DDR timing for vendor board
Hi all,
I have a RK3288 board from a Chinese display vendor that came with the usual giant Rockchip tarball that they patched here and there to make the board work. It seems to be based on a rk3288-evb, since that is what they patched in the kernel. The kernel is a 4.4 kernel with Android stuff in it (i.e. fiq-debugger) and a large amount of Rockchip patches, u-boot is 2017.09, with rk patches.
It turns out that u-boot TPL/SPL won't boot because the DDR timings are incorrect, and the Chinese vendor uses the Rockchip rk3288_ddr_400MHz_v1.09.bin loader. I'm using u-boot 2022.01 for now, and I've tried to naively modify the timing in arch/arm/dts/rk3288-evb.dts, but it doesn't work at all, with varying errors on boot.
The Rockchip loader provides the following info when booting:
In Channel a: DDR3 400MHz Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB Memory OK OUT Boot1 Release Time: Apr 11 2018 10:32:58, version: 2.36 ChipType = 0x8, 232
I've tried various DDR3 (not LPDDR3) settings from other boards, for example for a Firefly (666 MHz DDR3):
U-Boot TPL 2022.01 (Jan 10 2022 - 18:46:34) Col detect error DRAM init failed! ### ERROR ### Please RESET the board ###
It was expected that 666MHz doesn't work, but if I just change the frequency in the dts, that also fails (error -22).
How can I support the DDR for this board? I can't even see what the ID on the chips is, because the heatsink is blocking sight and seems to be attached with some sort of thermal glue.
Is there a way to read back the DDR timings (phy-timing, sdram-params) from the kernel/SoC on a board that is booted using the proprietary loader?
Cheers!
Rob
On 08/12/2022 04:01, Rob Kramer wrote:
Hi all,
Cheers!
Rob
Hi Rob,
You could be in for a world of hurt here as Rockchip are very poor at supporting different DDR init configurations in u-boot. In the past with awkward boards I've used the Rockchip DDR init blob as the TPL binary for u-boot then skip the DRAM init in the u-boot SPL.
From my travels in this area I've found that single channel RAM boards
are particularly difficult to get working as the majority if not all mainlined board use dual channel RAM.
Sorry I can't be more help, but trying to use the DDR blob is a good starting point to get you going on mainline.
Good Luck!
Hi Jack,
Thanks for your suggestion, I hadn't thought of using just the rkbin ddr file together with u-boot SPL. My biggest objection was the rkbin miniloader that makes assumptions on partition layout.
It seems to work, but now I'm in for some DT pain :)
Cheers,
Rob
9 Dec 2022 00:49:30 Jack Mitchell ml@embed.me.uk:
Hi all,
Cheers!
Rob
Hi Rob,
From my travels in this area I've found that single channel RAM boards are particularly difficult to get working as the majority if not all mainlined board use dual channel RAM.
Good Luck!
-- Jack Mitchell, Consultant https://www.tuxable.co.uk
Hi Rob,
On 12/9/22 12:10, Rob Kramer wrote:
Hi Jack,
I don't know anything about Rockchip but from experience with other SoC's and DDR2/3 controllers I would say that the reason for this closed-source loader is likely some proprietary dynamic tuning algorithm for some memory controller parameters (e.g. DQS) to adapt to manufacturing tolerances of the board. If that's the case, the static setting of memory size and timings via DT won't be enough to run the board stable and Jack's approach would be more reliable.
Cheers,
Rob
Hi all,
Cheers!
Rob
Hi Rob,
Good Luck!
Daniel Schwierzeck
Jack Mitchell
Rob Kramer
