[U-Boot] [PATCH] USB: Add high-speed (480Mb/s) to all USB related outputs
With this patch the USB related connection speed output ("usb tree" command and debug output) is now high-speed enabled.
This patch also fixes a compilation warning when debugging is enabled.
Signed-off-by: Stefan Roese sr@denx.de --- This patch is a replacement for the patch "USB: Change "usb tree" cmd to print 480MBit upon highspeed connection" sent on 2009-01-21. Again based on the usb/testing branch.
common/cmd_usb.c | 12 +++++++++++- common/usb.c | 19 +++++++++++++------ 2 files changed, 24 insertions(+), 7 deletions(-)
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 9e55c7c..c9eaa64 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -264,6 +264,16 @@ void usb_display_config(struct usb_device *dev) printf("\n"); }
+static inline char *portspeed(int speed) +{ + if (speed == USB_SPEED_HIGH) + return "480 Mb/s"; + else if (speed == USB_SPEED_LOW) + return "1.5 Mb/s"; + else + return "12 Mb/s"; +} + /* shows the device tree recursively */ void usb_show_tree_graph(struct usb_device *dev, char *pre) { @@ -310,7 +320,7 @@ void usb_show_tree_graph(struct usb_device *dev, char *pre) pre[index] = 0; printf(" %s (%s, %dmA)\n", usb_get_class_desc( dev->config.if_desc[0].bInterfaceClass), - dev->speed ? "1.5MBit/s" : "12MBit/s", + portspeed(dev->speed), dev->config.MaxPower * 2); if (strlen(dev->mf) || strlen(dev->prod) || strlen(dev->serial)) printf(" %s %s %s %s\n", pre, dev->mf, dev->prod, dev->serial); diff --git a/common/usb.c b/common/usb.c index 3350127..6ef36ad 100644 --- a/common/usb.c +++ b/common/usb.c @@ -681,7 +681,7 @@ int usb_string(struct usb_device *dev, int index, char *buf, size_t size) err = usb_string_sub(dev, 0, 0, tbuf); if (err < 0) { USB_PRINTF("error getting string descriptor 0 " \ - "(error=%x)\n", dev->status); + "(error=%lx)\n", dev->status); return -1; } else if (tbuf[0] < 4) { USB_PRINTF("string descriptor 0 too short\n"); @@ -1041,6 +1041,16 @@ struct usb_hub_device *usb_hub_allocate(void)
#define MAX_TRIES 5
+static inline char *portspeed(int portstatus) +{ + if (portstatus & (1 << USB_PORT_FEAT_HIGHSPEED)) + return "480 Mb/s"; + else if (portstatus & (1 << USB_PORT_FEAT_LOWSPEED)) + return "1.5 Mb/s"; + else + return "12 Mb/s"; +} + static int hub_port_reset(struct usb_device *dev, int port, unsigned short *portstat) { @@ -1064,8 +1074,7 @@ static int hub_port_reset(struct usb_device *dev, int port,
USB_HUB_PRINTF("portstatus %x, change %x, %s\n", portstatus, portchange, - portstatus & (1 << USB_PORT_FEAT_LOWSPEED) ? \ - "Low Speed" : "High Speed"); + portspeed(portstatus));
USB_HUB_PRINTF("STAT_C_CONNECTION = %d STAT_CONNECTION = %d" \ " USB_PORT_STAT_ENABLE %d\n", @@ -1111,9 +1120,7 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port) portstatus = le16_to_cpu(portsts.wPortStatus); portchange = le16_to_cpu(portsts.wPortChange); USB_HUB_PRINTF("portstatus %x, change %x, %s\n", - portstatus, portchange, - portstatus&(1 << USB_PORT_FEAT_LOWSPEED) ? \ - "Low Speed" : "High Speed"); + portstatus, portchange, portspeed(portstatus));
/* Clear the connection change status */ usb_clear_port_feature(dev, port + 1, USB_PORT_FEAT_C_CONNECTION);
Hello Stefan,
I moved your complete series to the usb/testing branch for compile/regression testing.
Thanks.
Remy
2009/1/22 Stefan Roese sr@denx.de:
return "480 Mb/s";
return "1.5 Mb/s";
else
return "12 Mb/s";
#define MAX_TRIES 5
return "480 Mb/s";
return "1.5 Mb/s";
else
return "12 Mb/s";
portspeed(portstatus)); USB_HUB_PRINTF("STAT_C_CONNECTION = %d STAT_CONNECTION = %d" \ " USB_PORT_STAT_ENABLE %d\n",
portstatus, portchange, portspeed(portstatus)); /* Clear the connection change status */ usb_clear_port_feature(dev, port + 1, USB_PORT_FEAT_C_CONNECTION);
-- 1.6.1
Remy Bohmer
Stefan Roese
