[U-Boot] [PATCH] P4080/esdhc: make the P4080 ESDHC13 errata workaround conditional
P4080 Rev3.0 fixes ESDHC13 errata, so update the code to make the workaround conditional. In formal release document, the errata number should be ESDHC13 instead of ESDHC136.
Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- for sdk1.3. fix defect ENGR180745
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 5 +++-- arch/powerpc/cpu/mpc85xx/cpu_init.c | 10 ++++++---- arch/powerpc/include/asm/config_mpc85xx.h | 2 +- 3 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 38e23c8..acc3b83 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -79,8 +79,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_SYS_FSL_ERRATUM_ESDHC135) puts("Work-around for Erratum ESDHC135 enabled\n"); #endif -#if defined(CONFIG_SYS_FSL_ERRATUM_ESDHC136) - puts("Work-around for Erratum ESDHC136 enabled\n"); +#if defined(CONFIG_SYS_FSL_ERRATUM_ESDHC13) + if (SVR_MAJ(svr) < 3) + puts("Work-around for Erratum ESDHC13 enabled\n"); #endif #if defined(CONFIG_SYS_FSL_ERRATUM_ESDHC_A001) puts("Work-around for Erratum ESDHC-A001 enabled\n"); diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 2397547..fe4b39e 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -495,11 +495,13 @@ skip_l2: setup_mp(); #endif
-#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC136 +#ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC13 { - void *p; - p = (void *)CONFIG_SYS_DCSRBAR + 0x20520; - setbits_be32(p, 1 << (31 - 14)); + if (SVR_MAJ(svr) < 3) { + void *p; + p = (void *)CONFIG_SYS_DCSRBAR + 0x20520; + setbits_be32(p, 1 << (31 - 14)); + } } #endif
diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index fab01d5..ddd6557 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -387,7 +387,7 @@ #define CONFIG_SYS_FSL_ERRATUM_ELBC_A001 #define CONFIG_SYS_FSL_ERRATUM_ESDHC111 #define CONFIG_SYS_FSL_ERRATUM_ESDHC135 -#define CONFIG_SYS_FSL_ERRATUM_ESDHC136 +#define CONFIG_SYS_FSL_ERRATUM_ESDHC13 #define CONFIG_SYS_P4080_ERRATUM_CPU22 #define CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011 #define CONFIG_SYS_P4080_ERRATUM_SERDES8
Roy Zang
