[PATCH v2 0/4] mkimage usability fixes
v2: Move -B and -E out from FIT_SIGNATURE check, and other fixes from Philippe's review.
Original cover letter:
I was learning about signed FIT today and was unable to convince mkimage to produce a signature node in my control device tree. It turns out that Debian's packaged mkimage doesn't enable FIT_SIGNATURE, so the options I was passing were silently ignored.
There's an existing Debian bug for that[1] but in the mean time this changes mkimage's behaviour to fail loudly when FIT_SIGNATURE is disabled.
The first two patches fix some issues I found when testing the third patch under sandbox_defconfig with FIT_SIGNATURE=n.
[1] https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=972513
Joel Stanley (4): tools/Makefile: FIT_CIPHER requires libssl image-fit: Fix FIT_CIPHER linking mkimage: Move padding commands outside of FIT_SIGNATURE mkimge: Reject signing-related flags without FIT_SIGNATURE
common/image-fit-sig.c | 14 -------------- common/image-fit.c | 15 +++++++++++++++ tools/Makefile | 2 +- tools/mkimage.c | 18 +++++++++++------- 4 files changed, 27 insertions(+), 22 deletions(-)
If CONFIG_FIT_CIPHER is enabled without CONFIG_FIT_SIGNATURE then mkimage/dumpimage will fail to link:
/usr/bin/ld: tools/common/image-cipher.o: in function `fit_image_decrypt_data': image-cipher.c:(.text+0x9a): undefined reference to `image_get_host_blob' /usr/bin/ld: tools/common/image-cipher.o:(.data.rel+0x10): undefined reference to `EVP_aes_128_cbc' /usr/bin/ld: tools/common/image-cipher.o:(.data.rel+0x40): undefined reference to `EVP_aes_192_cbc' /usr/bin/ld: tools/common/image-cipher.o:(.data.rel+0x70): undefined reference to `EVP_aes_256_cbc' /usr/bin/ld: tools/lib/aes/aes-encrypt.o: in function `image_aes_encrypt': aes-encrypt.c:(.text+0x22): undefined reference to `EVP_CIPHER_CTX_new' /usr/bin/ld: aes-encrypt.c:(.text+0x6f): undefined reference to `EVP_EncryptInit_ex' /usr/bin/ld: aes-encrypt.c:(.text+0x8d): undefined reference to `EVP_EncryptUpdate' /usr/bin/ld: aes-encrypt.c:(.text+0xac): undefined reference to `EVP_CIPHER_CTX_free' /usr/bin/ld: aes-encrypt.c:(.text+0xf2): undefined reference to `EVP_EncryptFinal_ex' collect2: error: ld returned 1 exit status
Signed-off-by: Joel Stanley joel@jms.id.au --- tools/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/Makefile b/tools/Makefile index 253a6b97065b..99a931312cd8 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -154,7 +154,7 @@ HOSTCFLAGS_kwbimage.o += -DCONFIG_KWB_SECURE endif
# MXSImage needs LibSSL -ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE),) +ifneq ($(CONFIG_MX23)$(CONFIG_MX28)$(CONFIG_ARMADA_38X)$(CONFIG_ARMADA_39X)$(CONFIG_FIT_SIGNATURE)$(CONFIG_FIT_CIPHER),) HOSTCFLAGS_kwbimage.o += \ $(shell pkg-config --cflags libssl libcrypto 2> /dev/null || echo "") HOSTLDLIBS_mkimage += \
Hi Joel,
Reviewed-by: Philippe Reynes philippe.reynes@softathome.com
Regards,
Philippe
When CONFIG_FIT_CIPHER=y and CONFIG_FIT_SIGNATURE=n is there is no implementation of image_get_host_blob for mkimage/dumpimage:
Move the implementation to a common file so it can be shaed between image-cipher.c and image-fit-sig.c.
Signed-off-by: Joel Stanley joel@jms.id.au --- v2: Fix compilation when signature and ciphering are both enabled --- common/image-fit-sig.c | 14 -------------- common/image-fit.c | 15 +++++++++++++++ 2 files changed, 15 insertions(+), 14 deletions(-)
diff --git a/common/image-fit-sig.c b/common/image-fit-sig.c index 5401d9411b98..d39741e9058f 100644 --- a/common/image-fit-sig.c +++ b/common/image-fit-sig.c @@ -19,20 +19,6 @@ DECLARE_GLOBAL_DATA_PTR;
#define IMAGE_MAX_HASHED_NODES 100
-#ifdef USE_HOSTCC -void *host_blob; - -void image_set_host_blob(void *blob) -{ - host_blob = blob; -} - -void *image_get_host_blob(void) -{ - return host_blob; -} -#endif - /** * fit_region_make_list() - Make a list of image regions * diff --git a/common/image-fit.c b/common/image-fit.c index c82d4d8015f0..664a0d00006c 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -112,6 +112,21 @@ int fit_parse_subimage(const char *spec, ulong addr_curr, } #endif /* !USE_HOSTCC */
+#ifdef USE_HOSTCC +/* Host tools use these implementations for Cipher and Signature support */ +static void *host_blob; + +void image_set_host_blob(void *blob) +{ + host_blob = blob; +} + +void *image_get_host_blob(void) +{ + return host_blob; +} +#endif /* USE_HOSTCC */ + static void fit_get_debug(const void *fit, int noffset, char *prop_name, int err) {
Hi Joel
- host_blob = blob;
- return host_blob;
-} -#endif
- fit_region_make_list() - Make a list of image regions
- host_blob = blob;
- return host_blob;
- static void fit_get_debug(const void *fit, int noffset, char *prop_name, int err) {
Regards, Philippe
These commands were disabled when CONFIG_FIT_SIGNATURE is disabled, but they do not depend on crypto support so they can be unconditionally enabled.
Signed-off-by: Joel Stanley joel@jms.id.au -- v2: New patch --- tools/mkimage.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index e78608293e72..68d5206cb4fd 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -94,18 +94,18 @@ static void usage(const char *msg) " -x ==> set XIP (execute in place)\n", params.cmdname); fprintf(stderr, - " %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] [-i <ramdisk.cpio.gz>] fit-image\n" + " %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] [-E] [-B size] [-i <ramdisk.cpio.gz>] fit-image\n" " <dtb> file is used with -f auto, it may occur multiple times.\n", params.cmdname); fprintf(stderr, " -D => set all options for device tree compiler\n" " -f => input filename for FIT source\n" - " -i => input filename for ramdisk file\n"); + " -i => input filename for ramdisk file\n" + " -E => place data outside of the FIT structure\n" + " -B => align size in hex for FIT structure and header\n"); #ifdef CONFIG_FIT_SIGNATURE fprintf(stderr, - "Signing / verified boot options: [-E] [-B size] [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r] [-N engine]\n" - " -E => place data outside of the FIT structure\n" - " -B => align size in hex for FIT structure and header\n" + "Signing / verified boot options: [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r] [-N engine]\n" " -k => set directory containing private keys\n" " -K => write public keys to this .dtb file\n" " -c => add comment in signature node\n" @@ -142,6 +142,7 @@ static int add_content(int type, const char *fname) return 0; }
+#define OPT_STRING "a:A:b:B:c:C:d:D:e:Ef:Fk:i:K:ln:N:p:O:rR:qstT:vVx" static void process_args(int argc, char **argv) { char *ptr;
Hi Joel
v2: New patch
" <dtb> file is used with -f auto, it may occur multiple times.\n", params.cmdname); fprintf(stderr, " -D => set all options for device tree compiler\n" " -f => input filename for FIT source\n"" %s [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb>]] [-E] [-B size] [-i <ramdisk.cpio.gz>] fit-image\n"
#ifdef CONFIG_FIT_SIGNATURE fprintf(stderr," -B => align size in hex for FIT structure and header\n");
" -k => set directory containing private keys\n" " -K => write public keys to this .dtb file\n" " -c => add comment in signature node\n""Signing / verified boot options: [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r] [-N engine]\n"
Option -p is a generic option, not a signing option. it defines the offset of the padding. So it should be moved above.
Option -k, -K are also used for ciphering. So it signature is disabled and ciphering is enabled, the help won't display those options. I think it could be acceptable to use #if CONFIG_IS_ENABLED(FIT_SIGNATURE) || CONFIG_IS_ENABLED(FIT_CIPHER) and also change a bit the text "Signing / verified option ..."
@@ -142,6 +142,7 @@ static int add_content(int type, const char *fname) return 0; } +#define OPT_STRING "a:A:b:B:c:C:d:D:e:Ef:Fk:i:K:ln:N:p:O:rR:qstT:vVx"
I think that OPT_STRING should be defined in the next patch.
Regards, Philippe
When CONFIG_FIT_SIGNATURE=n the signing options are not available. If a user is careful they will notice this when looking at the help output.
If they are not careful they will waste several hours wondering why their FIT doesn't contain a /signature node, as mkimage will silently ingore the signing related options.
Make it obvious that the commands don't work by removing them from the getopt opt_string.
$ mkimage -f machine.its -k keys -K u-boot-pubkey.dtb -r image.fit mkimage: invalid option -- 'k' Error: Invalid option
Signed-off-by: Joel Stanley joel@jms.id.au -- v2: Leave padding related options in the CONFIG_FIT_SIGNATURE=y optargs --- tools/mkimage.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index 68d5206cb4fd..f7d3ac40e681 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -142,7 +142,11 @@ static int add_content(int type, const char *fname) return 0; }
+#ifdef CONFIG_FIT_SIGNATURE #define OPT_STRING "a:A:b:B:c:C:d:D:e:Ef:Fk:i:K:ln:N:p:O:rR:qstT:vVx" +#else +#define OPT_STRING "a:A:b:B:C:d:D:e:Ef:i:ln:O:R:qstT:vVx" +#endif static void process_args(int argc, char **argv) { char *ptr; @@ -150,8 +154,7 @@ static void process_args(int argc, char **argv) char *datafile = NULL; int opt;
- while ((opt = getopt(argc, argv, - "a:A:b:B:c:C:d:D:e:Ef:Fk:i:K:ln:N:p:O:rR:qstT:vVx")) != -1) { + while ((opt = getopt(argc, argv, OPT_STRING)) != -1) { switch (opt) { case 'a': params.addr = strtoull(optarg, &ptr, 16);
Hi Joel
Option -k and -K is also needed for ciphering. So we should also check FIT_CIPHER. Option -p is "generic", it is used to define the size of the padding.
- while ((opt = getopt(argc, argv, OPT_STRING)) != -1) { switch (opt) { case 'a': params.addr = strtoull(optarg, &ptr, 16);
Regards, Philippe
On Tue, 8 Dec 2020 at 08:38, Philippe REYNES philippe.reynes@softathome.com wrote:
Hi Joel
I have somehow missed these patches on the mailing list. I'm not sure why, but I'm not going to review them as is.
This part of the series breaks a huge number of platforms default build because we don't have 'p' which is: -p => place external data at a static position and not strictly used in signature only options and is used for FIT_EXTERNAL_OFFSET. While I could adjust the patch to keep 'p' in both cases I wanted to bring this up so it's not a surprise and ask you to update just this patch, or suggest things need to be further adjusted. The rest of the series seems fine and is under review. Thanks!
Joel Stanley
Philippe REYNES
