[U-Boot] [PATCH] clk: Add support for Arm's Versatile Express OSC clock generators
The Arm Versatile Express and Juno development boards contain an OSC clock generator that can be accessed through the Versatile Express config bus. The generators are quite often being controlled by some MCU and the config bus offers a uniform way of exposing them.
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com --- drivers/clk/Kconfig | 7 +++ drivers/clk/Makefile | 1 + drivers/clk/clk_vexpress_osc.c | 109 +++++++++++++++++++++++++++++++++ 3 files changed, 117 insertions(+) create mode 100644 drivers/clk/clk_vexpress_osc.c
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 809eb3dacf..008cd1186e 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -68,6 +68,13 @@ config CLK_HSDK help Enable this to support the cgu clocks on Synopsys ARC HSDK
+config CLK_VEXPRESS_OSC + bool "Enable driver for Arm Versatile Express OSC clock generators" + depends on CLK && VEXPRESS_CONFIG + help + This clock driver adds support for clock generators present on + Arm Versatile Express platforms. + config CLK_ZYNQ bool "Enable clock driver support for Zynq" depends on CLK && ARCH_ZYNQ diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 82c36b7478..2975e21120 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_CLK_RENESAS) += renesas/ obj-$(CONFIG_CLK_STM32F) += clk_stm32f.o obj-$(CONFIG_CLK_STM32MP1) += clk_stm32mp1.o obj-$(CONFIG_CLK_UNIPHIER) += uniphier/ +obj-$(CONFIG_CLK_VEXPRESS_OSC) += clk_vexpress_osc.o obj-$(CONFIG_CLK_ZYNQ) += clk_zynq.o obj-$(CONFIG_CLK_ZYNQMP) += clk_zynqmp.o obj-$(CONFIG_ICS8N3QV01) += ics8n3qv01.o diff --git a/drivers/clk/clk_vexpress_osc.c b/drivers/clk/clk_vexpress_osc.c new file mode 100644 index 0000000000..450f47ac3d --- /dev/null +++ b/drivers/clk/clk_vexpress_osc.c @@ -0,1 +1,109 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Arm Ltd + * Author: Liviu Dudau liviu.dudau@foss.arm.com + * + */ +#define DEBUG +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dm/lists.h> +#include <errno.h> +#include <misc.h> + +#define CLK_FUNCTION BIT(20) + +struct vexpress_osc_clk_priv { + u8 osc; + ulong rate_min; + ulong rate_max; +}; + +static ulong vexpress_osc_clk_get_rate(struct clk *clk) +{ + int err; + u32 data; + struct udevice *vexpress_cfg = dev_get_parent(clk->dev); + struct vexpress_osc_clk_priv *priv = dev_get_priv(clk->dev); + + data = CLK_FUNCTION | priv->osc; + err = misc_read(vexpress_cfg, 0, &data, sizeof(data)); + if (err) + return err; + + return data; +} + +#ifndef CONFIG_SPL_BUILD +static ulong vexpress_osc_clk_set_rate(struct clk *clk, ulong rate) +{ + int err; + u32 buffer[2]; + struct udevice *vexpress_cfg = dev_get_parent(clk->dev); + struct vexpress_osc_clk_priv *priv = dev_get_priv(clk->dev); + + if (rate < priv->rate_min || rate > priv->rate_max) + return -EINVAL; + + /* + * we are sending the parent the info about the oscillator + * and the value we want to set + */ + buffer[0] = CLK_FUNCTION | priv->osc; + buffer[1] = rate; + err = misc_write(vexpress_cfg, 0, buffer, 2 * sizeof(u32)); + if (err) + return err; + + return rate; +} +#endif + +static struct clk_ops vexpress_osc_clk_ops = { + .get_rate = vexpress_osc_clk_get_rate, +#ifndef CONFIG_SPL_BUILD + .set_rate = vexpress_osc_clk_set_rate, +#endif +}; + +static int vexpress_osc_clk_probe(struct udevice *dev) +{ + struct vexpress_osc_clk_priv *priv = dev_get_priv(dev); + u32 values[2]; + int err; + + err = dev_read_u32_array(dev, "freq-range", values, 2); + if (err) + return err; + priv->rate_min = values[0]; + priv->rate_max = values[1]; + + err = dev_read_u32_array(dev, "arm,vexpress-sysreg,func", values, 2); + if (err) + return err; + + if (values[0] != 1) { + dev_err(dev, "Invalid VExpress function for clock, must be '1'"); + return -EINVAL; + } + priv->osc = values[1]; + debug("clk "%s%d", min freq %luHz, max freq %luHz\n", dev->name, + priv->osc, priv->rate_min, priv->rate_max); + + return 0; +} + +static const struct udevice_id vexpress_osc_clk_ids[] = { + { .compatible = "arm,vexpress-osc", }, + {} +}; + +U_BOOT_DRIVER(vexpress_osc_clk) = { + .name = "vexpress_osc_clk", + .id = UCLASS_CLK, + .of_match = vexpress_osc_clk_ids, + .ops = &vexpress_osc_clk_ops, + .priv_auto_alloc_size = sizeof(struct vexpress_osc_clk_priv), + .probe = vexpress_osc_clk_probe, +};
Hello Liviu,
Am 17.09.2018 um 18:50 schrieb Liviu Dudau:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com Reviewed-by: Heiko Schocher hs@denx.de
Thanks! The MAINTAINERS entry will get applied at a different time, I guess? (I know there is some implicit order there, with the vexpress_config.c driver introducing the entry, but the OSC driver is not useful without that driver)
Best regards, Liviu
-- Tom
I don't see a patch that update the MAINTAINERS file right now, can you please resend it? Thanks!
Apologies, I was under the impression that I have sent the v2 for this patch as well, which had the MAINTAINERS update.
Do you want me to send a patch only for the MAINTAINERS update? Should that patch add the VExpress config bus entry as well (will conflict with v2 of that patch anyway)?
Best regards, Liviu
-- Tom
Ah, OK, I see now. Let me also bring in Linus Walleij on this too. U-Boot has split the MAINTAINERS file up for a while now and stuff like these platform specific drivers should get popped into board/armltd/vexpress/MAINTAINERS or board/armltd/vexpress64/MAINTAINERS (I'd also be open, I suppose, to creating board/armltd/MAINTAINERS if it's more sensical, but... could we squash vexpress64 into the main vexpress directory or does that make no sense?). And, oops, I see that Linus should have been cc'd on this patch and I should wait for him to review the others[1] too.
[1]: https://patchwork.ozlabs.org/project/uboot/list/?submitter=67396
Just send it my way, I'll be happy to ACK it :)
I have full confidence in Liviu (and Ryan) so do not back out anything just because of me. But I'm happy to review them!
I have a vague memory that I took over some main responsibility for Vexpress in U-Boot at some point but I am sure it was mainly because of miscommunication or some temporary UEFI prioritization.
Yours, Linus Walleij
Understood, thanks.
If you want to pass the hat to someone else, that's fine, please just ack their updating of the overall MAINTAINER file :) We really don't want boards without someone listed on them however, long term. Thanks again!
I'm a bit confused on how this would work. The MAINTAINERS entry I'm talking about is for the OSC clk driver. Does this mean I will have to update both board files with the same info? I thought board specific MAINTAINERS files are for specifying who's looking over the board functionality overall?
Best regards, Liviu
-- Tom
> The Arm Versatile Express and Juno development boards contain an > OSC clock generator that can be accessed through the Versatile > Express config bus. The generators are quite often being controlled > by some MCU and the config bus offers a uniform way of exposing them. > > Signed-off-by: Liviu Dudau liviu.dudau@foss.arm.com > Reviewed-by: Heiko Schocher hs@denx.de
Well, I guess my point is given that we have more than one MAINTAINERS file, does it make more sense for this to be in say drivers/clk/MAINTAINERS or board/armltd/something/MAINTAINERS or the top-level file. And I further guess I'll withdraw the question for now as I see no one else yet is doing that, so yes, we can keep it top level for now. Thanks!
Acked-by: Linus Walleij linus.walleij@linaro.org
Heiko Schocher
Linus Walleij
Liviu Dudau
