[U-Boot] [PATCH v2] [x86] Add a basic implementation for a coreboot board
Signed-off-by: Gabe Black gabeblack@chromium.org --- Changes in v2: Get rid of some dead/unnecessary code in the Makefile and coreboot.c.
board/chromebook-x86/coreboot/Makefile | 53 +++++++++++++++ board/chromebook-x86/coreboot/coreboot.c | 77 ++++++++++++++++++++++ board/chromebook-x86/coreboot/coreboot_pci.c | 30 +++++++++ board/chromebook-x86/coreboot/coreboot_start.S | 29 ++++++++ board/chromebook-x86/coreboot/coreboot_start16.S | 46 +++++++++++++ 5 files changed, 235 insertions(+), 0 deletions(-) create mode 100644 board/chromebook-x86/coreboot/Makefile create mode 100644 board/chromebook-x86/coreboot/coreboot.c create mode 100644 board/chromebook-x86/coreboot/coreboot_pci.c create mode 100644 board/chromebook-x86/coreboot/coreboot_start.S create mode 100644 board/chromebook-x86/coreboot/coreboot_start16.S
diff --git a/board/chromebook-x86/coreboot/Makefile b/board/chromebook-x86/coreboot/Makefile new file mode 100644 index 0000000..dbeee50 --- /dev/null +++ b/board/chromebook-x86/coreboot/Makefile @@ -0,0 +1,53 @@ +# +# Copyright (c) 2011 The Chromium OS Authors. All rights reserved. +# (C) Copyright 2008 +# Graeme Russ, graeme.russ@gmail.com. +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2002 +# Daniel Engstr�m, Omicron Ceti AB, daniel@omicron.se. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += coreboot.o +COBJS-$(CONFIG_PCI) += coreboot_pci.o +SOBJS-y += coreboot_start16.o +SOBJS-y += coreboot_start.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/chromebook-x86/coreboot/coreboot.c b/board/chromebook-x86/coreboot/coreboot.c new file mode 100644 index 0000000..88e4223 --- /dev/null +++ b/board/chromebook-x86/coreboot/coreboot.c @@ -0,0 +1,77 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * (C) Copyright 2008 + * Graeme Russ, graeme.russ@gmail.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/u-boot-x86.h> +#include <flash.h> +#include <netdev.h> + +DECLARE_GLOBAL_DATA_PTR; + +unsigned long monitor_flash_len = CONFIG_SYS_MONITOR_LEN; + +/* + * Miscellaneous platform dependent initializations + */ +int board_early_init_f(void) +{ + return 0; +} + +int board_early_init_r(void) +{ + /* CPU Speed to 100MHz */ + gd->cpu_clk = 100000000; + + /* Crystal is 33.000MHz */ + gd->bus_clk = 33000000; + + return 0; +} + +void show_boot_progress(int val) +{ +} + + +int last_stage_init(void) +{ + return 0; +} + +#ifndef CONFIG_SYS_NO_FLASH +ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info) +{ + return 0; +} +#endif + +int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} + +void setup_pcat_compatibility() +{ +} diff --git a/board/chromebook-x86/coreboot/coreboot_pci.c b/board/chromebook-x86/coreboot/coreboot_pci.c new file mode 100644 index 0000000..4ef7e5a --- /dev/null +++ b/board/chromebook-x86/coreboot/coreboot_pci.c @@ -0,0 +1,30 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * (C) Copyright 2008,2009 + * Graeme Russ, graeme.russ@gmail.com + * + * (C) Copyright 2002 + * Daniel Engstr�m, Omicron Ceti AB, daniel@omicron.se + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +void pci_init_board(void) +{ +} diff --git a/board/chromebook-x86/coreboot/coreboot_start.S b/board/chromebook-x86/coreboot/coreboot_start.S new file mode 100644 index 0000000..ef1e1d1 --- /dev/null +++ b/board/chromebook-x86/coreboot/coreboot_start.S @@ -0,0 +1,29 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * (C) Copyright 2008 + * Graeme Russ, graeme.russ@gmail.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* board early intialization */ +.globl early_board_init +early_board_init: + /* No 32-bit board specific initialisation */ + jmp early_board_init_ret diff --git a/board/chromebook-x86/coreboot/coreboot_start16.S b/board/chromebook-x86/coreboot/coreboot_start16.S new file mode 100644 index 0000000..1bd6294 --- /dev/null +++ b/board/chromebook-x86/coreboot/coreboot_start16.S @@ -0,0 +1,46 @@ +/* + * Copyright (c) 2011 The Chromium OS Authors. All rights reserved. + * (C) Copyright 2008 + * Graeme Russ, graeme.russ@gmail.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * 16bit initialization code. + * This code have to map the area of the boot flash + * that is used by U-boot to its final destination. + */ + +.text +.section .start16, "ax" +.code16 +.globl board_init16 +board_init16: + jmp board_init16_ret + +.section .bios, "ax" +.code16 +.globl realmode_reset +.hidden realmode_reset +.type realmode_reset, @function +realmode_reset: + +1: hlt + jmp 1
i'm not terribly familiar with what it takes to make an x86 board, but i don't see anything jumping out of this patch.
i would note however that you should merge the boards.cfg update into this patch. merging one or the other doesn't make much sense, and there's no reason to keep them split.
should be "(void)" -mike
The early startup code is in arch/x86/cpu/start.S or start16.S depending on the state of the CPU when u-boot is entered, and this code is called back into at various points during startup. You can see that those callbacks stubbed out where there's a label and then a jump back immediately after it, for instance here:
I have no problem merging the commits, but I'll wait for Graeme to weigh in since it's a little easier to merge them than to unmerge them.
Gabe
when i said "jumping out", i meant "nothing jumps out at me as being wrong" ;) -mike
Hi Gabe,
+board_init16:
Well I guess that is my cue ;)
I agree that this should be a single commit. I have a few other comments...
I'm just about to send through another patchset (today) which will probably impact on your patches - In particular I am adding more config granularity to deal with the horrible mess that is board_init_r(). Now that the merge window is closed, I will create a 'next' branch which you can work from.
Since coreboot is doing all the low level initialisation, I don't see the need for any of the 16-bit start code (start_16.S). Let's look at CONFIG_SKIP_LOWLEVEL_INIT. I don't know how to _not_ compile a source file based on a define using the COBJS-$(CONFIG_<blah>) style.
Also, we may be performing a completely unnecessary relocation - I think we should be able to start at board_init_r(), but there may be some board_init_f() functions that we may still need to call. This seems a very close parallel to IPL/SPL - Have a look at what they do
From what I can gather, the likely scenario is that U-Boot will always be
loaded by coreboot on the chromebook, and it's likely that other coreboot motherboards may want to do the same. Therefore can you change: board/chromebook-x86/coreboot to: board/coreboot/chromebook-x86/
Regarding the empty functions, I know they are required to keep the linker happy. I see two options:
1) #ifdef the call sites 2) create weak stubs
I'm open to debate on the preferred approach
Regards,
Graeme
Gabe
On Fri, Nov 4, 2011 at 3:24 PM, Mike Frysinger <vapier@gentoo.org mailto:vapier@gentoo.org> wrote:
i'm not terribly familiar with what it takes to make an x86 board, but i don't see anything jumping out of this patch. i would note however that you should merge the boards.cfg update into this patch. merging one or the other doesn't make much sense, and there's no reason to keep them split. > +void setup_pcat_compatibility() should be "(void)" -mike
Dear Gabe Black,
In message 1320443602-2677-1-git-send-email-gabeblack@chromium.org you wrote:
--===============1488196431== Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit
v2 ?????
Drop empty functions.
- /* CPU Speed to 100MHz */
- gd->cpu_clk = 100000000;
- /* Crystal is 33.000MHz */
- gd->bus_clk = 33000000;
You should use #defines for these.
+} +#endif
Gabe Black
Graeme Russ
Mike Frysinger
