[U-Boot] [PATCH 05/13 v5] ARM: OMAP3: Add board, clock and interrupts common files
Subject: [PATCH 05/13 v5] ARM: OMAP3: Add board, clock and interrupts common files
Add board, clock, cpu and interrupts common files
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Changes in version v5:
- Add Readme, further clean up as proposed by Jean-Christophe PLAGNIOL-VILLARD
Changes in version v3:
- Add detection and support for 128MB/256MB RAM by Mans Rullgard
Changes in version v2:
- Move common ARM Cortex A8 code to cpu/arm_cortexa8/ and OMAP3 SoC specific common code to cpu/arm_cortexa8/omap3 as proposed by Wolfgang.
cpu/arm_cortexa8/omap3/Makefile | 2 cpu/arm_cortexa8/omap3/board.c | 326 +++++++++++++++++++++++++++++++++++ cpu/arm_cortexa8/omap3/clock.c | 328 ++++++++++++++++++++++++++++++++++++ cpu/arm_cortexa8/omap3/interrupts.c | 303 +++++++++++++++++++++++++++++++++ 4 files changed, 958 insertions(+), 1 deletion(-)
Index: u-boot-main/cpu/arm_cortexa8/omap3/Makefile =================================================================== --- u-boot-main.orig/cpu/arm_cortexa8/omap3/Makefile +++ u-boot-main/cpu/arm_cortexa8/omap3/Makefile @@ -26,7 +26,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).a
SOBJS := lowlevel_init.o -COBJS := sys_info.o +COBJS := sys_info.o board.o clock.o interrupts.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) Index: u-boot-main/cpu/arm_cortexa8/omap3/board.c =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/omap3/board.c @@ -0,0 +1,326 @@ +/* + * + * Common board functions for OMAP3 based boards. + * + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * + * Author : + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * + * Derived from Beagle Board and 3430 SDP code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/bits.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> + +#define NOT_EARLY 0 + +/* Permission values for registers -Full fledged permissions to all */ +#define UNLOCK_1 0xFFFFFFFF +#define UNLOCK_2 0x00000000 +#define UNLOCK_3 0x0000FFFF + +/****************************************************************************** + * Routine: delay + * Description: spinning delay to use before udelay works + *****************************************************************************/ +static inline void delay(unsigned long loops) +{ + __asm__ volatile ("1:\n" "subs %0, %1, #1\n" + "bne 1b":"=r" (loops):"0"(loops)); +} + +/****************************************************************************** + * Routine: secure_unlock + * Description: Setup security registers for access + * (GP Device only) + *****************************************************************************/ +void secure_unlock_mem(void) +{ + /* Protection Module Register Target APE (PM_RT) */ + writel(UNLOCK_1, RT_REQ_INFO_PERMISSION_1); + writel(UNLOCK_1, RT_READ_PERMISSION_0); + writel(UNLOCK_1, RT_WRITE_PERMISSION_0); + writel(UNLOCK_2, RT_ADDR_MATCH_1); + + writel(UNLOCK_3, GPMC_REQ_INFO_PERMISSION_0); + writel(UNLOCK_3, GPMC_READ_PERMISSION_0); + writel(UNLOCK_3, GPMC_WRITE_PERMISSION_0); + + writel(UNLOCK_3, OCM_REQ_INFO_PERMISSION_0); + writel(UNLOCK_3, OCM_READ_PERMISSION_0); + writel(UNLOCK_3, OCM_WRITE_PERMISSION_0); + writel(UNLOCK_2, OCM_ADDR_MATCH_2); + + /* IVA Changes */ + writel(UNLOCK_3, IVA2_REQ_INFO_PERMISSION_0); + writel(UNLOCK_3, IVA2_READ_PERMISSION_0); + writel(UNLOCK_3, IVA2_WRITE_PERMISSION_0); + + writel(UNLOCK_1, SMS_RG_ATT0); /* SDRC region 0 public */ +} + +/****************************************************************************** + * Routine: secureworld_exit() + * Description: If chip is EMU and boot type is external + * configure secure registers and exit secure world + * general use. + *****************************************************************************/ +void secureworld_exit() +{ + unsigned long i; + + /* configrue non-secure access control register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 2":"=r"(i)); + /* enabling co-processor CP10 and CP11 accesses in NS world */ + __asm__ __volatile__("orr %0, %0, #0xC00":"=r"(i)); + /* allow allocation of locked TLBs and L2 lines in NS world */ + /* allow use of PLE registers in NS world also */ + __asm__ __volatile__("orr %0, %0, #0x70000":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 2":"=r"(i)); + + /* Enable ASA in ACR register */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x10":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + + /* Exiting secure world */ + __asm__ __volatile__("mrc p15, 0, %0, c1, c1, 0":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x31":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c1, 0":"=r"(i)); +} + +/****************************************************************************** + * Routine: setup_auxcr() + * Description: Write to AuxCR desired value using SMI. + * general use. + *****************************************************************************/ +void setup_auxcr() +{ + unsigned long i; + volatile unsigned int j; + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + /* Enabling ASA */ + __asm__ __volatile__("orr r0, r0, #0x10"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); +} + +/****************************************************************************** + * Routine: try_unlock_sram() + * Description: If chip is GP/EMU(special) type, unlock the SRAM for + * general use. + *****************************************************************************/ +void try_unlock_memory() +{ + int mode; + int in_sdram = is_running_in_sdram(); + + /* if GP device unlock device SRAM for general use */ + /* secure code breaks for Secure/Emulation device - HS/E/T */ + mode = get_device_type(); + if (mode == GP_DEVICE) + secure_unlock_mem(); + + /* If device is EMU and boot is XIP external booting + * Unlock firewalls and disable L2 and put chip + * out of secure world + */ + /* Assuming memories are unlocked by the demon who put us in SDRAM */ + if ((mode <= EMU_DEVICE) && (get_boot_type() == 0x1F) + && (!in_sdram)) { + secure_unlock_mem(); + secureworld_exit(); + } + + return; +} + +/****************************************************************************** + * Routine: s_init + * Description: Does early system init of muxing and clocks. + * - Called path is with SRAM stack. + *****************************************************************************/ +void s_init(void) +{ + int in_sdram = is_running_in_sdram(); + + watchdog_init(); + + try_unlock_memory(); + + /* Right now flushing at low MPU speed. + Need to move after clock init */ + v7_flush_dcache_all(get_device_type()); +#ifndef CONFIG_ICACHE_OFF + icache_enable(); +#endif + +#ifdef CONFIG_L2_OFF + l2cache_disable(); +#else + l2cache_enable(); +#endif + /* Writing to AuxCR in U-boot using SMI for GP DEV */ + /* Currently SMI in Kernel on ES2 devices seems to have an isse + * Once that is resolved, we can postpone this config to kernel + */ + if (get_device_type() == GP_DEVICE) + setup_auxcr(); + + set_muxconf_regs(); + delay(100); + + prcm_init(); + + per_clocks_enable(); + + if (!in_sdram) + sdrc_init(); +} + +/****************************************************************************** + * Routine: wait_for_command_complete + * Description: Wait for posting to finish on watchdog + *****************************************************************************/ +void wait_for_command_complete(unsigned int wd_base) +{ + int pending = 1; + do { + pending = readl(wd_base + WWPS); + } while (pending); +} + +/****************************************************************************** + * Routine: watchdog_init + * Description: Shut down watch dogs + *****************************************************************************/ +void watchdog_init(void) +{ + /* There are 3 watch dogs WD1=Secure, WD2=MPU, WD3=IVA. WD1 is + * either taken care of by ROM (HS/EMU) or not accessible (GP). + * We need to take care of WD2-MPU or take a PRCM reset. WD3 + * should not be running and does not generate a PRCM reset. + */ + + sr32(CM_FCLKEN_WKUP, 5, 1, 1); + sr32(CM_ICLKEN_WKUP, 5, 1, 1); + wait_on_value(BIT5, 0x20, CM_IDLEST_WKUP, 5); /* some issue here */ + + writel(WD_UNLOCK1, WD2_BASE + WSPR); + wait_for_command_complete(WD2_BASE); + writel(WD_UNLOCK2, WD2_BASE + WSPR); +} + +/****************************************************************************** + * Routine: dram_init + * Description: sets uboots idea of sdram size + *****************************************************************************/ +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + unsigned int size0 = 0, size1 = 0; + u32 mtype, btype; + + btype = get_board_type(); + mtype = get_mem_type(); + + display_board_info(btype); + + /* If a second bank of DDR is attached to CS1 this is + * where it can be started. Early init code will init + * memory on CS0. + */ + if ((mtype == DDR_COMBO) || (mtype == DDR_STACKED)) { + do_sdrc_init(SDRC_CS1_OSET, NOT_EARLY); + make_cs1_contiguous(); + } + + size0 = get_sdr_cs_size(SDRC_CS0_OSET); + size1 = get_sdr_cs_size(SDRC_CS1_OSET); + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = size0; + gd->bd->bi_dram[1].start = PHYS_SDRAM_1 + get_sdr_cs_offset(1); + gd->bd->bi_dram[1].size = size1; + + return 0; +} + +/****************************************************************************** + * Dummy function to handle errors for EABI incompatibility + *****************************************************************************/ +void raise(void) +{ +} + +/****************************************************************************** + * Dummy function to handle errors for EABI incompatibility + *****************************************************************************/ +void abort(void) +{ +} + +#ifdef CONFIG_NAND_OMAP_GPMC +/****************************************************************************** + * OMAP3 specific command to switch between NAND HW and SW ecc + *****************************************************************************/ +static int do_switch_ecc(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + if (argc != 2) + goto usage; + if (strncmp(argv[1], "hw", 2) == 0) + omap_nand_switch_ecc(1); + else if (strncmp(argv[1], "sw", 2) == 0) + omap_nand_switch_ecc(0); + else + goto usage; + + return 0; + +usage: + printf ("Usage: nandecc %s\n", cmdtp->help); + return 1; +} + +U_BOOT_CMD( + nandecc, 2, 1, do_switch_ecc, + "nandecc - switch OMAP3 NAND ECC calculation algorithm\n", + "[hw/sw] - Switch between NAND hardware (hw) or software (sw) ecc algorithm\n" + ); + +#endif /* CONFIG_NAND_OMAP_GPMC */ Index: u-boot-main/cpu/arm_cortexa8/omap3/clock.c =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/omap3/clock.c @@ -0,0 +1,328 @@ +/* + * (C) Copyright 2008 + * Texas Instruments, <www.ti.com> + * + * Author : + * Manikandan Pillai mani.pillai@ti.com + * + * Derived from Beagle Board and OMAP3 SDP code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/bits.h> +#include <asm/arch/clocks.h> +#include <asm/arch/clocks_omap3.h> +#include <asm/arch/mem.h> +#include <asm/arch/sys_proto.h> +#include <environment.h> +#include <command.h> + +/****************************************************************************** + * get_sys_clk_speed() - determine reference oscillator speed + * based on known 32kHz clock and gptimer. + *****************************************************************************/ +u32 get_osc_clk_speed(void) +{ + u32 start, cstart, cend, cdiff, val; + + val = readl(PRM_CLKSRC_CTRL); + + /* If SYS_CLK is being divided by 2, remove for now */ + val = (val & (~BIT7)) | BIT6; + writel(val, PRM_CLKSRC_CTRL); + + /* enable timer2 */ + val = readl(CM_CLKSEL_WKUP) | BIT0; + writel(val, CM_CLKSEL_WKUP); /* select sys_clk for GPT1 */ + + /* Enable I and F Clocks for GPT1 */ + val = readl(CM_ICLKEN_WKUP) | BIT0 | BIT2; + writel(val, CM_ICLKEN_WKUP); + val = readl(CM_FCLKEN_WKUP) | BIT0; + writel(val, CM_FCLKEN_WKUP); + + writel(0, OMAP34XX_GPT1 + TLDR); /* start counting at 0 */ + writel(GPT_EN, OMAP34XX_GPT1 + TCLR); /* enable clock */ + + /* enable 32kHz source, determine sys_clk via gauging */ + start = 20 + readl(S32K_CR); /* start time in 20 cycles */ + while (readl(S32K_CR) < start) ; /* dead loop till start time */ + + /* get start sys_clk count */ + cstart = readl(OMAP34XX_GPT1 + TCRR); + + /* wait for 40 cycles */ + while (readl(S32K_CR) < (start + 20)) ; + cend = readl(OMAP34XX_GPT1 + TCRR); /* get end sys_clk count */ + cdiff = cend - cstart; /* get elapsed ticks */ + + /* based on number of ticks assign speed */ + if (cdiff > 19000) + return S38_4M; + else if (cdiff > 15200) + return S26M; + else if (cdiff > 13000) + return S24M; + else if (cdiff > 9000) + return S19_2M; + else if (cdiff > 7600) + return S13M; + else + return S12M; +} + +/****************************************************************************** + * get_sys_clkin_sel() - returns the sys_clkin_sel field value based on + * input oscillator clock frequency. + *****************************************************************************/ +void get_sys_clkin_sel(u32 osc_clk, u32 *sys_clkin_sel) +{ + switch(osc_clk) { + case S38_4M: + *sys_clkin_sel = 4; + break; + case S26M: + *sys_clkin_sel = 3; + break; + case S19_2M: + *sys_clkin_sel = 2; + break; + case S13M: + *sys_clkin_sel = 1; + break; + case S12M: + default: + *sys_clkin_sel = 0; + } +} + +/****************************************************************************** + * prcm_init() - inits clocks for PRCM as defined in clocks.h + * called from SRAM, or Flash (using temp SRAM stack). + *****************************************************************************/ +void prcm_init(void) +{ + void (*f_lock_pll) (u32, u32, u32, u32); + int xip_safe, p0, p1, p2, p3; + u32 osc_clk = 0, sys_clkin_sel; + u32 clk_index, sil_index; + dpll_param *dpll_param_p; + + f_lock_pll = (void *) ((u32) &_end_vect - (u32) &_start + + SRAM_VECT_CODE); + + xip_safe = is_running_in_sram(); + + /* Gauge the input clock speed and find out the sys_clkin_sel + * value corresponding to the input clock. + */ + osc_clk = get_osc_clk_speed(); + get_sys_clkin_sel(osc_clk, &sys_clkin_sel); + + sr32(PRM_CLKSEL, 0, 3, sys_clkin_sel); /* set input crystal speed */ + + /* If the input clock is greater than 19.2M always divide/2 */ + if (sys_clkin_sel > 2) { + sr32(PRM_CLKSRC_CTRL, 6, 2, 2); /* input clock divider */ + clk_index = sys_clkin_sel / 2; + } else { + sr32(PRM_CLKSRC_CTRL, 6, 2, 1); /* input clock divider */ + clk_index = sys_clkin_sel; + } + + /* The DPLL tables are defined according to sysclk value and + * silicon revision. The clk_index value will be used to get + * the values for that input sysclk from the DPLL param table + * and sil_index will get the values for that SysClk for the + * appropriate silicon rev. + */ + sil_index = get_cpu_rev() - 1; + + /* Unlock MPU DPLL (slows things down, and needed later) */ + sr32(CM_CLKEN_PLL_MPU, 0, 3, PLL_LOW_POWER_BYPASS); + wait_on_value(BIT0, 0, CM_IDLEST_PLL_MPU, LDELAY); + + /* Getting the base address of Core DPLL param table */ + dpll_param_p = (dpll_param *) get_core_dpll_param(); + + /* Moving it to the right sysclk and ES rev base */ + dpll_param_p = dpll_param_p + 3 * clk_index + sil_index; + if (xip_safe) { + /* CORE DPLL */ + /* sr32(CM_CLKSEL2_EMU) set override to work when asleep */ + sr32(CM_CLKEN_PLL, 0, 3, PLL_FAST_RELOCK_BYPASS); + wait_on_value(BIT0, 0, CM_IDLEST_CKGEN, LDELAY); + + /* For OMAP3 ES1.0 Errata 1.50, default value directly doesnt + * work. write another value and then default value. + */ + sr32(CM_CLKSEL1_EMU, 16, 5, CORE_M3X2 + 1); /* m3x2 */ + sr32(CM_CLKSEL1_EMU, 16, 5, CORE_M3X2); /* m3x2 */ + sr32(CM_CLKSEL1_PLL, 27, 2, dpll_param_p->m2); /* Set M2 */ + sr32(CM_CLKSEL1_PLL, 16, 11, dpll_param_p->m); /* Set M */ + sr32(CM_CLKSEL1_PLL, 8, 7, dpll_param_p->n); /* Set N */ + sr32(CM_CLKSEL1_PLL, 6, 1, 0); /* 96M Src */ + sr32(CM_CLKSEL_CORE, 8, 4, CORE_SSI_DIV); /* ssi */ + sr32(CM_CLKSEL_CORE, 4, 2, CORE_FUSB_DIV); /* fsusb */ + sr32(CM_CLKSEL_CORE, 2, 2, CORE_L4_DIV); /* l4 */ + sr32(CM_CLKSEL_CORE, 0, 2, CORE_L3_DIV); /* l3 */ + sr32(CM_CLKSEL_GFX, 0, 3, GFX_DIV); /* gfx */ + sr32(CM_CLKSEL_WKUP, 1, 2, WKUP_RSM); /* reset mgr */ + sr32(CM_CLKEN_PLL, 4, 4, dpll_param_p->fsel); /* FREQSEL */ + sr32(CM_CLKEN_PLL, 0, 3, PLL_LOCK); /* lock mode */ + + wait_on_value(BIT0, 1, CM_IDLEST_CKGEN, LDELAY); + } else if (is_running_in_flash()) { + /* if running from flash, jump to small relocated code + area in SRAM. */ + p0 = readl(CM_CLKEN_PLL); + sr32((u32) &p0, 0, 3, PLL_FAST_RELOCK_BYPASS); + sr32((u32) &p0, 4, 4, dpll_param_p->fsel); /* FREQSEL */ + + p1 = readl(CM_CLKSEL1_PLL); + sr32((u32) &p1, 27, 2, dpll_param_p->m2); /* Set M2 */ + sr32((u32) &p1, 16, 11, dpll_param_p->m); /* Set M */ + sr32((u32) &p1, 8, 7, dpll_param_p->n); /* Set N */ + sr32((u32) &p1, 6, 1, 0); /* set source for 96M */ + + p2 = readl(CM_CLKSEL_CORE); + sr32((u32) &p2, 8, 4, CORE_SSI_DIV); /* ssi */ + sr32((u32) &p2, 4, 2, CORE_FUSB_DIV); /* fsusb */ + sr32((u32) &p2, 2, 2, CORE_L4_DIV); /* l4 */ + sr32((u32) &p2, 0, 2, CORE_L3_DIV); /* l3 */ + + p3 = CM_IDLEST_CKGEN; + + (*f_lock_pll) (p0, p1, p2, p3); + } + + /* PER DPLL */ + sr32(CM_CLKEN_PLL, 16, 3, PLL_STOP); + wait_on_value(BIT1, 0, CM_IDLEST_CKGEN, LDELAY); + + /* Getting the base address to PER DPLL param table */ + /* Set N */ + dpll_param_p = (dpll_param *) get_per_dpll_param(); + + /* Moving it to the right sysclk base */ + dpll_param_p = dpll_param_p + clk_index; + + /* Errata 1.50 Workaround for OMAP3 ES1.0 only + * If using default divisors, write default divisor + 1 + * and then the actual divisor value + */ + sr32(CM_CLKSEL1_EMU, 24, 5, PER_M6X2 + 1); /* set M6 */ + sr32(CM_CLKSEL1_EMU, 24, 5, PER_M6X2); /* set M6 */ + sr32(CM_CLKSEL_CAM, 0, 5, PER_M5X2 + 1); /* set M5 */ + sr32(CM_CLKSEL_CAM, 0, 5, PER_M5X2); /* set M5 */ + sr32(CM_CLKSEL_DSS, 0, 5, PER_M4X2 + 1); /* set M4 */ + sr32(CM_CLKSEL_DSS, 0, 5, PER_M4X2); /* set M4 */ + sr32(CM_CLKSEL_DSS, 8, 5, PER_M3X2 + 1); /* set M3 */ + sr32(CM_CLKSEL_DSS, 8, 5, PER_M3X2); /* set M3 */ + sr32(CM_CLKSEL3_PLL, 0, 5, dpll_param_p->m2 + 1); /* set M2 */ + sr32(CM_CLKSEL3_PLL, 0, 5, dpll_param_p->m2); /* set M2 */ + /* Workaround end */ + + sr32(CM_CLKSEL2_PLL, 8, 11, dpll_param_p->m); /* set m */ + sr32(CM_CLKSEL2_PLL, 0, 7, dpll_param_p->n); /* set n */ + sr32(CM_CLKEN_PLL, 20, 4, dpll_param_p->fsel); /* FREQSEL */ + sr32(CM_CLKEN_PLL, 16, 3, PLL_LOCK); /* lock mode */ + wait_on_value(BIT1, 2, CM_IDLEST_CKGEN, LDELAY); + + /* Getting the base address to MPU DPLL param table */ + dpll_param_p = (dpll_param *) get_mpu_dpll_param(); + + /* Moving it to the right sysclk and ES rev base */ + dpll_param_p = dpll_param_p + 3 * clk_index + sil_index; + + /* MPU DPLL (unlocked already) */ + sr32(CM_CLKSEL2_PLL_MPU, 0, 5, dpll_param_p->m2); /* Set M2 */ + sr32(CM_CLKSEL1_PLL_MPU, 8, 11, dpll_param_p->m); /* Set M */ + sr32(CM_CLKSEL1_PLL_MPU, 0, 7, dpll_param_p->n); /* Set N */ + sr32(CM_CLKEN_PLL_MPU, 4, 4, dpll_param_p->fsel); /* FREQSEL */ + sr32(CM_CLKEN_PLL_MPU, 0, 3, PLL_LOCK); /* lock mode */ + wait_on_value(BIT0, 1, CM_IDLEST_PLL_MPU, LDELAY); + + /* Getting the base address to IVA DPLL param table */ + dpll_param_p = (dpll_param *) get_iva_dpll_param(); + + /* Moving it to the right sysclk and ES rev base */ + dpll_param_p = dpll_param_p + 3 * clk_index + sil_index; + + /* IVA DPLL (set to 12*20=240MHz) */ + sr32(CM_CLKEN_PLL_IVA2, 0, 3, PLL_STOP); + wait_on_value(BIT0, 0, CM_IDLEST_PLL_IVA2, LDELAY); + sr32(CM_CLKSEL2_PLL_IVA2, 0, 5, dpll_param_p->m2); /* set M2 */ + sr32(CM_CLKSEL1_PLL_IVA2, 8, 11, dpll_param_p->m); /* set M */ + sr32(CM_CLKSEL1_PLL_IVA2, 0, 7, dpll_param_p->n); /* set N */ + sr32(CM_CLKEN_PLL_IVA2, 4, 4, dpll_param_p->fsel); /* FREQSEL */ + sr32(CM_CLKEN_PLL_IVA2, 0, 3, PLL_LOCK); /* lock mode */ + wait_on_value(BIT0, 1, CM_IDLEST_PLL_IVA2, LDELAY); + + /* Set up GPTimers to sys_clk source only */ + sr32(CM_CLKSEL_PER, 0, 8, 0xff); + sr32(CM_CLKSEL_WKUP, 0, 1, 1); + + sdelay(5000); +} + +/****************************************************************************** + * peripheral_enable() - Enable the clks & power for perifs (GPT2, UART1,...) + *****************************************************************************/ +void per_clocks_enable(void) +{ + /* Enable GP2 timer. */ + sr32(CM_CLKSEL_PER, 0, 1, 0x1); /* GPT2 = sys clk */ + sr32(CM_ICLKEN_PER, 3, 1, 0x1); /* ICKen GPT2 */ + sr32(CM_FCLKEN_PER, 3, 1, 0x1); /* FCKen GPT2 */ + +#ifdef CONFIG_SYS_NS16550 + /* Enable UART1 clocks */ + sr32(CM_FCLKEN1_CORE, 13, 1, 0x1); + sr32(CM_ICLKEN1_CORE, 13, 1, 0x1); + + /* UART 3 Clocks */ + sr32(CM_FCLKEN_PER, 11, 1, 0x1); + sr32(CM_ICLKEN_PER, 11, 1, 0x1); +#endif +#ifdef CONFIG_DRIVER_OMAP34XX_I2C + /* Turn on all 3 I2C clocks */ + sr32(CM_FCLKEN1_CORE, 15, 3, 0x7); + sr32(CM_ICLKEN1_CORE, 15, 3, 0x7); /* I2C1,2,3 = on */ +#endif + /* Enable the ICLK for 32K Sync Timer as its used in udelay */ + sr32(CM_ICLKEN_WKUP, 2, 1, 0x1); + + sr32(CM_FCLKEN_IVA2, 0, 32, FCK_IVA2_ON); + sr32(CM_FCLKEN1_CORE, 0, 32, FCK_CORE1_ON); + sr32(CM_ICLKEN1_CORE, 0, 32, ICK_CORE1_ON); + sr32(CM_ICLKEN2_CORE, 0, 32, ICK_CORE2_ON); + sr32(CM_FCLKEN_WKUP, 0, 32, FCK_WKUP_ON); + sr32(CM_ICLKEN_WKUP, 0, 32, ICK_WKUP_ON); + sr32(CM_FCLKEN_DSS, 0, 32, FCK_DSS_ON); + sr32(CM_ICLKEN_DSS, 0, 32, ICK_DSS_ON); + sr32(CM_FCLKEN_CAM, 0, 32, FCK_CAM_ON); + sr32(CM_ICLKEN_CAM, 0, 32, ICK_CAM_ON); + sr32(CM_FCLKEN_PER, 0, 32, FCK_PER_ON); + sr32(CM_ICLKEN_PER, 0, 32, ICK_PER_ON); + + sdelay(1000); +} Index: u-boot-main/cpu/arm_cortexa8/omap3/interrupts.c =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/omap3/interrupts.c @@ -0,0 +1,303 @@ +/* + * (C) Copyright 2008 + * Texas Instruments + * + * Richard Woodruff r-woodruff2@ti.com + * Syed Moahmmed Khasim khasim@ti.com + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/bits.h> + +#include <asm/proc-armv/ptrace.h> + +#define TIMER_LOAD_VAL 0 + +/* macro to read the 32 bit timer */ +#define READ_TIMER (*(volatile ulong *)(CONFIG_SYS_TIMERBASE+TCRR)) + +#ifdef CONFIG_USE_IRQ +/* enable IRQ interrupts */ +void enable_interrupts(void) +{ + unsigned long temp; + __asm__ __volatile__("mrs %0, cpsr\n" + "bic %0, %0, #0x80\n" "msr cpsr_c, %0":"=r"(temp) + ::"memory"); +} + +/* + * disable IRQ/FIQ interrupts + * returns true if interrupts had been enabled before we disabled them + */ +int disable_interrupts(void) +{ + unsigned long old, temp; + __asm__ __volatile__("mrs %0, cpsr\n" + "orr %1, %0, #0xc0\n" + "msr cpsr_c, %1":"=r"(old), "=r"(temp) + ::"memory"); + return (old & 0x80) == 0; +} +#else +void enable_interrupts(void) +{ + return; +} +int disable_interrupts(void) +{ + return 0; +} +#endif + +void bad_mode(void) +{ + panic("Resetting CPU ...\n"); + reset_cpu(0); +} + +void show_regs(struct pt_regs *regs) +{ + unsigned long flags; + const char *processor_modes[] = { + "USER_26", "FIQ_26", "IRQ_26", "SVC_26", + "UK4_26", "UK5_26", "UK6_26", "UK7_26", + "UK8_26", "UK9_26", "UK10_26", "UK11_26", + "UK12_26", "UK13_26", "UK14_26", "UK15_26", + "USER_32", "FIQ_32", "IRQ_32", "SVC_32", + "UK4_32", "UK5_32", "UK6_32", "ABT_32", + "UK8_32", "UK9_32", "UK10_32", "UND_32", + "UK12_32", "UK13_32", "UK14_32", "SYS_32", + }; + + flags = condition_codes(regs); + + printf("pc : [<%08lx>] lr : [<%08lx>]\n" + "sp : %08lx ip : %08lx fp : %08lx\n", + instruction_pointer(regs), + regs->ARM_lr, regs->ARM_sp, regs->ARM_ip, regs->ARM_fp); + printf("r10: %08lx r9 : %08lx r8 : %08lx\n", + regs->ARM_r10, regs->ARM_r9, regs->ARM_r8); + printf("r7 : %08lx r6 : %08lx r5 : %08lx r4 : %08lx\n", + regs->ARM_r7, regs->ARM_r6, regs->ARM_r5, regs->ARM_r4); + printf("r3 : %08lx r2 : %08lx r1 : %08lx r0 : %08lx\n", + regs->ARM_r3, regs->ARM_r2, regs->ARM_r1, regs->ARM_r0); + printf("Flags: %c%c%c%c", + flags & CC_N_BIT ? 'N' : 'n', + flags & CC_Z_BIT ? 'Z' : 'z', + flags & CC_C_BIT ? 'C' : 'c', flags & CC_V_BIT ? 'V' : 'v'); + printf(" IRQs %s FIQs %s Mode %s%s\n", + interrupts_enabled(regs) ? "on" : "off", + fast_interrupts_enabled(regs) ? "on" : "off", + processor_modes[processor_mode(regs)], + thumb_mode(regs) ? " (T)" : ""); +} + +void do_undefined_instruction(struct pt_regs *pt_regs) +{ + printf("undefined instruction\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_software_interrupt(struct pt_regs *pt_regs) +{ + printf("software interrupt\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_prefetch_abort(struct pt_regs *pt_regs) +{ + printf("prefetch abort\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_data_abort(struct pt_regs *pt_regs) +{ + printf("data abort\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_not_used(struct pt_regs *pt_regs) +{ + printf("not used\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_fiq(struct pt_regs *pt_regs) +{ + printf("fast interrupt request\n"); + show_regs(pt_regs); + bad_mode(); +} + +void do_irq(struct pt_regs *pt_regs) +{ + printf("interrupt request\n"); + show_regs(pt_regs); + bad_mode(); +} + + +static ulong timestamp; +static ulong lastinc; + +/* nothing really to do with interrupts, just starts up a counter. */ +int interrupt_init(void) +{ + int32_t val; + + /* Start the counter ticking up */ + /* reload value on overflow */ + *((int32_t *) (CONFIG_SYS_TIMERBASE + TLDR)) = TIMER_LOAD_VAL; + /* mask to enable timer */ + val = (CONFIG_SYS_PVT << 2) | BIT5 | BIT1 | BIT0; + *((int32_t *) (CONFIG_SYS_TIMERBASE + TCLR)) = val; /* start timer */ + + reset_timer_masked(); /* init the timestamp and lastinc value */ + + return 0; +} + +/* + * timer without interrupts + */ +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +/* delay x useconds AND perserve advance timstamp value */ +void udelay(unsigned long usec) +{ + ulong tmo, tmp; + + /* if "big" number, spread normalization to seconds */ + if (usec >= 1000) { + /* if "big" number, spread normalization to seconds */ + tmo = usec / 1000; + /* find number of "ticks" to wait to achieve target */ + tmo *= CONFIG_SYS_HZ; + tmo /= 1000; /* finish normalize. */ + } else {/* else small number, don't kill it prior to HZ multiply */ + tmo = usec * CONFIG_SYS_HZ; + tmo /= (1000 * 1000); + } + + tmp = get_timer(0); /* get current timestamp */ + /* if setting this forward will roll time stamp */ + if ((tmo + tmp + 1) < tmp) + /* reset "advancing" timestamp to 0, set lastinc value */ + reset_timer_masked(); + else + tmo += tmp; /* else, set advancing stamp wake up time */ + while (get_timer_masked() < tmo) /* loop till event */ + /*NOP*/; +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastinc = READ_TIMER; /* capture current incrementer value time */ + timestamp = 0; /* start "advancing" time stamp from 0 */ +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; /* current tick value */ + + if (now >= lastinc) /* normal mode (non roll) */ + /* move stamp fordward with absoulte diff ticks */ + timestamp += (now - lastinc); + else /* we have rollover of incrementer */ + timestamp += (0xFFFFFFFF - lastinc) + now; + lastinc = now; + return timestamp; +} + +/* waits specified delay value and resets timestamp */ +void udelay_masked(unsigned long usec) +{ + ulong tmo; + ulong endtime; + signed long diff; + + /* if "big" number, spread normalization to seconds */ + if (usec >= 1000) { + /* start to normalize for usec to ticks per sec */ + tmo = usec / 1000; + /* find number of "ticks" to wait to achieve target */ + tmo *= CONFIG_SYS_HZ; + tmo /= 1000; /* finish normalize. */ + } else { /* else small number, */ + /* don't kill it prior to HZ multiply */ + tmo = usec * CONFIG_SYS_HZ; + tmo /= (1000 * 1000); + } + endtime = get_timer_masked() + tmo; + + do { + ulong now = get_timer_masked(); + diff = endtime - now; + } while (diff >= 0); +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + ulong tbclk; + tbclk = CONFIG_SYS_HZ; + return tbclk; +}
Dear dirk.behme@googlemail.com,
- /* if GP device unlock device SRAM for general use */
- /* secure code breaks for Secure/Emulation device - HS/E/T */
Multiline comment style?
- /* If device is EMU and boot is XIP external booting
Ditto.
And so on.
Where is it?
Best Regards, J.
Where is it?
http://git.denx.de/?p=u-boot/u-boot-arm.git;a=blob;f=doc/README.omap3;h=830a...
Best Regards, J.
Dirk Behme
dirk.behmeï¼ googlemail.com
