[U-Boot] Dumb question: is UMS/MASS_STORAGE_GADGET in SPL possible?
I'm trying to make a small image enabling u-boot UMS mode on BeagleBone Black against the on-board eMMC. Is it possible to enable UMS simply within SPL?
It seems like some others have done it in the past ( http://lists.denx.de/pipermail/u-boot/2015-March/207600.html), but I don't see an obvious way to enable it.
Performance might not be great ( https://boundarydevices.com/u-boot-usb-mass-storage-gadget/), but minimizing the user steps could make it worth doing it in u-boot (preferably SPL) than to load a kernel and ramdisk ( https://github.com/ungureanuvladvictor/BBBlfs).
Hi Jason
As fair as I remember UMS is not supported in SPL.
However, recently there was an attempt to use the DFU gadget in SPL (CONFIG_SPL_DFU_RAM):
http://u-boot.10912.n7.nabble.com/RFC-PATCH-v3-0-5-SPL-DFU-Support-in-SPL-td...
It is already supported in ML. You can look into this implementation and add similar code to support UMS.
In the link the UMS support is disabled to avoid too big size grown.
Maybe you can reuse as much as possible from the SPL-DFU support?
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Jason Kridner
Lukasz Majewski
