[scan-admin@coverity.com: New Defects reported by Coverity Scan for Das U-Boot]
Hey folks,
Here's the latest report and I think some of these are new tests rather than new code.
----- Forwarded message from scan-admin@coverity.com -----
Date: Mon, 31 Jan 2022 23:09:01 +0000 (UTC) From: scan-admin@coverity.com To: tom.rini@gmail.com Subject: New Defects reported by Coverity Scan for Das U-Boot
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
9 new defect(s) introduced to Das U-Boot found with Coverity Scan. 5 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 9 of 9 defect(s)
** CID 345920: API usage errors (CHAR_IO) /tools/bmp_logo.c: 165 in main()
________________________________________________________________________________________________________ *** CID 345920: API usage errors (CHAR_IO) /tools/bmp_logo.c: 165 in main() 159 "#define __BMP_LOGO_DATA_H__\n\n"); 160 161 /* read and print the palette information */ 162 printf("unsigned short bmp_logo_palette[] = {\n"); 163 164 for (i=0; i<n_colors; ++i) {
CID 345920: API usage errors (CHAR_IO) Assigning the return value of "fgetc" to char "b->palette[(int)(i * 3 + 2)]" truncates its value.
165 b->palette[(int)(i*3+2)] = fgetc(fp); 166 b->palette[(int)(i*3+1)] = fgetc(fp); 167 b->palette[(int)(i*3+0)] = fgetc(fp); 168 x=fgetc(fp); 169 170 printf ("%s0x0%X%X%X,%s",
** CID 345919: Resource leaks (RESOURCE_LEAK) /tools/image-host.c: 969 in fit_config_get_regions()
________________________________________________________________________________________________________ *** CID 345919: Resource leaks (RESOURCE_LEAK) /tools/image-host.c: 969 in fit_config_get_regions() 963 len += strlen(node_inc.strings[i]) + 1; 964 } 965 region_prop = malloc(len); 966 if (!region_prop) { 967 printf("Out of memory setting up regions for configuration '%s/%s'\n", 968 conf_name, sig_name);
CID 345919: Resource leaks (RESOURCE_LEAK) Variable "region" going out of scope leaks the storage it points to.
969 return -ENOMEM; 970 } 971 for (i = len = 0; i < node_inc.count; 972 len += strlen(node_inc.strings[i]) + 1, i++) 973 strcpy(region_prop + len, node_inc.strings[i]); 974 strlist_free(&node_inc);
** CID 345918: Error handling issues (CHECKED_RETURN) /tools/bmp_logo.c: 41 in skip_bytes()
________________________________________________________________________________________________________ *** CID 345918: Error handling issues (CHECKED_RETURN) /tools/bmp_logo.c: 41 in skip_bytes() 35 return val; 36 } 37 38 void skip_bytes (FILE *fp, int n) 39 { 40 while (n-- > 0)
CID 345918: Error handling issues (CHECKED_RETURN) Calling "fgetc(fp)" without checking return value. This library function may fail and return an error code. [Note: The source code implementation of the function has been overridden by a builtin model.]
41 fgetc (fp); 42 } 43 44 __attribute__ ((__noreturn__)) 45 int error (char * msg, FILE *fp) 46 {
** CID 345917: Resource leaks (RESOURCE_LEAK) /tools/mkeficapsule.c: 121 in read_bin_file()
________________________________________________________________________________________________________ *** CID 345917: Resource leaks (RESOURCE_LEAK) /tools/mkeficapsule.c: 121 in read_bin_file() 115 116 *data = buf; 117 *bin_size = bin_stat.st_size; 118 err: 119 fclose(g); 120
CID 345917: Resource leaks (RESOURCE_LEAK) Variable "buf" going out of scope leaks the storage it points to.
121 return ret; 122 } 123 124 /** 125 * write_capsule_file - write a capsule file 126 * @bin: FILE stream
** CID 345916: Code maintainability issues (UNUSED_VALUE) /tools/bmp_logo.c: 168 in main()
________________________________________________________________________________________________________ *** CID 345916: Code maintainability issues (UNUSED_VALUE) /tools/bmp_logo.c: 168 in main() 162 printf("unsigned short bmp_logo_palette[] = {\n"); 163 164 for (i=0; i<n_colors; ++i) { 165 b->palette[(int)(i*3+2)] = fgetc(fp); 166 b->palette[(int)(i*3+1)] = fgetc(fp); 167 b->palette[(int)(i*3+0)] = fgetc(fp);
CID 345916: Code maintainability issues (UNUSED_VALUE) Assigning value from "fgetc(fp)" to "x" here, but that stored value is overwritten before it can be used.
168 x=fgetc(fp); 169 170 printf ("%s0x0%X%X%X,%s", 171 ((i%8) == 0) ? "\t" : " ", 172 (b->palette[(int)(i*3+0)] >> 4) & 0x0F, 173 (b->palette[(int)(i*3+1)] >> 4) & 0x0F,
** CID 345915: Control flow issues (NO_EFFECT) /lib/image-sparse.c: 214 in write_sparse_image()
________________________________________________________________________________________________________ *** CID 345915: Control flow issues (NO_EFFECT) /lib/image-sparse.c: 214 in write_sparse_image() 208 response); 209 return -1; 210 } 211 212 blks = write_sparse_chunk_raw(info, blk, blkcnt, 213 data, response);
CID 345915: Control flow issues (NO_EFFECT) This less-than-zero comparison of an unsigned value is never true. "blks < 0UL".
214 if (blks < 0) 215 return -1; 216 217 blk += blks; 218 bytes_written += ((u64)blkcnt) * info->blksz; 219 total_blocks += chunk_header->chunk_sz;
** CID 345914: Integer handling issues (CONSTANT_EXPRESSION_RESULT) /tools/mkeficapsule.c: 96 in read_bin_file()
________________________________________________________________________________________________________ *** CID 345914: Integer handling issues (CONSTANT_EXPRESSION_RESULT) /tools/mkeficapsule.c: 96 in read_bin_file() 90 } 91 if (stat(bin, &bin_stat) < 0) { 92 fprintf(stderr, "cannot determine the size of %s\n", bin); 93 ret = -1; 94 goto err; 95 }
CID 345914: Integer handling issues (CONSTANT_EXPRESSION_RESULT) "bin_stat.st_size > 18446744073709551615UL" is always false regardless of the values of its operands. This occurs as the logical operand of "if".
96 if (bin_stat.st_size > SIZE_MAX) { 97 fprintf(stderr, "file size is too large for malloc: %s\n", bin); 98 ret = -1; 99 goto err; 100 } 101 buf = malloc(bin_stat.st_size);
** CID 345913: (TAINTED_SCALAR) /drivers/core/ofnode.c: 477 in ofnode_read_string_list()
________________________________________________________________________________________________________ *** CID 345913: (TAINTED_SCALAR) /drivers/core/ofnode.c: 473 in ofnode_read_string_list() 467 count = ofnode_read_string_count(node, property); 468 if (count < 0) 469 return count; 470 if (!count) 471 return 0; 472
CID 345913: (TAINTED_SCALAR) Passing tainted expression "count + 1" to "dlcalloc", which uses it as an offset.
473 prop = calloc(count + 1, sizeof(char *)); 474 if (!prop) 475 return -ENOMEM; 476 477 for (i = 0; i < count; i++) 478 ofnode_read_string_index(node, property, i, &prop[i]); /drivers/core/ofnode.c: 477 in ofnode_read_string_list() 471 return 0; 472 473 prop = calloc(count + 1, sizeof(char *)); 474 if (!prop) 475 return -ENOMEM; 476
CID 345913: (TAINTED_SCALAR) Using tainted variable "count" as a loop boundary.
477 for (i = 0; i < count; i++) 478 ofnode_read_string_index(node, property, i, &prop[i]); 479 prop[count] = NULL; 480 *listp = prop; 481 482 return count;
** CID 345912: Null pointer dereferences (FORWARD_NULL) /lib/efi_loader/efi_signature.c: 232 in efi_signature_lookup_digest()
________________________________________________________________________________________________________ *** CID 345912: Null pointer dereferences (FORWARD_NULL) /lib/efi_loader/efi_signature.c: 232 in efi_signature_lookup_digest() 226 sig_data = sig_data->next) { 227 #ifdef DEBUG 228 EFI_PRINT("Msg digest in database:\n"); 229 print_hex_dump(" ", DUMP_PREFIX_OFFSET, 16, 1, 230 sig_data->data, sig_data->size, false); 231 #endif
CID 345912: Null pointer dereferences (FORWARD_NULL) Passing null pointer "hash" to "memcmp", which dereferences it. [Note: The source code implementation of the function has been overridden by a builtin model.]
232 if (sig_data->size == size && 233 !memcmp(sig_data->data, hash, size)) { 234 found = true; 235 free(hash); 236 goto out; 237 }
________________________________________________________________________________________________________ To view the defects in Coverity Scan visit, https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0...
To manage Coverity Scan email notifications for "tom.rini@gmail.com", click https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0...
----- End forwarded message -----
