmactrl, DMACTRL_INIT_SETTINGS); - out_be32(®s->tstat, TSTAT_CLEAR_THALT); - out_be32(®s->rstat, RSTAT_CLEAR_RHALT); - clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); -} - -/* This returns the status bits of the device. The return value - * is never checked, and this is what the 8260 driver did, so we - * do the same. Presumably, this would be zero if there were no - * errors - */ -static int tsec_send(struct eth_device *dev, volatile void *packet, int length) -{ - int i; - int result = 0; - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - - /* Find an empty buffer descriptor */ - for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { - if (i >= TOUT_LOOP) { - debug("%s: tsec: tx buffers full\n", dev->name); - return result; - } - } - - rtx.txbd[txIdx].bufPtr = (uint) packet; - rtx.txbd[txIdx].length = length; - rtx.txbd[txIdx].status |= - (TXBD_READY | TXBD_LAST | TXBD_CRC | TXBD_INTERRUPT); - - /* Tell the DMA to go */ - out_be32(®s->tstat, TSTAT_CLEAR_THALT); - - /* Wait for buffer to be transmitted */ - for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { - if (i >= TOUT_LOOP) { - debug("%s: tsec: tx error\n", dev->name); - return result; - } - } - - txIdx = (txIdx + 1) % TX_BUF_CNT; - result = rtx.txbd[txIdx].status & TXBD_STATS; - - return result; -} - -static int tsec_recv(struct eth_device *dev) -{ - int length; - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - - while (!(rtx.rxbd[rxIdx].status & RXBD_EMPTY)) { - - length = rtx.rxbd[rxIdx].length; - - /* Send the packet up if there were no errors */ - if (!(rtx.rxbd[rxIdx].status & RXBD_STATS)) { - NetReceive(NetRxPackets[rxIdx], length - 4); - } else { - printf("Got error %x\n", - (rtx.rxbd[rxIdx].status & RXBD_STATS)); - } - - rtx.rxbd[rxIdx].length = 0; - - /* Set the wrap bit if this is the last element in the list */ - rtx.rxbd[rxIdx].status = - RXBD_EMPTY | (((rxIdx + 1) == PKTBUFSRX) ? RXBD_WRAP : 0); - - rxIdx = (rxIdx + 1) % PKTBUFSRX; - } - - if (in_be32(®s->ievent) & IEVENT_BSY) { - out_be32(®s->ievent, IEVENT_BSY); - out_be32(®s->rstat, RSTAT_CLEAR_RHALT); - } - - return -1; - -} - -/* Stop the interface */ -static void tsec_halt(struct eth_device *dev) -{ - struct tsec_private *priv = (struct tsec_private *)dev->priv; - tsec_t *regs = priv->regs; - - clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); - setbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); - - while ((in_be32(®s->ievent) & (IEVENT_GRSC | IEVENT_GTSC)) - != (IEVENT_GRSC | IEVENT_GTSC)) ; - - clrbits_be32(®s->maccfg1, MACCFG1_TX_EN | MACCFG1_RX_EN); - - /* Shut down the PHY, as needed */ - if(priv->phyinfo) - phy_run_commands(priv, priv->phyinfo->shutdown); -} - static struct phy_info phy_info_M88E1149S = { 0x1410ca, "Marvell 88E1149S", @@ -2003,3 +1562,419 @@ tsec_mcast_addr (struct eth_device *dev, u8 mcast_mac, u8 set) return 0; } #endif /* Multicast TFTP ? */ + +/* Initialized required registers to appropriate values, zeroing + * those we don't care about (unless zero is bad, in which case, + * choose a more appropriate value) + */ +static void init_registers(tsec_t * regs) +{ + /* Clear IEVENT */ + out_be32(®s->ievent, IEVENT_INIT_CLEAR); + + out_be32(®s->imask, IMASK_INIT_CLEAR); + + out_be32(®s->hash.iaddr0, 0); + out_be32(®s->hash.iaddr1, 0); + out_be32(®s->hash.iaddr2, 0); + out_be32(®s->hash.iaddr3, 0); + out_be32(®s->hash.iaddr4, 0); + out_be32(®s->hash.iaddr5, 0); + out_be32(®s->hash.iaddr6, 0); + out_be32(®s->hash.iaddr7, 0); + + out_be32(®s->hash.gaddr0, 0); + out_be32(®s->hash.gaddr1, 0); + out_be32(®s->hash.gaddr2, 0); + out_be32(®s->hash.gaddr3, 0); + out_be32(®s->hash.gaddr4, 0); + out_be32(®s->hash.gaddr5, 0); + out_be32(®s->hash.gaddr6, 0); + out_be32(®s->hash.gaddr7, 0); + + out_be32(®s->rctrl, 0x00000000); + + /* Init RMON mib registers */ + memset((void *)&(regs->rmon), 0, sizeof(rmon_mib_t)); + + out_be32(®s->rmon.cam1, 0xffffffff); + out_be32(®s->rmon.cam2, 0xffffffff); + + out_be32(®s->mrblr, MRBLR_INIT_SETTINGS); + + out_be32(®s->minflr, MINFLR_INIT_SETTINGS); + + out_be32(®s->attr, ATTR_INIT_SETTINGS); + out_be32(®s->attreli, ATTRELI_INIT_SETTINGS); + +} + +/* Configure maccfg2 based on negotiated speed and duplex + * reported by PHY handling code + */ +static void adjust_link(struct eth_device *dev) +{ + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + u32 ecntrl, maccfg2; + + if (!priv->link) { + printf("%s: No link.\n", dev->name); + return; + } + + /* clear all bits relative with interface mode */ + ecntrl = in_be32(®s->ecntrl); + ecntrl &= ~ECNTRL_R100; + + maccfg2 = in_be32(®s->maccfg2); + maccfg2 &= ~(MACCFG2_IF | MACCFG2_FULL_DUPLEX); + + if (priv->duplexity) + maccfg2 |= MACCFG2_FULL_DUPLEX; + + switch (priv->speed) { + case 1000: + maccfg2 |= MACCFG2_GMII; + break; + case 100: + case 10: + maccfg2 |= MACCFG2_MII; + + /* Set R100 bit in all modes although + * it is only used in RGMII mode + */ + if (priv->speed == 100) + ecntrl |= ECNTRL_R100; + break; + default: + printf("%s: Speed was bad\n", dev->name); + break; + } + + out_be32(®s->ecntrl, ecntrl); + out_be32(®s->maccfg2, maccfg2); + + printf("Speed: %d, %s duplex%s\n", priv->speed, + (priv->duplexity) ? "full" : "half", + (priv->flags & TSEC_FIBER) ? ", fiber mode" : ""); +} + +/* Set up the buffers and their descriptors, and bring up the + * interface + */ +static void startup_tsec(struct eth_device *dev) +{ + int i; + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + + /* Point to the buffer descriptors */ + out_be32(®s->tbase, (unsigned int)(&rtx.txbd[txIdx])); + out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[rxIdx])); + + /* Initialize the Rx Buffer descriptors */ + for (i = 0; i < PKTBUFSRX; i++) { + rtx.rxbd[i].status = RXBD_EMPTY; + rtx.rxbd[i].length = 0; + rtx.rxbd[i].bufPtr = (uint) NetRxPackets[i]; + } + rtx.rxbd[PKTBUFSRX - 1].status |= RXBD_WRAP; + + /* Initialize the TX Buffer Descriptors */ + for (i = 0; i < TX_BUF_CNT; i++) { + rtx.txbd[i].status = 0; + rtx.txbd[i].length = 0; + rtx.txbd[i].bufPtr = 0; + } + rtx.txbd[TX_BUF_CNT - 1].status |= TXBD_WRAP; + + /* Start up the PHY */ + if(priv->phyinfo) + phy_run_commands(priv, priv->phyinfo->startup); + + adjust_link(dev); + + /* Enable Transmit and Receive */ + setbits_be32(®s->maccfg1, MACCFG1_RX_EN | MACCFG1_TX_EN); + + /* Tell the DMA it is clear to go */ + setbits_be32(®s->dmactrl, DMACTRL_INIT_SETTINGS); + out_be32(®s->tstat, TSTAT_CLEAR_THALT); + out_be32(®s->rstat, RSTAT_CLEAR_RHALT); + clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); +} + +/* This returns the status bits of the device. The return value + * is never checked, and this is what the 8260 driver did, so we + * do the same. Presumably, this would be zero if there were no + * errors + */ +static int tsec_send(struct eth_device *dev, volatile void *packet, int length) +{ + int i; + int result = 0; + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + + /* Find an empty buffer descriptor */ + for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { + if (i >= TOUT_LOOP) { + debug("%s: tsec: tx buffers full\n", dev->name); + return result; + } + } + + rtx.txbd[txIdx].bufPtr = (uint) packet; + rtx.txbd[txIdx].length = length; + rtx.txbd[txIdx].status |= + (TXBD_READY | TXBD_LAST | TXBD_CRC | TXBD_INTERRUPT); + + /* Tell the DMA to go */ + out_be32(®s->tstat, TSTAT_CLEAR_THALT); + + /* Wait for buffer to be transmitted */ + for (i = 0; rtx.txbd[txIdx].status & TXBD_READY; i++) { + if (i >= TOUT_LOOP) { + debug("%s: tsec: tx error\n", dev->name); + return result; + } + } + + txIdx = (txIdx + 1) % TX_BUF_CNT; + result = rtx.txbd[txIdx].status & TXBD_STATS; + + return result; +} + +static int tsec_recv(struct eth_device *dev) +{ + int length; + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + + while (!(rtx.rxbd[rxIdx].status & RXBD_EMPTY)) { + + length = rtx.rxbd[rxIdx].length; + + /* Send the packet up if there were no errors */ + if (!(rtx.rxbd[rxIdx].status & RXBD_STATS)) { + NetReceive(NetRxPackets[rxIdx], length - 4); + } else { + printf("Got error %x\n", + (rtx.rxbd[rxIdx].status & RXBD_STATS)); + } + + rtx.rxbd[rxIdx].length = 0; + + /* Set the wrap bit if this is the last element in the list */ + rtx.rxbd[rxIdx].status = + RXBD_EMPTY | (((rxIdx + 1) == PKTBUFSRX) ? RXBD_WRAP : 0); + + rxIdx = (rxIdx + 1) % PKTBUFSRX; + } + + if (in_be32(®s->ievent) & IEVENT_BSY) { + out_be32(®s->ievent, IEVENT_BSY); + out_be32(®s->rstat, RSTAT_CLEAR_RHALT); + } + + return -1; + +} + +/* Stop the interface */ +static void tsec_halt(struct eth_device *dev) +{ + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + + clrbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); + setbits_be32(®s->dmactrl, DMACTRL_GRS | DMACTRL_GTS); + + while ((in_be32(®s->ievent) & (IEVENT_GRSC | IEVENT_GTSC)) + != (IEVENT_GRSC | IEVENT_GTSC)) ; + + clrbits_be32(®s->maccfg1, MACCFG1_TX_EN | MACCFG1_RX_EN); + + /* Shut down the PHY, as needed */ + if(priv->phyinfo) + phy_run_commands(priv, priv->phyinfo->shutdown); +} + +/* Initializes data structures and registers for the controller, + * and brings the interface up. Returns the link status, meaning + * that it returns success if the link is up, failure otherwise. + * This allows u-boot to find the first active controller. + */ +static int tsec_init(struct eth_device *dev, bd_t * bd) +{ + uint tempval; + char tmpbuf[MAC_ADDR_LEN]; + int i; + struct tsec_private *priv = (struct tsec_private *)dev->priv; + tsec_t *regs = priv->regs; + + /* Make sure the controller is stopped */ + tsec_halt(dev); + + /* Init MACCFG2. Defaults to GMII */ + out_be32(®s->maccfg2, MACCFG2_INIT_SETTINGS); + + /* Init ECNTRL */ + out_be32(®s->ecntrl, ECNTRL_INIT_SETTINGS); + + /* Copy the station address into the address registers. + * Backwards, because little endian MACS are dumb */ + for (i = 0; i < MAC_ADDR_LEN; i++) { + tmpbuf[MAC_ADDR_LEN - 1 - i] = dev->enetaddr[i]; + } + tempval = (tmpbuf[0] << 24) | (tmpbuf[1] << 16) | (tmpbuf[2] << 8) | + tmpbuf[3]; + + out_be32(®s->macstnaddr1, tempval); + + tempval = *((uint *) (tmpbuf + 4)); + + out_be32(®s->macstnaddr2, tempval); + + /* reset the indices to zero */ + rxIdx = 0; + txIdx = 0; + + /* Clear out (for the most part) the other registers */ + init_registers(regs); + + /* Ready the device for tx/rx */ + startup_tsec(dev); + + /* If there's no link, fail */ + return (priv->link ? 0 : -1); +} + +/* Discover which PHY is attached to the device, and configure it + * properly. If the PHY is not recognized, then return 0 + * (failure). Otherwise, return 1 + */ +static int init_phy(struct eth_device *dev) +{ + struct tsec_private *priv = (struct tsec_private *)dev->priv; + struct phy_info *curphy; + tsec_t *regs = priv->regs; + + /* Assign a Physical address to the TBI */ + out_be32(®s->tbipa, CONFIG_SYS_TBIPA_VALUE); + asm("sync"); + + /* Reset MII (due to new addresses) */ + out_be32(&priv->phyregs->miimcfg, MIIMCFG_RESET); + asm("sync"); + out_be32(&priv->phyregs->miimcfg, MIIMCFG_INIT_VALUE); + asm("sync"); + while (in_be32(&priv->phyregs->miimind) & MIIMIND_BUSY) ; + + /* Get the cmd structure corresponding to the attached + * PHY */ + curphy = get_phy_info(dev); + + if (curphy == NULL) { + priv->phyinfo = NULL; + printf("%s: No PHY found\n", dev->name); + + return 0; + } + + if (in_be32(®s->ecntrl) & ECNTRL_SGMII_MODE) + tsec_configure_serdes(priv); + + priv->phyinfo = curphy; + + phy_run_commands(priv, priv->phyinfo->config); + + return 1; +} + +/* Initialize device structure. Returns success if PHY + * initialization succeeded (i.e. if it recognizes the PHY) + */ +static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info) +{ + struct eth_device *dev; + int i; + struct tsec_private *priv; + + dev = (struct eth_device *)malloc(sizeof *dev); + + if (NULL == dev) + return 0; + + memset(dev, 0, sizeof *dev); + + priv = (struct tsec_private *)malloc(sizeof(*priv)); + + if (NULL == priv) + return 0; + + privlist[num_tsecs++] = priv; + priv->regs = tsec_info->regs; + priv->phyregs = tsec_info->miiregs; + priv->phyregs_sgmii = tsec_info->miiregs_sgmii; + + priv->phyaddr = tsec_info->phyaddr; + priv->flags = tsec_info->flags; + + sprintf(dev->name, tsec_info->devname); + dev->iobase = 0; + dev->priv = priv; + dev->init = tsec_init; + dev->halt = tsec_halt; + dev->send = tsec_send; + dev->recv = tsec_recv; +#ifdef CONFIG_MCAST_TFTP + dev->mcast = tsec_mcast_addr; +#endif + + /* Tell u-boot to get the addr from the env */ + for (i = 0; i < 6; i++) + dev->enetaddr[i] = 0; + + eth_register(dev); + + /* Reset the MAC */ + setbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); + udelay(2); /* Soft Reset must be asserted for 3 TX clocks */ + clrbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET); + +#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ + && !defined(BITBANGMII) + miiphy_register(dev->name, tsec_miiphy_read, tsec_miiphy_write); +#endif + + /* Try to initialize PHY here, and return */ + return init_phy(dev); +} + +/* + * Initialize all the TSEC devices + * + * Returns the number of TSEC devices that were initialized + */ +int tsec_eth_init(bd_t *bis, struct tsec_info_struct *tsecs, int num) +{ + int i; + int ret, count = 0; + + for (i = 0; i < num; i++) { + ret = tsec_initialize(bis, &tsecs[i]); + if (ret > 0) + count += ret; + } + + return count; +} + +int tsec_standard_init(bd_t *bis) +{ + return tsec_eth_init(bis, tsec_info, ARRAY_SIZE(tsec_info)); +} +
There were a few files which were already using phy_read and phy_write for their PHY function names. It's only a few places, and the name seems most appropriate for the high-level abstraction, so let's rename the other versions to something more specific.
Also, uec_phy.c had a marvell_init function which I renamed to not conflict with the one in marvell.c
Signed-off-by: Andy Fleming afleming@freescale.com --- drivers/net/dm9000x.c | 18 +++--- drivers/net/enc28j60.c | 24 ++++---- drivers/net/uli526x.c | 24 ++++---- drivers/qe/uec.c | 3 - drivers/qe/uec_phy.c | 145 ++++++++++++++++++++++++------------------------ 5 files changed, 107 insertions(+), 107 deletions(-)
diff --git a/drivers/net/dm9000x.c b/drivers/net/dm9000x.c index 709f67a..b5c5573 100644 --- a/drivers/net/dm9000x.c +++ b/drivers/net/dm9000x.c @@ -110,8 +110,8 @@ static board_info_t dm9000_info;
/* function declaration ------------------------------------- */ static int dm9000_probe(void); -static u16 phy_read(int); -static void phy_write(int, u16); +static u16 dm9000_phy_read(int); +static void dm9000_phy_write(int, u16); static u8 DM9000_ior(int); static void DM9000_iow(int reg, u8 value);
@@ -361,7 +361,7 @@ static int dm9000_init(struct eth_device *dev, bd_t *bd) DM9000_iow(DM9000_IMR, IMR_PAR);
i = 0; - while (!(phy_read(1) & 0x20)) { /* autonegation complete bit */ + while (!(dm9000_phy_read(1) & 0x20)) { /* autonegation complete bit */ udelay(1000); i++; if (i == 10000) { @@ -371,7 +371,7 @@ static int dm9000_init(struct eth_device *dev, bd_t *bd) }
/* see what we've got */ - lnk = phy_read(17) >> 12; + lnk = dm9000_phy_read(17) >> 12; printf("operating at "); switch (lnk) { case 1: @@ -445,7 +445,7 @@ static void dm9000_halt(struct eth_device *netdev) DM9000_DBG("%s\n", __func__);
/* RESET devie */ - phy_write(0, 0x8000); /* PHY RESET */ + dm9000_phy_write(0, 0x8000); /* PHY RESET */ DM9000_iow(DM9000_GPR, 0x01); /* Power-Down PHY */ DM9000_iow(DM9000_IMR, 0x80); /* Disable all interrupt */ DM9000_iow(DM9000_RCR, 0x00); /* Disable RX */ @@ -581,7 +581,7 @@ DM9000_iow(int reg, u8 value) Read a word from phyxcer */ static u16 -phy_read(int reg) +dm9000_phy_read(int reg) { u16 val;
@@ -593,7 +593,7 @@ phy_read(int reg) val = (DM9000_ior(DM9000_EPDRH) << 8) | DM9000_ior(DM9000_EPDRL);
/* The read data keeps on REG_0D & REG_0E */ - DM9000_DBG("phy_read(0x%x): 0x%x\n", reg, val); + DM9000_DBG("dm9000_phy_read(0x%x): 0x%x\n", reg, val); return val; }
@@ -601,7 +601,7 @@ phy_read(int reg) Write a word to phyxcer */ static void -phy_write(int reg, u16 value) +dm9000_phy_write(int reg, u16 value) {
/* Fill the phyxcer register into REG_0C */ @@ -613,7 +613,7 @@ phy_write(int reg, u16 value) DM9000_iow(DM9000_EPCR, 0xa); /* Issue phyxcer write command */ udelay(500); /* Wait write complete */ DM9000_iow(DM9000_EPCR, 0x0); /* Clear phyxcer write command */ - DM9000_DBG("phy_write(reg:0x%x, value:0x%x)\n", reg, value); + DM9000_DBG("dm9000_phy_write(reg:0x%x, value:0x%x)\n", reg, value); }
int dm9000_initialize(bd_t *bis) diff --git a/drivers/net/enc28j60.c b/drivers/net/enc28j60.c index 6c161b6..d55cacd 100644 --- a/drivers/net/enc28j60.c +++ b/drivers/net/enc28j60.c @@ -314,7 +314,7 @@ static void enc_release_bus(enc_dev_t *enc) /* * Read PHY register */ -static u16 phy_read(enc_dev_t *enc, const u8 addr) +static u16 enc_phy_read(enc_dev_t *enc, const u8 addr) { uint64_t etime; u8 status; @@ -339,7 +339,7 @@ static u16 phy_read(enc_dev_t *enc, const u8 addr) /* * Write PHY register */ -static void phy_write(enc_dev_t *enc, const u8 addr, const u16 data) +static void enc_phy_write(enc_dev_t *enc, const u8 addr, const u16 data) { uint64_t etime; u8 status; @@ -374,7 +374,7 @@ static int enc_phy_link_wait(enc_dev_t *enc)
#ifdef CONFIG_ENC_SILENTLINK /* check if we have a link, then just return */ - status = phy_read(enc, PHY_REG_PHSTAT1); + status = enc_phy_read(enc, PHY_REG_PHSTAT1); if (status & ENC_PHSTAT1_LLSTAT) return 0; #endif @@ -382,10 +382,10 @@ static int enc_phy_link_wait(enc_dev_t *enc) /* wait for link with 1 second timeout */ etime = get_ticks() + get_tbclk(); while (get_ticks() <= etime) { - status = phy_read(enc, PHY_REG_PHSTAT1); + status = enc_phy_read(enc, PHY_REG_PHSTAT1); if (status & ENC_PHSTAT1_LLSTAT) { /* now we have a link */ - status = phy_read(enc, PHY_REG_PHSTAT2); + status = enc_phy_read(enc, PHY_REG_PHSTAT2); duplex = (status & ENC_PHSTAT2_DPXSTAT) ? 1 : 0; printf("%s: link up, 10Mbps %s-duplex\n", enc->dev->name, duplex ? "full" : "half"); @@ -678,8 +678,8 @@ static int enc_setup(enc_dev_t *enc) enc->bank = 0xff; /* invalidate current bank in enc28j60 */
/* verify PHY identification */ - phid1 = phy_read(enc, PHY_REG_PHID1); - phid2 = phy_read(enc, PHY_REG_PHID2) & ENC_PHID2_MASK; + phid1 = enc_phy_read(enc, PHY_REG_PHID1); + phid2 = enc_phy_read(enc, PHY_REG_PHID2) & ENC_PHID2_MASK; if (phid1 != ENC_PHID1_VALUE || phid2 != ENC_PHID2_VALUE) { printf("%s: failed to identify PHY. Found %04x:%04x\n", enc->dev->name, phid1, phid2); @@ -694,7 +694,7 @@ static int enc_setup(enc_dev_t *enc) * Prevent automatic loopback of data beeing transmitted by setting * ENC_PHCON2_HDLDIS */ - phy_write(enc, PHY_REG_PHCON2, (1<<8)); + enc_phy_write(enc, PHY_REG_PHCON2, (1<<8));
/* * LEDs configuration @@ -702,10 +702,10 @@ static int enc_setup(enc_dev_t *enc) * LEDB: LBCFG = 0111 -> display TX & RX activity * STRCH = 1 -> LED pulses */ - phy_write(enc, PHY_REG_PHLCON, 0x0472); + enc_phy_write(enc, PHY_REG_PHLCON, 0x0472);
/* Reset PDPXMD-bit => half duplex */ - phy_write(enc, PHY_REG_PHCON1, 0); + enc_phy_write(enc, PHY_REG_PHCON1, 0);
#ifdef CONFIG_USE_IRQ /* enable interrupts */ @@ -771,7 +771,7 @@ int enc_miiphy_read(const char *devname, u8 phy_adr, u8 reg, u16 *value) enc_release_bus(enc); return -1; } - *value = phy_read(enc, reg); + *value = enc_phy_read(enc, reg); enc_release_bus(enc); return 0; } @@ -796,7 +796,7 @@ int enc_miiphy_write(const char *devname, u8 phy_adr, u8 reg, u16 value) enc_release_bus(enc); return -1; } - phy_write(enc, reg, value); + enc_phy_write(enc, reg, value); enc_release_bus(enc); return 0; } diff --git a/drivers/net/uli526x.c b/drivers/net/uli526x.c index a4624e1..5933bdd 100644 --- a/drivers/net/uli526x.c +++ b/drivers/net/uli526x.c @@ -175,9 +175,9 @@ static u16 read_srom_word(long, int); static void uli526x_descriptor_init(struct uli526x_board_info *, unsigned long); static void allocate_rx_buffer(struct uli526x_board_info *); static void update_cr6(u32, unsigned long); -static u16 phy_read(unsigned long, u8, u8, u32); +static u16 uli_phy_read(unsigned long, u8, u8, u32); static u16 phy_readby_cr10(unsigned long, u8, u8); -static void phy_write(unsigned long, u8, u8, u16, u32); +static void uli_phy_write(unsigned long, u8, u8, u16, u32); static void phy_writeby_cr10(unsigned long, u8, u8, u16); static void phy_write_1bit(unsigned long, u32, u32); static u16 phy_read_1bit(unsigned long, u32); @@ -349,7 +349,7 @@ static void uli526x_disable(struct eth_device *dev) /* Reset & stop ULI526X board */ outl(ULI526X_RESET, db->ioaddr + DCR0); udelay(5); - phy_write(db->ioaddr, db->phy_addr, 0, 0x8000, db->chip_id); + uli_phy_write(db->ioaddr, db->phy_addr, 0, 0x8000, db->chip_id);
/* reset the board */ db->cr6_data &= ~(CR6_RXSC | CR6_TXSC); /* Disable Tx/Rx */ @@ -385,7 +385,7 @@ static void uli526x_init(struct eth_device *dev) db->tx_packet_cnt = 0; for (phy_tmp = 0; phy_tmp < 32; phy_tmp++) { /* peer add */ - phy_value = phy_read(db->ioaddr, phy_tmp, 3, db->chip_id); + phy_value = uli_phy_read(db->ioaddr, phy_tmp, 3, db->chip_id); if (phy_value != 0xffff && phy_value != 0) { db->phy_addr = phy_tmp; break; @@ -404,10 +404,10 @@ static void uli526x_init(struct eth_device *dev)
if (!(inl(db->ioaddr + DCR12) & 0x8)) { /* Phyxcer capability setting */ - phy_reg_reset = phy_read(db->ioaddr, + phy_reg_reset = uli_phy_read(db->ioaddr, db->phy_addr, 0, db->chip_id); phy_reg_reset = (phy_reg_reset | 0x8000); - phy_write(db->ioaddr, db->phy_addr, 0, + uli_phy_write(db->ioaddr, db->phy_addr, 0, phy_reg_reset, db->chip_id); udelay(500);
@@ -781,7 +781,8 @@ static void uli526x_set_phyxcer(struct uli526x_board_info *db) u16 phy_reg;
/* Phyxcer capability setting */ - phy_reg = phy_read(db->ioaddr, db->phy_addr, 4, db->chip_id) & ~0x01e0; + phy_reg = uli_phy_read(db->ioaddr, + db->phy_addr, 4, db->chip_id) & ~0x01e0;
if (db->media_mode & ULI526X_AUTO) { /* AUTO Mode */ @@ -802,10 +803,10 @@ static void uli526x_set_phyxcer(struct uli526x_board_info *db) phy_reg |= db->PHY_reg4; db->media_mode |= ULI526X_AUTO; } - phy_write(db->ioaddr, db->phy_addr, 4, phy_reg, db->chip_id); + uli_phy_write(db->ioaddr, db->phy_addr, 4, phy_reg, db->chip_id);
/* Restart Auto-Negotiation */ - phy_write(db->ioaddr, db->phy_addr, 0, 0x1200, db->chip_id); + uli_phy_write(db->ioaddr, db->phy_addr, 0, 0x1200, db->chip_id); udelay(50); }
@@ -813,7 +814,7 @@ static void uli526x_set_phyxcer(struct uli526x_board_info *db) * Write a word to Phy register */
-static void phy_write(unsigned long iobase, u8 phy_addr, u8 offset, +static void uli_phy_write(unsigned long iobase, u8 phy_addr, u8 offset, u16 phy_data, u32 chip_id) { u16 i; @@ -862,7 +863,8 @@ static void phy_write(unsigned long iobase, u8 phy_addr, u8 offset, * Read a word data from phy register */
-static u16 phy_read(unsigned long iobase, u8 phy_addr, u8 offset, u32 chip_id) +static u16 uli_phy_read(unsigned long iobase, u8 phy_addr, u8 offset, + u32 chip_id) { int i; u16 phy_data; diff --git a/drivers/qe/uec.c b/drivers/qe/uec.c index 282ab23..81febd6 100644 --- a/drivers/qe/uec.c +++ b/drivers/qe/uec.c @@ -67,9 +67,6 @@ static uec_info_t uec_info[] = {
static struct eth_device *devlist[MAXCONTROLLERS];
-u16 phy_read (struct uec_mii_info *mii_info, u16 regnum); -void phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val); - static int uec_mac_enable(uec_private_t *uec, comm_dir_e mode) { uec_t *uec_regs; diff --git a/drivers/qe/uec_phy.c b/drivers/qe/uec_phy.c index 55c2622..247d522 100644 --- a/drivers/qe/uec_phy.c +++ b/drivers/qe/uec_phy.c @@ -121,8 +121,8 @@ static int gbit_config_aneg (struct uec_mii_info *mii_info); static int genmii_config_aneg (struct uec_mii_info *mii_info); static int genmii_update_link (struct uec_mii_info *mii_info); static int genmii_read_status (struct uec_mii_info *mii_info); -u16 phy_read (struct uec_mii_info *mii_info, u16 regnum); -void phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val); +u16 uec_phy_read (struct uec_mii_info *mii_info, u16 regnum); +void uec_phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val);
/* Write value to the PHY for this device to the register at regnum, */ /* waiting until the write is done before it returns. All PHY */ @@ -242,7 +242,7 @@ static void config_genmii_advert (struct uec_mii_info *mii_info) advertise = mii_info->advertising;
/* Setup standard advertisement */ - adv = phy_read (mii_info, MII_ADVERTISE); + adv = uec_phy_read (mii_info, MII_ADVERTISE); adv &= ~(ADVERTISE_ALL | ADVERTISE_100BASE4); if (advertise & ADVERTISED_10baseT_Half) adv |= ADVERTISE_10HALF; @@ -252,7 +252,7 @@ static void config_genmii_advert (struct uec_mii_info *mii_info) adv |= ADVERTISE_100HALF; if (advertise & ADVERTISED_100baseT_Full) adv |= ADVERTISE_100FULL; - phy_write (mii_info, MII_ADVERTISE, adv); + uec_phy_write (mii_info, MII_ADVERTISE, adv); }
static void genmii_setup_forced (struct uec_mii_info *mii_info) @@ -260,7 +260,7 @@ static void genmii_setup_forced (struct uec_mii_info *mii_info) u16 ctrl; u32 features = mii_info->phyinfo->features;
- ctrl = phy_read (mii_info, MII_BMCR); + ctrl = uec_phy_read (mii_info, MII_BMCR);
ctrl &= ~(BMCR_FULLDPLX | BMCR_SPEED100 | BMCR_SPEED1000 | BMCR_ANENABLE); @@ -290,7 +290,7 @@ static void genmii_setup_forced (struct uec_mii_info *mii_info) break; }
- phy_write (mii_info, MII_BMCR, ctrl); + uec_phy_write (mii_info, MII_BMCR, ctrl); }
/* Enable and Restart Autonegotiation */ @@ -298,9 +298,9 @@ static void genmii_restart_aneg (struct uec_mii_info *mii_info) { u16 ctl;
- ctl = phy_read (mii_info, MII_BMCR); + ctl = uec_phy_read (mii_info, MII_BMCR); ctl |= (BMCR_ANENABLE | BMCR_ANRESTART); - phy_write (mii_info, MII_BMCR, ctl); + uec_phy_write (mii_info, MII_BMCR, ctl); }
static int gbit_config_aneg (struct uec_mii_info *mii_info) @@ -313,14 +313,14 @@ static int gbit_config_aneg (struct uec_mii_info *mii_info) config_genmii_advert (mii_info); advertise = mii_info->advertising;
- adv = phy_read (mii_info, MII_CTRL1000); + adv = uec_phy_read (mii_info, MII_CTRL1000); adv &= ~(ADVERTISE_1000FULL | ADVERTISE_1000HALF); if (advertise & SUPPORTED_1000baseT_Half) adv |= ADVERTISE_1000HALF; if (advertise & SUPPORTED_1000baseT_Full) adv |= ADVERTISE_1000FULL; - phy_write (mii_info, MII_CTRL1000, adv); + uec_phy_write (mii_info, MII_CTRL1000, adv);
/* Start/Restart aneg */ genmii_restart_aneg (mii_info); @@ -335,13 +335,13 @@ static int marvell_config_aneg (struct uec_mii_info *mii_info) /* The Marvell PHY has an errata which requires * that certain registers get written in order * to restart autonegotiation */ - phy_write (mii_info, MII_BMCR, BMCR_RESET); + uec_phy_write (mii_info, MII_BMCR, BMCR_RESET);
- phy_write (mii_info, 0x1d, 0x1f); - phy_write (mii_info, 0x1e, 0x200c); - phy_write (mii_info, 0x1d, 0x5); - phy_write (mii_info, 0x1e, 0); - phy_write (mii_info, 0x1e, 0x100); + uec_phy_write (mii_info, 0x1d, 0x1f); + uec_phy_write (mii_info, 0x1e, 0x200c); + uec_phy_write (mii_info, 0x1d, 0x5); + uec_phy_write (mii_info, 0x1e, 0); + uec_phy_write (mii_info, 0x1e, 0x100);
gbit_config_aneg (mii_info);
@@ -373,13 +373,13 @@ static int genmii_update_link (struct uec_mii_info *mii_info) u16 status;
/* Status is read once to clear old link state */ - phy_read (mii_info, MII_BMSR); + uec_phy_read (mii_info, MII_BMSR);
/* * Wait if the link is up, and autonegotiation is in progress * (ie - we're capable and it's not done) */ - status = phy_read(mii_info, MII_BMSR); + status = uec_phy_read(mii_info, MII_BMSR); if ((status & BMSR_LSTATUS) && (status & BMSR_ANEGCAPABLE) && !(status & BMSR_ANEGCOMPLETE)) { int i = 0; @@ -395,7 +395,7 @@ static int genmii_update_link (struct uec_mii_info *mii_info)
i++; udelay(1000); /* 1 ms */ - status = phy_read(mii_info, MII_BMSR); + status = uec_phy_read(mii_info, MII_BMSR); } mii_info->link = 1; } else { @@ -420,7 +420,7 @@ static int genmii_read_status (struct uec_mii_info *mii_info) return err;
if (mii_info->autoneg) { - status = phy_read(mii_info, MII_STAT1000); + status = uec_phy_read(mii_info, MII_STAT1000);
if (status & (LPA_1000FULL | LPA_1000HALF)) { mii_info->speed = SPEED_1000; @@ -429,7 +429,7 @@ static int genmii_read_status (struct uec_mii_info *mii_info) else mii_info->duplex = DUPLEX_HALF; } else { - status = phy_read(mii_info, MII_LPA); + status = uec_phy_read(mii_info, MII_LPA);
if (status & (LPA_10FULL | LPA_100FULL)) mii_info->duplex = DUPLEX_FULL; @@ -463,25 +463,25 @@ static int bcm_init(struct uec_mii_info *mii_info)
/* Wait for aneg to complete. */ do - val = phy_read(mii_info, MII_BMSR); + val = uec_phy_read(mii_info, MII_BMSR); while (--cnt && !(val & BMSR_ANEGCOMPLETE));
/* Set RDX clk delay. */ - phy_write(mii_info, 0x18, 0x7 | (7 << 12)); + uec_phy_write(mii_info, 0x18, 0x7 | (7 << 12));
- val = phy_read(mii_info, 0x18); + val = uec_phy_read(mii_info, 0x18); /* Set RDX-RXC skew. */ val |= (1 << 8); val |= (7 | (7 << 12)); /* Write bits 14:0. */ val |= (1 << 15); - phy_write(mii_info, 0x18, val); + uec_phy_write(mii_info, 0x18, val); }
return 0; }
-static int marvell_init(struct uec_mii_info *mii_info) +static int uec_marvell_init(struct uec_mii_info *mii_info) { struct eth_device *edev = mii_info->dev; uec_private_t *uec = edev->priv; @@ -494,7 +494,7 @@ static int marvell_init(struct uec_mii_info *mii_info) iface == RGMII_TXID)) { int temp;
- temp = phy_read(mii_info, MII_M1111_PHY_EXT_CR); + temp = uec_phy_read(mii_info, MII_M1111_PHY_EXT_CR); if (iface == RGMII_ID) { temp |= MII_M1111_RX_DELAY | MII_M1111_TX_DELAY; } else if (iface == RGMII_RXID) { @@ -504,14 +504,14 @@ static int marvell_init(struct uec_mii_info *mii_info) temp &= ~MII_M1111_RX_DELAY; temp |= MII_M1111_TX_DELAY; } - phy_write(mii_info, MII_M1111_PHY_EXT_CR, temp); + uec_phy_write(mii_info, MII_M1111_PHY_EXT_CR, temp);
- temp = phy_read(mii_info, MII_M1111_PHY_EXT_SR); + temp = uec_phy_read(mii_info, MII_M1111_PHY_EXT_SR); temp &= ~MII_M1111_HWCFG_MODE_MASK; temp |= MII_M1111_HWCFG_MODE_RGMII; - phy_write(mii_info, MII_M1111_PHY_EXT_SR, temp); + uec_phy_write(mii_info, MII_M1111_PHY_EXT_SR, temp);
- phy_write(mii_info, MII_BMCR, BMCR_RESET); + uec_phy_write(mii_info, MII_BMCR, BMCR_RESET); }
return 0; @@ -534,7 +534,7 @@ static int marvell_read_status (struct uec_mii_info *mii_info) if (mii_info->autoneg && mii_info->link) { int speed;
- status = phy_read (mii_info, MII_M1011_PHY_SPEC_STATUS); + status = uec_phy_read (mii_info, MII_M1011_PHY_SPEC_STATUS);
/* Get the duplexity */ if (status & MII_M1011_PHY_SPEC_STATUS_FULLDUPLEX) @@ -564,7 +564,7 @@ static int marvell_read_status (struct uec_mii_info *mii_info) static int marvell_ack_interrupt (struct uec_mii_info *mii_info) { /* Clear the interrupts by reading the reg */ - phy_read (mii_info, MII_M1011_IEVENT); + uec_phy_read (mii_info, MII_M1011_IEVENT);
return 0; } @@ -572,9 +572,10 @@ static int marvell_ack_interrupt (struct uec_mii_info *mii_info) static int marvell_config_intr (struct uec_mii_info *mii_info) { if (mii_info->interrupts == MII_INTERRUPT_ENABLED) - phy_write (mii_info, MII_M1011_IMASK, MII_M1011_IMASK_INIT); + uec_phy_write (mii_info, MII_M1011_IMASK, MII_M1011_IMASK_INIT); else - phy_write (mii_info, MII_M1011_IMASK, MII_M1011_IMASK_CLEAR); + uec_phy_write (mii_info, MII_M1011_IMASK, + MII_M1011_IMASK_CLEAR);
return 0; } @@ -582,13 +583,13 @@ static int marvell_config_intr (struct uec_mii_info *mii_info) static int dm9161_init (struct uec_mii_info *mii_info) { /* Reset the PHY */ - phy_write (mii_info, MII_BMCR, phy_read (mii_info, MII_BMCR) | + uec_phy_write (mii_info, MII_BMCR, uec_phy_read (mii_info, MII_BMCR) | BMCR_RESET); /* PHY and MAC connect */ - phy_write (mii_info, MII_BMCR, phy_read (mii_info, MII_BMCR) & + uec_phy_write (mii_info, MII_BMCR, uec_phy_read (mii_info, MII_BMCR) & ~BMCR_ISOLATE);
- phy_write (mii_info, MII_DM9161_SCR, MII_DM9161_SCR_INIT); + uec_phy_write (mii_info, MII_DM9161_SCR, MII_DM9161_SCR_INIT);
config_genmii_advert (mii_info); /* Start/restart aneg */ @@ -614,7 +615,7 @@ static int dm9161_read_status (struct uec_mii_info *mii_info) /* If the link is up, read the speed and duplex If we aren't autonegotiating assume speeds are as set */ if (mii_info->autoneg && mii_info->link) { - status = phy_read (mii_info, MII_DM9161_SCSR); + status = uec_phy_read (mii_info, MII_DM9161_SCSR); if (status & (MII_DM9161_SCSR_100F | MII_DM9161_SCSR_100H)) mii_info->speed = SPEED_100; else @@ -632,7 +633,7 @@ static int dm9161_read_status (struct uec_mii_info *mii_info) static int dm9161_ack_interrupt (struct uec_mii_info *mii_info) { /* Clear the interrupt by reading the reg */ - phy_read (mii_info, MII_DM9161_INTR); + uec_phy_read (mii_info, MII_DM9161_INTR);
return 0; } @@ -640,9 +641,9 @@ static int dm9161_ack_interrupt (struct uec_mii_info *mii_info) static int dm9161_config_intr (struct uec_mii_info *mii_info) { if (mii_info->interrupts == MII_INTERRUPT_ENABLED) - phy_write (mii_info, MII_DM9161_INTR, MII_DM9161_INTR_INIT); + uec_phy_write (mii_info, MII_DM9161_INTR, MII_DM9161_INTR_INIT); else - phy_write (mii_info, MII_DM9161_INTR, MII_DM9161_INTR_STOP); + uec_phy_write (mii_info, MII_DM9161_INTR, MII_DM9161_INTR_STOP);
return 0; } @@ -696,7 +697,7 @@ static int smsc_read_status (struct uec_mii_info *mii_info) if (mii_info->autoneg && mii_info->link) { int val;
- status = phy_read (mii_info, 0x1f); + status = uec_phy_read (mii_info, 0x1f); val = (status & 0x1c) >> 2;
switch (val) { @@ -751,7 +752,7 @@ static struct phy_info phy_info_marvell = { .phy_id_mask = 0xffffff00, .name = "Marvell 88E11x1", .features = MII_GBIT_FEATURES, - .init = &marvell_init, + .init = &uec_marvell_init, .config_aneg = &marvell_config_aneg, .read_status = &marvell_read_status, .ack_interrupt = &marvell_ack_interrupt, @@ -804,12 +805,12 @@ static struct phy_info *phy_info[] = { NULL };
-u16 phy_read (struct uec_mii_info *mii_info, u16 regnum) +u16 uec_phy_read (struct uec_mii_info *mii_info, u16 regnum) { return mii_info->mdio_read (mii_info->dev, mii_info->mii_id, regnum); }
-void phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val) +void uec_phy_write (struct uec_mii_info *mii_info, u16 regnum, u16 val) { mii_info->mdio_write (mii_info->dev, mii_info->mii_id, regnum, val); } @@ -825,11 +826,11 @@ struct phy_info *uec_get_phy_info (struct uec_mii_info *mii_info) struct phy_info *theInfo = NULL;
/* Grab the bits from PHYIR1, and put them in the upper half */ - phy_reg = phy_read (mii_info, MII_PHYSID1); + phy_reg = uec_phy_read (mii_info, MII_PHYSID1); phy_ID = (phy_reg & 0xffff) << 16;
/* Grab the bits from PHYIR2, and put them in the lower half */ - phy_reg = phy_read (mii_info, MII_PHYSID2); + phy_reg = uec_phy_read (mii_info, MII_PHYSID2); phy_ID |= (phy_reg & 0xffff);
/* loop through all the known PHY types, and find one that */ @@ -869,39 +870,39 @@ void marvell_phy_interface_mode (struct eth_device *dev,
if (type == RGMII) { if (speed == 100) { - phy_write (mii_info, 0x00, 0x9140); - phy_write (mii_info, 0x1d, 0x001f); - phy_write (mii_info, 0x1e, 0x200c); - phy_write (mii_info, 0x1d, 0x0005); - phy_write (mii_info, 0x1e, 0x0000); - phy_write (mii_info, 0x1e, 0x0100); - phy_write (mii_info, 0x09, 0x0e00); - phy_write (mii_info, 0x04, 0x01e1); - phy_write (mii_info, 0x00, 0x9140); - phy_write (mii_info, 0x00, 0x1000); + uec_phy_write (mii_info, 0x00, 0x9140); + uec_phy_write (mii_info, 0x1d, 0x001f); + uec_phy_write (mii_info, 0x1e, 0x200c); + uec_phy_write (mii_info, 0x1d, 0x0005); + uec_phy_write (mii_info, 0x1e, 0x0000); + uec_phy_write (mii_info, 0x1e, 0x0100); + uec_phy_write (mii_info, 0x09, 0x0e00); + uec_phy_write (mii_info, 0x04, 0x01e1); + uec_phy_write (mii_info, 0x00, 0x9140); + uec_phy_write (mii_info, 0x00, 0x1000); udelay (100000); - phy_write (mii_info, 0x00, 0x2900); - phy_write (mii_info, 0x14, 0x0cd2); - phy_write (mii_info, 0x00, 0xa100); - phy_write (mii_info, 0x09, 0x0000); - phy_write (mii_info, 0x1b, 0x800b); - phy_write (mii_info, 0x04, 0x05e1); - phy_write (mii_info, 0x00, 0xa100); - phy_write (mii_info, 0x00, 0x2100); + uec_phy_write (mii_info, 0x00, 0x2900); + uec_phy_write (mii_info, 0x14, 0x0cd2); + uec_phy_write (mii_info, 0x00, 0xa100); + uec_phy_write (mii_info, 0x09, 0x0000); + uec_phy_write (mii_info, 0x1b, 0x800b); + uec_phy_write (mii_info, 0x04, 0x05e1); + uec_phy_write (mii_info, 0x00, 0xa100); + uec_phy_write (mii_info, 0x00, 0x2100); udelay (1000000); } else if (speed == 10) { - phy_write (mii_info, 0x14, 0x8e40); - phy_write (mii_info, 0x1b, 0x800b); - phy_write (mii_info, 0x14, 0x0c82); - phy_write (mii_info, 0x00, 0x8100); + uec_phy_write (mii_info, 0x14, 0x8e40); + uec_phy_write (mii_info, 0x1b, 0x800b); + uec_phy_write (mii_info, 0x14, 0x0c82); + uec_phy_write (mii_info, 0x00, 0x8100); udelay (1000000); } }
/* handle 88e1111 rev.B2 erratum 5.6 */ if (mii_info->autoneg) { - status = phy_read (mii_info, MII_BMCR); - phy_write (mii_info, MII_BMCR, status | BMCR_ANENABLE); + status = uec_phy_read (mii_info, MII_BMCR); + uec_phy_write (mii_info, MII_BMCR, status | BMCR_ANENABLE); } /* now the B2 will correctly report autoneg completion status */ }
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support
The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45).
The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure.
We now have MDIO drivers and PHY drivers
An MDIO driver provides: read write reset
A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed
The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown()
Each PHY driver can be configured separately, or all at once using phylib_all_drivers.h (added in the patch which adds the drivers)
Signed-off-by: Andy Fleming afleming@freescale.com --- common/Makefile | 1 + common/miiphyutil.c | 173 ++++++++++-- drivers/net/phy/Makefile | 1 + drivers/net/phy/phy.c | 705 ++++++++++++++++++++++++++++++++++++++++++++++ include/miiphy.h | 31 ++ include/phy.h | 487 ++++++++++++++++++++++++++++++++ net/eth.c | 6 + 7 files changed, 1375 insertions(+), 29 deletions(-) create mode 100644 drivers/net/phy/phy.c create mode 100644 include/phy.h
diff --git a/common/Makefile b/common/Makefile index 048df0c..00847ef 100644 --- a/common/Makefile +++ b/common/Makefile @@ -114,6 +114,7 @@ COBJS-$(CONFIG_CMD_MFSL) += cmd_mfsl.o COBJS-$(CONFIG_CMD_MG_DISK) += cmd_mgdisk.o COBJS-$(CONFIG_MII) += miiphyutil.o COBJS-$(CONFIG_CMD_MII) += miiphyutil.o +COBJS-$(CONFIG_PHYLIB) += miiphyutil.o COBJS-$(CONFIG_CMD_MII) += cmd_mii.o COBJS-$(CONFIG_CMD_MISC) += cmd_misc.o COBJS-$(CONFIG_CMD_MMC) += cmd_mmc.o diff --git a/common/miiphyutil.c b/common/miiphyutil.c index e282096..e79c639 100644 --- a/common/miiphyutil.c +++ b/common/miiphyutil.c @@ -28,6 +28,7 @@
#include <common.h> #include <miiphy.h> +#include <phy.h>
#include <asm/types.h> #include <linux/list.h> @@ -44,22 +45,13 @@ #define debug(fmt,args...) #endif /* MII_DEBUG */
-struct mii_dev { - struct list_head link; - const char *name; - int (*read) (const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value); - int (*write) (const char *devname, unsigned char addr, - unsigned char reg, unsigned short value); -}; - static struct list_head mii_devs; static struct mii_dev *current_mii;
/* * Lookup the mii_dev struct by the registered device name. */ -static struct mii_dev *miiphy_get_dev_by_name(const char *devname, int quiet) +struct mii_dev *miiphy_get_dev_by_name(const char *devname) { struct list_head *entry; struct mii_dev *dev; @@ -75,8 +67,6 @@ static struct mii_dev *miiphy_get_dev_by_name(const char *devname, int quiet) return dev; }
- if (!quiet) - printf("No such device: %s\n", devname); return NULL; }
@@ -90,6 +80,25 @@ void miiphy_init(void) current_mii = NULL; }
+static int legacy_miiphy_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + unsigned short val; + int ret; + struct legacy_mii_dev *ldev = bus->priv; + + ret = ldev->read(bus->name, addr, reg, &val); + + return ret ? -1 : (int)val; +} + +static int legacy_miiphy_write(struct mii_dev *bus, int addr, int devad, + int reg, u16 val) +{ + struct legacy_mii_dev *ldev = bus->priv; + + return ldev->write(bus->name, addr, reg, val); +} + /***************************************************************************** * * Register read and write MII access routines for the device <name>. @@ -101,11 +110,12 @@ void miiphy_register(const char *name, unsigned char reg, unsigned short value)) { struct mii_dev *new_dev; + struct legacy_mii_dev *ldev; unsigned int name_len; char *new_name;
/* check if we have unique name */ - new_dev = miiphy_get_dev_by_name(name, 1); + new_dev = miiphy_get_dev_by_name(name); if (new_dev) { printf("miiphy_register: non unique device name '%s'\n", name); return; @@ -113,10 +123,10 @@ void miiphy_register(const char *name,
/* allocate memory */ name_len = strlen (name); - new_dev = - (struct mii_dev *)malloc (sizeof (struct mii_dev) + name_len + 1); + new_dev = malloc (sizeof (struct mii_dev) + name_len + 1); + ldev = malloc (sizeof (*ldev));
- if (new_dev == NULL) { + if (new_dev == NULL || ldev == NULL) { printf ("miiphy_register: cannot allocate memory for '%s'\n", name); return; @@ -125,14 +135,17 @@ void miiphy_register(const char *name,
/* initalize mii_dev struct fields */ INIT_LIST_HEAD (&new_dev->link); - new_dev->read = read; - new_dev->write = write; + new_dev->read = legacy_miiphy_read; + new_dev->write = legacy_miiphy_write; new_dev->name = new_name = (char *)(new_dev + 1); strncpy (new_name, name, name_len); new_name[name_len] = '\0'; + ldev->read = read; + ldev->write = write; + new_dev->priv = ldev;
debug ("miiphy_register: added '%s', read=0x%08lx, write=0x%08lx\n", - new_dev->name, new_dev->read, new_dev->write); + new_dev->name, ldev->read, ldev->write);
/* add it to the list */ list_add_tail (&new_dev->link, &mii_devs); @@ -141,19 +154,119 @@ void miiphy_register(const char *name, current_mii = new_dev; }
+struct mii_dev *mdio_alloc(void) +{ + struct mii_dev *bus; + + bus = malloc(sizeof(*bus)); + if (!bus) + return bus; + + memset(bus, 0, sizeof (*bus)); + + bus->name = malloc(MDIO_NAME_LEN); + if (!bus->name) { + printf("Could not allocate name for mii_dev\n"); + free(bus); + return NULL; + } + + memset(bus->name, 0, MDIO_NAME_LEN); + + /* initalize mii_dev struct fields */ + INIT_LIST_HEAD (&bus->link); + + return bus; +} + +int mdio_register(struct mii_dev *bus) +{ + if (!bus || !bus->name || !bus->read || !bus->write) + return -1; + + /* check if we have unique name */ + if (miiphy_get_dev_by_name(bus->name)) { + printf("mdio_register: non unique device name '%s'\n", + bus->name); + return -1; + } + + /* add it to the list */ + list_add_tail (&bus->link, &mii_devs); + + if (!current_mii) + current_mii = bus; + + return 0; +} + +void mdio_list_devices(void) +{ + struct list_head *entry; + + list_for_each(entry, &mii_devs) { + int i; + struct mii_dev *bus = list_entry(entry, struct mii_dev, link); + + printf("%s:\n", bus->name); + + for (i = 0; i < PHY_MAX_ADDR; i++) { + struct phy_device *phydev = bus->phymap[i]; + + if (phydev) { + printf("%d - %s", i, phydev->drv->name); + + if (phydev->dev) + printf(" <--> %s\n", phydev->dev->name); + else + printf("\n"); + } + } + } +} + int miiphy_set_current_dev(const char *devname) { struct mii_dev *dev;
- dev = miiphy_get_dev_by_name(devname, 0); + dev = miiphy_get_dev_by_name(devname); if (dev) { current_mii = dev; return 0; }
+ printf("No such device: %s\n", devname); + return 1; }
+struct mii_dev *mdio_get_current_dev(void) +{ + return current_mii; +} + +struct phy_device *mdio_phydev_for_ethname(const char *ethname) +{ + struct list_head *entry; + struct mii_dev *bus; + + list_for_each(entry, &mii_devs) { + int i; + bus = list_entry(entry, struct mii_dev, link); + + for (i = 0; i < PHY_MAX_ADDR; i++) { + if ((!bus->phymap[i]) || (!bus->phymap[i]->dev)) + continue; + + if (strcmp(bus->phymap[i]->dev->name, ethname) == 0) + return bus->phymap[i]; + } + } + + printf("%s is not a known ethernet\n", ethname); + return NULL; +} + const char *miiphy_get_current_dev(void) { if (current_mii) @@ -187,13 +300,15 @@ static struct mii_dev *miiphy_get_active_dev(const char *devname) int miiphy_read(const char *devname, unsigned char addr, unsigned char reg, unsigned short *value) { - struct mii_dev *dev; + struct mii_dev *bus;
- dev = miiphy_get_active_dev(devname); - if (dev) - return dev->read(devname, addr, reg, value); + bus = miiphy_get_active_dev(devname); + if (bus) + *value = bus->read(bus, addr, MDIO_DEVAD_NONE, reg); + else + return 1;
- return 1; + return (*value < 0) ? 1 : 0; }
/***************************************************************************** @@ -207,11 +322,11 @@ int miiphy_read(const char *devname, unsigned char addr, unsigned char reg, int miiphy_write(const char *devname, unsigned char addr, unsigned char reg, unsigned short value) { - struct mii_dev *dev; + struct mii_dev *bus;
- dev = miiphy_get_active_dev(devname); - if (dev) - return dev->write(devname, addr, reg, value); + bus = miiphy_get_active_dev(devname); + if (bus) + return bus->write(bus, addr, MDIO_DEVAD_NONE, reg, value);
return 1; } diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index bba8901..7cb1094 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libphy.o
COBJS-$(CONFIG_BITBANGMII) += miiphybb.o COBJS-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o +COBJS-$(CONFIG_PHYLIB) += phy.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c new file mode 100644 index 0000000..ca35404 --- /dev/null +++ b/drivers/net/phy/phy.c @@ -0,0 +1,705 @@ +/* + * Generic PHY Management code + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + * Based loosely off of Linux's PHY Lib + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> +#include <net.h> +#include <command.h> +#include <miiphy.h> +#include <phy.h> +#include <errno.h> + +int phy_read(struct phy_device *phydev, int devad, int regnum) +{ + struct mii_dev *bus = phydev->bus; + + return bus->read(bus, phydev->addr, devad, regnum); +} + +int phy_write(struct phy_device *phydev, int devad, int regnum, u16 val) +{ + struct mii_dev *bus = phydev->bus; + + return bus->write(bus, phydev->addr, devad, regnum, val); +} + + +int gen10g_shutdown(struct phy_device *phydev) +{ + return 0; +} + +int gen10g_startup(struct phy_device *phydev) +{ + int devad, reg; + u32 mmd_mask = phydev->mmds; + + phydev->link = 1; + + /* For now just lie and say it's 10G all the time */ + phydev->speed = SPEED_10000; + phydev->duplex = DUPLEX_FULL; + + for (devad = 0; mmd_mask; devad++, mmd_mask = mmd_mask >> 1) { + if (!mmd_mask & 1) + continue; + + /* Read twice because link state is latched and a + * read moves the current state into the register */ + phy_read(phydev, devad, MDIO_STAT1); + reg = phy_read(phydev, devad, MDIO_STAT1); + if (reg < 0 || !(reg & MDIO_STAT1_LSTATUS)) + phydev->link = 0; + } + + return 0; +} + +int gen10g_config(struct phy_device *phydev) +{ + int mmd, stat2, devs1, devs2; + + phydev->supported = phydev->advertising = SUPPORTED_10000baseT_Full; + + /* Assume PHY must have at least one of PMA/PMD, WIS, PCS, PHY + * XS or DTE XS; give up if none is present. */ + for (mmd = 1; mmd <= 5; mmd++) { + /* Is this MMD present? */ + stat2 = phy_read(phydev, mmd, MDIO_STAT2); + if (stat2 < 0 || + (stat2 & MDIO_STAT2_DEVPRST) != MDIO_STAT2_DEVPRST_VAL) + continue; + + /* It should tell us about all the other MMDs */ + devs1 = phy_read(phydev, mmd, MDIO_DEVS1); + devs2 = phy_read(phydev, mmd, MDIO_DEVS2); + if (devs1 < 0 || devs2 < 0) + continue; + + phydev->mmds = devs1 | (devs2 << 16); + return 0; + } + + return -1; +} + + +static struct phy_driver gen10g_driver = { + .uid = 0xffffffff, + .mask = 0xffffffff, + .name = "Generic 10G PHY", + .features = 0, + .config = gen10g_config, + .startup = gen10g_startup, + .shutdown = gen10g_shutdown, +}; + +/* Generic PHY support and helper functions */ + +/** + * genphy_config_advert - sanitize and advertise auto-negotation parameters + * @phydev: target phy_device struct + * + * Description: Writes MII_ADVERTISE with the appropriate values, + * after sanitizing the values to make sure we only advertise + * what is supported. Returns < 0 on error, 0 if the PHY's advertisement + * hasn't changed, and > 0 if it has changed. + */ +int genphy_config_advert(struct phy_device *phydev) +{ + u32 advertise; + int oldadv, adv; + int err, changed = 0; + + /* Only allow advertising what + * this PHY supports */ + phydev->advertising &= phydev->supported; + advertise = phydev->advertising; + + /* Setup standard advertisement */ + oldadv = adv = phy_read(phydev, MDIO_DEVAD_NONE, MII_ADVERTISE); + + if (adv < 0) + return adv; + + adv &= ~(ADVERTISE_ALL | ADVERTISE_100BASE4 | ADVERTISE_PAUSE_CAP | + ADVERTISE_PAUSE_ASYM); + if (advertise & ADVERTISED_10baseT_Half) + adv |= ADVERTISE_10HALF; + if (advertise & ADVERTISED_10baseT_Full) + adv |= ADVERTISE_10FULL; + if (advertise & ADVERTISED_100baseT_Half) + adv |= ADVERTISE_100HALF; + if (advertise & ADVERTISED_100baseT_Full) + adv |= ADVERTISE_100FULL; + if (advertise & ADVERTISED_Pause) + adv |= ADVERTISE_PAUSE_CAP; + if (advertise & ADVERTISED_Asym_Pause) + adv |= ADVERTISE_PAUSE_ASYM; + + if (adv != oldadv) { + err = phy_write(phydev, MDIO_DEVAD_NONE, MII_ADVERTISE, adv); + + if (err < 0) + return err; + changed = 1; + } + + /* Configure gigabit if it's supported */ + if (phydev->supported & (SUPPORTED_1000baseT_Half | + SUPPORTED_1000baseT_Full)) { + oldadv = adv = phy_read(phydev, MDIO_DEVAD_NONE, MII_CTRL1000); + + if (adv < 0) + return adv; + + adv &= ~(ADVERTISE_1000FULL | ADVERTISE_1000HALF); + if (advertise & SUPPORTED_1000baseT_Half) + adv |= ADVERTISE_1000HALF; + if (advertise & SUPPORTED_1000baseT_Full) + adv |= ADVERTISE_1000FULL; + + if (adv != oldadv) { + err = phy_write(phydev, MDIO_DEVAD_NONE, MII_CTRL1000, adv); + + if (err < 0) + return err; + changed = 1; + } + } + + return changed; +} + + +/** + * genphy_setup_forced - configures/forces speed/duplex from @phydev + * @phydev: target phy_device struct + * + * Description: Configures MII_BMCR to force speed/duplex + * to the values in phydev. Assumes that the values are valid. + */ +int genphy_setup_forced(struct phy_device *phydev) +{ + int err; + int ctl = 0; + + phydev->pause = phydev->asym_pause = 0; + + if (SPEED_1000 == phydev->speed) + ctl |= BMCR_SPEED1000; + else if (SPEED_100 == phydev->speed) + ctl |= BMCR_SPEED100; + + if (DUPLEX_FULL == phydev->duplex) + ctl |= BMCR_FULLDPLX; + + err = phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, ctl); + + return err; +} + + +/** + * genphy_restart_aneg - Enable and Restart Autonegotiation + * @phydev: target phy_device struct + */ +int genphy_restart_aneg(struct phy_device *phydev) +{ + int ctl; + + ctl = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); + + if (ctl < 0) + return ctl; + + ctl |= (BMCR_ANENABLE | BMCR_ANRESTART); + + /* Don't isolate the PHY if we're negotiating */ + ctl &= ~(BMCR_ISOLATE); + + ctl = phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, ctl); + + return ctl; +} + + +/** + * genphy_config_aneg - restart auto-negotiation or write BMCR + * @phydev: target phy_device struct + * + * Description: If auto-negotiation is enabled, we configure the + * advertising, and then restart auto-negotiation. If it is not + * enabled, then we write the BMCR. + */ +int genphy_config_aneg(struct phy_device *phydev) +{ + int result; + + if (AUTONEG_ENABLE != phydev->autoneg) + return genphy_setup_forced(phydev); + + result = genphy_config_advert(phydev); + + if (result < 0) /* error */ + return result; + + if (result == 0) { + /* Advertisment hasn't changed, but maybe aneg was never on to + * begin with? Or maybe phy was isolated? */ + int ctl = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); + + if (ctl < 0) + return ctl; + + if (!(ctl & BMCR_ANENABLE) || (ctl & BMCR_ISOLATE)) + result = 1; /* do restart aneg */ + } + + /* Only restart aneg if we are advertising something different + * than we were before. */ + if (result > 0) + result = genphy_restart_aneg(phydev); + + return result; +} + +/** + * genphy_update_link - update link status in @phydev + * @phydev: target phy_device struct + * + * Description: Update the value in phydev->link to reflect the + * current link value. In order to do this, we need to read + * the status register twice, keeping the second value. + */ +int genphy_update_link(struct phy_device *phydev) +{ + unsigned int mii_reg; + + /* + * Wait if the link is up, and autonegotiation is in progress + * (ie - we're capable and it's not done) + */ + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR); + + /* + * If we already saw the link up, and it hasn't gone down, then + * we don't need to wait for autoneg again + */ + if (phydev->link && mii_reg & BMSR_LSTATUS) + return 0; + + if ((mii_reg & BMSR_ANEGCAPABLE) && !(mii_reg & BMSR_ANEGCOMPLETE)) { + int i = 0; + + printf("%s Waiting for PHY auto negotiation to complete", + phydev->dev->name); + while (!(mii_reg & BMSR_ANEGCOMPLETE)) { + /* + * Timeout reached ? + */ + if (i > 5000) { + printf(" TIMEOUT !\n"); + phydev->link = 0; + return 0; + } + + if (ctrlc()) { + puts("user interrupt!\n"); + phydev->link = 0; + return -EINTR; + } + + if ((i++ % 500) == 0) + printf("."); + + udelay(1000); /* 1 ms */ + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR); + } + printf(" done\n"); + phydev->link = 1; + udelay(500000); /* another 500 ms (results in faster booting) */ + } else { + /* Read the link a second time to clear the latched state */ + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR); + + if (mii_reg & BMSR_LSTATUS) + phydev->link = 1; + else + phydev->link = 0; + } + + return 0; +} + +/* + * Generic function which updates the speed and duplex. If + * autonegotiation is enabled, it uses the AND of the link + * partner's advertised capabilities and our advertised + * capabilities. If autonegotiation is disabled, we use the + * appropriate bits in the control register. + * + * Stolen from Linux's mii.c and phy_device.c + */ +static int genphy_parse_link(struct phy_device *phydev) +{ + int mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR); + + /* We're using autonegotiation */ + if (mii_reg & BMSR_ANEGCAPABLE) { + u32 lpa = 0; + u32 gblpa = 0; + + /* Check for gigabit capability */ + if (mii_reg & BMSR_ERCAP) { + /* We want a list of states supported by + * both PHYs in the link + */ + gblpa = phy_read(phydev, MDIO_DEVAD_NONE, MII_STAT1000); + gblpa &= phy_read(phydev, MDIO_DEVAD_NONE, MII_CTRL1000) << 2; + } + + /* Set the baseline so we only have to set them + * if they're different + */ + phydev->speed = SPEED_10; + phydev->duplex = DUPLEX_HALF; + + /* Check the gigabit fields */ + if (gblpa & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) { + phydev->speed = SPEED_1000; + + if (gblpa & PHY_1000BTSR_1000FD) + phydev->duplex = DUPLEX_FULL; + + /* We're done! */ + return 0; + } + + lpa = phy_read(phydev, MDIO_DEVAD_NONE, MII_ADVERTISE); + lpa &= phy_read(phydev, MDIO_DEVAD_NONE, MII_LPA); + + if (lpa & (LPA_100FULL | LPA_100HALF)) { + phydev->speed = SPEED_100; + + if (lpa & LPA_100FULL) + phydev->duplex = DUPLEX_FULL; + + } else if (lpa & LPA_10FULL) + phydev->duplex = DUPLEX_FULL; + } else { + u32 bmcr = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); + + phydev->speed = SPEED_10; + phydev->duplex = DUPLEX_HALF; + + if (bmcr & BMCR_FULLDPLX) + phydev->duplex = DUPLEX_FULL; + + if (bmcr & BMCR_SPEED1000) + phydev->speed = SPEED_1000; + else if (bmcr & BMCR_SPEED100) + phydev->speed = SPEED_100; + } + + return 0; +} + +int genphy_config(struct phy_device *phydev) +{ + int val; + u32 features; + + /* For now, I'll claim that the generic driver supports + * all possible port types */ + features = (SUPPORTED_TP | SUPPORTED_MII + | SUPPORTED_AUI | SUPPORTED_FIBRE | + SUPPORTED_BNC); + + /* Do we support autonegotiation? */ + val = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR); + + if (val < 0) + return val; + + if (val & BMSR_ANEGCAPABLE) + features |= SUPPORTED_Autoneg; + + if (val & BMSR_100FULL) + features |= SUPPORTED_100baseT_Full; + if (val & BMSR_100HALF) + features |= SUPPORTED_100baseT_Half; + if (val & BMSR_10FULL) + features |= SUPPORTED_10baseT_Full; + if (val & BMSR_10HALF) + features |= SUPPORTED_10baseT_Half; + + if (val & BMSR_ESTATEN) { + val = phy_read(phydev, MDIO_DEVAD_NONE, MII_ESTATUS); + + if (val < 0) + return val; + + if (val & ESTATUS_1000_TFULL) + features |= SUPPORTED_1000baseT_Full; + if (val & ESTATUS_1000_THALF) + features |= SUPPORTED_1000baseT_Half; + } + + phydev->supported = features; + phydev->advertising = features; + + genphy_config_aneg(phydev); + + return 0; +} + +int genphy_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + genphy_parse_link(phydev); + + return 0; +} + +int genphy_shutdown(struct phy_device *phydev) +{ + return 0; +} + +static struct phy_driver genphy_driver = { + .uid = 0xffffffff, + .mask = 0xffffffff, + .name = "Generic PHY", + .features = 0, + .config = genphy_config, + .startup = genphy_startup, + .shutdown = genphy_shutdown, +}; + +static struct list_head phy_drivers; + +int phy_init(void) +{ + INIT_LIST_HEAD(&phy_drivers); + + return 0; +} + +int phy_register(struct phy_driver *drv) +{ + INIT_LIST_HEAD(&drv->list); + list_add_tail (&drv->list, &phy_drivers); + + return 0; +} + +int phy_probe(struct phy_device *phydev) +{ + int err = 0; + + phydev->advertising = phydev->supported = phydev->drv->features; + + if (phydev->drv->probe) + err = phydev->drv->probe(phydev); + + return err; +} + +struct phy_driver *get_phy_driver(struct phy_device *phydev, + phy_interface_t interface) +{ + struct list_head *entry; + int phy_id = phydev->phy_id; + struct phy_driver *drv = NULL; + + list_for_each(entry, &phy_drivers) { + drv = list_entry(entry, struct phy_driver, list); + if ((drv->uid & drv->mask) == (phy_id & drv->mask)) + return drv; + } + + /* If we made it here, there's no driver for this PHY */ + if (interface == PHY_INTERFACE_MODE_XGMII) + return &gen10g_driver; + else + return &genphy_driver; +} + +struct phy_device* phy_device_create(struct mii_dev *bus, int addr, int phy_id, + phy_interface_t interface) +{ + struct phy_device *dev; + + /* We allocate the device, and initialize the + * default values */ + dev = malloc(sizeof(*dev)); + if (!dev) { + printf("Failed to allocate PHY device for %s:%d\n", + bus->name, addr); + return NULL; + } + + memset(dev, 0, sizeof(*dev)); + + dev->duplex = -1; + dev->link = 1; + dev->interface = interface; + + dev->autoneg = AUTONEG_ENABLE; + + dev->addr = addr; + dev->phy_id = phy_id; + dev->bus = bus; + + dev->drv = get_phy_driver(dev, interface); + + phy_probe(dev); + + return dev; +} + +/** + * get_phy_id - reads the specified addr for its ID. + * @bus: the target MII bus + * @addr: PHY address on the MII bus + * @phy_id: where to store the ID retrieved. + * + * Description: Reads the ID registers of the PHY at @addr on the + * @bus, stores it in @phy_id and returns zero on success. + */ +int get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id) +{ + int phy_reg; + + /* Grab the bits from PHYIR1, and put them + * in the upper half */ + phy_reg = bus->read(bus, addr, devad, MII_PHYSID1); + + if (phy_reg < 0) + return -EIO; + + *phy_id = (phy_reg & 0xffff) << 16; + + /* Grab the bits from PHYIR2, and put them in the lower half */ + phy_reg = bus->read(bus, addr, devad, MII_PHYSID2); + + if (phy_reg < 0) + return -EIO; + + *phy_id |= (phy_reg & 0xffff); + + return 0; +} + +/** + * get_phy_device - reads the specified PHY device and returns its @phy_device struct + * @bus: the target MII bus + * @addr: PHY address on the MII bus + * + * Description: Reads the ID registers of the PHY at @addr on the + * @bus, then allocates and returns the phy_device to represent it. + */ +struct phy_device * get_phy_device(struct mii_dev *bus, int addr, + phy_interface_t interface) +{ + u32 phy_id = 0x1fffffff; + int i; + int r; + + /* Try Standard (ie Clause 22) access */ + r = get_phy_id(bus, addr, MDIO_DEVAD_NONE, &phy_id); + if (r) + return NULL; + + /* If the PHY ID is mostly f's, we didn't find anything */ + if ((phy_id & 0x1fffffff) != 0x1fffffff) + return phy_device_create(bus, addr, phy_id, interface); + + /* Otherwise we have to try Clause 45 */ + for (i = 1; i < 5; i++) { + r = get_phy_id(bus, addr, i, &phy_id); + if (r) + return NULL; + + /* If the phy_id is mostly Fs, there is no device there */ + if ((phy_id & 0x1fffffff) != 0x1fffffff) + break; + } + + return phy_device_create(bus, addr, phy_id, interface); +} + +struct phy_device *phy_connect(struct mii_dev *bus, int addr, + struct eth_device *dev, + phy_interface_t interface) +{ + /* Reset the bus */ + bus->reset(bus); + + /* If the PHY is not in the map, probe the PHY to id it */ + if (!bus->phymap[addr]) { + bus->phymap[addr] = get_phy_device(bus, addr, interface); + + if (!bus->phymap[addr]) + printf("Could not get PHY for %s:%d\n", bus->name, addr); + } + + if (bus->phymap[addr]->dev) + printf("%s:%d is connected to %s. Reconnecting to %s\n", + bus->name, addr, bus->phymap[addr]->dev->name, + dev->name); + + bus->phymap[addr]->dev = dev; + + printf("%s connected to %s\n", dev->name, + bus->phymap[addr]->drv->name); + + return bus->phymap[addr]; +} + +int phy_startup(struct phy_device *phydev) +{ + if (phydev->drv->startup) + phydev->drv->startup(phydev); + + return 0; +} + +static int __board_phy_config(struct phy_device *phydev) +{ + return 0; +} + +int board_phy_config(struct phy_device *phydev) + __attribute__((weak, alias("__board_phy_config"))); + +int phy_config(struct phy_device *phydev) +{ + if (phydev->drv->config) + phydev->drv->config(phydev); + + /* Invoke an optional board-specific helper */ + board_phy_config(phydev); + + return 0; +} + +int phy_shutdown(struct phy_device *phydev) +{ + if (phydev->drv->shutdown) + phydev->drv->shutdown(phydev); + + return 0; +} diff --git a/include/miiphy.h b/include/miiphy.h index 42dc127..ea42775 100644 --- a/include/miiphy.h +++ b/include/miiphy.h @@ -34,8 +34,32 @@ #ifndef _miiphy_h_ #define _miiphy_h_
+#include <common.h> #include <linux/mii.h> +#include <linux/list.h> #include <net.h> +#include <phy.h> + +struct legacy_mii_dev { + int (*read) (const char *devname, unsigned char addr, + unsigned char reg, unsigned short *value); + int (*write) (const char *devname, unsigned char addr, + unsigned char reg, unsigned short value); +}; + +#define MDIO_NAME_LEN 32 + +struct mii_dev { + struct list_head link; + char *name; + void *priv; + int (*read) (struct mii_dev *bus, int addr, int devad, int reg); + int (*write) (struct mii_dev *bus, int addr, int devad, int reg, + u16 val); + int (*reset) (struct mii_dev *bus); + struct phy_device *phymap[PHY_MAX_ADDR]; + u32 phy_mask; +};
int miiphy_read (const char *devname, unsigned char addr, unsigned char reg, unsigned short *value); @@ -61,9 +85,16 @@ void miiphy_register (const char *devname,
int miiphy_set_current_dev (const char *devname); const char *miiphy_get_current_dev (void); +struct mii_dev *mdio_get_current_dev (void); +struct mii_dev *miiphy_get_dev_by_name(const char *devname); +struct phy_device *mdio_phydev_for_ethname(const char *devname);
void miiphy_listdev (void);
+struct mii_dev *mdio_alloc(void); +int mdio_register(struct mii_dev *bus); +void mdio_list_devices(void); + #ifdef CONFIG_BITBANGMII
#define BB_MII_DEVNAME "bb_miiphy" diff --git a/include/phy.h b/include/phy.h new file mode 100644 index 0000000..fccf1f7 --- /dev/null +++ b/include/phy.h @@ -0,0 +1,487 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * Andy Fleming afleming@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * This file pretty much stolen from Linux's mii.h/ethtool.h/phy.h + */ + +#ifndef _PHY_H +#define _PHY_H + +#include <linux/list.h> +#include <linux/mii.h> + +/* MDIO Manageable Devices (MMDs). */ +#define MDIO_MMD_PMAPMD 1 /* Physical Medium Attachment/ + * Physical Medium Dependent */ +#define MDIO_MMD_WIS 2 /* WAN Interface Sublayer */ +#define MDIO_MMD_PCS 3 /* Physical Coding Sublayer */ +#define MDIO_MMD_PHYXS 4 /* PHY Extender Sublayer */ +#define MDIO_MMD_DTEXS 5 /* DTE Extender Sublayer */ +#define MDIO_MMD_TC 6 /* Transmission Convergence */ +#define MDIO_MMD_AN 7 /* Auto-Negotiation */ +#define MDIO_MMD_C22EXT 29 /* Clause 22 extension */ +#define MDIO_MMD_VEND1 30 /* Vendor specific 1 */ +#define MDIO_MMD_VEND2 31 /* Vendor specific 2 */ + +/* Generic MDIO registers. */ +#define MDIO_CTRL1 MII_BMCR +#define MDIO_STAT1 MII_BMSR +#define MDIO_DEVID1 MII_PHYSID1 +#define MDIO_DEVID2 MII_PHYSID2 +#define MDIO_SPEED 4 /* Speed ability */ +#define MDIO_DEVS1 5 /* Devices in package */ +#define MDIO_DEVS2 6 +#define MDIO_CTRL2 7 /* 10G control 2 */ +#define MDIO_STAT2 8 /* 10G status 2 */ +#define MDIO_PMA_TXDIS 9 /* 10G PMA/PMD transmit disable */ +#define MDIO_PMA_RXDET 10 /* 10G PMA/PMD receive signal detect */ +#define MDIO_PMA_EXTABLE 11 /* 10G PMA/PMD extended ability */ +#define MDIO_PKGID1 14 /* Package identifier */ +#define MDIO_PKGID2 15 +#define MDIO_AN_ADVERTISE 16 /* AN advertising (base page) */ +#define MDIO_AN_LPA 19 /* AN LP abilities (base page) */ +#define MDIO_PHYXS_LNSTAT 24 /* PHY XGXS lane state */ + +/* Media-dependent registers. */ +#define MDIO_PMA_10GBT_SWAPPOL 130 /* 10GBASE-T pair swap & polarity */ +#define MDIO_PMA_10GBT_TXPWR 131 /* 10GBASE-T TX power control */ +#define MDIO_PMA_10GBT_SNR 133 /* 10GBASE-T SNR margin, lane A. + * Lanes B-D are numbered 134-136. */ +#define MDIO_PMA_10GBR_FECABLE 170 /* 10GBASE-R FEC ability */ +#define MDIO_PCS_10GBX_STAT1 24 /* 10GBASE-X PCS status 1 */ +#define MDIO_PCS_10GBRT_STAT1 32 /* 10GBASE-R/-T PCS status 1 */ +#define MDIO_PCS_10GBRT_STAT2 33 /* 10GBASE-R/-T PCS status 2 */ +#define MDIO_AN_10GBT_CTRL 32 /* 10GBASE-T auto-negotiation control */ +#define MDIO_AN_10GBT_STAT 33 /* 10GBASE-T auto-negotiation status */ + +/* LASI (Link Alarm Status Interrupt) registers, defined by XENPAK MSA. */ +#define MDIO_PMA_LASI_RXCTRL 0x9000 /* RX_ALARM control */ +#define MDIO_PMA_LASI_TXCTRL 0x9001 /* TX_ALARM control */ +#define MDIO_PMA_LASI_CTRL 0x9002 /* LASI control */ +#define MDIO_PMA_LASI_RXSTAT 0x9003 /* RX_ALARM status */ +#define MDIO_PMA_LASI_TXSTAT 0x9004 /* TX_ALARM status */ +#define MDIO_PMA_LASI_STAT 0x9005 /* LASI status */ + +/* Control register 1. */ +/* Enable extended speed selection */ +#define MDIO_CTRL1_SPEEDSELEXT (BMCR_SPEED1000 | BMCR_SPEED100) +/* All speed selection bits */ +#define MDIO_CTRL1_SPEEDSEL (MDIO_CTRL1_SPEEDSELEXT | 0x003c) +#define MDIO_CTRL1_FULLDPLX BMCR_FULLDPLX +#define MDIO_CTRL1_LPOWER BMCR_PDOWN +#define MDIO_CTRL1_RESET BMCR_RESET +#define MDIO_PMA_CTRL1_LOOPBACK 0x0001 +#define MDIO_PMA_CTRL1_SPEED1000 BMCR_SPEED1000 +#define MDIO_PMA_CTRL1_SPEED100 BMCR_SPEED100 +#define MDIO_PCS_CTRL1_LOOPBACK BMCR_LOOPBACK +#define MDIO_PHYXS_CTRL1_LOOPBACK BMCR_LOOPBACK +#define MDIO_AN_CTRL1_RESTART BMCR_ANRESTART +#define MDIO_AN_CTRL1_ENABLE BMCR_ANENABLE +#define MDIO_AN_CTRL1_XNP 0x2000 /* Enable extended next page */ + +/* 10 Gb/s */ +#define MDIO_CTRL1_SPEED10G (MDIO_CTRL1_SPEEDSELEXT | 0x00) +/* 10PASS-TS/2BASE-TL */ +#define MDIO_CTRL1_SPEED10P2B (MDIO_CTRL1_SPEEDSELEXT | 0x04) + +/* Status register 1. */ +#define MDIO_STAT1_LPOWERABLE 0x0002 /* Low-power ability */ +#define MDIO_STAT1_LSTATUS BMSR_LSTATUS +#define MDIO_STAT1_FAULT 0x0080 /* Fault */ +#define MDIO_AN_STAT1_LPABLE 0x0001 /* Link partner AN ability */ +#define MDIO_AN_STAT1_ABLE BMSR_ANEGCAPABLE +#define MDIO_AN_STAT1_RFAULT BMSR_RFAULT +#define MDIO_AN_STAT1_COMPLETE BMSR_ANEGCOMPLETE +#define MDIO_AN_STAT1_PAGE 0x0040 /* Page received */ +#define MDIO_AN_STAT1_XNP 0x0080 /* Extended next page status */ + +/* Speed register. */ +#define MDIO_SPEED_10G 0x0001 /* 10G capable */ +#define MDIO_PMA_SPEED_2B 0x0002 /* 2BASE-TL capable */ +#define MDIO_PMA_SPEED_10P 0x0004 /* 10PASS-TS capable */ +#define MDIO_PMA_SPEED_1000 0x0010 /* 1000M capable */ +#define MDIO_PMA_SPEED_100 0x0020 /* 100M capable */ +#define MDIO_PMA_SPEED_10 0x0040 /* 10M capable */ +#define MDIO_PCS_SPEED_10P2B 0x0002 /* 10PASS-TS/2BASE-TL capable */ + +/* Device present registers. */ +#define MDIO_DEVS_PRESENT(devad) (1 << (devad)) +#define MDIO_DEVS_PMAPMD MDIO_DEVS_PRESENT(MDIO_MMD_PMAPMD) +#define MDIO_DEVS_WIS MDIO_DEVS_PRESENT(MDIO_MMD_WIS) +#define MDIO_DEVS_PCS MDIO_DEVS_PRESENT(MDIO_MMD_PCS) +#define MDIO_DEVS_PHYXS MDIO_DEVS_PRESENT(MDIO_MMD_PHYXS) +#define MDIO_DEVS_DTEXS MDIO_DEVS_PRESENT(MDIO_MMD_DTEXS) +#define MDIO_DEVS_TC MDIO_DEVS_PRESENT(MDIO_MMD_TC) +#define MDIO_DEVS_AN MDIO_DEVS_PRESENT(MDIO_MMD_AN) +#define MDIO_DEVS_C22EXT MDIO_DEVS_PRESENT(MDIO_MMD_C22EXT) +#define MDIO_DEVS_VEND1 MDIO_DEVS_PRESENT(MDIO_MMD_VEND1) +#define MDIO_DEVS_VEND2 MDIO_DEVS_PRESENT(MDIO_MMD_VEND2) + +/* Control register 2. */ +#define MDIO_PMA_CTRL2_TYPE 0x000f /* PMA/PMD type selection */ +#define MDIO_PMA_CTRL2_10GBCX4 0x0000 /* 10GBASE-CX4 type */ +#define MDIO_PMA_CTRL2_10GBEW 0x0001 /* 10GBASE-EW type */ +#define MDIO_PMA_CTRL2_10GBLW 0x0002 /* 10GBASE-LW type */ +#define MDIO_PMA_CTRL2_10GBSW 0x0003 /* 10GBASE-SW type */ +#define MDIO_PMA_CTRL2_10GBLX4 0x0004 /* 10GBASE-LX4 type */ +#define MDIO_PMA_CTRL2_10GBER 0x0005 /* 10GBASE-ER type */ +#define MDIO_PMA_CTRL2_10GBLR 0x0006 /* 10GBASE-LR type */ +#define MDIO_PMA_CTRL2_10GBSR 0x0007 /* 10GBASE-SR type */ +#define MDIO_PMA_CTRL2_10GBLRM 0x0008 /* 10GBASE-LRM type */ +#define MDIO_PMA_CTRL2_10GBT 0x0009 /* 10GBASE-T type */ +#define MDIO_PMA_CTRL2_10GBKX4 0x000a /* 10GBASE-KX4 type */ +#define MDIO_PMA_CTRL2_10GBKR 0x000b /* 10GBASE-KR type */ +#define MDIO_PMA_CTRL2_1000BT 0x000c /* 1000BASE-T type */ +#define MDIO_PMA_CTRL2_1000BKX 0x000d /* 1000BASE-KX type */ +#define MDIO_PMA_CTRL2_100BTX 0x000e /* 100BASE-TX type */ +#define MDIO_PMA_CTRL2_10BT 0x000f /* 10BASE-T type */ +#define MDIO_PCS_CTRL2_TYPE 0x0003 /* PCS type selection */ +#define MDIO_PCS_CTRL2_10GBR 0x0000 /* 10GBASE-R type */ +#define MDIO_PCS_CTRL2_10GBX 0x0001 /* 10GBASE-X type */ +#define MDIO_PCS_CTRL2_10GBW 0x0002 /* 10GBASE-W type */ +#define MDIO_PCS_CTRL2_10GBT 0x0003 /* 10GBASE-T type */ + +/* Status register 2. */ +#define MDIO_STAT2_RXFAULT 0x0400 /* Receive fault */ +#define MDIO_STAT2_TXFAULT 0x0800 /* Transmit fault */ +#define MDIO_STAT2_DEVPRST 0xc000 /* Device present */ +#define MDIO_STAT2_DEVPRST_VAL 0x8000 /* Device present value */ +#define MDIO_PMA_STAT2_LBABLE 0x0001 /* PMA loopback ability */ +#define MDIO_PMA_STAT2_10GBEW 0x0002 /* 10GBASE-EW ability */ +#define MDIO_PMA_STAT2_10GBLW 0x0004 /* 10GBASE-LW ability */ +#define MDIO_PMA_STAT2_10GBSW 0x0008 /* 10GBASE-SW ability */ +#define MDIO_PMA_STAT2_10GBLX4 0x0010 /* 10GBASE-LX4 ability */ +#define MDIO_PMA_STAT2_10GBER 0x0020 /* 10GBASE-ER ability */ +#define MDIO_PMA_STAT2_10GBLR 0x0040 /* 10GBASE-LR ability */ +#define MDIO_PMA_STAT2_10GBSR 0x0080 /* 10GBASE-SR ability */ +#define MDIO_PMD_STAT2_TXDISAB 0x0100 /* PMD TX disable ability */ +#define MDIO_PMA_STAT2_EXTABLE 0x0200 /* Extended abilities */ +#define MDIO_PMA_STAT2_RXFLTABLE 0x1000 /* Receive fault ability */ +#define MDIO_PMA_STAT2_TXFLTABLE 0x2000 /* Transmit fault ability */ +#define MDIO_PCS_STAT2_10GBR 0x0001 /* 10GBASE-R capable */ +#define MDIO_PCS_STAT2_10GBX 0x0002 /* 10GBASE-X capable */ +#define MDIO_PCS_STAT2_10GBW 0x0004 /* 10GBASE-W capable */ +#define MDIO_PCS_STAT2_RXFLTABLE 0x1000 /* Receive fault ability */ +#define MDIO_PCS_STAT2_TXFLTABLE 0x2000 /* Transmit fault ability */ + +/* Transmit disable register. */ +#define MDIO_PMD_TXDIS_GLOBAL 0x0001 /* Global PMD TX disable */ +#define MDIO_PMD_TXDIS_0 0x0002 /* PMD TX disable 0 */ +#define MDIO_PMD_TXDIS_1 0x0004 /* PMD TX disable 1 */ +#define MDIO_PMD_TXDIS_2 0x0008 /* PMD TX disable 2 */ +#define MDIO_PMD_TXDIS_3 0x0010 /* PMD TX disable 3 */ + +/* Receive signal detect register. */ +#define MDIO_PMD_RXDET_GLOBAL 0x0001 /* Global PMD RX signal detect */ +#define MDIO_PMD_RXDET_0 0x0002 /* PMD RX signal detect 0 */ +#define MDIO_PMD_RXDET_1 0x0004 /* PMD RX signal detect 1 */ +#define MDIO_PMD_RXDET_2 0x0008 /* PMD RX signal detect 2 */ +#define MDIO_PMD_RXDET_3 0x0010 /* PMD RX signal detect 3 */ + +/* Extended abilities register. */ +#define MDIO_PMA_EXTABLE_10GCX4 0x0001 /* 10GBASE-CX4 ability */ +#define MDIO_PMA_EXTABLE_10GBLRM 0x0002 /* 10GBASE-LRM ability */ +#define MDIO_PMA_EXTABLE_10GBT 0x0004 /* 10GBASE-T ability */ +#define MDIO_PMA_EXTABLE_10GBKX4 0x0008 /* 10GBASE-KX4 ability */ +#define MDIO_PMA_EXTABLE_10GBKR 0x0010 /* 10GBASE-KR ability */ +#define MDIO_PMA_EXTABLE_1000BT 0x0020 /* 1000BASE-T ability */ +#define MDIO_PMA_EXTABLE_1000BKX 0x0040 /* 1000BASE-KX ability */ +#define MDIO_PMA_EXTABLE_100BTX 0x0080 /* 100BASE-TX ability */ +#define MDIO_PMA_EXTABLE_10BT 0x0100 /* 10BASE-T ability */ + +/* PHY XGXS lane state register. */ +#define MDIO_PHYXS_LNSTAT_SYNC0 0x0001 +#define MDIO_PHYXS_LNSTAT_SYNC1 0x0002 +#define MDIO_PHYXS_LNSTAT_SYNC2 0x0004 +#define MDIO_PHYXS_LNSTAT_SYNC3 0x0008 +#define MDIO_PHYXS_LNSTAT_ALIGN 0x1000 + +/* PMA 10GBASE-T pair swap & polarity */ +#define MDIO_PMA_10GBT_SWAPPOL_ABNX 0x0001 /* Pair A/B uncrossed */ +#define MDIO_PMA_10GBT_SWAPPOL_CDNX 0x0002 /* Pair C/D uncrossed */ +#define MDIO_PMA_10GBT_SWAPPOL_AREV 0x0100 /* Pair A polarity reversed */ +#define MDIO_PMA_10GBT_SWAPPOL_BREV 0x0200 /* Pair B polarity reversed */ +#define MDIO_PMA_10GBT_SWAPPOL_CREV 0x0400 /* Pair C polarity reversed */ +#define MDIO_PMA_10GBT_SWAPPOL_DREV 0x0800 /* Pair D polarity reversed */ + +/* PMA 10GBASE-T TX power register. */ +#define MDIO_PMA_10GBT_TXPWR_SHORT 0x0001 /* Short-reach mode */ + +/* PMA 10GBASE-T SNR registers. */ +/* Value is SNR margin in dB, clamped to range [-127, 127], plus 0x8000. */ +#define MDIO_PMA_10GBT_SNR_BIAS 0x8000 +#define MDIO_PMA_10GBT_SNR_MAX 127 + +/* PMA 10GBASE-R FEC ability register. */ +#define MDIO_PMA_10GBR_FECABLE_ABLE 0x0001 /* FEC ability */ +#define MDIO_PMA_10GBR_FECABLE_ERRABLE 0x0002 /* FEC error indic. ability */ + +/* PCS 10GBASE-R/-T status register 1. */ +#define MDIO_PCS_10GBRT_STAT1_BLKLK 0x0001 /* Block lock attained */ + +/* PCS 10GBASE-R/-T status register 2. */ +#define MDIO_PCS_10GBRT_STAT2_ERR 0x00ff +#define MDIO_PCS_10GBRT_STAT2_BER 0x3f00 + +/* AN 10GBASE-T control register. */ +#define MDIO_AN_10GBT_CTRL_ADV10G 0x1000 /* Advertise 10GBASE-T */ + +/* AN 10GBASE-T status register. */ +#define MDIO_AN_10GBT_STAT_LPTRR 0x0200 /* LP training reset req. */ +#define MDIO_AN_10GBT_STAT_LPLTABLE 0x0400 /* LP loop timing ability */ +#define MDIO_AN_10GBT_STAT_LP10G 0x0800 /* LP is 10GBT capable */ +#define MDIO_AN_10GBT_STAT_REMOK 0x1000 /* Remote OK */ +#define MDIO_AN_10GBT_STAT_LOCOK 0x2000 /* Local OK */ +#define MDIO_AN_10GBT_STAT_MS 0x4000 /* Master/slave config */ +#define MDIO_AN_10GBT_STAT_MSFLT 0x8000 /* Master/slave config fault */ + +/* LASI RX_ALARM control/status registers. */ +#define MDIO_PMA_LASI_RX_PHYXSLFLT 0x0001 /* PHY XS RX local fault */ +#define MDIO_PMA_LASI_RX_PCSLFLT 0x0008 /* PCS RX local fault */ +#define MDIO_PMA_LASI_RX_PMALFLT 0x0010 /* PMA/PMD RX local fault */ +#define MDIO_PMA_LASI_RX_OPTICPOWERFLT 0x0020 /* RX optical power fault */ +#define MDIO_PMA_LASI_RX_WISLFLT 0x0200 /* WIS local fault */ + +/* LASI TX_ALARM control/status registers. */ +#define MDIO_PMA_LASI_TX_PHYXSLFLT 0x0001 /* PHY XS TX local fault */ +#define MDIO_PMA_LASI_TX_PCSLFLT 0x0008 /* PCS TX local fault */ +#define MDIO_PMA_LASI_TX_PMALFLT 0x0010 /* PMA/PMD TX local fault */ +#define MDIO_PMA_LASI_TX_LASERPOWERFLT 0x0080 /* Laser output power fault */ +#define MDIO_PMA_LASI_TX_LASERTEMPFLT 0x0100 /* Laser temperature fault */ +#define MDIO_PMA_LASI_TX_LASERBICURRFLT 0x0200 /* Laser bias current fault */ + +/* LASI control/status registers. */ +#define MDIO_PMA_LASI_LSALARM 0x0001 /* LS_ALARM enable/status */ +#define MDIO_PMA_LASI_TXALARM 0x0002 /* TX_ALARM enable/status */ +#define MDIO_PMA_LASI_RXALARM 0x0004 /* RX_ALARM enable/status */ + +/* Mapping between MDIO PRTAD/DEVAD and mii_ioctl_data::phy_id */ + +#define MDIO_PHY_ID_C45 0x8000 +#define MDIO_PHY_ID_PRTAD 0x03e0 +#define MDIO_PHY_ID_DEVAD 0x001f +#define MDIO_PHY_ID_C45_MASK \ + (MDIO_PHY_ID_C45 | MDIO_PHY_ID_PRTAD | MDIO_PHY_ID_DEVAD) + +/* Indicates what features are supported by the interface. */ +#define SUPPORTED_10baseT_Half (1 << 0) +#define SUPPORTED_10baseT_Full (1 << 1) +#define SUPPORTED_100baseT_Half (1 << 2) +#define SUPPORTED_100baseT_Full (1 << 3) +#define SUPPORTED_1000baseT_Half (1 << 4) +#define SUPPORTED_1000baseT_Full (1 << 5) +#define SUPPORTED_Autoneg (1 << 6) +#define SUPPORTED_TP (1 << 7) +#define SUPPORTED_AUI (1 << 8) +#define SUPPORTED_MII (1 << 9) +#define SUPPORTED_FIBRE (1 << 10) +#define SUPPORTED_BNC (1 << 11) +#define SUPPORTED_10000baseT_Full (1 << 12) +#define SUPPORTED_Pause (1 << 13) +#define SUPPORTED_Asym_Pause (1 << 14) +#define SUPPORTED_2500baseX_Full (1 << 15) +#define SUPPORTED_Backplane (1 << 16) +#define SUPPORTED_1000baseKX_Full (1 << 17) +#define SUPPORTED_10000baseKX4_Full (1 << 18) +#define SUPPORTED_10000baseKR_Full (1 << 19) +#define SUPPORTED_10000baseR_FEC (1 << 20) + +/* Indicates what features are advertised by the interface. */ +#define ADVERTISED_10baseT_Half (1 << 0) +#define ADVERTISED_10baseT_Full (1 << 1) +#define ADVERTISED_100baseT_Half (1 << 2) +#define ADVERTISED_100baseT_Full (1 << 3) +#define ADVERTISED_1000baseT_Half (1 << 4) +#define ADVERTISED_1000baseT_Full (1 << 5) +#define ADVERTISED_Autoneg (1 << 6) +#define ADVERTISED_TP (1 << 7) +#define ADVERTISED_AUI (1 << 8) +#define ADVERTISED_MII (1 << 9) +#define ADVERTISED_FIBRE (1 << 10) +#define ADVERTISED_BNC (1 << 11) +#define ADVERTISED_10000baseT_Full (1 << 12) +#define ADVERTISED_Pause (1 << 13) +#define ADVERTISED_Asym_Pause (1 << 14) +#define ADVERTISED_2500baseX_Full (1 << 15) +#define ADVERTISED_Backplane (1 << 16) +#define ADVERTISED_1000baseKX_Full (1 << 17) +#define ADVERTISED_10000baseKX4_Full (1 << 18) +#define ADVERTISED_10000baseKR_Full (1 << 19) +#define ADVERTISED_10000baseR_FEC (1 << 20) + +/* The following are all involved in forcing a particular link + * mode for the device for setting things. When getting the + * devices settings, these indicate the current mode and whether + * it was foced up into this mode or autonegotiated. + */ + +/* The forced speed, 10Mb, 100Mb, gigabit, 2.5Gb, 10GbE. */ +#define SPEED_10 10 +#define SPEED_100 100 +#define SPEED_1000 1000 +#define SPEED_2500 2500 +#define SPEED_10000 10000 + +/* Duplex, half or full. */ +#define DUPLEX_HALF 0x00 +#define DUPLEX_FULL 0x01 + +/* Which connector port. */ +#define PORT_TP 0x00 +#define PORT_AUI 0x01 +#define PORT_MII 0x02 +#define PORT_FIBRE 0x03 +#define PORT_BNC 0x04 +#define PORT_DA 0x05 +#define PORT_NONE 0xef +#define PORT_OTHER 0xff + +/* Which transceiver to use. */ +#define XCVR_INTERNAL 0x00 +#define XCVR_EXTERNAL 0x01 +#define XCVR_DUMMY1 0x02 +#define XCVR_DUMMY2 0x03 +#define XCVR_DUMMY3 0x04 + +/* Enable or disable autonegotiation. If this is set to enable, + * the forced link modes above are completely ignored. + */ +#define AUTONEG_DISABLE 0x00 +#define AUTONEG_ENABLE 0x01 + +#define MDIO_DEVAD_NONE -1 +#define PHY_MAX_ADDR 32 + +#define PHY_BASIC_FEATURES (SUPPORTED_10baseT_Half | \ + SUPPORTED_10baseT_Full | \ + SUPPORTED_100baseT_Half | \ + SUPPORTED_100baseT_Full | \ + SUPPORTED_Autoneg | \ + SUPPORTED_TP | \ + SUPPORTED_MII) + +#define PHY_GBIT_FEATURES (PHY_BASIC_FEATURES | \ + SUPPORTED_1000baseT_Half | \ + SUPPORTED_1000baseT_Full) + +#define PHY_10G_FEATURES (PHY_GBIT_FEATURES | \ + SUPPORTED_10000baseT_Full) + + +typedef enum { + PHY_INTERFACE_MODE_MII, + PHY_INTERFACE_MODE_GMII, + PHY_INTERFACE_MODE_SGMII, + PHY_INTERFACE_MODE_TBI, + PHY_INTERFACE_MODE_RMII, + PHY_INTERFACE_MODE_RGMII, + PHY_INTERFACE_MODE_RGMII_ID, + PHY_INTERFACE_MODE_RGMII_RXID, + PHY_INTERFACE_MODE_RGMII_TXID, + PHY_INTERFACE_MODE_RTBI, + PHY_INTERFACE_MODE_XGMII +} phy_interface_t; + +struct phy_device; + +/* struct phy_driver: a structure which defines PHY behavior + * + * uid will contain a number which represents the PHY. During + * startup, the driver will poll the PHY to find out what its + * UID--as defined by registers 2 and 3--is. The 32-bit result + * gotten from the PHY will be masked to + * discard any bits which may change based on revision numbers + * unimportant to functionality + * + */ +struct phy_driver { + char *name; + unsigned int uid; + unsigned int mask; + + u32 features; + + /* Called to do any driver startup necessities */ + /* Will be called during phy_connect */ + int (*probe)(struct phy_device *phydev); + + /* Called to configure the PHY, and modify the controller + * based on the results. Should be called after phy_connect */ + int (*config)(struct phy_device *phydev); + + /* Called when starting up the controller */ + int (*startup)(struct phy_device *phydev); + + /* Called when bringing down the controller */ + int (*shutdown)(struct phy_device *phydev); + + struct list_head list; +}; + +struct phy_device { + /* Information about the PHY type */ + /* And management functions */ + struct mii_dev *bus; + struct phy_driver *drv; + void *priv; + + struct eth_device *dev; + + /* forced speed & duplex (no autoneg) + * partner speed & duplex & pause (autoneg) + */ + int speed; + int duplex; + + /* The most recently read link state */ + int link; + int port; + phy_interface_t interface; + + u32 advertising; + u32 supported; + u32 mmds; + + int autoneg; + int addr; + int pause; + int asym_pause; + u32 phy_id; + u32 flags; +}; + +int phy_init(void); +struct phy_device *phy_connect(struct mii_dev *bus, int addr, + struct eth_device *dev, + phy_interface_t interface); +int phy_startup(struct phy_device *phydev); +int phy_config(struct phy_device *phydev); +int phy_shutdown(struct phy_device *phydev); +int phy_write(struct phy_device *phydev, int devad, int reg, u16 val); +int phy_read(struct phy_device *phydev, int devad, int reg); +int phy_register(struct phy_driver *drv); +int genphy_config_aneg(struct phy_device *phydev); +int genphy_update_link(struct phy_device *phydev); +int genphy_config(struct phy_device *phydev); +int genphy_startup(struct phy_device *phydev); +int genphy_shutdown(struct phy_device *phydev); +int gen10g_config(struct phy_device *phydev); +int gen10g_startup(struct phy_device *phydev); +int gen10g_shutdown(struct phy_device *phydev); +#endif diff --git a/net/eth.c b/net/eth.c index 3a7ff50..6523834 100644 --- a/net/eth.c +++ b/net/eth.c @@ -25,6 +25,7 @@ #include <command.h> #include <net.h> #include <miiphy.h> +#include <phy.h>
void eth_parse_enetaddr(const char *addr, uchar *enetaddr) { @@ -217,6 +218,11 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_init(); #endif + +#ifdef CONFIG_PHYLIB + phy_init(); +#endif + /* * If board-specific initialization exists, call it. * If not, call a CPU-specific one
The new mdio command doesn't have all of the features of the mii command, but it provides the necessary read/write primitives, and allows users to interact with 10G PHYs, and other PHYs which use Clause 45 of 802.3. This means that the mdio command requires a "Device Address" argument, though for clause 22 PHYs, the argument can be "-".
Signed-off-by: Andy Fleming afleming@freescale.com --- common/Makefile | 3 + common/cmd_mdio.c | 293 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 296 insertions(+), 0 deletions(-) create mode 100644 common/cmd_mdio.c
diff --git a/common/Makefile b/common/Makefile index 00847ef..a644627 100644 --- a/common/Makefile +++ b/common/Makefile @@ -116,6 +116,9 @@ COBJS-$(CONFIG_MII) += miiphyutil.o COBJS-$(CONFIG_CMD_MII) += miiphyutil.o COBJS-$(CONFIG_PHYLIB) += miiphyutil.o COBJS-$(CONFIG_CMD_MII) += cmd_mii.o +ifdef CONFIG_PHYLIB +COBJS-$(CONFIG_CMD_MII) += cmd_mdio.o +endif COBJS-$(CONFIG_CMD_MISC) += cmd_misc.o COBJS-$(CONFIG_CMD_MMC) += cmd_mmc.o COBJS-$(CONFIG_MP) += cmd_mp.o diff --git a/common/cmd_mdio.c b/common/cmd_mdio.c new file mode 100644 index 0000000..3ab0bef --- /dev/null +++ b/common/cmd_mdio.c @@ -0,0 +1,293 @@ +/* + * (C) Copyright 2011 Freescale Semiconductor, Inc + * Andy Fleming + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * MDIO Commands + */ + +#include <common.h> +#include <command.h> +#include <miiphy.h> +#include <phy.h> + + +static char last_op[2]; +static uint last_data; +static uint last_addr_lo; +static uint last_addr_hi; +static uint last_devad_lo; +static uint last_devad_hi; +static uint last_reg_lo; +static uint last_reg_hi; + +static int extract_range(char *input, int *plo, int *phi) +{ + char * end; + *plo = simple_strtol(input, &end, 0); + if (end == input) + return -1; + + if (*end == '-') { + end++; + *phi = simple_strtol(end, NULL, 0); + } else if (*end == '\0') { + *phi = *plo; + } else + return -1; + + return 0; +} + +int mdio_write_ranges(struct mii_dev *bus, int addrlo, + int addrhi, int devadlo, int devadhi, + int reglo, int reghi, unsigned short data) +{ + int addr, devad, reg; + int err = 0; + + for (addr = addrlo; addr <= addrhi; addr++) { + for (devad = devadlo; devad <= devadhi; devad++) { + for (reg = reglo; reg <= reghi; reg++) { + err = bus->write(bus, addr, devad, reg, data); + + if (err) + goto err_out; + } + } + } + +err_out: + return err; +} + +int mdio_read_ranges(struct mii_dev *bus, int addrlo, + int addrhi, int devadlo, int devadhi, + int reglo, int reghi) +{ + int addr, devad, reg; + + printf("Reading from bus %s\n", bus->name); + for (addr = addrlo; addr <= addrhi; addr++) { + printf("PHY at address %d:\n", addr); + + for (devad = devadlo; devad <= devadhi; devad++) { + for (reg = reglo; reg <= reghi; reg++) { + u16 val; + val = bus->read(bus, addr, devad, reg); + + if (val < 0) { + printf("Error\n"); + + return val; + } + + if (devad >= 0) + printf("%d.", devad); + + printf("%d - 0x%x\n", reg, val & 0xffff); + } + } + } + + return 0; +} + +int extract_phy_range(char * const argv[], int argc, struct mii_dev **bus, + int *addrlo, int *addrhi) +{ + struct phy_device *phydev; + char *addrstr; + int addrlen, namelen; + char busname[MDIO_NAME_LEN]; + + if ((argc < 1) || (argc > 2)) + return -1; + + /* If there are two arguments, it's busname addr */ + if (argc == 2) { + *bus = miiphy_get_dev_by_name(argv[0]); + + if (!*bus) + return -1; + + return extract_range(argv[1], addrlo, addrhi); + } + + /* It must be one argument, here */ + + /* + * This argument can be one of three things: + * 1) Ethernet device name + * 2) bus name and address in one string (name:addr) + * 3) Just an address (use the previously-used bus) + * + * We'll assume that no ethernet device will have a name that collides + * with the format for busname:addr. So we check all buses for a PHY + * which is connected to that ethernet device. If none are found, we + * look for a ':'. If it's found, then this is busname:addr. If so, + * we split the string, find the bus, and call extract_range() on the + * addr. If we didn't find ':', then we just call extract_range() on + * the string, and see if it's an address or address range. + */ + phydev = mdio_phydev_for_ethname(argv[0]); + + if (phydev) { + *addrlo = *addrhi = phydev->addr; + *bus = phydev->bus; + + return 0; + } + + /* use strrchr to find the last string after a ':' */ + addrstr = strrchr(argv[0], ':'); + + /* + * If it doesn't exist, or is not a valid range + * check to see if the whole string is a valid range + */ + if (!addrstr || extract_range(++addrstr, addrlo, addrhi)) + return extract_range(argv[0], addrlo, addrhi); + + /* Use the length of the returned string to determine where it starts */ + addrlen = strlen(addrstr); + namelen = strlen(argv[0]) - addrlen - 1; + + if (namelen >= MDIO_NAME_LEN) + namelen = MDIO_NAME_LEN - 1; + /* Copy the name string, and search for a bus with that name */ + strncpy(busname, argv[0], namelen); + busname[namelen] = '\0'; + + *bus = miiphy_get_dev_by_name(busname); + + if (!*bus) + return -1; + + return 0; +} + +/* ---------------------------------------------------------------- */ +static int do_mdio(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char op[2]; + int addrlo, addrhi, reglo, reghi, devadlo, devadhi; + unsigned short data; + int pos = argc - 1; + struct mii_dev *bus; + + if (argc < 2) + return cmd_usage(cmdtp); + + /* + * We use the last specified parameters, unless new ones are + * entered. + */ + op[0] = argv[1][0]; + addrlo = last_addr_lo; + addrhi = last_addr_hi; + devadlo = last_devad_lo; + devadhi = last_devad_hi; + reglo = last_reg_lo; + reghi = last_reg_hi; + data = last_data; + + bus = mdio_get_current_dev(); + + if (flag & CMD_FLAG_REPEAT) + op[0] = last_op[0]; + + switch (op[0]) { + case 'w': + if (pos > 1) + data = simple_strtoul (argv[pos--], NULL, 16); + case 'r': + if (pos > 1) + if (extract_range(argv[pos--], ®lo, ®hi)) + return -1; + if (pos > 1) { + if (argv[pos][0] == '-') + devadlo = devadhi = MDIO_DEVAD_NONE; + else if (extract_range(argv[pos], &devadlo, &devadhi)) + return -1; + } + default: + if (pos > 2) + if (extract_phy_range(&(argv[2]), pos - 2, &bus, + &addrlo, &addrhi)) + return -1; + + break; + } + + if (op[0] == 'l') { + mdio_list_devices(); + + return 0; + } + + /* Save the chosen bus */ + miiphy_set_current_dev(bus->name); + + switch (op[0]) { + case 'w': + mdio_write_ranges(bus, addrlo, addrhi, devadlo, devadhi, + reglo, reghi, data); + break; + + case 'r': + mdio_read_ranges(bus, addrlo, addrhi, devadlo, devadhi, + reglo, reghi); + break; + } + + /* + * Save the parameters for repeats. + */ + last_op[0] = op[0]; + last_addr_lo = addrlo; + last_addr_hi = addrhi; + last_devad_lo = devadlo; + last_devad_hi = devadhi; + last_reg_lo = reglo; + last_reg_hi = reghi; + last_data = data; + + return 0; +} + +/***************************************************/ + +U_BOOT_CMD( + mdio, 7, 1, do_mdio, + "MDIO utility commands", + "list - List MDIO buses\n" + "mdio read <phydev> <devad> <reg> - read PHY's register at <devad> <reg>\n" + "mdio write <phydev> <devad> <reg> <data> - write PHY's register at <devad> <reg>\n" + "<phydev> may be:\n" + " <busname> <addr>\n" + " <busname>:<addr>\n" + " <addr>\n" + " <eth name>\n" + "Addr devad, and reg may be ranges, e.g. 2-7.\n" + "devad should be '-' for standard MII (802.3 Clause 22)." +);
The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib.
Signed-off-by: Andy Fleming afleming@freescale.com --- drivers/net/phy/Makefile | 10 ++ drivers/net/phy/atheros.c | 37 +++++ drivers/net/phy/broadcom.c | 275 ++++++++++++++++++++++++++++++++ drivers/net/phy/davicom.c | 86 ++++++++++ drivers/net/phy/lxt.c | 76 +++++++++ drivers/net/phy/marvell.c | 357 ++++++++++++++++++++++++++++++++++++++++++ drivers/net/phy/micrel.c | 29 ++++ drivers/net/phy/natsemi.c | 85 ++++++++++ drivers/net/phy/phy.c | 28 ++++ drivers/net/phy/realtek.c | 120 ++++++++++++++ drivers/net/phy/teranetics.c | 43 +++++ drivers/net/phy/vitesse.c | 330 ++++++++++++++++++++++++++++++++++++++ include/phy.h | 11 ++ include/phylib_all_drivers.h | 25 +++ 14 files changed, 1512 insertions(+), 0 deletions(-) create mode 100644 drivers/net/phy/atheros.c create mode 100644 drivers/net/phy/broadcom.c create mode 100644 drivers/net/phy/davicom.c create mode 100644 drivers/net/phy/lxt.c create mode 100644 drivers/net/phy/marvell.c create mode 100644 drivers/net/phy/micrel.c create mode 100644 drivers/net/phy/natsemi.c create mode 100644 drivers/net/phy/realtek.c create mode 100644 drivers/net/phy/teranetics.c create mode 100644 drivers/net/phy/vitesse.c create mode 100644 include/phylib_all_drivers.h
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index 7cb1094..f67a79a 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -28,6 +28,16 @@ LIB := $(obj)libphy.o COBJS-$(CONFIG_BITBANGMII) += miiphybb.o COBJS-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o COBJS-$(CONFIG_PHYLIB) += phy.o +COBJS-$(CONFIG_PHY_VITESSE) += vitesse.o +COBJS-$(CONFIG_PHY_TERANETICS) += teranetics.o +COBJS-$(CONFIG_PHY_MARVELL) += marvell.o +COBJS-$(CONFIG_PHY_REALTEK) += realtek.o +COBJS-$(CONFIG_PHY_BROADCOM) += broadcom.o +COBJS-$(CONFIG_PHY_DAVICOM) += davicom.o +COBJS-$(CONFIG_PHY_LXT) += lxt.o +COBJS-$(CONFIG_PHY_NATSEMI) += natsemi.o +COBJS-$(CONFIG_PHY_MICREL) += micrel.o +COBJS-$(CONFIG_PHY_ATHEROS) += atheros.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c new file mode 100644 index 0000000..68bb5cd --- /dev/null +++ b/drivers/net/phy/atheros.c @@ -0,0 +1,37 @@ +/* + * Atheros PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +static int ar8021_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x3D47); + + return 0; +} + +struct phy_driver AR8021_driver = { + .name = "AR8021", + .uid = 0x4dd040, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = ar8021_config, + .startup = genphy_startup, + .shutdown = genphy_shutdown, +}; + +int atheros_init(void) +{ + phy_register(&AR8021_driver); + + return 0; +} diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c new file mode 100644 index 0000000..e62a81d --- /dev/null +++ b/drivers/net/phy/broadcom.c @@ -0,0 +1,275 @@ +/* + * Broadcom PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <config.h> +#include <common.h> +#include <phy.h> + +/* Broadcom BCM54xx -- taken from linux sungem_phy */ +#define MIIM_BCM54xx_AUXCNTL 0x18 +#define MIIM_BCM54xx_AUXCNTL_ENCODE(val) ((val & 0x7) << 12)|(val & 0x7) +#define MIIM_BCM54xx_AUXSTATUS 0x19 +#define MIIM_BCM54xx_AUXSTATUS_LINKMODE_MASK 0x0700 +#define MIIM_BCM54xx_AUXSTATUS_LINKMODE_SHIFT 8 + +#define MIIM_BCM54XX_SHD 0x1c +#define MIIM_BCM54XX_SHD_WRITE 0x8000 +#define MIIM_BCM54XX_SHD_VAL(x) ((x & 0x1f) << 10) +#define MIIM_BCM54XX_SHD_DATA(x) ((x & 0x3ff) << 0) +#define MIIM_BCM54XX_SHD_WR_ENCODE(val, data) \ + (MIIM_BCM54XX_SHD_WRITE | MIIM_BCM54XX_SHD_VAL(val) | \ + MIIM_BCM54XX_SHD_DATA(data)) + +#define MIIM_BCM54XX_EXP_DATA 0x15 /* Expansion register data */ +#define MIIM_BCM54XX_EXP_SEL 0x17 /* Expansion register select */ +#define MIIM_BCM54XX_EXP_SEL_SSD 0x0e00 /* Secondary SerDes select */ +#define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */ + +/* Broadcom BCM5461S */ +static int bcm5461_config(struct phy_device *phydev) +{ + genphy_config_aneg(phydev); + + return 0; +} + +static int bcm54xx_parse_status(struct phy_device *phydev) +{ + unsigned int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXSTATUS); + + switch ((mii_reg & MIIM_BCM54xx_AUXSTATUS_LINKMODE_MASK) >> + MIIM_BCM54xx_AUXSTATUS_LINKMODE_SHIFT) { + case 1: + phydev->duplex = DUPLEX_HALF; + phydev->speed = SPEED_10; + break; + case 2: + phydev->duplex = DUPLEX_FULL; + phydev->speed = SPEED_10; + break; + case 3: + phydev->duplex = DUPLEX_HALF; + phydev->speed = SPEED_100; + break; + case 5: + phydev->duplex = DUPLEX_FULL; + phydev->speed = SPEED_100; + break; + case 6: + phydev->duplex = DUPLEX_HALF; + phydev->speed = SPEED_1000; + break; + case 7: + phydev->duplex = DUPLEX_FULL; + phydev->speed = SPEED_1000; + break; + default: + printf("Auto-neg error, defaulting to 10BT/HD\n"); + phydev->duplex = DUPLEX_HALF; + phydev->speed = SPEED_10; + break; + } + + return 0; +} + +static int bcm54xx_startup(struct phy_device *phydev) +{ + /* Read the Status (2x to make sure link is right) */ + genphy_update_link(phydev); + bcm54xx_parse_status(phydev); + + return 0; +} + +/* Broadcom BCM5482S */ +/* + * "Ethernet@Wirespeed" needs to be enabled to achieve link in certain + * circumstances. eg a gigabit TSEC connected to a gigabit switch with + * a 4-wire ethernet cable. Both ends advertise gigabit, but can't + * link. "Ethernet@Wirespeed" reduces advertised speed until link + * can be achieved. + */ +static u32 bcm5482_read_wirespeed(struct phy_device *phydev, u32 reg) +{ + return (phy_read(phydev, MDIO_DEVAD_NONE, reg) & 0x8FFF) | 0x8010; +} + +static int bcm5482_config(struct phy_device *phydev) +{ + unsigned int reg; + + /* reset the PHY */ + reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMCR); + reg |= BMCR_RESET; + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, reg); + + /* Setup read from auxilary control shadow register 7 */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, + MIIM_BCM54xx_AUXCNTL_ENCODE(7)); + /* Read Misc Control register and or in Ethernet@Wirespeed */ + reg = bcm5482_read_wirespeed(phydev, MIIM_BCM54xx_AUXCNTL); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, reg); + + /* Initial config/enable of secondary SerDes interface */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_WR_ENCODE(0x14, 0xf)); + /* Write intial value to secondary SerDes Contol */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_SEL, + MIIM_BCM54XX_EXP_SEL_SSD | 0); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_DATA, + BMCR_ANRESTART); + /* Enable copper/fiber auto-detect */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_WR_ENCODE(0x1e, 0x201)); + + genphy_config_aneg(phydev); + + return 0; +} + +/* + * Find out if PHY is in copper or serdes mode by looking at Expansion Reg + * 0x42 - "Operating Mode Status Register" + */ +static int bcm5482_is_serdes(struct phy_device *phydev) +{ + u16 val; + int serdes = 0; + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_SEL, + MIIM_BCM54XX_EXP_SEL_ER | 0x42); + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_DATA); + + switch (val & 0x1f) { + case 0x0d: /* RGMII-to-100Base-FX */ + case 0x0e: /* RGMII-to-SGMII */ + case 0x0f: /* RGMII-to-SerDes */ + case 0x12: /* SGMII-to-SerDes */ + case 0x13: /* SGMII-to-100Base-FX */ + case 0x16: /* SerDes-to-Serdes */ + serdes = 1; + break; + case 0x6: /* RGMII-to-Copper */ + case 0x14: /* SGMII-to-Copper */ + case 0x17: /* SerDes-to-Copper */ + break; + default: + printf("ERROR, invalid PHY mode (0x%x\n)", val); + break; + } + + return serdes; +} + +/* + * Determine SerDes link speed and duplex from Expansion reg 0x42 "Operating + * Mode Status Register" + */ +static u32 bcm5482_parse_serdes_sr(struct phy_device *phydev) +{ + u16 val; + int i = 0; + + /* Wait 1s for link - Clause 37 autonegotiation happens very fast */ + while (1) { + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_SEL, + MIIM_BCM54XX_EXP_SEL_ER | 0x42); + val = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_EXP_DATA); + + if (val & 0x8000) + break; + + if (i++ > 1000) { + phydev->link = 0; + return 1; + } + + udelay(1000); /* 1 ms */ + } + + phydev->link = 1; + switch ((val >> 13) & 0x3) { + case (0x00): + phydev->speed = 10; + break; + case (0x01): + phydev->speed = 100; + break; + case (0x02): + phydev->speed = 1000; + break; + } + + phydev->duplex = (val & 0x1000) == 0x1000; + + return 0; +} + +/* + * Figure out if BCM5482 is in serdes or copper mode and determine link + * configuration accordingly + */ +static int bcm5482_startup(struct phy_device *phydev) +{ + if (bcm5482_is_serdes(phydev)) { + bcm5482_parse_serdes_sr(phydev); + phydev->port = PORT_FIBRE; + } else { + /* Wait for auto-negotiation to complete or fail */ + genphy_update_link(phydev); + /* Parse BCM54xx copper aux status register */ + bcm54xx_parse_status(phydev); + } + + return 0; +} + +static struct phy_driver BCM5461S_driver = { + .name = "Broadcom BCM5461S", + .uid = 0x2060c0, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = &bcm5461_config, + .startup = &bcm54xx_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver BCM5464S_driver = { + .name = "Broadcom BCM5464S", + .uid = 0x2060b0, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = &bcm5461_config, + .startup = &bcm54xx_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver BCM5482S_driver = { + .name = "Broadcom BCM5482S", + .uid = 0x143bcb0, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &bcm5482_config, + .startup = &bcm5482_startup, + .shutdown = &genphy_shutdown, +}; + +int broadcom_init(void) +{ + phy_register(&BCM5482S_driver); + phy_register(&BCM5464S_driver); + phy_register(&BCM5461S_driver); + + return 0; +} diff --git a/drivers/net/phy/davicom.c b/drivers/net/phy/davicom.c new file mode 100644 index 0000000..229e1bd --- /dev/null +++ b/drivers/net/phy/davicom.c @@ -0,0 +1,86 @@ +/* + * Davicom PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +#define MIIM_DM9161_SCR 0x10 +#define MIIM_DM9161_SCR_INIT 0x0610 + +/* DM9161 Specified Configuration and Status Register */ +#define MIIM_DM9161_SCSR 0x11 +#define MIIM_DM9161_SCSR_100F 0x8000 +#define MIIM_DM9161_SCSR_100H 0x4000 +#define MIIM_DM9161_SCSR_10F 0x2000 +#define MIIM_DM9161_SCSR_10H 0x1000 + +/* DM9161 10BT Configuration/Status */ +#define MIIM_DM9161_10BTCSR 0x12 +#define MIIM_DM9161_10BTCSR_INIT 0x7800 + + +/* Davicom DM9161E */ +static int dm9161_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_ISOLATE); + /* Do not bypass the scrambler/descrambler */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_DM9161_SCR, + MIIM_DM9161_SCR_INIT); + /* Clear 10BTCSR to default */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_DM9161_10BTCSR, MIIM_DM9161_10BTCSR_INIT); + + genphy_config_aneg(phydev); + + return 0; +} + +static int dm9161_parse_status(struct phy_device *phydev) +{ + int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_DM9161_SCSR); + + if (mii_reg & (MIIM_DM9161_SCSR_100F | MIIM_DM9161_SCSR_100H)) + phydev->speed = SPEED_100; + else + phydev->speed = SPEED_10; + + if (mii_reg & (MIIM_DM9161_SCSR_100F | MIIM_DM9161_SCSR_10F)) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + return 0; +} + +static int dm9161_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + dm9161_parse_status(phydev); + + return 0; +} + +static struct phy_driver DM9161_driver = { + .name = "Davicom DM9161E", + .uid = 0x181b880, + .mask = 0xffffff0, + .features = PHY_BASIC_FEATURES, + .config = &dm9161_config, + .startup = &dm9161_startup, + .shutdown = &genphy_shutdown, +}; + +int davicom_init(void) +{ + phy_register(&DM9161_driver); + + return 0; +} diff --git a/drivers/net/phy/lxt.c b/drivers/net/phy/lxt.c new file mode 100644 index 0000000..4e38bb6 --- /dev/null +++ b/drivers/net/phy/lxt.c @@ -0,0 +1,76 @@ +/* + * LXT PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +/* LXT971 Status 2 registers */ +#define MIIM_LXT971_SR2 0x11 /* Status Register 2 */ +#define MIIM_LXT971_SR2_SPEED_MASK 0x4200 +#define MIIM_LXT971_SR2_10HDX 0x0000 /* 10 Mbit half duplex selected */ +#define MIIM_LXT971_SR2_10FDX 0x0200 /* 10 Mbit full duplex selected */ +#define MIIM_LXT971_SR2_100HDX 0x4000 /* 100 Mbit half duplex selected */ +#define MIIM_LXT971_SR2_100FDX 0x4200 /* 100 Mbit full duplex selected */ + + +/* LXT971 */ +static int lxt971_parse_status(struct phy_device *phydev) +{ + int mii_reg; + int speed; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_LXT971_SR2); + speed = mii_reg & MIIM_LXT971_SR2_SPEED_MASK; + + switch (speed) { + case MIIM_LXT971_SR2_10HDX: + phydev->speed = SPEED_10; + phydev->duplex = DUPLEX_HALF; + break; + case MIIM_LXT971_SR2_10FDX: + phydev->speed = SPEED_10; + phydev->duplex = DUPLEX_FULL; + break; + case MIIM_LXT971_SR2_100HDX: + phydev->speed = SPEED_100; + phydev->duplex = DUPLEX_HALF; + break; + default: + phydev->speed = SPEED_100; + phydev->duplex = DUPLEX_FULL; + } + + return 0; +} + +static int lxt971_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + lxt971_parse_status(phydev); + + return 0; +} + +static struct phy_driver LXT971_driver = { + .name = "LXT971", + .uid = 0x1378e0, + .mask = 0xfffff0, + .features = PHY_BASIC_FEATURES, + .config = &genphy_config, + .startup = &lxt971_startup, + .shutdown = &genphy_shutdown, +}; + +int lxt_init(void) +{ + phy_register(&LXT971_driver); + + return 0; +} diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c new file mode 100644 index 0000000..6937c93 --- /dev/null +++ b/drivers/net/phy/marvell.c @@ -0,0 +1,357 @@ +/* + * Marvell PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <config.h> +#include <common.h> +#include <phy.h> + +#define PHY_AUTONEGOTIATE_TIMEOUT 5000 + +/* 88E1011 PHY Status Register */ +#define MIIM_88E1011_PHY_STATUS 0x11 +#define MIIM_88E1011_PHYSTAT_SPEED 0xc000 +#define MIIM_88E1011_PHYSTAT_GBIT 0x8000 +#define MIIM_88E1011_PHYSTAT_100 0x4000 +#define MIIM_88E1011_PHYSTAT_DUPLEX 0x2000 +#define MIIM_88E1011_PHYSTAT_SPDDONE 0x0800 +#define MIIM_88E1011_PHYSTAT_LINK 0x0400 + +#define MIIM_88E1011_PHY_SCR 0x10 +#define MIIM_88E1011_PHY_MDI_X_AUTO 0x0060 + +/* 88E1111 PHY LED Control Register */ +#define MIIM_88E1111_PHY_LED_CONTROL 24 +#define MIIM_88E1111_PHY_LED_DIRECT 0x4100 +#define MIIM_88E1111_PHY_LED_COMBINE 0x411C + +/* 88E1121 PHY LED Control Register */ +#define MIIM_88E1121_PHY_LED_CTRL 16 +#define MIIM_88E1121_PHY_LED_PAGE 3 +#define MIIM_88E1121_PHY_LED_DEF 0x0030 + +/* 88E1121 PHY IRQ Enable/Status Register */ +#define MIIM_88E1121_PHY_IRQ_EN 18 +#define MIIM_88E1121_PHY_IRQ_STATUS 19 + +#define MIIM_88E1121_PHY_PAGE 22 + +/* 88E1145 Extended PHY Specific Control Register */ +#define MIIM_88E1145_PHY_EXT_CR 20 +#define MIIM_M88E1145_RGMII_RX_DELAY 0x0080 +#define MIIM_M88E1145_RGMII_TX_DELAY 0x0002 + +#define MIIM_88E1145_PHY_PAGE 29 +#define MIIM_88E1145_PHY_CAL_OV 30 + +/* Marvell 88E1011S */ +static int m88e1011s_config(struct phy_device *phydev) +{ + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x200c); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + genphy_config_aneg(phydev); + + return 0; +} + +/* Parse the 88E1011's status register for speed and duplex + * information + */ +static uint m88e1011s_parse_status(struct phy_device *phydev) +{ + unsigned int speed; + unsigned int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1011_PHY_STATUS); + + if ((mii_reg & MIIM_88E1011_PHYSTAT_LINK) && + !(mii_reg & MIIM_88E1011_PHYSTAT_SPDDONE)) { + int i = 0; + + puts("Waiting for PHY realtime link"); + while (!(mii_reg & MIIM_88E1011_PHYSTAT_SPDDONE)) { + /* Timeout reached ? */ + if (i > PHY_AUTONEGOTIATE_TIMEOUT) { + puts(" TIMEOUT !\n"); + phydev->link = 0; + break; + } + + if ((i++ % 1000) == 0) { + putc('.'); + } + udelay(1000); + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, + MIIM_88E1011_PHY_STATUS); + } + puts(" done\n"); + udelay(500000); /* another 500 ms (results in faster booting) */ + } else { + if (mii_reg & MIIM_88E1011_PHYSTAT_LINK) + phydev->link = 1; + else + phydev->link = 0; + } + + if (mii_reg & MIIM_88E1011_PHYSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = mii_reg & MIIM_88E1011_PHYSTAT_SPEED; + + switch (speed) { + case MIIM_88E1011_PHYSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_88E1011_PHYSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + break; + } + + return 0; +} + +static int m88e1011s_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + m88e1011s_parse_status(phydev); + + return 0; +} + +/* Marvell 88E1111S */ +static int m88e1111s_config(struct phy_device *phydev) +{ + int reg; + + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + if ((phydev->interface == PHY_INTERFACE_MODE_RGMII) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) { + reg = phy_read(phydev, MDIO_DEVAD_NONE, 0x1b); + reg = (reg & 0xfff0) | 0xb; + phy_write(phydev, MDIO_DEVAD_NONE, 0x1b, reg); + } else { + phy_write(phydev, MDIO_DEVAD_NONE, 0x1b, 0x1f); + } + + phy_write(phydev, MDIO_DEVAD_NONE, 0x14, 0x0cd2); + + genphy_config_aneg(phydev); + + return 0; +} + +/* Marvell 88E1118 */ +static int m88e1118_config(struct phy_device *phydev) +{ + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + /* Change Page Number */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0002); + /* Delay RGMII TX and RX */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x15, 0x1070); + /* Change Page Number */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0003); + /* Adjust LED control */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x10, 0x021e); + /* Change Page Number */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0000); + + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + genphy_config_aneg(phydev); + + return 0; +} + +static int m88e1118_startup(struct phy_device *phydev) +{ + /* Change Page Number */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0000); + + genphy_update_link(phydev); + m88e1011s_parse_status(phydev); + + return 0; +} + +/* Marvell 88E1121R */ +static int m88e1121_config(struct phy_device *phydev) +{ + int pg; + + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + genphy_config_aneg(phydev); + + /* Switch the page to access the led register */ + pg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE, + MIIM_88E1121_PHY_LED_PAGE); + /* Configure leds */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_LED_CTRL, + MIIM_88E1121_PHY_LED_DEF); + /* Restore the page pointer */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE, pg); + + /* Disable IRQs and de-assert interrupt */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_IRQ_EN, 0); + phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_IRQ_STATUS); + + return 0; +} + +/* Marvell 88E1145 */ +static int m88e1145_config(struct phy_device *phydev) +{ + int reg; + + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + /* Errata E0, E1 */ + phy_write(phydev, MDIO_DEVAD_NONE, 29, 0x001b); + phy_write(phydev, MDIO_DEVAD_NONE, 30, 0x418f); + phy_write(phydev, MDIO_DEVAD_NONE, 29, 0x0016); + phy_write(phydev, MDIO_DEVAD_NONE, 30, 0xa2da); + + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1011_PHY_SCR, + MIIM_88E1011_PHY_MDI_X_AUTO); + + reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1145_PHY_EXT_CR); + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + reg |= MIIM_M88E1145_RGMII_RX_DELAY | + MIIM_M88E1145_RGMII_TX_DELAY; + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1145_PHY_EXT_CR, reg); + + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + genphy_config_aneg(phydev); + + return 0; +} + +static int m88e1145_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1111_PHY_LED_CONTROL, + MIIM_88E1111_PHY_LED_DIRECT); + m88e1011s_parse_status(phydev); + + return 0; +} + +/* Marvell 88E1149S */ +static int m88e1149_config(struct phy_device *phydev) +{ + /* Reset and configure the PHY */ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x200c); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x0); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + genphy_config_aneg(phydev); + + return 0; +} + + +static struct phy_driver M88E1011S_driver = { + .name = "Marvell 88E1011S", + .uid = 0x1410c60, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1011s_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver M88E1111S_driver = { + .name = "Marvell 88E1111S", + .uid = 0x1410cc0, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1111s_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver M88E1118_driver = { + .name = "Marvell 88E1118", + .uid = 0x1410e10, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1118_config, + .startup = &m88e1118_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver M88E1121R_driver = { + .name = "Marvell 88E1121R", + .uid = 0x1410cb0, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1121_config, + .startup = &genphy_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver M88E1145_driver = { + .name = "Marvell 88E1145", + .uid = 0x1410cd0, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1145_config, + .startup = &m88e1145_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver M88E1149S_driver = { + .name = "Marvell 88E1149S", + .uid = 0x1410ca0, + .mask = 0xffffff0, + .features = PHY_GBIT_FEATURES, + .config = &m88e1149_config, + .startup = &m88e1011s_startup, + .shutdown = &genphy_shutdown, +}; + +int marvell_init(void) +{ + phy_register(&M88E1149S_driver); + phy_register(&M88E1145_driver); + phy_register(&M88E1121R_driver); + phy_register(&M88E1118_driver); + phy_register(&M88E1111S_driver); + phy_register(&M88E1011S_driver); + + return 0; +} diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c new file mode 100644 index 0000000..4e0389a --- /dev/null +++ b/drivers/net/phy/micrel.c @@ -0,0 +1,29 @@ +/* + * Micrel PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +static struct phy_driver KSZ804_driver = { + .name = "Micrel KSZ804", + .uid = 0x221510, + .mask = 0xfffff0, + .features = PHY_BASIC_FEATURES, + .config = &genphy_config, + .startup = &genphy_startup, + .shutdown = &genphy_shutdown, +}; + +int micrel_init(void) +{ + phy_register(&KSZ804_driver); + + return 0; +} diff --git a/drivers/net/phy/natsemi.c b/drivers/net/phy/natsemi.c new file mode 100644 index 0000000..a669eac --- /dev/null +++ b/drivers/net/phy/natsemi.c @@ -0,0 +1,85 @@ +/* + * National Semiconductor PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +/* DP83865 Link and Auto-Neg Status Register */ +#define MIIM_DP83865_LANR 0x11 +#define MIIM_DP83865_SPD_MASK 0x0018 +#define MIIM_DP83865_SPD_1000 0x0010 +#define MIIM_DP83865_SPD_100 0x0008 +#define MIIM_DP83865_DPX_FULL 0x0002 + + +/* NatSemi DP83865 */ +static int dp83865_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + genphy_config_aneg(phydev); + + return 0; +} + +static int dp83865_parse_status(struct phy_device *phydev) +{ + int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_DP83865_LANR); + + switch (mii_reg & MIIM_DP83865_SPD_MASK) { + + case MIIM_DP83865_SPD_1000: + phydev->speed = SPEED_1000; + break; + + case MIIM_DP83865_SPD_100: + phydev->speed = SPEED_100; + break; + + default: + phydev->speed = SPEED_10; + break; + + } + + if (mii_reg & MIIM_DP83865_DPX_FULL) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + return 0; +} + +static int dp83865_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + dp83865_parse_status(phydev); + + return 0; +} + + +static struct phy_driver DP83865_driver = { + .name = "NatSemi DP83865", + .uid = 0x20005c70, + .mask = 0xfffffff0, + .features = PHY_GBIT_FEATURES, + .config = &dp83865_config, + .startup = &dp83865_startup, + .shutdown = &genphy_shutdown, +}; + +int natsemi_init(void) +{ + phy_register(&DP83865_driver); + + return 0; +} diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index ca35404..50e85fe 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -494,6 +494,34 @@ int phy_init(void) { INIT_LIST_HEAD(&phy_drivers);
+#ifdef CONFIG_PHY_BROADCOM + broadcom_init(); +#endif +#ifdef CONFIG_PHY_DAVICOM + davicom_init(); +#endif +#ifdef CONFIG_PHY_LXT + lxt_init(); +#endif +#ifdef CONFIG_PHY_MARVELL + marvell_init(); +#endif +#ifdef CONFIG_PHY_MICREL + micrel_init(); +#endif +#ifdef CONFIG_PHY_NATSEMI + natsemi_init(); +#endif +#ifdef CONFIG_PHY_REALTEK + realtek_init(); +#endif +#ifdef CONFIG_PHY_VITESSE + vitesse_init(); +#endif +#ifdef CONFIG_PHY_ATHEROS + atheros_init(); +#endif + return 0; }
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c new file mode 100644 index 0000000..8cb696f --- /dev/null +++ b/drivers/net/phy/realtek.c @@ -0,0 +1,120 @@ +/* + * RealTek PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <config.h> +#include <common.h> +#include <phy.h> + +#define PHY_AUTONEGOTIATE_TIMEOUT 5000 + +/* RTL8211B PHY Status Register */ +#define MIIM_RTL8211B_PHY_STATUS 0x11 +#define MIIM_RTL8211B_PHYSTAT_SPEED 0xc000 +#define MIIM_RTL8211B_PHYSTAT_GBIT 0x8000 +#define MIIM_RTL8211B_PHYSTAT_100 0x4000 +#define MIIM_RTL8211B_PHYSTAT_DUPLEX 0x2000 +#define MIIM_RTL8211B_PHYSTAT_SPDDONE 0x0800 +#define MIIM_RTL8211B_PHYSTAT_LINK 0x0400 + + +/* RealTek RTL8211B */ +static int rtl8211b_config(struct phy_device *phydev) +{ + phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET); + + genphy_config_aneg(phydev); + + return 0; +} + +static int rtl8211b_parse_status(struct phy_device *phydev) +{ + unsigned int speed; + unsigned int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211B_PHY_STATUS); + + if (!(mii_reg & MIIM_RTL8211B_PHYSTAT_SPDDONE)) { + int i = 0; + + /* in case of timeout ->link is cleared */ + phydev->link = 1; + puts("Waiting for PHY realtime link"); + while (!(mii_reg & MIIM_RTL8211B_PHYSTAT_SPDDONE)) { + /* Timeout reached ? */ + if (i > PHY_AUTONEGOTIATE_TIMEOUT) { + puts(" TIMEOUT !\n"); + phydev->link = 0; + break; + } + + if ((i++ % 1000) == 0) { + putc('.'); + } + udelay(1000); /* 1 ms */ + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, + MIIM_RTL8211B_PHY_STATUS); + } + puts(" done\n"); + udelay(500000); /* another 500 ms (results in faster booting) */ + } else { + if (mii_reg & MIIM_RTL8211B_PHYSTAT_LINK) + phydev->link = 1; + else + phydev->link = 0; + } + + if (mii_reg & MIIM_RTL8211B_PHYSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = (mii_reg & MIIM_RTL8211B_PHYSTAT_SPEED); + + switch (speed) { + case MIIM_RTL8211B_PHYSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_RTL8211B_PHYSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + } + + return 0; +} + +static int rtl8211b_startup(struct phy_device *phydev) +{ + /* Read the Status (2x to make sure link is right) */ + genphy_update_link(phydev); + rtl8211b_parse_status(phydev); + + return 0; +} + +static struct phy_driver RTL8211B_driver = { + .name = "RealTek RTL8211B", + .uid = 0x1cc910, + .mask = 0xfffff0, + .features = PHY_GBIT_FEATURES, + .config = &rtl8211b_config, + .startup = &rtl8211b_startup, + .shutdown = &genphy_shutdown, +}; + +int realtek_init(void) +{ + phy_register(&RTL8211B_driver); + + return 0; +} diff --git a/drivers/net/phy/teranetics.c b/drivers/net/phy/teranetics.c new file mode 100644 index 0000000..387e044 --- /dev/null +++ b/drivers/net/phy/teranetics.c @@ -0,0 +1,43 @@ +/* + * Teranetics PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <phy.h> + +int tn2020_config(struct phy_device *phydev) +{ + if (phydev->port == PORT_FIBRE) { + phy_write(phydev, 30, 93, 2); + phy_write(phydev, 7, 0, 0x3200); + } + + phydev->mmds = (MDIO_DEVS_PMAPMD | MDIO_DEVS_PCS | + MDIO_DEVS_PHYXS | MDIO_DEVS_AN | + MDIO_DEVS_VEND1 | MDIO_DEVS_VEND2); + + return 0; +} + +struct phy_driver tn2020_driver = { + .name = "Teranetics TN2020", + .uid = 0x00a19410, + .mask = 0xfffffff0, + .features = PHY_10G_FEATURES, + .config = &tn2020_config, + .startup = &gen10g_startup, + .shutdown = &gen10g_shutdown, +}; + +int teranetics_init(void) +{ + phy_register(&tn2020_driver); + + return 0; +} diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c new file mode 100644 index 0000000..d34f04b --- /dev/null +++ b/drivers/net/phy/vitesse.c @@ -0,0 +1,330 @@ +/* + * Vitesse PHY drivers + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2010-2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#include <miiphy.h> + +/* Cicada Auxiliary Control/Status Register */ +#define MIIM_CIS8201_AUX_CONSTAT 0x1c +#define MIIM_CIS8201_AUXCONSTAT_INIT 0x0004 +#define MIIM_CIS8201_AUXCONSTAT_DUPLEX 0x0020 +#define MIIM_CIS8201_AUXCONSTAT_SPEED 0x0018 +#define MIIM_CIS8201_AUXCONSTAT_GBIT 0x0010 +#define MIIM_CIS8201_AUXCONSTAT_100 0x0008 + +/* Cicada Extended Control Register 1 */ +#define MIIM_CIS8201_EXT_CON1 0x17 +#define MIIM_CIS8201_EXTCON1_INIT 0x0000 + +/* Cicada 8204 Extended PHY Control Register 1 */ +#define MIIM_CIS8204_EPHY_CON 0x17 +#define MIIM_CIS8204_EPHYCON_INIT 0x0006 +#define MIIM_CIS8204_EPHYCON_RGMII 0x1100 + +/* Cicada 8204 Serial LED Control Register */ +#define MIIM_CIS8204_SLED_CON 0x1b +#define MIIM_CIS8204_SLEDCON_INIT 0x1115 + +/* Entry for Vitesse VSC8244 regs starts here */ +/* Vitesse VSC8244 Auxiliary Control/Status Register */ +#define MIIM_VSC8244_AUX_CONSTAT 0x1c +#define MIIM_VSC8244_AUXCONSTAT_INIT 0x0000 +#define MIIM_VSC8244_AUXCONSTAT_DUPLEX 0x0020 +#define MIIM_VSC8244_AUXCONSTAT_SPEED 0x0018 +#define MIIM_VSC8244_AUXCONSTAT_GBIT 0x0010 +#define MIIM_VSC8244_AUXCONSTAT_100 0x0008 +#define MIIM_CONTROL_INIT_LOOPBACK 0x4000 + +/* Vitesse VSC8601 Extended PHY Control Register 1 */ +#define MIIM_VSC8601_EPHY_CON 0x17 +#define MIIM_VSC8601_EPHY_CON_INIT_SKEW 0x1120 +#define MIIM_VSC8601_SKEW_CTRL 0x1c + +#define PHY_EXT_PAGE_ACCESS 0x1f + +/* CIS8201 */ +static int cis8201_config(struct phy_device *phydev) +{ + /* Override PHY config settings */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT, + MIIM_CIS8201_AUXCONSTAT_INIT); + /* Set up the interface mode */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_EXT_CON1, + MIIM_CIS8201_EXTCON1_INIT); + + genphy_config_aneg(phydev); + + return 0; +} + +static int cis8201_parse_status(struct phy_device *phydev) +{ + int speed; + int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT); + + if (mii_reg & MIIM_CIS8201_AUXCONSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = mii_reg & MIIM_CIS8201_AUXCONSTAT_SPEED; + switch (speed) { + case MIIM_CIS8201_AUXCONSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_CIS8201_AUXCONSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + break; + } + + return 0; +} + +static int cis8201_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + cis8201_parse_status(phydev); + + return 0; +} + +static int cis8204_config(struct phy_device *phydev) +{ + /* Override PHY config settings */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT, + MIIM_CIS8201_AUXCONSTAT_INIT); + + genphy_config_aneg(phydev); + + if ((phydev->interface == PHY_INTERFACE_MODE_RGMII) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) || + (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8204_EPHY_CON, + MIIM_CIS8204_EPHYCON_INIT | + MIIM_CIS8204_EPHYCON_RGMII); + else + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8204_EPHY_CON, + MIIM_CIS8204_EPHYCON_INIT); + + return 0; +} + +/* Vitesse VSC8211 */ +static int vsc8211_config(struct phy_device *phydev) +{ + /* Override PHY config settings */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT, + MIIM_CIS8201_AUXCONSTAT_INIT); + /* Set up the interface mode */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_EXT_CON1, + MIIM_CIS8201_EXTCON1_INIT); + + genphy_config_aneg(phydev); + + return 0; +} + +static int vsc8211_parse_status(struct phy_device *phydev) +{ + unsigned int speed; + unsigned int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT); + + if (mii_reg & MIIM_CIS8201_AUXCONSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = mii_reg & MIIM_CIS8201_AUXCONSTAT_SPEED; + switch (speed) { + case MIIM_CIS8201_AUXCONSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_CIS8201_AUXCONSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + break; + } + + return 0; +} + +static int vsc8211_startup(struct phy_device *phydev) +{ + /* Read the Status (2x to make sure link is right) */ + genphy_update_link(phydev); + vsc8211_parse_status(phydev); + + return 0; +} + +/* Vitesse VSC8244 */ +static int vsc8244_parse_status(struct phy_device *phydev) +{ + unsigned int speed; + unsigned int mii_reg; + + mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_VSC8244_AUX_CONSTAT); + + if (mii_reg & MIIM_VSC8244_AUXCONSTAT_DUPLEX) + phydev->duplex = DUPLEX_FULL; + else + phydev->duplex = DUPLEX_HALF; + + speed = mii_reg & MIIM_VSC8244_AUXCONSTAT_SPEED; + switch (speed) { + case MIIM_VSC8244_AUXCONSTAT_GBIT: + phydev->speed = SPEED_1000; + break; + case MIIM_VSC8244_AUXCONSTAT_100: + phydev->speed = SPEED_100; + break; + default: + phydev->speed = SPEED_10; + break; + } + + return 0; +} + +static int vsc8244_startup(struct phy_device *phydev) +{ + /* Read the Status (2x to make sure link is right) */ + genphy_update_link(phydev); + vsc8244_parse_status(phydev); + + return 0; +} + +/* Vitesse VSC8601 */ +int vsc8601_config(struct phy_device *phydev) +{ + /* Configure some basic stuff */ +#ifdef CONFIG_SYS_VSC8601_SKEWFIX + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8601_EPHY_CON, + MIIM_VSC8601_EPHY_CON_INIT_SKEW); +#if defined(CONFIG_SYS_VSC8601_SKEW_TX) && defined(CONFIG_SYS_VSC8601_SKEW_RX) + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, 1); +#define VSC8101_SKEW \ + (CONFIG_SYS_VSC8601_SKEW_TX << 14) | (CONFIG_SYS_VSC8601_SKEW_RX << 12) + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_VSC8601_SKEW_CTRL, + VSC8101_SKEW); + phy_write(phydev, MDIO_DEVAD_NONE, PHY_EXT_PAGE_ACCESS, 0); +#endif +#endif + + genphy_config_aneg(phydev); + + return 0; +} + +static struct phy_driver VSC8211_driver = { + .name = "Vitesse VSC8211", + .uid = 0xfc4b0, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8211_config, + .startup = &vsc8211_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver VSC8221_driver = { + .name = "Vitesse VSC8221", + .uid = 0xfc550, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &genphy_config, + .startup = &vsc8244_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver VSC8244_driver = { + .name = "Vitesse VSC8244", + .uid = 0xfc6c0, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &genphy_config, + .startup = &vsc8244_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver VSC8234_driver = { + .name = "Vitesse VSC8234", + .uid = 0xfc620, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &genphy_config, + .startup = &vsc8244_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver VSC8601_driver = { + .name = "Vitesse VSC8601", + .uid = 0x70420, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &vsc8601_config, + .startup = &vsc8244_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver VSC8641_driver = { + .name = "Vitesse VSC8641", + .uid = 0x70430, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &genphy_config, + .startup = &vsc8244_startup, + .shutdown = &genphy_shutdown, +}; + +/* Vitesse bought Cicada, so we'll put these here */ +static struct phy_driver cis8201_driver = { + .name = "CIS8201", + .uid = 0xfc410, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &cis8201_config, + .startup = &cis8201_startup, + .shutdown = &genphy_shutdown, +}; + +static struct phy_driver cis8204_driver = { + .name = "Cicada Cis8204", + .uid = 0xfc440, + .mask = 0xffff0, + .features = PHY_GBIT_FEATURES, + .config = &cis8204_config, + .startup = &cis8201_startup, + .shutdown = &genphy_shutdown, +}; + +int vitesse_init(void) +{ + phy_register(&VSC8641_driver); + phy_register(&VSC8601_driver); + phy_register(&VSC8234_driver); + phy_register(&VSC8244_driver); + phy_register(&VSC8211_driver); + phy_register(&VSC8221_driver); + phy_register(&cis8201_driver); + phy_register(&cis8204_driver); + + return 0; +} diff --git a/include/phy.h b/include/phy.h index fccf1f7..54b5663 100644 --- a/include/phy.h +++ b/include/phy.h @@ -484,4 +484,15 @@ int genphy_shutdown(struct phy_device *phydev); int gen10g_config(struct phy_device *phydev); int gen10g_startup(struct phy_device *phydev); int gen10g_shutdown(struct phy_device *phydev); + +int teranetics_init(void); +int vitesse_init(void); +int marvell_init(void); +int davicom_init(void); +int realtek_init(void); +int micrel_init(void); +int natsemi_init(void); +int broadcom_init(void); +int lxt_init(void); +int atheros_init(void); #endif diff --git a/include/phylib_all_drivers.h b/include/phylib_all_drivers.h new file mode 100644 index 0000000..a73b3d7 --- /dev/null +++ b/include/phylib_all_drivers.h @@ -0,0 +1,25 @@ +/* + * Enable all PHYs + * + * This software may be used and distributed according to the + * terms of the GNU Public License, Version 2, incorporated + * herein by reference. + * + * Copyright 2011 Freescale Semiconductor, Inc. + * author Andy Fleming + * + */ +#ifndef _CONFIG_PHYLIB_ALL_H +#define _CONFIG_PHYLIB_ALL_H + +#define CONFIG_PHY_VITESSE +#define CONFIG_PHY_MARVELL +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_BROADCOM +#define CONFIG_PHY_DAVICOM +#define CONFIG_PHY_REALTEK +#define CONFIG_PHY_NATSEMI +#define CONFIG_PHY_TERANETICS +#define CONFIG_PHY_LXT + +#endif
This converts tsec to use the new PHY Lib. All of the old PHY support is ripped out. The old MDIO driver is split off, and placed in fsl_mdio.c. The initialization is modified to initialize the MDIO driver as well. The powerpc config file is modified to configure PHYLIB if TSEC_ENET is configured.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Signed-off-by: Andy Fleming afleming@freescale.com --- arch/powerpc/include/asm/config.h | 7 + arch/powerpc/include/asm/fsl_enet.h | 10 + board/freescale/mpc837xemds/mpc837xemds.c | 7 + board/freescale/mpc8536ds/mpc8536ds.c | 6 + board/freescale/mpc8544ds/mpc8544ds.c | 30 + board/freescale/mpc8572ds/mpc8572ds.c | 6 + board/freescale/p1022ds/p1022ds.c | 6 + board/freescale/p1_p2_rdb/p1_p2_rdb.c | 6 + board/freescale/p2020ds/p2020ds.c | 7 + drivers/net/Makefile | 2 +- drivers/net/fsl_mdio.c | 117 +++ drivers/net/tsec.c | 1581 ++--------------------------- include/fsl_mdio.h | 62 ++ include/tsec.h | 298 +----- 14 files changed, 386 insertions(+), 1759 deletions(-) create mode 100644 drivers/net/fsl_mdio.c create mode 100644 include/fsl_mdio.h
diff --git a/arch/powerpc/include/asm/config.h b/arch/powerpc/include/asm/config.h index 2b6b233..d2e8c9d 100644 --- a/arch/powerpc/include/asm/config.h +++ b/arch/powerpc/include/asm/config.h @@ -78,6 +78,13 @@ #define CONFIG_FSL_LBC #endif
+/* The TSEC driver uses the PHYLIB infrastructure */ +#if defined(CONFIG_TSEC_ENET) || defined(CONFIG_FMAN_ENET) +#define CONFIG_PHYLIB + +#include <phylib_all_drivers.h> +#endif /* PHYLIB-supporting ethernets */ + /* All PPC boards must swap IDE bytes */ #define CONFIG_IDE_SWAP_IO
diff --git a/arch/powerpc/include/asm/fsl_enet.h b/arch/powerpc/include/asm/fsl_enet.h index 4fb2857..9475249 100644 --- a/arch/powerpc/include/asm/fsl_enet.h +++ b/arch/powerpc/include/asm/fsl_enet.h @@ -28,6 +28,16 @@ enum fsl_phy_enet_if { FSL_ETH_IF_NONE, };
+typedef struct tsec_mii_mng { + u32 miimcfg; /* MII management configuration reg */ + u32 miimcom; /* MII management command reg */ + u32 miimadd; /* MII management address reg */ + u32 miimcon; /* MII management control reg */ + u32 miimstat; /* MII management status reg */ + u32 miimind; /* MII management indication reg */ + u32 ifstat; /* Interface Status Register */ +} __attribute__ ((packed))tsec_mii_t; + int fdt_fixup_phy_connection(void *blob, int offset, enum fsl_phy_enet_if phyc);
#endif /* __ASM_PPC_FSL_ENET_H */ diff --git a/board/freescale/mpc837xemds/mpc837xemds.c b/board/freescale/mpc837xemds/mpc837xemds.c index 51dd692..1139cd8 100644 --- a/board/freescale/mpc837xemds/mpc837xemds.c +++ b/board/freescale/mpc837xemds/mpc837xemds.c @@ -21,6 +21,7 @@ #include <libfdt.h> #include <fdt_support.h> #include <fsl_esdhc.h> +#include <fsl_mdio.h> #include "pci.h" #include "../common/pq-mds-pib.h"
@@ -86,6 +87,7 @@ int board_mmc_init(bd_t *bd) #if defined(CONFIG_TSEC1) || defined(CONFIG_TSEC2) int board_eth_init(bd_t *bd) { + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[2]; struct immap __iomem *im = (struct immap __iomem *)CONFIG_SYS_IMMR; u32 rcwh = in_be32(&im->reset.rcwh); @@ -131,6 +133,11 @@ int board_eth_init(bd_t *bd) } num++; #endif + + mdio_info.regs = (tsec_mii_t *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + fsl_pq_mdio_init(bd, &mdio_info); + return tsec_eth_init(bd, tsec_info, num); }
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index f83f629..da4912f 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -36,6 +36,7 @@ #include <libfdt.h> #include <spd_sdram.h> #include <fdt_support.h> +#include <fsl_mdio.h> #include <tsec.h> #include <netdev.h> #include <sata.h> @@ -234,6 +235,7 @@ int board_early_init_r(void) int board_eth_init(bd_t *bis) { #ifdef CONFIG_TSEC_ENET + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[2]; int num = 0;
@@ -268,6 +270,10 @@ int board_eth_init(bd_t *bis) } #endif
+ mdio_info.regs = (tsec_mii_t *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + fsl_pq_mdio_init(bis, &mdio_info); + tsec_eth_init(bis, tsec_info, num); #endif return pci_eth_init(bis); diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index a48c815..e46ab9a 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -33,6 +33,7 @@ #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> +#include <fsl_mdio.h> #include <tsec.h> #include <netdev.h>
@@ -248,9 +249,35 @@ get_board_sys_clk(ulong dummy) return val; }
+ +#define MIIM_CIS8204_SLED_CON 0x1b +#define MIIM_CIS8204_SLEDCON_INIT 0x1115 +/* + * Hack to write all 4 PHYs with the LED values + */ +int board_phy_config(struct phy_device *phydev) +{ + static int do_once = 0; + uint phyid; + struct mii_dev *bus = phydev->bus; + + if (do_once) + return 0; + + for (phyid = 0; phyid < 4; phyid++) + bus->write(bus, phyid, MDIO_DEVAD_NONE, MIIM_CIS8204_SLED_CON, + MIIM_CIS8204_SLEDCON_INIT); + + do_once = 1; + + return 0; +} + + int board_eth_init(bd_t *bis) { #ifdef CONFIG_TSEC_ENET + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[2]; int num = 0;
@@ -282,6 +309,9 @@ int board_eth_init(bd_t *bis) fsl_sgmii_riser_init(tsec_info, num); }
tsec_eth_init(bis, tsec_info, num); #endif diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 4b2ef4e..f64264a 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -35,6 +35,7 @@ #include <libfdt.h> #include <fdt_support.h> #include <tsec.h> +#include <fsl_mdio.h> #include <netdev.h>
#include "../common/sgmii_riser.h" @@ -187,6 +188,7 @@ int board_early_init_r(void) #ifdef CONFIG_TSEC_ENET int board_eth_init(bd_t *bis) { + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[4]; int num = 0;
@@ -233,6 +235,10 @@ int board_eth_init(bd_t *bis) fsl_sgmii_riser_init(tsec_info, num); #endif
return pci_eth_init(bis); diff --git a/board/freescale/p1022ds/p1022ds.c b/board/freescale/p1022ds/p1022ds.c index 0ea0bdf..74f6fec 100644 --- a/board/freescale/p1022ds/p1022ds.c +++ b/board/freescale/p1022ds/p1022ds.c @@ -22,6 +22,7 @@ #include <asm/io.h> #include <libfdt.h> #include <fdt_support.h> +#include <fsl_mdio.h> #include <tsec.h> #include <asm/fsl_law.h> #include <asm/mp.h> @@ -243,6 +244,7 @@ int board_early_init_r(void) */ int board_eth_init(bd_t *bis) { + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[2]; unsigned int num = 0;
@@ -255,6 +257,10 @@ int board_eth_init(bd_t *bis) num++; #endif
+ mdio_info.regs = (tsec_mii_t *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + fsl_pq_mdio_init(bis, &mdio_info); + return tsec_eth_init(bis, tsec_info, num) + pci_eth_init(bis); }
diff --git a/board/freescale/p1_p2_rdb/p1_p2_rdb.c b/board/freescale/p1_p2_rdb/p1_p2_rdb.c index 0780942..c8e5231 100644 --- a/board/freescale/p1_p2_rdb/p1_p2_rdb.c +++ b/board/freescale/p1_p2_rdb/p1_p2_rdb.c @@ -31,6 +31,7 @@ #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> +#include <fsl_mdio.h> #include <tsec.h> #include <vsc7385.h> #include <netdev.h> @@ -166,6 +167,7 @@ int board_early_init_r(void) #ifdef CONFIG_TSEC_ENET int board_eth_init(bd_t *bis) { + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[4]; int num = 0; char *tmp; @@ -203,6 +205,10 @@ int board_eth_init(bd_t *bis) puts("No address specified for VSC7385 microcode.\n"); #endif
return pci_eth_init(bis); diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index 8546aa9..9eed028 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -34,6 +34,7 @@ #include <miiphy.h> #include <libfdt.h> #include <fdt_support.h> +#include <fsl_mdio.h> #include <tsec.h> #include <asm/fsl_law.h> #include <asm/mp.h> @@ -189,6 +190,7 @@ int board_early_init_r(void) #ifdef CONFIG_TSEC_ENET int board_eth_init(bd_t *bis) { + struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[4]; int num = 0;
@@ -223,6 +225,11 @@ int board_eth_init(bd_t *bis) fsl_sgmii_riser_init(tsec_info, num); #endif
+ mdio_info.regs = (tsec_mii_t *)CONFIG_SYS_MDIO_BASE_ADDR; + mdio_info.name = DEFAULT_MII_NAME; + + fsl_pq_mdio_init(bis, &mdio_info); + tsec_eth_init(bis, tsec_info, num);
return pci_eth_init(bis); diff --git a/drivers/net/Makefile b/drivers/net/Makefile index fd9d0b4..819b197 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -79,7 +79,7 @@ COBJS-$(CONFIG_TIGON3) += tigon3.o COBJS-$(CONFIG_TIGON3) += bcm570x_autoneg.o COBJS-$(CONFIG_TIGON3) += 5701rls.o COBJS-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o -COBJS-$(CONFIG_TSEC_ENET) += tsec.o +COBJS-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o COBJS-$(CONFIG_TSI108_ETH) += tsi108_eth.o COBJS-$(CONFIG_ULI526X) += uli526x.o COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c new file mode 100644 index 0000000..3239171 --- /dev/null +++ b/drivers/net/fsl_mdio.c @@ -0,0 +1,117 @@ +/* + * Copyright 2009-2010 Freescale Semiconductor, Inc. + * Jun-jie Zhang b18070@freescale.com + * Mingkai Hu Mingkai.hu@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <miiphy.h> +#include <phy.h> +#include <fsl_mdio.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/fsl_enet.h> + +void tsec_local_mdio_write(tsec_mii_t *phyregs, int port_addr, + int dev_addr, int regnum, int value) +{ + int timeout = 1000000; + + out_be32(&phyregs->miimadd, (port_addr << 8) | (regnum & 0x1f)); + out_be32(&phyregs->miimcon, value); + asm("sync"); + + while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--); +} + +int tsec_local_mdio_read(tsec_mii_t *phyregs, int port_addr, + int dev_addr, int regnum) +{ + int value; + int timeout = 1000000; + + /* Put the address of the phy, and the register + * number into MIIMADD */ + out_be32(&phyregs->miimadd, (port_addr << 8) | (regnum & 0x1f)); + + /* Clear the command register, and wait */ + out_be32(&phyregs->miimcom, 0); + asm("sync"); + + /* Initiate a read command, and wait */ + out_be32(&phyregs->miimcom, MIIMCOM_READ_CYCLE); + asm("sync"); + + /* Wait for the the indication that the read is done */ + while ((in_be32(&phyregs->miimind) & (MIIMIND_NOTVALID | MIIMIND_BUSY)) + && timeout--); + + /* Grab the value read from the PHY */ + value = in_be32(&phyregs->miimstat); + + return value; +} + +static int fsl_pq_mdio_reset(struct mii_dev *bus) +{ + tsec_mii_t *regs = bus->priv; + + /* Reset MII (due to new addresses) */ + out_be32(®s->miimcfg, MIIMCFG_RESET_MGMT); + + out_be32(®s->miimcfg, MIIMCFG_INIT_VALUE); + + while (in_be32(®s->miimind) & MIIMIND_BUSY) ; + + return 0; +} + +int tsec_phy_read(struct mii_dev *bus, int addr, int dev_addr, int regnum) +{ + tsec_mii_t *phyregs = bus->priv; + + return tsec_local_mdio_read(phyregs, addr, dev_addr, regnum); +} + +int tsec_phy_write(struct mii_dev *bus, int addr, int dev_addr, int regnum, + u16 value) +{ + tsec_mii_t *phyregs = bus->priv; + + tsec_local_mdio_write(phyregs, addr, dev_addr, regnum, value); + + return 0; +} + +int fsl_pq_mdio_init(bd_t *bis, struct fsl_pq_mdio_info *info) +{ + struct mii_dev *bus = mdio_alloc(); + + if (!bus) { + printf("Failed to allocate FSL MDIO bus\n"); + return -1; + } + + bus->read = tsec_phy_read; + bus->write = tsec_phy_write; + bus->reset = fsl_pq_mdio_reset; + sprintf(bus->name, info->name); + + bus->priv = info->regs; + + return mdio_register(bus); +} diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index f563d34..1fb407a 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -17,10 +17,9 @@ #include <net.h> #include <command.h> #include <tsec.h> +#include <fsl_mdio.h> #include <asm/errno.h>
-#include "miiphy.h" - DECLARE_GLOBAL_DATA_PTR;
#define TX_BUF_CNT 2 @@ -56,10 +55,10 @@ static struct tsec_info_struct tsec_info[] = { #ifdef CONFIG_MPC85XX_FEC { .regs = (tsec_t *)(TSEC_BASE_ADDR + 0x2000), - .miiregs = (tsec_mdio_t *)(MDIO_BASE_ADDR), .devname = CONFIG_MPC85XX_FEC_NAME, .phyaddr = FEC_PHY_ADDR, - .flags = FEC_FLAGS + .flags = FEC_FLAGS, + .mii_devname = DEFAULT_MII_NAME }, /* FEC */ #endif #ifdef CONFIG_TSEC3 @@ -70,59 +69,6 @@ static struct tsec_info_struct tsec_info[] = { #endif };
-/* Writes the given phy's reg with value, using the specified MDIO regs */ -static void tsec_local_mdio_write(tsec_mdio_t *phyregs, uint addr, - uint reg, uint value) -{ - int timeout = 1000000; - - out_be32(&phyregs->miimadd, (addr << 8) | reg); - out_be32(&phyregs->miimcon, value); - asm("sync"); - - timeout = 1000000; - while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--) ; -} - -/* Provide the default behavior of writing the PHY of this ethernet device */ -#define write_phy_reg(priv, regnum, value) \ - tsec_local_mdio_write(priv->phyregs,priv->phyaddr,regnum,value) - -/* Reads register regnum on the device's PHY through the - * specified registers. It lowers and raises the read - * command, and waits for the data to become valid (miimind - * notvalid bit cleared), and the bus to cease activity (miimind - * busy bit cleared), and then returns the value - */ -static uint tsec_local_mdio_read(tsec_mdio_t *phyregs, uint phyid, uint regnum) -{ - uint value; - - /* Put the address of the phy, and the register - * number into MIIMADD */ - out_be32(&phyregs->miimadd, (phyid << 8) | regnum); - - /* Clear the command register, and wait */ - out_be32(&phyregs->miimcom, 0); - asm("sync"); - - /* Initiate a read command, and wait */ - out_be32(&phyregs->miimcom, MIIM_READ_COMMAND); - asm("sync"); - - /* Wait for the the indication that the read is done */ - while ((in_be32(&phyregs->miimind) & (MIIMIND_NOTVALID | MIIMIND_BUSY))) ; - - /* Grab the value read from the PHY */ - value = in_be32(&phyregs->miimstat); - - return value; -} - -/* #define to provide old read_phy_reg functionality without duplicating code */ -#define read_phy_reg(priv,regnum) \ - tsec_local_mdio_read(priv->phyregs,priv->phyaddr,regnum) - #define TBIANA_SETTINGS ( \ TBIANA_ASYMMETRIC_PAUSE \ | TBIANA_SYMMETRIC_PAUSE \ @@ -144,1383 +90,14 @@ static void tsec_configure_serdes(struct tsec_private *priv) { /* Access TBI PHY registers at given TSEC register offset as opposed * to the register offset used for external PHY accesses */ - tsec_local_mdio_write(priv->phyregs_sgmii, priv->regs->tbipa, TBI_ANA, - TBIANA_SETTINGS); - tsec_local_mdio_write(priv->phyregs_sgmii, priv->regs->tbipa, TBI_TBICON, - TBICON_CLK_SELECT); - tsec_local_mdio_write(priv->phyregs_sgmii, priv->regs->tbipa, TBI_CR, - CONFIG_TSEC_TBICR_SETTINGS); -} - -/* - * Returns which value to write to the control register. - * For 10/100, the value is slightly different - */ -static uint mii_cr_init(uint mii_reg, struct tsec_private * priv) -{ - if (priv->flags & TSEC_GIGABIT) - return MIIM_CONTROL_INIT; - else - return MIIM_CR_INIT; -} - -/* - * Wait for auto-negotiation to complete, then determine link - */ -static uint mii_parse_sr(uint mii_reg, struct tsec_private * priv) -{ - /* - * Wait if the link is up, and autonegotiation is in progress - * (ie - we're capable and it's not done) - */ - mii_reg = read_phy_reg(priv, MIIM_STATUS); - if ((mii_reg & BMSR_ANEGCAPABLE) && !(mii_reg & BMSR_ANEGCOMPLETE)) { - int i = 0; - - puts("Waiting for PHY auto negotiation to complete"); - while (!(mii_reg & BMSR_ANEGCOMPLETE)) { - /* - * Timeout reached ? - */ - if (i > PHY_AUTONEGOTIATE_TIMEOUT) { - puts(" TIMEOUT !\n"); - priv->link = 0; - return 0; - } - - if (ctrlc()) { - puts("user interrupt!\n"); - priv->link = 0; - return -EINTR; - } - - if ((i++ % 1000) == 0) { - putc('.'); - } - udelay(1000); /* 1 ms */ - mii_reg = read_phy_reg(priv, MIIM_STATUS); - } - puts(" done\n"); - - /* Link status bit is latched low, read it again */ - mii_reg = read_phy_reg(priv, MIIM_STATUS); - - udelay(500000); /* another 500 ms (results in faster booting) */ - } - - priv->link = mii_reg & MIIM_STATUS_LINK ? 1 : 0; - - return 0; -} - -/* Generic function which updates the speed and duplex. If - * autonegotiation is enabled, it uses the AND of the link - * partner's advertised capabilities and our advertised - * capabilities. If autonegotiation is disabled, we use the - * appropriate bits in the control register. - * - * Stolen from Linux's mii.c and phy_device.c - */ -static uint mii_parse_link(uint mii_reg, struct tsec_private *priv) -{ - /* We're using autonegotiation */ - if (mii_reg & BMSR_ANEGCAPABLE) { - uint lpa = 0; - uint gblpa = 0; - - /* Check for gigabit capability */ - if (mii_reg & BMSR_ERCAP) { - /* We want a list of states supported by - * both PHYs in the link - */ - gblpa = read_phy_reg(priv, MII_STAT1000); - gblpa &= read_phy_reg(priv, MII_CTRL1000) << 2; - } - - /* Set the baseline so we only have to set them - * if they're different - */ - priv->speed = 10; - priv->duplexity = 0; - - /* Check the gigabit fields */ - if (gblpa & (PHY_1000BTSR_1000FD | PHY_1000BTSR_1000HD)) { - priv->speed = 1000; - - if (gblpa & PHY_1000BTSR_1000FD) - priv->duplexity = 1; - - /* We're done! */ - return 0; - } - - lpa = read_phy_reg(priv, MII_ADVERTISE); - lpa &= read_phy_reg(priv, MII_LPA); - - if (lpa & (LPA_100FULL | LPA_100HALF)) { - priv->speed = 100; - - if (lpa & LPA_100FULL) - priv->duplexity = 1; - - } else if (lpa & LPA_10FULL) - priv->duplexity = 1; - } else { - uint bmcr = read_phy_reg(priv, MII_BMCR); - - priv->speed = 10; - priv->duplexity = 0; - - if (bmcr & BMCR_FULLDPLX) - priv->duplexity = 1; - - if (bmcr & BMCR_SPEED1000) - priv->speed = 1000; - else if (bmcr & BMCR_SPEED100) - priv->speed = 100; - } - - return 0; -} - -/* - * "Ethernet@Wirespeed" needs to be enabled to achieve link in certain - * circumstances. eg a gigabit TSEC connected to a gigabit switch with - * a 4-wire ethernet cable. Both ends advertise gigabit, but can't - * link. "Ethernet@Wirespeed" reduces advertised speed until link - * can be achieved. - */ -static uint mii_BCM54xx_wirespeed(uint mii_reg, struct tsec_private *priv) -{ - return (read_phy_reg(priv, mii_reg) & 0x8FFF) | 0x8010; -} - -/* - * Parse the BCM54xx status register for speed and duplex information. - * The linux sungem_phy has this information, but in a table format. - */ -static uint mii_parse_BCM54xx_sr(uint mii_reg, struct tsec_private *priv) -{ - /* If there is no link, speed and duplex don't matter */ - if (!priv->link) - return 0; - - switch ((mii_reg & MIIM_BCM54xx_AUXSTATUS_LINKMODE_MASK) >> - MIIM_BCM54xx_AUXSTATUS_LINKMODE_SHIFT) { - case 1: - priv->duplexity = 0; - priv->speed = 10; - break; - case 2: - priv->duplexity = 1; - priv->speed = 10; - break; - case 3: - priv->duplexity = 0; - priv->speed = 100; - break; - case 5: - priv->duplexity = 1; - priv->speed = 100; - break; - case 6: - priv->duplexity = 0; - priv->speed = 1000; - break; - case 7: - priv->duplexity = 1; - priv->speed = 1000; - break; - default: - printf("Auto-neg error, defaulting to 10BT/HD\n"); - priv->duplexity = 0; - priv->speed = 10; - break; - } - - return 0; -} - -/* - * Find out if PHY is in copper or serdes mode by looking at Expansion Reg - * 0x42 - "Operating Mode Status Register" - */ -static int BCM8482_is_serdes(struct tsec_private *priv) -{ - u16 val; - int serdes = 0; - - write_phy_reg(priv, MIIM_BCM54XX_EXP_SEL, MIIM_BCM54XX_EXP_SEL_ER | 0x42); - val = read_phy_reg(priv, MIIM_BCM54XX_EXP_DATA); - - switch (val & 0x1f) { - case 0x0d: /* RGMII-to-100Base-FX */ - case 0x0e: /* RGMII-to-SGMII */ - case 0x0f: /* RGMII-to-SerDes */ - case 0x12: /* SGMII-to-SerDes */ - case 0x13: /* SGMII-to-100Base-FX */ - case 0x16: /* SerDes-to-Serdes */ - serdes = 1; - break; - case 0x6: /* RGMII-to-Copper */ - case 0x14: /* SGMII-to-Copper */ - case 0x17: /* SerDes-to-Copper */ - break; - default: - printf("ERROR, invalid PHY mode (0x%x\n)", val); - break; - } - - return serdes; -} - -/* - * Determine SerDes link speed and duplex from Expansion reg 0x42 "Operating - * Mode Status Register" - */ -uint mii_parse_BCM5482_serdes_sr(struct tsec_private *priv) -{ - u16 val; - int i = 0; - - /* Wait 1s for link - Clause 37 autonegotiation happens very fast */ - while (1) { - write_phy_reg(priv, MIIM_BCM54XX_EXP_SEL, - MIIM_BCM54XX_EXP_SEL_ER | 0x42); - val = read_phy_reg(priv, MIIM_BCM54XX_EXP_DATA); - - if (val & 0x8000) - break; - - if (i++ > 1000) { - priv->link = 0; - return 1; - } - - udelay(1000); /* 1 ms */ - } - - priv->link = 1; - switch ((val >> 13) & 0x3) { - case (0x00): - priv->speed = 10; - break; - case (0x01): - priv->speed = 100; - break; - case (0x02): - priv->speed = 1000; - break; - } - - priv->duplexity = (val & 0x1000) == 0x1000; - - return 0; -} - -/* - * Figure out if BCM5482 is in serdes or copper mode and determine link - * configuration accordingly - */ -static uint mii_parse_BCM5482_sr(uint mii_reg, struct tsec_private *priv) -{ - if (BCM8482_is_serdes(priv)) { - mii_parse_BCM5482_serdes_sr(priv); - priv->flags |= TSEC_FIBER; - } else { - /* Wait for auto-negotiation to complete or fail */ - mii_parse_sr(mii_reg, priv); - - /* Parse BCM54xx copper aux status register */ - mii_reg = read_phy_reg(priv, MIIM_BCM54xx_AUXSTATUS); - mii_parse_BCM54xx_sr(mii_reg, priv); - } - - return 0; + tsec_local_mdio_write(priv->phyregs_sgmii, in_be32(&priv->regs->tbipa), 0, + TBI_ANA, TBIANA_SETTINGS); + tsec_local_mdio_write(priv->phyregs_sgmii, in_be32(&priv->regs->tbipa), 0, + TBI_TBICON, TBICON_CLK_SELECT); + tsec_local_mdio_write(priv->phyregs_sgmii, in_be32(&priv->regs->tbipa), 0, + TBI_CR, CONFIG_TSEC_TBICR_SETTINGS); }
-/* Parse the 88E1011's status register for speed and duplex - * information - */ -static uint mii_parse_88E1011_psr(uint mii_reg, struct tsec_private * priv) -{ - uint speed; - - mii_reg = read_phy_reg(priv, MIIM_88E1011_PHY_STATUS); - - if ((mii_reg & MIIM_88E1011_PHYSTAT_LINK) && - !(mii_reg & MIIM_88E1011_PHYSTAT_SPDDONE)) { - int i = 0; - - puts("Waiting for PHY realtime link"); - while (!(mii_reg & MIIM_88E1011_PHYSTAT_SPDDONE)) { - /* Timeout reached ? */ - if (i > PHY_AUTONEGOTIATE_TIMEOUT) { - puts(" TIMEOUT !\n"); - priv->link = 0; - break; - } - - if ((i++ % 1000) == 0) { - putc('.'); - } - udelay(1000); /* 1 ms */ - mii_reg = read_phy_reg(priv, MIIM_88E1011_PHY_STATUS); - } - puts(" done\n"); - udelay(500000); /* another 500 ms (results in faster booting) */ - } else { - if (mii_reg & MIIM_88E1011_PHYSTAT_LINK) - priv->link = 1; - else - priv->link = 0; - } - - if (mii_reg & MIIM_88E1011_PHYSTAT_DUPLEX) - priv->duplexity = 1; - else - priv->duplexity = 0; - - speed = (mii_reg & MIIM_88E1011_PHYSTAT_SPEED); - - switch (speed) { - case MIIM_88E1011_PHYSTAT_GBIT: - priv->speed = 1000; - break; - case MIIM_88E1011_PHYSTAT_100: - priv->speed = 100; - break; - default: - priv->speed = 10; - } - - return 0; -} - -/* Parse the RTL8211B's status register for speed and duplex - * information - */ -static uint mii_parse_RTL8211B_sr(uint mii_reg, struct tsec_private * priv) -{ - uint speed; - - mii_reg = read_phy_reg(priv, MIIM_RTL8211B_PHY_STATUS); - if (!(mii_reg & MIIM_RTL8211B_PHYSTAT_SPDDONE)) { - int i = 0; - - /* in case of timeout ->link is cleared */ - priv->link = 1; - puts("Waiting for PHY realtime link"); - while (!(mii_reg & MIIM_RTL8211B_PHYSTAT_SPDDONE)) { - /* Timeout reached ? */ - if (i > PHY_AUTONEGOTIATE_TIMEOUT) { - puts(" TIMEOUT !\n"); - priv->link = 0; - break; - } - - if ((i++ % 1000) == 0) { - putc('.'); - } - udelay(1000); /* 1 ms */ - mii_reg = read_phy_reg(priv, MIIM_RTL8211B_PHY_STATUS); - } - puts(" done\n"); - udelay(500000); /* another 500 ms (results in faster booting) */ - } else { - if (mii_reg & MIIM_RTL8211B_PHYSTAT_LINK) - priv->link = 1; - else - priv->link = 0; - } - - if (mii_reg & MIIM_RTL8211B_PHYSTAT_DUPLEX) - priv->duplexity = 1; - else - priv->duplexity = 0; - - speed = (mii_reg & MIIM_RTL8211B_PHYSTAT_SPEED); - - switch (speed) { - case MIIM_RTL8211B_PHYSTAT_GBIT: - priv->speed = 1000; - break; - case MIIM_RTL8211B_PHYSTAT_100: - priv->speed = 100; - break; - default: - priv->speed = 10; - } - - return 0; -} - -/* Parse the cis8201's status register for speed and duplex - * information - */ -static uint mii_parse_cis8201(uint mii_reg, struct tsec_private * priv) -{ - uint speed; - - if (mii_reg & MIIM_CIS8201_AUXCONSTAT_DUPLEX) - priv->duplexity = 1; - else - priv->duplexity = 0; - - speed = mii_reg & MIIM_CIS8201_AUXCONSTAT_SPEED; - switch (speed) { - case MIIM_CIS8201_AUXCONSTAT_GBIT: - priv->speed = 1000; - break; - case MIIM_CIS8201_AUXCONSTAT_100: - priv->speed = 100; - break; - default: - priv->speed = 10; - break; - } - - return 0; -} - -/* Parse the vsc8244's status register for speed and duplex - * information - */ -static uint mii_parse_vsc8244(uint mii_reg, struct tsec_private * priv) -{ - uint speed; - - if (mii_reg & MIIM_VSC8244_AUXCONSTAT_DUPLEX) - priv->duplexity = 1; - else - priv->duplexity = 0; - - speed = mii_reg & MIIM_VSC8244_AUXCONSTAT_SPEED; - switch (speed) { - case MIIM_VSC8244_AUXCONSTAT_GBIT: - priv->speed = 1000; - break; - case MIIM_VSC8244_AUXCONSTAT_100: - priv->speed = 100; - break; - default: - priv->speed = 10; - break; - } - - return 0; -} - -/* Parse the DM9161's status register for speed and duplex - * information - */ -static uint mii_parse_dm9161_scsr(uint mii_reg, struct tsec_private * priv) -{ - if (mii_reg & (MIIM_DM9161_SCSR_100F | MIIM_DM9161_SCSR_100H)) - priv->speed = 100; - else - priv->speed = 10; - - if (mii_reg & (MIIM_DM9161_SCSR_100F | MIIM_DM9161_SCSR_10F)) - priv->duplexity = 1; - else - priv->duplexity = 0; - - return 0; -} - -/* - * Hack to write all 4 PHYs with the LED values - */ -static uint mii_cis8204_fixled(uint mii_reg, struct tsec_private * priv) -{ - uint phyid; - tsec_mdio_t *regbase = priv->phyregs; - int timeout = 1000000; - - for (phyid = 0; phyid < 4; phyid++) { - out_be32(®base->miimadd, (phyid << 8) | mii_reg); - out_be32(®base->miimcon, MIIM_CIS8204_SLEDCON_INIT); - asm("sync"); - - timeout = 1000000; - while ((in_be32(®base->miimind) & MIIMIND_BUSY) && timeout--) ; - } - - return MIIM_CIS8204_SLEDCON_INIT; -} - -static uint mii_cis8204_setmode(uint mii_reg, struct tsec_private * priv) -{ - if (priv->flags & TSEC_REDUCED) - return MIIM_CIS8204_EPHYCON_INIT | MIIM_CIS8204_EPHYCON_RGMII; - else - return MIIM_CIS8204_EPHYCON_INIT; -} - -static uint mii_m88e1111s_setmode(uint mii_reg, struct tsec_private *priv) -{ - uint mii_data = read_phy_reg(priv, mii_reg); - - if (priv->flags & TSEC_REDUCED) - mii_data = (mii_data & 0xfff0) | 0x000b; - return mii_data; -} - -static struct phy_info phy_info_M88E1149S = { - 0x1410ca, - "Marvell 88E1149S", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {0x1d, 0x1f, NULL}, - {0x1e, 0x200c, NULL}, - {0x1d, 0x5, NULL}, - {0x1e, 0x0, NULL}, - {0x1e, 0x100, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_88E1011_PHY_STATUS, miim_read, &mii_parse_88E1011_psr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -/* The 5411 id is 0x206070, the 5421 is 0x2060e0 */ -static struct phy_info phy_info_BCM5461S = { - 0x02060c1, /* 5461 ID */ - "Broadcom BCM5461S", - 0, /* not clear to me what minor revisions we can shift away */ - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_BCM54xx_AUXSTATUS, miim_read, &mii_parse_BCM54xx_sr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_BCM5464S = { - 0x02060b1, /* 5464 ID */ - "Broadcom BCM5464S", - 0, /* not clear to me what minor revisions we can shift away */ - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_BCM54xx_AUXSTATUS, miim_read, &mii_parse_BCM54xx_sr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_BCM5482S = { - 0x0143bcb, - "Broadcom BCM5482S", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - /* Setup read from auxilary control shadow register 7 */ - {MIIM_BCM54xx_AUXCNTL, MIIM_BCM54xx_AUXCNTL_ENCODE(7), NULL}, - /* Read Misc Control register and or in Ethernet@Wirespeed */ - {MIIM_BCM54xx_AUXCNTL, 0, &mii_BCM54xx_wirespeed}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - /* Initial config/enable of secondary SerDes interface */ - {MIIM_BCM54XX_SHD, MIIM_BCM54XX_SHD_WR_ENCODE(0x14, 0xf), NULL}, - /* Write intial value to secondary SerDes Contol */ - {MIIM_BCM54XX_EXP_SEL, MIIM_BCM54XX_EXP_SEL_SSD | 0, NULL}, - {MIIM_BCM54XX_EXP_DATA, MIIM_CONTROL_RESTART, NULL}, - /* Enable copper/fiber auto-detect */ - {MIIM_BCM54XX_SHD, MIIM_BCM54XX_SHD_WR_ENCODE(0x1e, 0x201)}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Determine copper/fiber, auto-negotiate, and read the result */ - {MIIM_STATUS, miim_read, &mii_parse_BCM5482_sr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_M88E1011S = { - 0x01410c6, - "Marvell 88E1011S", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {0x1d, 0x1f, NULL}, - {0x1e, 0x200c, NULL}, - {0x1d, 0x5, NULL}, - {0x1e, 0x0, NULL}, - {0x1e, 0x100, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_88E1011_PHY_STATUS, miim_read, &mii_parse_88E1011_psr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_M88E1111S = { - 0x01410cc, - "Marvell 88E1111S", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {0x1b, 0x848f, &mii_m88e1111s_setmode}, - {0x14, 0x0cd2, NULL}, /* Delay RGMII TX and RX */ - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_88E1011_PHY_STATUS, miim_read, &mii_parse_88E1011_psr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_M88E1118 = { - 0x01410e1, - "Marvell 88E1118", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {0x16, 0x0002, NULL}, /* Change Page Number */ - {0x15, 0x1070, NULL}, /* Delay RGMII TX and RX */ - {0x16, 0x0003, NULL}, /* Change Page Number */ - {0x10, 0x021e, NULL}, /* Adjust LED control */ - {0x16, 0x0000, NULL}, /* Change Page Number */ - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - {0x16, 0x0000, NULL}, /* Change Page Number */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_88E1011_PHY_STATUS, miim_read, - &mii_parse_88E1011_psr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -/* - * Since to access LED register we need do switch the page, we - * do LED configuring in the miim_read-like function as follows - */ -static uint mii_88E1121_set_led (uint mii_reg, struct tsec_private *priv) -{ - uint pg; - - /* Switch the page to access the led register */ - pg = read_phy_reg(priv, MIIM_88E1121_PHY_PAGE); - write_phy_reg(priv, MIIM_88E1121_PHY_PAGE, MIIM_88E1121_PHY_LED_PAGE); - - /* Configure leds */ - write_phy_reg(priv, MIIM_88E1121_PHY_LED_CTRL, - MIIM_88E1121_PHY_LED_DEF); - - /* Restore the page pointer */ - write_phy_reg(priv, MIIM_88E1121_PHY_PAGE, pg); - return 0; -} - -static struct phy_info phy_info_M88E1121R = { - 0x01410cb, - "Marvell 88E1121R", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - /* Configure leds */ - {MIIM_88E1121_PHY_LED_CTRL, miim_read, &mii_88E1121_set_led}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - /* Disable IRQs and de-assert interrupt */ - {MIIM_88E1121_PHY_IRQ_EN, 0, NULL}, - {MIIM_88E1121_PHY_IRQ_STATUS, miim_read, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - {MIIM_STATUS, miim_read, &mii_parse_sr}, - {MIIM_STATUS, miim_read, &mii_parse_link}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static unsigned int m88e1145_setmode(uint mii_reg, struct tsec_private *priv) -{ - uint mii_data = read_phy_reg(priv, mii_reg); - - /* Setting MIIM_88E1145_PHY_EXT_CR */ - if (priv->flags & TSEC_REDUCED) - return mii_data | - MIIM_M88E1145_RGMII_RX_DELAY | MIIM_M88E1145_RGMII_TX_DELAY; - else - return mii_data; -} - -static struct phy_info phy_info_M88E1145 = { - 0x01410cd, - "Marvell 88E1145", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - - /* Errata E0, E1 */ - {29, 0x001b, NULL}, - {30, 0x418f, NULL}, - {29, 0x0016, NULL}, - {30, 0xa2da, NULL}, - - /* Configure the PHY */ - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_88E1011_PHY_SCR, MIIM_88E1011_PHY_MDI_X_AUTO, NULL}, - {MIIM_88E1145_PHY_EXT_CR, 0, &m88e1145_setmode}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - {MIIM_88E1111_PHY_LED_CONTROL, MIIM_88E1111_PHY_LED_DIRECT, NULL}, - /* Read the Status */ - {MIIM_88E1011_PHY_STATUS, miim_read, &mii_parse_88E1011_psr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_cis8204 = { - 0x3f11, - "Cicada Cis8204", - 6, - (struct phy_cmd[]) { /* config */ - /* Override PHY config settings */ - {MIIM_CIS8201_AUX_CONSTAT, MIIM_CIS8201_AUXCONSTAT_INIT, NULL}, - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {MIIM_CIS8204_SLED_CON, MIIM_CIS8204_SLEDCON_INIT, - &mii_cis8204_fixled}, - {MIIM_CIS8204_EPHY_CON, MIIM_CIS8204_EPHYCON_INIT, - &mii_cis8204_setmode}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_CIS8201_AUX_CONSTAT, miim_read, &mii_parse_cis8201}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -/* Cicada 8201 */ -static struct phy_info phy_info_cis8201 = { - 0xfc41, - "CIS8201", - 4, - (struct phy_cmd[]) { /* config */ - /* Override PHY config settings */ - {MIIM_CIS8201_AUX_CONSTAT, MIIM_CIS8201_AUXCONSTAT_INIT, NULL}, - /* Set up the interface mode */ - {MIIM_CIS8201_EXT_CON1, MIIM_CIS8201_EXTCON1_INIT, NULL}, - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_CIS8201_AUX_CONSTAT, miim_read, &mii_parse_cis8201}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_VSC8211 = { - 0xfc4b, - "Vitesse VSC8211", - 4, - (struct phy_cmd[]) { /* config */ - /* Override PHY config settings */ - {MIIM_CIS8201_AUX_CONSTAT, MIIM_CIS8201_AUXCONSTAT_INIT, NULL}, - /* Set up the interface mode */ - {MIIM_CIS8201_EXT_CON1, MIIM_CIS8201_EXTCON1_INIT, NULL}, - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_CIS8201_AUX_CONSTAT, miim_read, &mii_parse_cis8201}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_VSC8244 = { - 0x3f1b, - "Vitesse VSC8244", - 6, - (struct phy_cmd[]) { /* config */ - /* Override PHY config settings */ - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_VSC8244_AUX_CONSTAT, miim_read, &mii_parse_vsc8244}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_VSC8641 = { - 0x7043, - "Vitesse VSC8641", - 4, - (struct phy_cmd[]) { /* config */ - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_VSC8244_AUX_CONSTAT, miim_read, &mii_parse_vsc8244}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_VSC8221 = { - 0xfc55, - "Vitesse VSC8221", - 4, - (struct phy_cmd[]) { /* config */ - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_VSC8244_AUX_CONSTAT, miim_read, &mii_parse_vsc8244}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_VSC8601 = { - 0x00007042, - "Vitesse VSC8601", - 4, - (struct phy_cmd[]) { /* config */ - /* Override PHY config settings */ - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, -#ifdef CONFIG_SYS_VSC8601_SKEWFIX - {MIIM_VSC8601_EPHY_CON,MIIM_VSC8601_EPHY_CON_INIT_SKEW,NULL}, -#if defined(CONFIG_SYS_VSC8601_SKEW_TX) && defined(CONFIG_SYS_VSC8601_SKEW_RX) - {MIIM_EXT_PAGE_ACCESS,1,NULL}, -#define VSC8101_SKEW \ - (CONFIG_SYS_VSC8601_SKEW_TX << 14) | (CONFIG_SYS_VSC8601_SKEW_RX << 12) - {MIIM_VSC8601_SKEW_CTRL,VSC8101_SKEW,NULL}, - {MIIM_EXT_PAGE_ACCESS,0,NULL}, -#endif -#endif - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESTART, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Read the Status (2x to make sure link is right) */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_VSC8244_AUX_CONSTAT, miim_read, &mii_parse_vsc8244}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_dm9161 = { - 0x0181b88, - "Davicom DM9161E", - 4, - (struct phy_cmd[]) { /* config */ - {MIIM_CONTROL, MIIM_DM9161_CR_STOP, NULL}, - /* Do not bypass the scrambler/descrambler */ - {MIIM_DM9161_SCR, MIIM_DM9161_SCR_INIT, NULL}, - /* Clear 10BTCSR to default */ - {MIIM_DM9161_10BTCSR, MIIM_DM9161_10BTCSR_INIT, NULL}, - /* Configure some basic stuff */ - {MIIM_CONTROL, MIIM_CR_INIT, NULL}, - /* Restart Auto Negotiation */ - {MIIM_CONTROL, MIIM_DM9161_CR_RSTAN, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_DM9161_SCSR, miim_read, &mii_parse_dm9161_scsr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -/* micrel KSZ804 */ -static struct phy_info phy_info_ksz804 = { - 0x0022151, - "Micrel KSZ804 PHY", - 4, - (struct phy_cmd[]) { /* config */ - {MII_BMCR, BMCR_RESET, NULL}, - {MII_BMCR, BMCR_ANENABLE|BMCR_ANRESTART, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - {MII_BMSR, miim_read, NULL}, - {MII_BMSR, miim_read, &mii_parse_sr}, - {MII_BMSR, miim_read, &mii_parse_link}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - } -}; - -/* a generic flavor. */ -static struct phy_info phy_info_generic = { - 0, - "Unknown/Generic PHY", - 32, - (struct phy_cmd[]) { /* config */ - {MII_BMCR, BMCR_RESET, NULL}, - {MII_BMCR, BMCR_ANENABLE|BMCR_ANRESTART, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - {MII_BMSR, miim_read, NULL}, - {MII_BMSR, miim_read, &mii_parse_sr}, - {MII_BMSR, miim_read, &mii_parse_link}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - } -}; - -static uint mii_parse_lxt971_sr2(uint mii_reg, struct tsec_private *priv) -{ - unsigned int speed; - if (priv->link) { - speed = mii_reg & MIIM_LXT971_SR2_SPEED_MASK; - - switch (speed) { - case MIIM_LXT971_SR2_10HDX: - priv->speed = 10; - priv->duplexity = 0; - break; - case MIIM_LXT971_SR2_10FDX: - priv->speed = 10; - priv->duplexity = 1; - break; - case MIIM_LXT971_SR2_100HDX: - priv->speed = 100; - priv->duplexity = 0; - break; - default: - priv->speed = 100; - priv->duplexity = 1; - } - } else { - priv->speed = 0; - priv->duplexity = 0; - } - - return 0; -} - -static struct phy_info phy_info_lxt971 = { - 0x0001378e, - "LXT971", - 4, - (struct phy_cmd[]) { /* config */ - {MIIM_CR, MIIM_CR_INIT, mii_cr_init}, /* autonegotiate */ - {miim_end,} - }, - (struct phy_cmd[]) { /* startup - enable interrupts */ - /* { 0x12, 0x00f2, NULL }, */ - {MIIM_STATUS, miim_read, NULL}, - {MIIM_STATUS, miim_read, &mii_parse_sr}, - {MIIM_LXT971_SR2, miim_read, &mii_parse_lxt971_sr2}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown - disable interrupts */ - {miim_end,} - }, -}; - -/* Parse the DP83865's link and auto-neg status register for speed and duplex - * information - */ -static uint mii_parse_dp83865_lanr(uint mii_reg, struct tsec_private *priv) -{ - switch (mii_reg & MIIM_DP83865_SPD_MASK) { - - case MIIM_DP83865_SPD_1000: - priv->speed = 1000; - break; - - case MIIM_DP83865_SPD_100: - priv->speed = 100; - break; - - default: - priv->speed = 10; - break; - - } - - if (mii_reg & MIIM_DP83865_DPX_FULL) - priv->duplexity = 1; - else - priv->duplexity = 0; - - return 0; -} - -static struct phy_info phy_info_dp83865 = { - 0x20005c7, - "NatSemi DP83865", - 4, - (struct phy_cmd[]) { /* config */ - {MIIM_CONTROL, MIIM_DP83865_CR_INIT, NULL}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the link and auto-neg status */ - {MIIM_DP83865_LANR, miim_read, &mii_parse_dp83865_lanr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info phy_info_rtl8211b = { - 0x001cc91, - "RealTek RTL8211B", - 4, - (struct phy_cmd[]) { /* config */ - /* Reset and configure the PHY */ - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_GBIT_CONTROL, MIIM_GBIT_CONTROL_INIT, NULL}, - {MIIM_ANAR, MIIM_ANAR_INIT, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_RESET, NULL}, - {MIIM_CONTROL, MIIM_CONTROL_INIT, &mii_cr_init}, - {miim_end,} - }, - (struct phy_cmd[]) { /* startup */ - /* Status is read once to clear old link state */ - {MIIM_STATUS, miim_read, NULL}, - /* Auto-negotiate */ - {MIIM_STATUS, miim_read, &mii_parse_sr}, - /* Read the status */ - {MIIM_RTL8211B_PHY_STATUS, miim_read, &mii_parse_RTL8211B_sr}, - {miim_end,} - }, - (struct phy_cmd[]) { /* shutdown */ - {miim_end,} - }, -}; - -static struct phy_info *phy_info[] = { - &phy_info_cis8204, - &phy_info_cis8201, - &phy_info_BCM5461S, - &phy_info_BCM5464S, - &phy_info_BCM5482S, - &phy_info_M88E1011S, - &phy_info_M88E1111S, - &phy_info_M88E1118, - &phy_info_M88E1121R, - &phy_info_M88E1145, - &phy_info_M88E1149S, - &phy_info_dm9161, - &phy_info_ksz804, - &phy_info_lxt971, - &phy_info_VSC8211, - &phy_info_VSC8244, - &phy_info_VSC8601, - &phy_info_VSC8641, - &phy_info_VSC8221, - &phy_info_dp83865, - &phy_info_rtl8211b, - &phy_info_generic, /* must be last; has ID 0 and 32 bit mask */ - NULL -}; - -/* Grab the identifier of the device's PHY, and search through - * all of the known PHYs to see if one matches. If so, return - * it, if not, return NULL - */ -static struct phy_info *get_phy_info(struct eth_device *dev) -{ - struct tsec_private *priv = (struct tsec_private *)dev->priv; - uint phy_reg, phy_ID; - int i; - struct phy_info *theInfo = NULL; - - /* Grab the bits from PHYIR1, and put them in the upper half */ - phy_reg = read_phy_reg(priv, MIIM_PHYIR1); - phy_ID = (phy_reg & 0xffff) << 16; - - /* Grab the bits from PHYIR2, and put them in the lower half */ - phy_reg = read_phy_reg(priv, MIIM_PHYIR2); - phy_ID |= (phy_reg & 0xffff); - - /* loop through all the known PHY types, and find one that */ - /* matches the ID we read from the PHY. */ - for (i = 0; phy_info[i]; i++) { - if (phy_info[i]->id == (phy_ID >> phy_info[i]->shift)) { - theInfo = phy_info[i]; - break; - } - } - - if (theInfo == &phy_info_generic) { - printf("%s: No support for PHY id %x; assuming generic\n", - dev->name, phy_ID); - } else { - debug("%s: PHY is %s (%x)\n", dev->name, theInfo->name, phy_ID); - } - - return theInfo; -} - -/* Execute the given series of commands on the given device's - * PHY, running functions as necessary - */ -static void phy_run_commands(struct tsec_private *priv, struct phy_cmd *cmd) -{ - int i; - uint result; - tsec_mdio_t *phyregs = priv->phyregs; - - out_be32(&phyregs->miimcfg, MIIMCFG_RESET); - - out_be32(&phyregs->miimcfg, MIIMCFG_INIT_VALUE); - - while (in_be32(&phyregs->miimind) & MIIMIND_BUSY) ; - - for (i = 0; cmd->mii_reg != miim_end; i++) { - if (cmd->mii_data == miim_read) { - result = read_phy_reg(priv, cmd->mii_reg); - - if (cmd->funct != NULL) - (*(cmd->funct)) (result, priv); - - } else { - if (cmd->funct != NULL) - result = (*(cmd->funct)) (cmd->mii_reg, priv); - else - result = cmd->mii_data; - - write_phy_reg(priv, cmd->mii_reg, result); - - } - cmd++; - } -} - -#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ - && !defined(BITBANGMII) - -/* - * Read a MII PHY register. - * - * Returns: - * 0 on success - */ -static int tsec_miiphy_read(const char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) -{ - unsigned short ret; - struct tsec_private *priv = privlist[0]; - - if (NULL == priv) { - printf("Can't read PHY at address %d\n", addr); - return -1; - } - - ret = (unsigned short)tsec_local_mdio_read(priv->phyregs, addr, reg); - *value = ret; - - return 0; -} - -/* - * Write a MII PHY register. - * - * Returns: - * 0 on success - */ -static int tsec_miiphy_write(const char *devname, unsigned char addr, - unsigned char reg, unsigned short value) -{ - struct tsec_private *priv = privlist[0]; - - if (NULL == priv) { - printf("Can't write PHY at address %d\n", addr); - return -1; - } - - tsec_local_mdio_write(priv->phyregs, addr, reg, value); - - return 0; -} - -#endif - #ifdef CONFIG_MCAST_TFTP
/* CREDITS: linux gianfar driver, slightly adjusted... thanx. */ @@ -1612,14 +189,13 @@ static void init_registers(tsec_t * regs) /* Configure maccfg2 based on negotiated speed and duplex * reported by PHY handling code */ -static void adjust_link(struct eth_device *dev) +static void adjust_link(struct tsec_private *priv, struct phy_device *phydev) { - struct tsec_private *priv = (struct tsec_private *)dev->priv; tsec_t *regs = priv->regs; u32 ecntrl, maccfg2;
- if (!priv->link) { - printf("%s: No link.\n", dev->name); + if (!phydev->link) { + printf("%s: No link.\n", phydev->dev->name); return; }
@@ -1630,10 +206,10 @@ static void adjust_link(struct eth_device *dev) maccfg2 = in_be32(®s->maccfg2); maccfg2 &= ~(MACCFG2_IF | MACCFG2_FULL_DUPLEX);
- if (priv->duplexity) + if (phydev->duplex) maccfg2 |= MACCFG2_FULL_DUPLEX;
- switch (priv->speed) { + switch (phydev->speed) { case 1000: maccfg2 |= MACCFG2_GMII; break; @@ -1644,20 +220,20 @@ static void adjust_link(struct eth_device *dev) /* Set R100 bit in all modes although * it is only used in RGMII mode */ - if (priv->speed == 100) + if (phydev->speed == 100) ecntrl |= ECNTRL_R100; break; default: - printf("%s: Speed was bad\n", dev->name); + printf("%s: Speed was bad\n", phydev->dev->name); break; }
out_be32(®s->ecntrl, ecntrl); out_be32(®s->maccfg2, maccfg2);
- printf("Speed: %d, %s duplex%s\n", priv->speed, - (priv->duplexity) ? "full" : "half", - (priv->flags & TSEC_FIBER) ? ", fiber mode" : ""); + printf("Speed: %d, %s duplex%s\n", phydev->speed, + (phydev->duplex) ? "full" : "half", + (phydev->port == PORT_FIBRE) ? ", fiber mode" : ""); }
/* Set up the buffers and their descriptors, and bring up the @@ -1669,6 +245,10 @@ static void startup_tsec(struct eth_device *dev) struct tsec_private *priv = (struct tsec_private *)dev->priv; tsec_t *regs = priv->regs;
+ /* reset the indices to zero */ + rxIdx = 0; + txIdx = 0; + /* Point to the buffer descriptors */ out_be32(®s->tbase, (unsigned int)(&rtx.txbd[txIdx])); out_be32(®s->rbase, (unsigned int)(&rtx.rxbd[rxIdx])); @@ -1689,12 +269,6 @@ static void startup_tsec(struct eth_device *dev) } rtx.txbd[TX_BUF_CNT - 1].status |= TXBD_WRAP;
- /* Start up the PHY */ - if(priv->phyinfo) - phy_run_commands(priv, priv->phyinfo->startup); - - adjust_link(dev); - /* Enable Transmit and Receive */ setbits_be32(®s->maccfg1, MACCFG1_RX_EN | MACCFG1_TX_EN);
@@ -1798,8 +372,7 @@ static void tsec_halt(struct eth_device *dev) clrbits_be32(®s->maccfg1, MACCFG1_TX_EN | MACCFG1_RX_EN);
/* Shut down the PHY, as needed */ - if(priv->phyinfo) - phy_run_commands(priv, priv->phyinfo->shutdown); + phy_shutdown(priv->phydev); }
/* Initializes data structures and registers for the controller, @@ -1838,20 +411,64 @@ static int tsec_init(struct eth_device *dev, bd_t * bd)
out_be32(®s->macstnaddr2, tempval);
- /* reset the indices to zero */ - rxIdx = 0; - txIdx = 0; - /* Clear out (for the most part) the other registers */ init_registers(regs);
/* Ready the device for tx/rx */ startup_tsec(dev);
+ /* Start up the PHY */ + phy_startup(priv->phydev); + + adjust_link(priv, priv->phydev); + /* If there's no link, fail */ - return (priv->link ? 0 : -1); + return (priv->phydev->link ? 0 : -1); }
+static phy_interface_t tsec_get_interface(struct tsec_private *priv) +{ + tsec_t *regs = priv->regs; + u32 ecntrl; + + ecntrl = in_be32(®s->ecntrl); + + if (ecntrl & ECNTRL_SGMII_MODE) + return PHY_INTERFACE_MODE_SGMII; + + if (ecntrl & ECNTRL_TBI_MODE) { + if (ecntrl & ECNTRL_REDUCED_MODE) + return PHY_INTERFACE_MODE_RTBI; + else + return PHY_INTERFACE_MODE_TBI; + } + + if (ecntrl & ECNTRL_REDUCED_MODE) { + if (ecntrl & ECNTRL_REDUCED_MII_MODE) + return PHY_INTERFACE_MODE_RMII; + else { + phy_interface_t interface = priv->interface; + + /* + * This isn't autodetected, so it must + * be set by the platform code. + */ + if ((interface == PHY_INTERFACE_MODE_RGMII_ID) || + (interface == PHY_INTERFACE_MODE_RGMII_TXID) || + (interface == PHY_INTERFACE_MODE_RGMII_RXID)) + return interface; + + return PHY_INTERFACE_MODE_RGMII; + } + } + + if (priv->flags & TSEC_GIGABIT) + return PHY_INTERFACE_MODE_GMII; + + return PHY_INTERFACE_MODE_MII; +} + + /* Discover which PHY is attached to the device, and configure it * properly. If the PHY is not recognized, then return 0 * (failure). Otherwise, return 1 @@ -1859,37 +476,32 @@ static int tsec_init(struct eth_device *dev, bd_t * bd) static int init_phy(struct eth_device *dev) { struct tsec_private *priv = (struct tsec_private *)dev->priv; - struct phy_info *curphy; + struct phy_device *phydev; tsec_t *regs = priv->regs; + u32 supported = (SUPPORTED_10baseT_Half | + SUPPORTED_10baseT_Full | + SUPPORTED_100baseT_Half | + SUPPORTED_100baseT_Full); + + if (priv->flags & TSEC_GIGABIT) + supported |= SUPPORTED_1000baseT_Full;
/* Assign a Physical address to the TBI */ out_be32(®s->tbipa, CONFIG_SYS_TBIPA_VALUE); - asm("sync"); - - /* Reset MII (due to new addresses) */ - out_be32(&priv->phyregs->miimcfg, MIIMCFG_RESET); - asm("sync"); - out_be32(&priv->phyregs->miimcfg, MIIMCFG_INIT_VALUE); - asm("sync"); - while (in_be32(&priv->phyregs->miimind) & MIIMIND_BUSY) ;
- /* Get the cmd structure corresponding to the attached - * PHY */ - curphy = get_phy_info(dev); + priv->interface = tsec_get_interface(priv);
- if (curphy == NULL) { - priv->phyinfo = NULL; - printf("%s: No PHY found\n", dev->name); + if (priv->interface == PHY_INTERFACE_MODE_SGMII) + tsec_configure_serdes(priv);
- return 0; - } + phydev = phy_connect(priv->bus, priv->phyaddr, dev, priv->interface);
- if (in_be32(®s->ecntrl) & ECNTRL_SGMII_MODE) - tsec_configure_serdes(priv); + phydev->supported &= supported; + phydev->advertising = phydev->supported;
- priv->phyinfo = curphy; + priv->phydev = phydev;
- phy_run_commands(priv, priv->phyinfo->config); + phy_config(phydev);
return 1; } @@ -1917,13 +529,14 @@ static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info)
privlist[num_tsecs++] = priv; priv->regs = tsec_info->regs; - priv->phyregs = tsec_info->miiregs; priv->phyregs_sgmii = tsec_info->miiregs_sgmii;
priv->phyaddr = tsec_info->phyaddr; priv->flags = tsec_info->flags;
sprintf(dev->name, tsec_info->devname); + priv->interface = tsec_info->interface; + priv->bus = miiphy_get_dev_by_name(tsec_info->mii_devname); dev->iobase = 0; dev->priv = priv; dev->init = tsec_init; @@ -1945,11 +558,6 @@ static int tsec_initialize(bd_t * bis, struct tsec_info_struct *tsec_info) udelay(2); /* Soft Reset must be asserted for 3 TX clocks */ clrbits_be32(&priv->regs->maccfg1, MACCFG1_SOFT_RESET);
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) \ - && !defined(BITBANGMII) - miiphy_register(dev->name, tsec_miiphy_read, tsec_miiphy_write); -#endif - /* Try to initialize PHY here, and return */ return init_phy(dev); } @@ -1975,6 +583,13 @@ int tsec_eth_init(bd_t *bis, struct tsec_info_struct *tsecs, int num)
int tsec_standard_init(bd_t *bis) { + struct fsl_pq_mdio_info info; + + info.regs = (tsec_mii_t *)CONFIG_SYS_MDIO_BASE_ADDR; + info.name = DEFAULT_MII_NAME; + + fsl_pq_mdio_init(bis, &info); + return tsec_eth_init(bis, tsec_info, ARRAY_SIZE(tsec_info)); }
diff --git a/include/fsl_mdio.h b/include/fsl_mdio.h new file mode 100644 index 0000000..5a36507 --- /dev/null +++ b/include/fsl_mdio.h @@ -0,0 +1,62 @@ +/* + * Copyright 2009-2010 Freescale Semiconductor, Inc. + * Jun-jie Zhang b18070@freescale.com + * Mingkai Hu Mingkai.hu@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __FSL_PHY_H__ +#define __FSL_PHY_H__ + +#include <net.h> +#include <miiphy.h> +#include <asm/fsl_enet.h> + +/* PHY register offsets */ +#define PHY_EXT_PAGE_ACCESS 0x1f + +/* MII Management Configuration Register */ +#define MIIMCFG_RESET_MGMT 0x80000000 +#define MIIMCFG_MGMT_CLOCK_SELECT 0x00000007 +#define MIIMCFG_INIT_VALUE 0x00000003 + +/* MII Management Command Register */ +#define MIIMCOM_READ_CYCLE 0x00000001 +#define MIIMCOM_SCAN_CYCLE 0x00000002 + +/* MII Management Address Register */ +#define MIIMADD_PHY_ADDR_SHIFT 8 + +/* MII Management Indicator Register */ +#define MIIMIND_BUSY 0x00000001 +#define MIIMIND_NOTVALID 0x00000004 + +void tsec_local_mdio_write(tsec_mii_t *phyregs, int port_addr, int dev_addr, + int reg, int value); +int tsec_local_mdio_read(tsec_mii_t *phyregs, int port_addr, int dev_addr, + int regnum); +int tsec_phy_read(struct mii_dev *bus, int addr, int dev_addr, int regnum); +int tsec_phy_write(struct mii_dev *bus, int addr, int dev_addr, int regnum, + u16 value); + +struct fsl_pq_mdio_info { + tsec_mii_t *regs; + char *name; +}; +int fsl_pq_mdio_init(bd_t *bis, struct fsl_pq_mdio_info *info); + +#endif /* __FSL_PHY_H__ */ + diff --git a/include/tsec.h b/include/tsec.h index a066d97..2b2f70d 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -19,30 +19,36 @@
#include <net.h> #include <config.h> +#include <phy.h> +#include <asm/fsl_enet.h>
#define TSEC_SIZE 0x01000 #define TSEC_MDIO_OFFSET 0x01000
+#define CONFIG_SYS_MDIO_BASE_ADDR (TSEC_BASE_ADDR + 0x520) + +#define DEFAULT_MII_NAME "FSL_MDIO" + #define STD_TSEC_INFO(num) \ { \ .regs = (tsec_t *)(TSEC_BASE_ADDR + ((num - 1) * TSEC_SIZE)), \ - .miiregs = (tsec_mdio_t *)(MDIO_BASE_ADDR), \ - .miiregs_sgmii = (tsec_mdio_t *)(MDIO_BASE_ADDR \ + .miiregs_sgmii = (tsec_mii_t *)(CONFIG_SYS_MDIO_BASE_ADDR \ + (num - 1) * TSEC_MDIO_OFFSET), \ .devname = CONFIG_TSEC##num##_NAME, \ .phyaddr = TSEC##num##_PHY_ADDR, \ - .flags = TSEC##num##_FLAGS \ + .flags = TSEC##num##_FLAGS, \ + .mii_devname = DEFAULT_MII_NAME \ }
#define SET_STD_TSEC_INFO(x, num) \ { \ x.regs = (tsec_t *)(TSEC_BASE_ADDR + ((num - 1) * TSEC_SIZE)); \ - x.miiregs = (tsec_mdio_t *)(MDIO_BASE_ADDR); \ - x.miiregs_sgmii = (tsec_mdio_t *)(MDIO_BASE_ADDR \ + x.miiregs_sgmii = (tsec_mii_t *)(CONFIG_SYS_MDIO_BASE_ADDR \ + (num - 1) * TSEC_MDIO_OFFSET); \ x.devname = CONFIG_TSEC##num##_NAME; \ x.phyaddr = TSEC##num##_PHY_ADDR; \ x.flags = TSEC##num##_FLAGS;\ + x.mii_devname = DEFAULT_MII_NAME;\ }
#define MAC_ADDR_LEN 6 @@ -51,8 +57,6 @@ #define TSEC_TIMEOUT 1000 #define TOUT_LOOP 1000000
-#define PHY_AUTONEGOTIATE_TIMEOUT 5000 /* in ms */ - /* TBI register addresses */ #define TBI_CR 0x00 #define TBI_SR 0x01 @@ -96,204 +100,14 @@
#define ECNTRL_INIT_SETTINGS 0x00001000 #define ECNTRL_TBI_MODE 0x00000020 +#define ECNTRL_REDUCED_MODE 0x00000010 #define ECNTRL_R100 0x00000008 +#define ECNTRL_REDUCED_MII_MODE 0x00000004 #define ECNTRL_SGMII_MODE 0x00000002
-#define miim_end -2 -#define miim_read -1 - #ifndef CONFIG_SYS_TBIPA_VALUE #define CONFIG_SYS_TBIPA_VALUE 0x1f #endif -#define MIIMCFG_INIT_VALUE 0x00000003 -#define MIIMCFG_RESET 0x80000000 - -#define MIIMIND_BUSY 0x00000001 -#define MIIMIND_NOTVALID 0x00000004 - -#define MIIM_CONTROL 0x00 -#define MIIM_CONTROL_RESET 0x00009140 -#define MIIM_CONTROL_INIT 0x00001140 -#define MIIM_CONTROL_RESTART 0x00001340 -#define MIIM_ANEN 0x00001000 - -#define MIIM_CR 0x00 -#define MIIM_CR_RST 0x00008000 -#define MIIM_CR_INIT 0x00001000 - -#define MIIM_STATUS 0x1 -#define MIIM_STATUS_AN_DONE 0x00000020 -#define MIIM_STATUS_LINK 0x0004 - -#define MIIM_PHYIR1 0x2 -#define MIIM_PHYIR2 0x3 - -#define MIIM_ANAR 0x4 -#define MIIM_ANAR_INIT 0x1e1 - -#define MIIM_TBI_ANLPBPA 0x5 -#define MIIM_TBI_ANLPBPA_HALF 0x00000040 -#define MIIM_TBI_ANLPBPA_FULL 0x00000020 - -#define MIIM_TBI_ANEX 0x6 -#define MIIM_TBI_ANEX_NP 0x00000004 -#define MIIM_TBI_ANEX_PRX 0x00000002 - -#define MIIM_GBIT_CONTROL 0x9 -#define MIIM_GBIT_CONTROL_INIT 0xe00 - -#define MIIM_EXT_PAGE_ACCESS 0x1f - -/* Broadcom BCM54xx -- taken from linux sungem_phy */ -#define MIIM_BCM54xx_AUXCNTL 0x18 -#define MIIM_BCM54xx_AUXCNTL_ENCODE(val) ((val & 0x7) << 12)|(val & 0x7) -#define MIIM_BCM54xx_AUXSTATUS 0x19 -#define MIIM_BCM54xx_AUXSTATUS_LINKMODE_MASK 0x0700 -#define MIIM_BCM54xx_AUXSTATUS_LINKMODE_SHIFT 8 - -#define MIIM_BCM54XX_SHD 0x1c /* 0x1c shadow registers */ -#define MIIM_BCM54XX_SHD_WRITE 0x8000 -#define MIIM_BCM54XX_SHD_VAL(x) ((x & 0x1f) << 10) -#define MIIM_BCM54XX_SHD_DATA(x) ((x & 0x3ff) << 0) -#define MIIM_BCM54XX_SHD_WR_ENCODE(val, data) \ - (MIIM_BCM54XX_SHD_WRITE | MIIM_BCM54XX_SHD_VAL(val) | \ - MIIM_BCM54XX_SHD_DATA(data)) - -#define MIIM_BCM54XX_EXP_DATA 0x15 /* Expansion register data */ -#define MIIM_BCM54XX_EXP_SEL 0x17 /* Expansion register select */ -#define MIIM_BCM54XX_EXP_SEL_SSD 0x0e00 /* Secondary SerDes select */ -#define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */ - -/* Cicada Auxiliary Control/Status Register */ -#define MIIM_CIS8201_AUX_CONSTAT 0x1c -#define MIIM_CIS8201_AUXCONSTAT_INIT 0x0004 -#define MIIM_CIS8201_AUXCONSTAT_DUPLEX 0x0020 -#define MIIM_CIS8201_AUXCONSTAT_SPEED 0x0018 -#define MIIM_CIS8201_AUXCONSTAT_GBIT 0x0010 -#define MIIM_CIS8201_AUXCONSTAT_100 0x0008 - -/* Cicada Extended Control Register 1 */ -#define MIIM_CIS8201_EXT_CON1 0x17 -#define MIIM_CIS8201_EXTCON1_INIT 0x0000 - -/* Cicada 8204 Extended PHY Control Register 1 */ -#define MIIM_CIS8204_EPHY_CON 0x17 -#define MIIM_CIS8204_EPHYCON_INIT 0x0006 -#define MIIM_CIS8204_EPHYCON_RGMII 0x1100 - -/* Cicada 8204 Serial LED Control Register */ -#define MIIM_CIS8204_SLED_CON 0x1b -#define MIIM_CIS8204_SLEDCON_INIT 0x1115 - -#define MIIM_GBIT_CON 0x09 -#define MIIM_GBIT_CON_ADVERT 0x0e00 - -/* Entry for Vitesse VSC8244 regs starts here */ -/* Vitesse VSC8244 Auxiliary Control/Status Register */ -#define MIIM_VSC8244_AUX_CONSTAT 0x1c -#define MIIM_VSC8244_AUXCONSTAT_INIT 0x0000 -#define MIIM_VSC8244_AUXCONSTAT_DUPLEX 0x0020 -#define MIIM_VSC8244_AUXCONSTAT_SPEED 0x0018 -#define MIIM_VSC8244_AUXCONSTAT_GBIT 0x0010 -#define MIIM_VSC8244_AUXCONSTAT_100 0x0008 -#define MIIM_CONTROL_INIT_LOOPBACK 0x4000 - -/* Vitesse VSC8244 Extended PHY Control Register 1 */ -#define MIIM_VSC8244_EPHY_CON 0x17 -#define MIIM_VSC8244_EPHYCON_INIT 0x0006 - -/* Vitesse VSC8244 Serial LED Control Register */ -#define MIIM_VSC8244_LED_CON 0x1b -#define MIIM_VSC8244_LEDCON_INIT 0xF011 - -/* Entry for Vitesse VSC8601 regs starts here (Not complete) */ -/* Vitesse VSC8601 Extended PHY Control Register 1 */ -#define MIIM_VSC8601_EPHY_CON 0x17 -#define MIIM_VSC8601_EPHY_CON_INIT_SKEW 0x1120 -#define MIIM_VSC8601_SKEW_CTRL 0x1c - -/* 88E1011 PHY Status Register */ -#define MIIM_88E1011_PHY_STATUS 0x11 -#define MIIM_88E1011_PHYSTAT_SPEED 0xc000 -#define MIIM_88E1011_PHYSTAT_GBIT 0x8000 -#define MIIM_88E1011_PHYSTAT_100 0x4000 -#define MIIM_88E1011_PHYSTAT_DUPLEX 0x2000 -#define MIIM_88E1011_PHYSTAT_SPDDONE 0x0800 -#define MIIM_88E1011_PHYSTAT_LINK 0x0400 - -#define MIIM_88E1011_PHY_SCR 0x10 -#define MIIM_88E1011_PHY_MDI_X_AUTO 0x0060 - -/* 88E1111 PHY LED Control Register */ -#define MIIM_88E1111_PHY_LED_CONTROL 24 -#define MIIM_88E1111_PHY_LED_DIRECT 0x4100 -#define MIIM_88E1111_PHY_LED_COMBINE 0x411C - -/* 88E1121 PHY LED Control Register */ -#define MIIM_88E1121_PHY_LED_CTRL 16 -#define MIIM_88E1121_PHY_LED_PAGE 3 -#define MIIM_88E1121_PHY_LED_DEF 0x0030 - -/* 88E1121 PHY IRQ Enable/Status Register */ -#define MIIM_88E1121_PHY_IRQ_EN 18 -#define MIIM_88E1121_PHY_IRQ_STATUS 19 - -#define MIIM_88E1121_PHY_PAGE 22 - -/* 88E1145 Extended PHY Specific Control Register */ -#define MIIM_88E1145_PHY_EXT_CR 20 -#define MIIM_M88E1145_RGMII_RX_DELAY 0x0080 -#define MIIM_M88E1145_RGMII_TX_DELAY 0x0002 - -#define MIIM_88E1145_PHY_PAGE 29 -#define MIIM_88E1145_PHY_CAL_OV 30 - -/* RTL8211B PHY Status Register */ -#define MIIM_RTL8211B_PHY_STATUS 0x11 -#define MIIM_RTL8211B_PHYSTAT_SPEED 0xc000 -#define MIIM_RTL8211B_PHYSTAT_GBIT 0x8000 -#define MIIM_RTL8211B_PHYSTAT_100 0x4000 -#define MIIM_RTL8211B_PHYSTAT_DUPLEX 0x2000 -#define MIIM_RTL8211B_PHYSTAT_SPDDONE 0x0800 -#define MIIM_RTL8211B_PHYSTAT_LINK 0x0400 - -/* DM9161 Control register values */ -#define MIIM_DM9161_CR_STOP 0x0400 -#define MIIM_DM9161_CR_RSTAN 0x1200 - -#define MIIM_DM9161_SCR 0x10 -#define MIIM_DM9161_SCR_INIT 0x0610 - -/* DM9161 Specified Configuration and Status Register */ -#define MIIM_DM9161_SCSR 0x11 -#define MIIM_DM9161_SCSR_100F 0x8000 -#define MIIM_DM9161_SCSR_100H 0x4000 -#define MIIM_DM9161_SCSR_10F 0x2000 -#define MIIM_DM9161_SCSR_10H 0x1000 - -/* DM9161 10BT Configuration/Status */ -#define MIIM_DM9161_10BTCSR 0x12 -#define MIIM_DM9161_10BTCSR_INIT 0x7800 - -/* LXT971 Status 2 registers */ -#define MIIM_LXT971_SR2 0x11 /* Status Register 2 */ -#define MIIM_LXT971_SR2_SPEED_MASK 0x4200 -#define MIIM_LXT971_SR2_10HDX 0x0000 /* 10 Mbit half duplex selected */ -#define MIIM_LXT971_SR2_10FDX 0x0200 /* 10 Mbit full duplex selected */ -#define MIIM_LXT971_SR2_100HDX 0x4000 /* 100 Mbit half duplex selected */ -#define MIIM_LXT971_SR2_100FDX 0x4200 /* 100 Mbit full duplex selected */ - -/* DP83865 Control register values */ -#define MIIM_DP83865_CR_INIT 0x9200 - -/* DP83865 Link and Auto-Neg Status Register */ -#define MIIM_DP83865_LANR 0x11 -#define MIIM_DP83865_SPD_MASK 0x0018 -#define MIIM_DP83865_SPD_1000 0x0010 -#define MIIM_DP83865_SPD_100 0x0008 -#define MIIM_DP83865_DPX_FULL 0x0002 - -#define MIIM_READ_COMMAND 0x00000001
#define MRBLR_INIT_SETTINGS PKTSIZE_ALIGN
@@ -467,22 +281,6 @@ typedef struct tsec_hash_regs uint res2[24]; } tsec_hash_t;
-typedef struct tsec_mdio { - uint res1[4]; - uint ieventm; - uint imaskm; - uint res2; - uint emapm; - uint res3[320]; - uint miimcfg; /* MII Management: Configuration */ - uint miimcom; /* MII Management: Command */ - uint miimadd; /* MII Management: Address */ - uint miimcon; /* MII Management: Control */ - uint miimstat; /* MII Management: Status */ - uint miimind; /* MII Management: Indicators */ - uint res4[690]; -} tsec_mdio_t; - typedef struct tsec { /* General Control and Status Registers (0x2_n000) */ @@ -578,79 +376,29 @@ typedef struct tsec uint resc00[256]; } tsec_t;
-#define TSEC_GIGABIT (1) +#define TSEC_GIGABIT (1 << 0)
-/* This flag currently only has - * meaning if we're using the eTSEC */ +/* These flags currently only have meaning if we're using the eTSEC */ #define TSEC_REDUCED (1 << 1) /* MAC-PHY interface uses RGMII */ #define TSEC_SGMII (1 << 2) /* MAC-PHY interface uses SGMII */ -#define TSEC_FIBER (1 << 3) /* PHY uses fiber, eg 1000 Base-X */
struct tsec_private { tsec_t *regs; - tsec_mdio_t *phyregs; - tsec_mdio_t *phyregs_sgmii; - struct phy_info *phyinfo; + tsec_mii_t *phyregs_sgmii; + struct phy_device *phydev; + phy_interface_t interface; + struct mii_dev *bus; uint phyaddr; + char mii_devname[16]; u32 flags; - uint link; - uint duplexity; - uint speed; -}; - - -/* - * struct phy_cmd: A command for reading or writing a PHY register - * - * mii_reg: The register to read or write - * - * mii_data: For writes, the value to put in the register. - * A value of -1 indicates this is a read. - * - * funct: A function pointer which is invoked for each command. - * For reads, this function will be passed the value read - * from the PHY, and process it. - * For writes, the result of this function will be written - * to the PHY register - */ -struct phy_cmd { - uint mii_reg; - uint mii_data; - uint (*funct) (uint mii_reg, struct tsec_private * priv); -}; - -/* struct phy_info: a structure which defines attributes for a PHY - * - * id will contain a number which represents the PHY. During - * startup, the driver will poll the PHY to find out what its - * UID--as defined by registers 2 and 3--is. The 32-bit result - * gotten from the PHY will be shifted right by "shift" bits to - * discard any bits which may change based on revision numbers - * unimportant to functionality - * - * The struct phy_cmd entries represent pointers to an arrays of - * commands which tell the driver what to do to the PHY. - */ -struct phy_info { - uint id; - char *name; - uint shift; - /* Called to configure the PHY, and modify the controller - * based on the results */ - struct phy_cmd *config; - - /* Called when starting up the controller */ - struct phy_cmd *startup; - - /* Called when bringing down the controller */ - struct phy_cmd *shutdown; };
struct tsec_info_struct { tsec_t *regs; - tsec_mdio_t *miiregs; - tsec_mdio_t *miiregs_sgmii; + tsec_mii_t *miiregs_sgmii; char *devname; + char *mii_devname; + phy_interface_t interface; unsigned int phyaddr; u32 flags; };
Hi Andy,
This converts tsec to use the new PHY Lib. All of the old PHY support is ripped out. The old MDIO driver is split off, and placed in fsl_mdio.c. The initialization is modified to initialize the MDIO driver as well. The powerpc config file is modified to configure PHYLIB if TSEC_ENET is configured.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Signed-off-by: Andy Fleming afleming@freescale.com
diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c new file mode 100644 index 0000000..3239171 --- /dev/null +++ b/drivers/net/fsl_mdio.c @@ -0,0 +1,117 @@ +/*
- Copyright 2009-2010 Freescale Semiconductor, Inc.
- Jun-jie Zhang b18070@freescale.com
- Mingkai Hu Mingkai.hu@freescale.com
- MA 02111-1307 USA
+#include <common.h> +#include <miiphy.h> +#include <phy.h> +#include <fsl_mdio.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/fsl_enet.h>
int dev_addr, int regnum, int value)
- out_be32(&phyregs->miimadd, (port_addr << 8) | (regnum & 0x1f));
- asm("sync");
- while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--);
Semicolon needs to be on its own line.
- int value;
- asm("sync");
- out_be32(&phyregs->miimcom, MIIMCOM_READ_CYCLE);
- asm("sync");
&& timeout--);
dito.
Other than that this also looks good, so once my concerns are addressed:
Acked-by: Detlev Zundel dzu@denx.de
Cheers Detlev
Hi Andy,
The tsec driver had a bunch of PHY drivers already written. This converts them all into PHY Lib drivers, and serves as the first set of PHY drivers for PHY Lib.
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c new file mode 100644 index 0000000..68bb5cd --- /dev/null +++ b/drivers/net/phy/atheros.c @@ -0,0 +1,37 @@ +/*
- Atheros PHY drivers
- This software may be used and distributed according to the
- terms of the GNU Public License, Version 2, incorporated
- herein by reference.
Again, new files need GPLv2+. I know that this is split out from a GPLv2 file, but we have our rules in the meantime.
diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c new file mode 100644 index 0000000..e62a81d --- /dev/null +++ b/drivers/net/phy/broadcom.c @@ -0,0 +1,275 @@ +/*
- Broadcom PHY drivers
GPLv2+
+static int bcm54xx_parse_status(struct phy_device *phydev) +{
- unsigned int mii_reg;
- mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXSTATUS);
case 1:
phydev->duplex = DUPLEX_HALF;
phydev->speed = SPEED_10;
break;
case 2:
phydev->duplex = DUPLEX_FULL;
break;
case 3:
phydev->speed = SPEED_100;
break;
case 5:
break;
case 6:
phydev->speed = SPEED_1000;
break;
case 7:
break;
default:
break;
Very strange indentation, please fix.
diff --git a/drivers/net/phy/davicom.c b/drivers/net/phy/davicom.c new file mode 100644 index 0000000..229e1bd --- /dev/null +++ b/drivers/net/phy/davicom.c @@ -0,0 +1,86 @@ +/*
- Davicom PHY drivers
GPLv2+
diff --git a/drivers/net/phy/lxt.c b/drivers/net/phy/lxt.c new file mode 100644 index 0000000..4e38bb6 --- /dev/null +++ b/drivers/net/phy/lxt.c @@ -0,0 +1,76 @@ +/*
- LXT PHY drivers
GPLv2+
diff --git a/drivers/net/phy/marvell.c b/drivers/net/phy/marvell.c new file mode 100644 index 0000000..6937c93 --- /dev/null +++ b/drivers/net/phy/marvell.c @@ -0,0 +1,357 @@ +/*
- Marvell PHY drivers
dito
+/* Parse the 88E1011's status register for speed and duplex
- information
+static uint m88e1011s_parse_status(struct phy_device *phydev) +{
- mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1011_PHY_STATUS);
int i = 0;
phydev->link = 0;
break;
putc('.');
udelay(1000);
puts(" done\n");
Ah, again the "faster booting when waiting half a second" - probably that's the origin ;) Still a comment will be nice.
+/* Marvell 88E1118 */ +static int m88e1118_config(struct phy_device *phydev) +{
- phy_write(phydev, MDIO_DEVAD_NONE, MII_BMCR, BMCR_RESET);
- /* Change Page Number */
- phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0002);
- /* Delay RGMII TX and RX */
- phy_write(phydev, MDIO_DEVAD_NONE, 0x15, 0x1070);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0003);
- /* Adjust LED control */
- phy_write(phydev, MDIO_DEVAD_NONE, 0x10, 0x021e);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x16, 0x0000);
Below there are constants for the PHY_PAGE and LED_PAGE, so why not use them? Also there is a constant for the LED control, this makes sense IMHO.
- genphy_config_aneg(phydev);
+static int m88e1118_startup(struct phy_device *phydev) +{
- genphy_update_link(phydev);
- m88e1011s_parse_status(phydev);
+/* Marvell 88E1121R */ +static int m88e1121_config(struct phy_device *phydev) +{
- int pg;
- pg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE);
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE,
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_LED_CTRL,
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_PAGE, pg);
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_IRQ_EN, 0);
- phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1121_PHY_IRQ_STATUS);
This is what I mean - please code the 88e1118 case accordingly.
+/* Marvell 88E1145 */ +static int m88e1145_config(struct phy_device *phydev) +{
- int reg;
- phy_write(phydev, MDIO_DEVAD_NONE, 29, 0x001b);
- phy_write(phydev, MDIO_DEVAD_NONE, 30, 0x418f);
- phy_write(phydev, MDIO_DEVAD_NONE, 29, 0x0016);
- phy_write(phydev, MDIO_DEVAD_NONE, 30, 0xa2da);
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1011_PHY_SCR,
MIIM_88E1011_PHY_MDI_X_AUTO);
Hm, the 88e1145 uses 88e1011 constants? Maybe we can come up with 88e1xxx constants?
- reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_88E1145_PHY_EXT_CR);
- if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID)
reg |= MIIM_M88E1145_RGMII_RX_DELAY |
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1145_PHY_EXT_CR, reg);
+static int m88e1145_startup(struct phy_device *phydev) +{
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_88E1111_PHY_LED_CONTROL,
MIIM_88E1111_PHY_LED_DIRECT);
... and 88e1111 constants. Pretty confusing.
+/* Marvell 88E1149S */ +static int m88e1149_config(struct phy_device *phydev) +{
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x200c);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x0);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100);
Lots of magic numbers - defines would be nice.
diff --git a/drivers/net/phy/micrel.c b/drivers/net/phy/micrel.c new file mode 100644 index 0000000..4e0389a --- /dev/null +++ b/drivers/net/phy/micrel.c @@ -0,0 +1,29 @@ +/*
- Micrel PHY drivers
GPLv2+
--- /dev/null +++ b/drivers/net/phy/natsemi.c @@ -0,0 +1,85 @@ +/*
- National Semiconductor PHY drivers
GPLv2+
diff --git a/drivers/net/phy/realtek.c b/drivers/net/phy/realtek.c new file mode 100644 index 0000000..8cb696f --- /dev/null +++ b/drivers/net/phy/realtek.c @@ -0,0 +1,120 @@ +/*
- RealTek PHY drivers
dito.
+static int rtl8211b_parse_status(struct phy_device *phydev) +{
- mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MIIM_RTL8211B_PHY_STATUS);
int i = 0;
phydev->link = 1;
phydev->link = 0;
break;
putc('.');
puts(" done\n");
Once more half a second. Maybe this is not needed at all and costs us boot time on every single boot? We should really check if this is needed at all and remove it. Somehow I doubt that we need to do this generically.
diff --git a/drivers/net/phy/teranetics.c b/drivers/net/phy/teranetics.c new file mode 100644 index 0000000..387e044 --- /dev/null +++ b/drivers/net/phy/teranetics.c @@ -0,0 +1,43 @@ +/*
- Teranetics PHY drivers
GPLv2+
diff --git a/drivers/net/phy/vitesse.c b/drivers/net/phy/vitesse.c new file mode 100644 index 0000000..d34f04b --- /dev/null +++ b/drivers/net/phy/vitesse.c @@ -0,0 +1,330 @@ +/*
- Vitesse PHY drivers
dito
+static int cis8204_config(struct phy_device *phydev) +{
- phy_write(phydev, MDIO_DEVAD_NONE, MIIM_CIS8201_AUX_CONSTAT,
MIIM_CIS8201_AUXCONSTAT_INIT);
cis8204 usind CIS8201 constants and CIS8204 constants. Can we generalize some? This continues in the 8211 cases below...
If we cannot (easily) generalize, then maybe we should really have correctly named defines even if they are redundand? This would be more consistent and better for maintenance than the current mix.
diff --git a/include/phylib_all_drivers.h b/include/phylib_all_drivers.h new file mode 100644 index 0000000..a73b3d7 --- /dev/null +++ b/include/phylib_all_drivers.h @@ -0,0 +1,25 @@ +/*
- Enable all PHYs
GPLv2+
Otherwise looks good, thanks! Detlev
On Mar 30, 2011, at 7:26 AM, Detlev Zundel wrote:
Hi Andy,
Fixed.
- switch ((mii_reg & MIIM_BCM54xx_AUXSTATUS_LINKMODE_MASK) >>
MIIM_BCM54xx_AUXSTATUS_LINKMODE_SHIFT) {
case 1:
break;
case 2:
break;
case 3:
break;
case 5:
break;
case 6:
break;
case 7:
break;
default:
printf("Auto-neg error, defaulting to 10BT/HD\n");
break;
done
- information
int i = 0;
phydev->link = 0;
break;
putc('.');
udelay(1000);
puts(" done\n");
Hmm... I'm going to think about this one. We had some discussions about it on the list before, and I'm once again pondering whether we can drop it with proper changes. As usual, the 802.3 spec likes to leave some things up to PHY vendors. Like the meaning of "link up".
Sadly, I can fill in some of these, but Marvell did not provide documentation to us on these fixes. Just a sequence of register writes.
I'll ponder the half-second thing some more. I will note that this is the way it currently is for tsec, so it's not really a degradation in functionality, but I agree that other ports may not want to use Freescale's ugly hacks when things work just fine for them without them.
Andy
Hi Andy,
The new mdio command doesn't have all of the features of the mii command, but it provides the necessary read/write primitives, and allows users to interact with 10G PHYs, and other PHYs which use Clause 45 of 802.3. This means that the mdio command requires a "Device Address" argument, though for clause 22 PHYs, the argument can be "-".
common/Makefile | 3 + common/cmd_mdio.c | 293 +++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 296 insertions(+), 0 deletions(-) create mode 100644 common/cmd_mdio.c
+static int extract_range(char *input, int *plo, int *phi) +{
- char * end;
- *plo = simple_strtol(input, &end, 0);
- if (end == input)
return -1;
- if (*end == '-') {
What about the case of input="12-"? Shouldn't there be an "&& *(end+1)"?
end++;
*phi = simple_strtol(end, NULL, 0);
- } else if (*end == '\0') {
*phi = *plo;
- } else
return -1;
Other than that, looks good, so once my above concern is addressed
Thanks! Detlev
On Mar 30, 2011, at 6:55 AM, Detlev Zundel wrote:
Hi Andy,
- char * end;
- if (end == input)
return -1;
Ok. It should be noted that cmd_mii.c has the same issue.
I'm about to send out the v2.
Andy
Hi Andy,
Extends the mii_dev structure to participate in a full-blown MDIO and PHY driver scheme. The mii_dev structure and miiphy calls are modified in such a way to allow the original mii command and miiphy infrastructure to work as before, but also to support a new set of APIs which allow (among other things) sharing of PHY driver code and 10G support
The mii command will continue to support normal PHY management functions (Clause 22 of 802.3), but will not be changed to support 10G (Clause 45).
The basic design is similar to PHY Lib from Linux, but simplified for U-Boot's network and driver infrastructure.
We now have MDIO drivers and PHY drivers
An MDIO driver provides: read write reset
A PHY driver provides: (optionally): probe config - initial setup, starting of auto-negotiation startup - waiting for AN, and reading link state shutdown - any cleanup needed
The ethernet drivers interact with the PHY Lib using these functions: phy_connect() phy_config() phy_startup() phy_shutdown()
Each PHY driver can be configured separately, or all at once using phylib_all_drivers.h (added in the patch which adds the drivers)
Looks really good - a few comments:
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c new file mode 100644 index 0000000..ca35404 --- /dev/null +++ b/drivers/net/phy/phy.c @@ -0,0 +1,705 @@ +/*
- Generic PHY Management code
- Copyright 2011 Freescale Semiconductor, Inc.
- author Andy Fleming
- Based loosely off of Linux's PHY Lib
According to http://www.denx.de/wiki/U-Boot/Patches new files need GPLv2+ headers and if I check Linux, I see GPLv2+ in drivers/net/phy/phy.c (and other people have contributed under this), so please change accrodingly.
- genphy_update_link - update link status in @phydev
- @phydev: target phy_device struct
- Description: Update the value in phydev->link to reflect the
- current link value. In order to do this, we need to read
- the status register twice, keeping the second value.
+int genphy_update_link(struct phy_device *phydev) +{
* Wait if the link is up, and autonegotiation is in progress
* (ie - we're capable and it's not done)
- mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR);
* If we already saw the link up, and it hasn't gone down, then
* we don't need to wait for autoneg again
- if (phydev->link && mii_reg & BMSR_LSTATUS)
- if ((mii_reg & BMSR_ANEGCAPABLE) && !(mii_reg & BMSR_ANEGCOMPLETE)) {
int i = 0;
printf("%s Waiting for PHY auto negotiation to complete",
phydev->dev->name);
while (!(mii_reg & BMSR_ANEGCOMPLETE)) {
* Timeout reached ?
if (i > 5000) {
printf(" TIMEOUT !\n");
phydev->link = 0;
if (ctrlc()) {
puts("user interrupt!\n");
phydev->link = 0;
return -EINTR;
if ((i++ % 500) == 0)
printf(".");
udelay(1000); /* 1 ms */
printf(" done\n");
phydev->link = 1;
udelay(500000); /* another 500 ms (results in faster booting) */
I don't understand this, why does sleeping half a second speed up booting? A comment would be in order here.
- } else {
/* Read the link a second time to clear the latched state */
if (mii_reg & BMSR_LSTATUS)
phydev->link = 1;
else
phydev->link = 0;
+struct phy_driver *get_phy_driver(struct phy_device *phydev,
phy_interface_t interface)
- struct list_head *entry;
- int phy_id = phydev->phy_id;
- struct phy_driver *drv = NULL;
- list_for_each(entry, &phy_drivers) {
drv = list_entry(entry, struct phy_driver, list);
if ((drv->uid & drv->mask) == (phy_id & drv->mask))
return drv;
- /* If we made it here, there's no driver for this PHY */
- if (interface == PHY_INTERFACE_MODE_XGMII)
return &gen10g_driver;
- else
return &genphy_driver;
Maybe output a warning when the generic driver is used? From what I see later we should get a message from phy_connect, correct? If this is the case, then disregard this comment ;)
Apart from these minor things, the code looks really good. I'm looking forward to seeing this merged, thanks a lot! Detlev
Hi Andy,
There were a few files which were already using phy_read and phy_write for their PHY function names. It's only a few places, and the name seems most appropriate for the high-level abstraction, so let's rename the other versions to something more specific.
Also, uec_phy.c had a marvell_init function which I renamed to not conflict with the one in marvell.c
Looks like these are harmless changes, so
Might be worthwhile to see some Tested-by from people with the hardware though.
Cheers Detlev
Hi Andy,
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Acked-by: Andy Fleming afleming@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org
drivers/net/tsec.c | 857 +++++++++++++++++++++++++--------------------------- 1 files changed, 416 insertions(+), 441 deletions(-)
Does this patch really only rearrange code and not change any functionality? In this case this information should be in the commit message IMHO.
Cheers Detlev
I'm concerned this differs from the version in 85xx 'next'
- k
Ah, I didnt see it was already in next
- k
drivers/net/tsec.c | 234 ++++++++++++++++++++++++++------------------------- include/tsec.h | 8 +- 2 files changed, 123 insertions(+), 119 deletions(-)
This is already in 85xx next
- k
Hi Andy,
Or PHY Lib for U-Boot.
This sequence of patches adds infrastructure for universally-available PHY drivers (and MDIO drivers). It piggy-backs on the existing miiphy code, for backwards compatibility, but it also creates a new set of APIs. This was necessary partly to provide cleaner interfaces for more robust driver support, and partly because one goal was to support 10G (802.3 Clause 45) MDIO buses, which has an extra argument for addressing PHY registers.
The first three patches clear the way, and are in this sequence mostly because the tsec changes depend on them.
Special thanks goes to Mingkai Hu, who did a substantial amount of work up front to convert the tsec PHY code into something more usable, which I have mostly copied for the purposes of PHY Lib.
As the subject says, these are submitted here for comment. I hope they will go in for the presumptive June release.
Andy Fleming (5): Remove instances of phy_read/write Create PHY Lib for U-Boot Add mdio command for new PHY infrastructure phylib: Add a bunch of PHY drivers from tsec tsec: Convert tsec to use PHY Lib
Mingkai Hu (2): tsec: use IO accessories to access the register tsec: arrange the code to avoid useless function declaration
Thanks for this extensive work! Still the whole series has checkpatch problems, so please clean them up:
total: 29 errors, 95 warnings, 7792 lines checked
Some of them can be ignored, but some like this really need fixing:
ERROR: trailing statements should be on next line #206: FILE: drivers/net/tsec.c:243: + while ((in_be32(&phyregs->miimind) & MIIMIND_BUSY) && timeout--) ;
Cheers Detlev
participants (5)
Andy Fleming
Detlev Zundel
Fleming Andy-AFLEMING
Kumar Gala
Mike Frysinger
