[U-Boot] question: U-boot linking against libgcc
Hello Wolfgang,
In U-boot I see that it links against libgcc. Why is this? I believe this relation should not be needed. I could provide a patch to remove this relation...
Kind Regards,
Remy
Dear Remy,
In message 3efb10970810310111j5a82af83p124011a76b45ebf@mail.gmail.com you wrote:
Because the GNU compiler references code form it's library.
I believe it is needed.
Hm.. try it out. I wouldbe surprised if it worked.
Linux works fine without libgcc. I only had to add three 64-bit shift routines for avr32.
And as an added bonus, you get a linker error if you introduce an open-coded 64-bit division by mistake :-)
Haavard
It's simple to do it on arm
Best Regards, J.
Haavard Skinnemoen
Jean-Christophe PLAGNIOL-VILLARD
Remy Bohmer
