[U-Boot] [PATCH 4/5] video: cfb_console: Allow VGA device to work without i8042 keyboard
So far if CONFIG_VGA_AS_SINGLE_DEVICE is not defined, the VGA device will try to initialize a keyboard device (for x86, it is i8042). But if i8042 controller initialization fails (eg: there is no keyboard connected to the PS/2 port), drv_video_init() just simply returns. This kills the opportunity of using a usb keyboard later with the vga concole, as the vga initialization part is actually ok, only keyboard part fails. Change the code logic to allow this.
Signed-off-by: Bin Meng bmeng.cn@gmail.com
--- In the long term, we should remove CONFIG_VGA_AS_SINGLE_DEVICE and treat the cfb_concole an output device only. The keyboard part should be moved out of cfb_console driver and be as a input device driver separately.
drivers/video/cfb_console.c | 11 +++++------ 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index 30e0317..aa7ca86 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -2247,16 +2247,17 @@ __weak int board_video_skip(void)
int drv_video_init(void) { - int skip_dev_init; struct stdio_dev console_dev; bool have_keyboard; + bool __maybe_unused keyboard_ok = false;
/* Check if video initialization should be skipped */ if (board_video_skip()) return 0;
/* Init video chip - returns with framebuffer cleared */ - skip_dev_init = (video_init() == -1); + if (video_init() == -1) + return 0;
if (board_cfb_skip()) return 0; @@ -2272,11 +2273,9 @@ int drv_video_init(void) if (have_keyboard) { debug("KBD: Keyboard init ...\n"); #if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - skip_dev_init |= (VIDEO_KBD_INIT_FCT == -1); + keyboard_ok = !(VIDEO_KBD_INIT_FCT == -1); #endif } - if (skip_dev_init) - return 0;
/* Init vga device */ memset(&console_dev, 0, sizeof(console_dev)); @@ -2287,7 +2286,7 @@ int drv_video_init(void) console_dev.puts = video_puts; /* 'puts' function */
#if !defined(CONFIG_VGA_AS_SINGLE_DEVICE) - if (have_keyboard) { + if (have_keyboard && keyboard_ok) { /* Also init console device */ console_dev.flags |= DEV_FLAGS_INPUT; console_dev.tstc = VIDEO_TSTC_FCT; /* 'tstc' function */
+Anatolij
Hi Bin,
console
This is a change in behaviour. It seems OK to me though. In fact this problem annoyed me quite recently.
Agreed. Actually we should implement driver model for vga/lcd and input.
bool __maybe_unused keyboard_ok = false; /* Check if video initialization should be skipped */ if (board_video_skip()) return 0; /* Init video chip - returns with framebuffer cleared */
return 0; if (board_cfb_skip()) return 0;
#endif }
if (skip_dev_init)
return 0; /* Init vga device */ memset(&console_dev, 0, sizeof(console_dev));
-- 1.8.2.1
On Tue, Aug 18, 2015 at 10:00 AM, Simon Glass sjg@chromium.org wrote:
+Anatolij
Hi Bin,
console
Will fix in v2.
Yes, I was planning to do. But that's a lot work so I decided not to change it in this series.
#endif }
if (skip_dev_init)
Regards, Bin
Bin Meng
