[GIT PULL] Please pull u-boot-imx-master-20240706
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit fd46ea0e701920eb205c2bce9d527bf0dec10b59:
Merge branch '2024-07-05-assorted-updates' (2024-07-05 16:36:43 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240706
for you to fetch changes up to 3d4c29258f8b4c4a5cf4ce79fb1ac80f66e4cf65:
clk: imx: add mux ops for i.MX8M composite clk (2024-07-06 15:40:04 -0300)
u-boot-imx-master-20240706 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/21504
- Fixes for i.MX8M and i.MX93 clk-composite. - Set CAN oscillator frequency based on model on verdin-imx8mm. - Enable CAAM for phycore-imx8mp_defconfig. - Miscellaneous improvements for Gateworks i.MX8M boards. - Fix initramfs boot on msc_sm2s_imx8mp. - Fixe EQoS on imx8mp-beacon-kit. - Fix error message in fsl_esdhc_imx. ---------------------------------------------------------------- Adam Ford (1): ARM: dts: imx8mp-beacon-kit-u-boot: Drop EQoS clock work-around
Alexander Stein (1): mmc: fsl_esdhc_imx: Fix error message
Fabio Estevam (1): msc_sm2s_imx8mp: Adjust the initrd_addr location
Leonard Anderweit (1): configs: phycore-imx8mp_defconfig: Initialize caam
Marek Vasut (4): ARM: imx: verdin-imx8mm: Set CAN oscillator frequency based on model ARM: imx: Enable cat and xxd commands on DH i.MX8M Plus DHCOM ARM: imx: Enable PCA953x driver on DH i.MX8MP DHCOM PDK2 ARM: imx: Update Fast ethernet PHY MDIO addresses to match DH i.MX8MP DHCOM rev.200
Michael Trimarchi (4): clk: imx: Fix wrong flags assignment clk-composite-8m clk: imx: Fix wrong flags assignment clk-composite-93 clk: clk-mux: Make public the clk_fetch_parent_index clk: imx: add mux ops for i.MX8M composite clk
arch/arm/dts/Makefile | 1 + arch/arm/dts/imx8mp-beacon-kit-u-boot.dtsi | 6 ---- arch/arm/dts/imx8mp-dhcom-som-overlay-rev100.dts | 5 +++ arch/arm/dts/imx8mp-dhcom-som.dtsi | 8 ++--- board/toradex/verdin-imx8mm/verdin-imx8mm.c | 29 +++++++++++++++++ configs/imx8mp_dhcom_pdk2_defconfig | 3 ++ configs/imx8mp_dhcom_pdk3_defconfig | 2 ++ configs/phycore-imx8mp_defconfig | 5 ++- drivers/clk/clk-mux.c | 5 ++- drivers/clk/imx/clk-composite-8m.c | 41 +++++++++++++++++++++--- drivers/clk/imx/clk-composite-93.c | 2 -- drivers/mmc/fsl_esdhc_imx.c | 4 +-- include/configs/msc_sm2s_imx8mp.h | 4 +-- include/linux/clk-provider.h | 1 + 14 files changed, 92 insertions(+), 24 deletions(-)
On Sat, Jul 06, 2024 at 05:45:47PM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
