[U-Boot] arm: socfpga: Question about FPGA/HPS SDRAM Bridge
Hi!
I've read about an implementation requirement regarding the usage of FPGA/HPS SDRAM bridge. (Link and Text attached at the end.)
The 3. step involves writing the APPLYCFG bit in the STATICCFG register while the SDRAM interface is completely IDLE. IMHO, it's only possible in SPL stage where everything runs in SRAM. FPGA however can not be configured until U-Boot is ready (step 2). So warm reset should be performed after FPGA configuration.
My idea is to patch sdram.c to dynamically write FPGAPORTRST and APPLYCFG based on information in sysmgr_regs->romcodegrp_bootromswstate.
Is any one working on this?
Thanks!
On Tuesday, September 01, 2015 at 10:41:31 AM, Jian Luo wrote:
Hi!
We do this sort of stuff by running code from cache, see socfpga_sdram_apply_static_cfg() in arch/arm/mach-socfpga/misc.c .
You want to use the "bridge enable" and "bridge disable" commands to enable/disable the bridges between FPGA and HPS in U-Boot.
Hope that helps ;-)
Best regards, Marek Vasut
** Hi Marek,
Hi!
Thanks. It's way better than run bootloader twice!
What about calling socfpga_sdram_apply_static_cfg() direct in socfpga_load() in drivers/fpga/socfpga.c to make it generic? socfpga_load() already did step 1 and 2. Is there any side effect when fpga2sdram bridge is not used?
Hope that helps ;-)
On Tuesday, September 01, 2015 at 01:49:43 PM, Jian Luo wrote:
** Hi Marek,
Hi!
Hi!
Yeah :)
Which code exactly do you refer to ?
The idea is to keep the FPGA programming code and the code which controls the bridges separate. The reason for that is that you can have content in the FPGA which is running completely independent of the HPS software. You don't always need to enable the bridges.
The FPGA2SDRAM bridge (or, more like fpga2hps bridge) is used for stuff like framebuffers implemented in the FPGA, so that the FPGA can fetch data from the SDRAM.
Hi Marek,
----snip----
I mean something like this.
diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index 4448250..d0f67f6 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -300,5 +300,12 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) return status;
/* Ensure the FPGA entering user mode */ - return fpgamgr_program_poll_usermode(); + status = fpgamgr_program_poll_usermode(); + if (status) + return status; + + /* Latch FPGA2SDRAM bridge configuration */ + socfpga_sdram_apply_static_cfg(); + + return 0; }
No, it's the other way around here. socfpga_load() runs eventually when command "fpga load" is called. So when I explicitly use "fpga load" command, the old FPGA program is expected to stop running, right?
And I don't want to enable the bridge here, just to latch the SDRAM configuration.
Jian Luo
On Tuesday, September 01, 2015 at 02:32:26 PM, Jian Luo wrote:
Hi Marek,
Hi!
----snip----
if (status)
return status;
}return 0;
Right
So what you want to do is "bridge disable ; fpga load ... ; bridge enable", isn't that the correct sequence ? I might be missing something though, sorry.
Jian Luo
Hi Marek,
Hi Marek,
Hi!
----snip----
if (status)
return status;
}return 0;
can have
the HPS
Right
enable",
though, sorry.
No, you are right. Sorry, I didn't think it through.
My original thought was, that "fpga load" should not depend on "bridge e/d" regardless of how fpga2sdram is configured. Now I think the dependency is a bad idea. Sorry for the confusion.
stuff
Jian Luo
Jian Luo
On Wednesday, September 02, 2015 at 01:29:36 PM, Jian Luo wrote:
Hi Marek,
Hi!
Hi Marek,
Hi!
----snip----
return status; /* Ensure the FPGA entering user mode */
if (status)
return status;
can have
the HPS
Right
enable",
though, sorry.
Yeah, you should be able to control the bridges between the FPGA and the FPGA loading independently for the particular case where the FPGA runs independently of the HPS.
Well, I'm glad it got sorted out :)
Jian Luo
