[U-Boot] [PATCH 1/2] mx6sabreauto: Do not enable WEIM by default
WEIM cannot be used when I2C3 is enabled due to pin conflict, so keep WEIM disabled by default.
I2C3 controls GPIO I2C expander (USB host and OTG have VBUS controlled by the GPIO I2C expander), magnetometer, accelerometer.
Not disabling WEIM in U-Boot causes I2C3 to behave badly when booting a NXP 4.1 kernel, which leads to probe failure on several devices, including the lack of USB:
imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517
By keeping WEIM disabled in U-Boot these kernel issues are gone.
Reported-by: Takashi Matsuzawa tmatsuzawa@xevo.com Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- board/freescale/mx6sabreauto/mx6sabreauto.c | 9 ++++++++- configs/mx6sabreauto_defconfig | 2 +- include/configs/mx6sabreauto.h | 2 ++ 3 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index 927ebe4..8faf479 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -197,6 +197,7 @@ static int port_exp_direction_output(unsigned gpio, int value) return 0; }
+#ifdef CONFIG_MTD_NOR_FLASH static iomux_v3_cfg_t const eimnor_pads[] = { IOMUX_PADS(PAD_EIM_D16__EIM_DATA16 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), IOMUX_PADS(PAD_EIM_D17__EIM_DATA17 | MUX_PAD_CTRL(WEIM_NOR_PAD_CTRL)), @@ -292,6 +293,7 @@ static void setup_iomux_eimnor(void)
eimnor_cs_setup(); } +#endif
static void setup_iomux_enet(void) { @@ -571,8 +573,10 @@ int board_early_init_f(void) #ifdef CONFIG_NAND_MXS setup_gpmi_nand(); #endif - eim_clk_setup();
+#ifdef CONFIG_MTD_NOR_FLASH + eim_clk_setup(); +#endif return 0; }
@@ -601,7 +605,10 @@ int board_init(void) #ifdef CONFIG_VIDEO_IPUV3 setup_display(); #endif + +#ifdef CONFIG_MTD_NOR_FLASH setup_iomux_eimnor(); +#endif return 0; }
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index c1b3bbf..f8b2f7d 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -38,7 +38,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y -CONFIG_MTD_NOR_FLASH=y +# CONFIG_MTD_NOR_FLASH is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index fd0d5ce..2c08fd1 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -31,6 +31,7 @@
#include "mx6sabre_common.h"
+#ifdef CONFIG_MTD_NOR_FLASH #define CONFIG_SYS_FLASH_BASE WEIM_ARB_BASE_ADDR #define CONFIG_SYS_FLASH_SECT_SIZE (128 * 1024) #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ @@ -40,6 +41,7 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* Use buffered writes*/ #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#endif
#define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC)
mx6sabre boards can run different kernel versions, such as NXP 4.1 or mainline.
Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version.
In order to avoid such issue, use UUID method to specify the rootfs location.
Succesfully tested booting a NXP 4.1 and also a mainline kernel on a mx6qsabresd and mx6dlsabreauto.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- configs/mx6sabreauto_defconfig | 1 + configs/mx6sabresd_defconfig | 1 + include/configs/mx6sabre_common.h | 5 +++-- include/configs/mx6sabreauto.h | 1 - include/configs/mx6sabresd.h | 1 - 5 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index f8b2f7d..73b81ea 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index a1d0c84..7adc7da 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 9b0fe5a..d4e4628 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -77,7 +77,7 @@ "initrd_high=0xffffffff\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "mmcpart=1\0" \ - "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "finduuid=part uuid mmc ${mmcdev}:2 uuid\0" \ "update_sd_firmware=" \ "if test ${ip_dyn} = yes; then " \ "setenv get_cmd dhcp; " \ @@ -93,7 +93,7 @@ "fi\0" \ EMMC_ENV \ "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=${mmcroot}\0" \ + "root=PARTUUID=${uuid} rootwait rw\0" \ "loadbootscript=" \ "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ "bootscript=echo Running bootscript from mmc ...; " \ @@ -101,6 +101,7 @@ "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ "mmcboot=echo Booting from mmc ...; " \ + "run finduuid; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ "if run loadfdt; then " \ diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 2c08fd1..1883eb0 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -16,7 +16,6 @@ #define CONFIG_MACH_TYPE 3529 #define CONFIG_MXC_UART_BASE UART4_BASE #define CONSOLE_DEV "ttymxc3" -#define CONFIG_MMCROOT "/dev/mmcblk0p2"
/* USB Configs */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 3eba70a..27e7672 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -16,7 +16,6 @@ #define CONFIG_MACH_TYPE 3980 #define CONFIG_MXC_UART_BASE UART1_BASE #define CONSOLE_DEV "ttymxc0" -#define CONFIG_MMCROOT "/dev/mmcblk1p2"
#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
Applied to -master, thanks !
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
