[PATCH] arm: apple: Disable SMBIOS again
Apple machines do not have memory below 4G. Since U-Boot does not support the SMBIOS 3 header structures this means we can't support SMBIOS on these machines. Unfortunately the refactoring of the SMBIOS code this cycle accidentally enabled it again.
Fixes: 53fab13a7b1 ("efi: Use the installed SMBIOS tables") Signed-off-by: Mark Kettenis kettenis@openbsd.org --- configs/apple_m1_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/apple_m1_defconfig b/configs/apple_m1_defconfig index d58a9030db..b868d0e319 100644 --- a/configs/apple_m1_defconfig +++ b/configs/apple_m1_defconfig @@ -21,5 +21,5 @@ CONFIG_USB_KEYBOARD=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_NO_FB_CLEAR=y CONFIG_VIDEO_SIMPLE=y -# CONFIG_GENERATE_SMBIOS_TABLE is not set +# CONFIG_SMBIOS is not set CONFIG_LMB_MAX_REGIONS=64
My understanding this is for origin/master. For next we have pending patches from Simon to move to SMBIOS 3.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Date: Sun, 24 Dec 2023 20:37:47 +0100 From: Heinrich Schuchardt xypron.glpk@gmx.de
Right. Without this fix EFI boot will fail on U-Boot 2024.01. And that is 99% of the users.
When the SMBIOS 3 patches land, I intend to turn this back on again (after making sure the tables are populated with the appropriate information).
participants (5)
Mark Kettenis
Mark Kettenis
