Re: [U-Boot] JFFS2 with NAND flash is very SLOW ...
In my side: MTD0 (720kB): U-boot MTD1 (80kB) : env. Variables MTD2 (12MB) : kernel + initramfs MTD3 (50MB) : rootfs
Maybe it will not help you but I have
MTD0 (all the nand 256M) MTD1 uboot+ embedded config 2M RAW MTD2 1M JFFS2 MTD5 config 5M JFFS2 MTD3 Kernel + initramfs 12M JFFS2 MTD4 KernelBKp 12M JFFS2 MTD5 content 224M
Scanning and fsload of the MTD3 partition take 3 seconds with 2009.03 With 1.3.4 it was something like 6-10 seconds. But never 1 minute. I have seen that when scanning the content partition of 224M.
If it exists a difference between 2009.03 and 1.3.3 it is not sufficient. It is very slow in both versions. It takes more than 1 minutes to obtain the result of "fsinfo" command !!!
sYLVAIN
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
This electronic message may contain proprietary and confidential information of Verint Systems Inc., its affiliates and/or subsidiaries. The information is intended to be for the use of the individual(s) or entity(ies) named above. If you are not the intended recipient (or authorized to receive this e-mail for the intended recipient), you may not use, copy, disclose or distribute to anyone this message or any information contained in this message. If you have received this electronic message in error, please notify us by replying to this e-mail.
Parameters like I-cache and D-cache handling greatly effect this scan time. Some platforms have caches enabled others don't. This might explain some differences here.
Best regards, Stefan
Is it better to use or not D-cache and I-cache? Currently, in my config file, I have only #define CONFIG_CMD_CACHE What do I have to add?
Thanks in advance for your help.
Pierre
-----Message d'origine----- De : u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] De la part de Stefan Roese Envoyé : mardi 2 juin 2009 15:18 À : u-boot@lists.denx.de Cc : Pierre Savary; Cote, Sylvain Objet : Re: [U-Boot] JFFS2 with NAND flash is very SLOW ...
have
===================================================================== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Cote, Sylvain
Pierre Savary
Stefan Roese
