[U-Boot] [PATCH] arm: mvebu: armada-370-xp.dtsi: Add "u-boot, dm-pre-reloc" to "internal-regs"
Without this U-Boot specific property, booting on Armada XP theadorable fails in SPL. All nodes in the "internal-regs" (simple-bus) DT node are not scanned, so the UART node is missing (and others).
I'm not adding this property in an *u-boot.dtsi file, since there is none matching the generic rules for all files including this dtsi file. So to not miss any of the boards using this dtsi file, I'm adding it to this file directly, which makes the Linux merge a less easy unforunately.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chris Packham judge.packham@gmail.com Cc: Marek Behún marek.behun@nic.cz --- arch/arm/dts/armada-370-xp.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/armada-370-xp.dtsi b/arch/arm/dts/armada-370-xp.dtsi index e4c35d4e98..50fc0be9f7 100644 --- a/arch/arm/dts/armada-370-xp.dtsi +++ b/arch/arm/dts/armada-370-xp.dtsi @@ -102,6 +102,7 @@ #address-cells = <1>; #size-cells = <1>; ranges = <0 MBUS_ID(0xf0, 0x01) 0 0x100000>; + u-boot,dm-pre-reloc;
rtc: rtc@10300 { compatible = "marvell,orion-rtc";
Thanks. Is this a regression from my last sync? The only Armada XP like platform I had access to was msys and that doesn't use SPL (yet).
Reviewed-by: Chris Packham judge.packham@gmail.com
u-boot,dm-pre-reloc; rtc: rtc@10300 { compatible = "marvell,orion-rtc";
-- 2.21.0
On 11.05.19 02:09, Chris Packham wrote:
On Fri, 10 May 2019, 11:34 PM Stefan Roese, <sr@denx.de mailto:sr@denx.de> wrote:
Without this U-Boot specific property, booting on Armada XP theadorable fails in SPL. All nodes in the "internal-regs" (simple-bus) DT node are not scanned, so the UART node is missing (and others). I'm not adding this property in an *u-boot.dtsi file, since there is none matching the generic rules for all files including this dtsi file. So to not miss any of the boards using this dtsi file, I'm adding it to this file directly, which makes the Linux merge a less easy unforunately. Signed-off-by: Stefan Roese <sr@denx.de <mailto:sr@denx.de>> Cc: Chris Packham <judge.packham@gmail.com <mailto:judge.packham@gmail.com>> Cc: Marek Behún <marek.behun@nic.cz <mailto:marek.behun@nic.cz>>
I'm not 100% sure if its only a regression caused by your DT sync or also by this patch:
c7a88dae "dm: remove pre reloc properties in SPL and TPL device tree"
I stopped debugging at some point, once I had the node enabled in the SPL DT again.
Reviewed-by: Chris Packham <judge.packham@gmail.com mailto:judge.packham@gmail.com>
Thanks, Stefan
^^^ Gah, this is from the gmail app on my tablet it seems intent on linkifying things now. This has been known to make the patchwork client spew html into the patch when you download it.
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
