[U-Boot] [PATCH 1/3] mp2usb: remove board support
this board was cancelled long time ago so remove it as it won't be maintained anymore
Signed-off-by: Eric Bénard eric@eukrea.com --- board/mp2usb/Makefile | 50 ----- board/mp2usb/config.mk | 3 - board/mp2usb/flash.c | 552 ---------------------------------------------- board/mp2usb/mp2usb.c | 98 -------- boards.cfg | 1 - include/configs/mp2usb.h | 242 -------------------- 6 files changed, 0 insertions(+), 946 deletions(-) delete mode 100644 board/mp2usb/Makefile delete mode 100644 board/mp2usb/config.mk delete mode 100644 board/mp2usb/flash.c delete mode 100644 board/mp2usb/mp2usb.c delete mode 100644 include/configs/mp2usb.h
diff --git a/board/mp2usb/Makefile b/board/mp2usb/Makefile deleted file mode 100644 index 335734a..0000000 --- a/board/mp2usb/Makefile +++ /dev/null @@ -1,50 +0,0 @@ -# -# (C) Copyright 2003-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := mp2usb.o flash.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/mp2usb/config.mk b/board/mp2usb/config.mk deleted file mode 100644 index 948e4ff..0000000 --- a/board/mp2usb/config.mk +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x27F00000 -## For testing: load at 0x20100000 and "go" at 0x201000A4 -#CONFIG_SYS_TEXT_BASE = 0x20100000 diff --git a/board/mp2usb/flash.c b/board/mp2usb/flash.c deleted file mode 100644 index 21a8ef9..0000000 --- a/board/mp2usb/flash.c +++ /dev/null @@ -1,552 +0,0 @@ -/* - * (C) Copyright 2001 - * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net - * - * (C) Copyright 2001 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Modified for the MP2USB by (C) Copyright 2005 Eric Benard - * ebenard@eukrea.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <linux/byteorder/swab.h> - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define PHYS_FLASH_SECT_SIZE 0x00020000 /* 128 KB sectors (x1) */ - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -#define FLASH_PORT_WIDTH ushort -#define FLASH_PORT_WIDTHV vu_short -#define SWAP(x) __swab16(x) - -#define FPW FLASH_PORT_WIDTH -#define FPWV FLASH_PORT_WIDTHV - -#define mb() __asm__ __volatile__ ("" : : : "memory") - -/* Intel-compatible flash commands */ -#define INTEL_PROGRAM 0x00100010 -#define INTEL_ERASE 0x00200020 -#define INTEL_PROG 0x00400040 -#define INTEL_CLEAR 0x00500050 -#define INTEL_LOCKBIT 0x00600060 -#define INTEL_PROTECT 0x00010001 -#define INTEL_STATUS 0x00700070 -#define INTEL_READID 0x00900090 -#define INTEL_SUSPEND 0x00B000B0 -#define INTEL_CONFIRM 0x00D000D0 -#define INTEL_RESET 0xFFFFFFFF - -/* Intel-compatible flash status bits */ -#define INTEL_FINISHED 0x00800080 -#define INTEL_OK 0x00800080 - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (FPW *addr, flash_info_t *info); -static int write_data (flash_info_t *info, ulong dest, FPW data); -static void flash_get_offsets (ulong base, flash_info_t *info); -void inline spin_wheel (void); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - int i; - ulong size = 0; - - for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - switch (i) { - case 0: - flash_get_size ((FPW *) PHYS_FLASH_1, &flash_info[i]); - flash_get_offsets (PHYS_FLASH_1, &flash_info[i]); - break; - default: - panic ("configured too many flash banks!\n"); - break; - } - size += flash_info[i].size; - } - - /* Protect monitor and environment sectors - */ - flash_protect ( FLAG_PROTECT_SET, - CONFIG_SYS_FLASH_BASE, - CONFIG_SYS_FLASH_BASE + monitor_flash_len - 1, - &flash_info[0] ); - - flash_protect ( FLAG_PROTECT_SET, - CONFIG_ENV_ADDR, - CONFIG_ENV_ADDR + CONFIG_ENV_SIZE - 1, &flash_info[0] ); - - return size; -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - return; - } - - if ((info->flash_id & FLASH_VENDMASK) == FLASH_MAN_INTEL) { - for (i = 0; i < info->sector_count; i++) { - info->start[i] = base + (i * PHYS_FLASH_SECT_SIZE); - info->protect[i] = 0; - } - } -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_INTEL: - printf ("INTEL "); - break; - default: - printf ("Unknown Vendor "); - break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_28F640J3A: - printf ("28F640J3A\n"); - break; - case FLASH_28F128J3A: - printf ("28F128J3A\n"); - break; - default: - printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i = 0; i < info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " "); - } - printf ("\n"); - return; -} - -/* - * The following code cannot be run from FLASH! - */ -static ulong flash_get_size (FPW *addr, flash_info_t *info) -{ - volatile FPW value; - - /* Write auto select command: read Manufacturer ID */ - addr[0x5555] = (FPW) 0x00AA00AA; - addr[0x2AAA] = (FPW) 0x00550055; - addr[0x5555] = (FPW) 0x00900090; - - mb (); - value = addr[0]; - - switch (value) { - - case (FPW) INTEL_MANUFACT: - info->flash_id = FLASH_MAN_INTEL; - break; - - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - addr[0] = (FPW) INTEL_RESET; /* restore read mode */ - return (0); /* no or unknown flash */ - } - - mb (); - value = addr[1]; /* device ID */ - - switch (value) { - - case (FPW) INTEL_ID_28F640J3A: - info->flash_id += FLASH_28F640J3A; - info->sector_count = 64; - info->size = 0x00800000; - break; /* => 8 MB */ - - case (FPW) INTEL_ID_28F128J3A: - info->flash_id += FLASH_28F128J3A; - info->sector_count = 128; - info->size = 0x01000000; - break; /* => 16 MB */ - - default: - info->flash_id = FLASH_UNKNOWN; - break; - } - - if (info->sector_count > CONFIG_SYS_MAX_FLASH_SECT) { - printf ("** ERROR: sector count %d > max (%d) **\n", - info->sector_count, CONFIG_SYS_MAX_FLASH_SECT); - info->sector_count = CONFIG_SYS_MAX_FLASH_SECT; - } - - addr[0] = (FPW) INTEL_RESET; /* restore read mode */ - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - int prot, sect; - ulong type, start, last; - int rcode = 0; - int cflag, iflag; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - type = (info->flash_id & FLASH_VENDMASK); - if ((type != FLASH_MAN_INTEL)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect = s_first; sect <= s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - start = get_timer (0); - last = start; - - /* - * Disable interrupts which might cause a timeout - * here. Remember that our exception vectors are - * at address 0 in the flash, and we don't want a - * (ticker) exception to happen while the flash - * chip is in programming mode. - */ - cflag = icache_status (); - icache_disable (); - /* Disable interrupts which might cause a timeout here */ - iflag = disable_interrupts (); - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect <= s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - FPWV *addr = (FPWV *) (info->start[sect]); - FPW status; - - printf ("Erasing sector %2d ... ", sect); - - /* arm simple, non interrupt dependent timer */ - reset_timer_masked (); - - *addr = (FPW) INTEL_CLEAR; /* clear status register */ - *addr = (FPW) INTEL_ERASE; /* erase setup */ - *addr = (FPW) INTEL_CONFIRM; /* erase confirm */ - - while (((status = *addr) & (FPW) INTEL_FINISHED) != (FPW) INTEL_FINISHED) { - if (get_timer_masked () > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - *addr = (FPW) INTEL_SUSPEND; /* suspend erase */ - *addr = (FPW) INTEL_RESET; /* reset to read mode */ - rcode = 1; - break; - } - } - - *addr = (FPWV)INTEL_CLEAR; /* clear status register cmd. */ - *addr = (FPWV)INTEL_RESET; /* resest to read mode */ - - printf (" done\n"); - } - } - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return rcode; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - * 4 - Flash not identified - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - ulong cp, wp; - FPW data; - int count, i, l, rc, port_width; - - if (info->flash_id == FLASH_UNKNOWN) { - return 4; - } - - /* get lower word aligned address */ - wp = (addr & ~1); - port_width = 2; - - /* - * handle unaligned start bytes - */ - if ((l = addr - wp) != 0) { - data = 0; - for (i = 0, cp = wp; i < l; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - for (; i < port_width && cnt > 0; ++i) { - data = (data << 8) | *src++; - --cnt; - ++cp; - } - for (; cnt == 0 && i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return (rc); - } - wp += port_width; - } - - /* - * handle word aligned part - */ - count = 0; - while (cnt >= port_width) { - data = 0; - for (i = 0; i < port_width; ++i) { - data = (data << 8) | *src++; - } - if ((rc = write_data (info, wp, SWAP (data))) != 0) { - return (rc); - } - wp += port_width; - cnt -= port_width; - if (count++ > 0x800) { - spin_wheel (); - count = 0; - } - } - - if (cnt == 0) { - return (0); - } - - /* - * handle unaligned tail bytes - */ - data = 0; - for (i = 0, cp = wp; i < port_width && cnt > 0; ++i, ++cp) { - data = (data << 8) | *src++; - --cnt; - } - for (; i < port_width; ++i, ++cp) { - data = (data << 8) | (*(uchar *) cp); - } - - return (write_data (info, wp, SWAP (data))); -} - -/*----------------------------------------------------------------------- - * Write a word or halfword to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_data (flash_info_t *info, ulong dest, FPW data) -{ - FPWV *addr = (FPWV *) dest; - ulong status; - int cflag, iflag; - - /* Check if Flash is (sufficiently) erased */ - if ((*addr & data) != data) { - printf ("not erased at %08lx (%lx)\n", (ulong) addr, (ulong) *addr); - return (2); - } - /* - * Disable interrupts which might cause a timeout - * here. Remember that our exception vectors are - * at address 0 in the flash, and we don't want a - * (ticker) exception to happen while the flash - * chip is in programming mode. - */ - cflag = icache_status (); - icache_disable (); - /* Disable interrupts which might cause a timeout here */ - iflag = disable_interrupts (); - - *addr = (FPW) INTEL_PROG; /* write setup */ - *addr = data; - - /* arm simple, non interrupt dependent timer */ - reset_timer_masked (); - - /* wait while polling the status register */ - while (((status = *addr) & (FPW) INTEL_FINISHED) != (FPW) INTEL_FINISHED) { - if (get_timer_masked () > CONFIG_SYS_FLASH_WRITE_TOUT) { - *addr = (FPW) INTEL_RESET; /* restore read mode */ - return (1); - } - } - - *addr = (FPW) INTEL_RESET; /* restore read mode */ - - if (iflag) - enable_interrupts (); - - if (cflag) - icache_enable (); - - return (0); -} - -void inline spin_wheel (void) -{ - static int p = 0; - static char w[] = "\/-"; - - printf ("\010%c", w[p]); - (++p == 3) ? (p = 0) : 0; -} - -/*----------------------------------------------------------------------- - * Set/Clear sector's lock bit, returns: - * 0 - OK - * 1 - Error (timeout, voltage problems, etc.) - */ -int flash_real_protect(flash_info_t *info, long sector, int prot) -{ - int i; - int rc = 0; - FPWV *addr = (FPWV *)(info->start[sector]); - int flag = disable_interrupts(); - - *addr = (FPW) INTEL_CLEAR; /* Clear status register */ - if (prot) { /* Set sector lock bit */ - *addr = (FPW) INTEL_LOCKBIT; /* Sector lock bit */ - *addr = (FPW) INTEL_PROTECT; /* set */ - } - else { /* Clear sector lock bit */ - *addr = (FPW) INTEL_LOCKBIT; /* All sectors lock bits */ - *addr = (FPW) INTEL_CONFIRM; /* clear */ - } - - reset_timer_masked (); - - while ((*addr & (FPW) INTEL_FINISHED) != (FPW) INTEL_FINISHED) { - if (get_timer_masked () > CONFIG_SYS_FLASH_UNLOCK_TOUT) { - printf("Flash lock bit operation timed out\n"); - rc = 1; - break; - } - } - - if (*addr != (FPW) INTEL_OK) { - printf("Flash lock bit operation failed at %08X, CSR=%08X\n", - (uint)addr, (uint)*addr); - rc = 1; - } - - if (!rc) - info->protect[sector] = prot; - - /* - * Clear lock bit command clears all sectors lock bits, so - * we have to restore lock bits of protected sectors. - */ - if (!prot) - { - for (i = 0; i < info->sector_count; i++) - { - if (info->protect[i]) - { - reset_timer_masked (); - addr = (FPWV *) (info->start[i]); - *addr = (FPW) INTEL_LOCKBIT; /* Sector lock bit */ - *addr = (FPW) INTEL_PROTECT; /* set */ - while ((*addr & (FPW) INTEL_FINISHED) != (FPW) INTEL_FINISHED) - { - if (get_timer_masked () > CONFIG_SYS_FLASH_UNLOCK_TOUT) - { - printf("Flash lock bit operation timed out\n"); - rc = 1; - break; - } - } - } - } - } - - if (flag) - enable_interrupts(); - - *addr = (FPW) INTEL_RESET; /* Reset to read array mode */ - - return rc; -} diff --git a/board/mp2usb/mp2usb.c b/board/mp2usb/mp2usb.c deleted file mode 100644 index e5eba6b..0000000 --- a/board/mp2usb/mp2usb.c +++ /dev/null @@ -1,98 +0,0 @@ -/* - * (C) Copyright 2002 - * Sysgo Real-Time Solutions, GmbH <www.elinos.com> - * Marius Groeger mgroeger@sysgo.de - * - * Modified for the MP2USB by (C) Copyright 2005 Eric Benard - * ebenard@eukrea.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/arch/AT91RM9200.h> -#include <netdev.h> -#include <asm/io.h> -#if defined(CONFIG_DRIVER_ETHER) -#include <at91rm9200_net.h> -#include <dm9161.h> -#endif -#include <asm/mach-types.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* - * Miscelaneous platform dependent initialisations - */ - -int board_init (void) -{ - /* Enable Ctrlc */ - console_init_f (); - - /* memory and cpu-speed are setup before relocation */ - /* so we do _nothing_ here */ - - /* arch number of MP2USB-Board. */ - gd->bd->bi_arch_number = MACH_TYPE_MP2USB; - /* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; - - return 0; -} - -int dram_init (void) -{ - gd->bd->bi_dram[0].start = PHYS_SDRAM; - gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; - return 0; -} - -#ifdef CONFIG_DRIVER_ETHER -#if defined(CONFIG_CMD_NET) - -/* - * Name: - * at91rm9200_GetPhyInterface - * Description: - * Initialise the interface functions to the PHY - * Arguments: - * None - * Return value: - * None - */ -void at91rm9200_GetPhyInterface(AT91PS_PhyOps p_phyops) -{ - p_phyops->Init = dm9161_InitPhy; - p_phyops->IsPhyConnected = dm9161_IsPhyConnected; - p_phyops->GetLinkSpeed = dm9161_GetLinkSpeed; - p_phyops->AutoNegotiate = dm9161_AutoNegotiate; -} - -#endif -#endif /* CONFIG_DRIVER_ETHER */ - -#ifdef CONFIG_DRIVER_AT91EMAC -int board_eth_init(bd_t *bis) -{ - int rc = 0; - rc = at91emac_register(bis, 0); - return rc; -} -#endif diff --git a/boards.cfg b/boards.cfg index 45c3102..105c748 100644 --- a/boards.cfg +++ b/boards.cfg @@ -56,7 +56,6 @@ cmc_pu2 arm arm920t - - csb637 arm arm920t - - at91rm9200 kb9202 arm arm920t - - at91rm9200 m501sk arm arm920t - - at91rm9200 -mp2usb arm arm920t - - at91rm9200 at91rm9200dk arm arm920t - atmel at91rm9200 mx1ads arm arm920t - - imx mx1fs2 arm arm920t - - imx diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h deleted file mode 100644 index 8e398d7..0000000 --- a/include/configs/mp2usb.h +++ /dev/null @@ -1,242 +0,0 @@ -/* - * 2004-2005 Gary Jennejohn garyj@denx.de - * - * Modified for the MP2USB by (C) Copyright 2005 Eric Benard - * ebenard@eukrea.com - * - * Configuration settings for the MP2USB board. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -#define CONFIG_AT91_LEGACY - -/* ARM asynchronous clock */ -#define AT91C_MAIN_CLOCK 179712000 /* from 18.432 MHz crystal (18432000 / 4 * 45) */ -#define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK/3) /* peripheral clock */ - -#define AT91_SLOW_CLOCK 32768 /* slow clock */ - -#define CONFIG_ARM920T 1 /* This is an ARM920T Core */ -#define CONFIG_AT91RM9200 1 /* It's an Atmel AT91RM9200 SoC */ -#define CONFIG_AT91RM9200DK 1 /* on an AT91RM9200DK Board */ -#define CONFIG_MP2USB 1 /* on an MP2USB Board */ -#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ -#define USE_920T_MMU 1 - -#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 - -#define CONFIG_SYS_ATMEL_PLL_INIT_BUG 1 -#ifndef CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_USE_MAIN_OSCILLATOR 1 -/* flash */ -#define CONFIG_SYS_EBI_CFGR_VAL 0x00000000 -#define CONFIG_SYS_SMC_CSR0_VAL 0x00003084 /* 16bit, 2 TDF, 4 WS */ - -/* clocks */ -#define CONFIG_SYS_PLLAR_VAL 0x20263E04 /* 180 MHz for PCK */ -#define CONFIG_SYS_PLLBR_VAL 0x1048bE0E /* 48 MHz (divider by 2 for USB) */ -#define CONFIG_SYS_MCKR_VAL 0x00000202 /* PCK/3 = MCK Master Clock = 60MHz from PLLA */ - -/* sdram */ -#define CONFIG_SYS_PIOC_ASR_VAL 0xFFFF0000 /* Configure PIOC as peripheral (D16/D31) */ -#define CONFIG_SYS_PIOC_BSR_VAL 0x00000000 -#define CONFIG_SYS_PIOC_PDR_VAL 0xFFFF0000 -#define CONFIG_SYS_EBI_CSA_VAL 0x00000002 /* CS1=CONFIG_SYS_SDRAM */ -#define CONFIG_SYS_SDRC_CR_VAL 0x3211295A /* set up the CONFIG_SYS_SDRAM */ -#define CONFIG_SYS_SDRAM 0x20000000 /* address of the CONFIG_SYS_SDRAM */ -#define CONFIG_SYS_SDRAM1 0x20000020 /* address of the CONFIG_SYS_SDRAM */ -#define CONFIG_SYS_SDRAM_VAL 0x00000000 /* value written to CONFIG_SYS_SDRAM */ -#define CONFIG_SYS_SDRC_MR_VAL 0x00000002 /* Precharge All */ -#define CONFIG_SYS_SDRC_MR_VAL1 0x00000004 /* refresh */ -#define CONFIG_SYS_SDRC_MR_VAL2 0x00000003 /* Load Mode Register */ -#define CONFIG_SYS_SDRC_MR_VAL3 0x00000000 /* Normal Mode */ -#define CONFIG_SYS_SDRC_TR_VAL 0x000002E0 /* Write refresh rate */ -#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ - -/* - * Size of malloc() pool - */ -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) - -#define CONFIG_BAUDRATE 115200 - -#define CONFIG_SYS_AT91C_BRGR_DIVISOR 33 /* hardcode so no __divsi3 : AT91C_MASTER_CLOCK /(baudrate * 16) */ - -/* - * Hardware drivers - */ - -/* define one of these to choose the DBGU, USART0 or USART1 as console */ -#define CONFIG_AT91RM9200_USART -#define CONFIG_DBGU -#undef CONFIG_USART0 -#undef CONFIG_USART1 - -#undef CONFIG_HWFLOW /* don't include RTS/CTS flow control support */ - -#undef CONFIG_MODEM_SUPPORT /* disable modem initialization stuff */ - -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_KEYBOARD 1 -#define CONFIG_USB_STORAGE 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_AT91C_PQFP_UHPBUG 1 - -#undef CONFIG_SYS_USB_OHCI_BOARD_INIT -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 -#define CONFIG_SYS_USB_OHCI_REGS_BASE AT91_USB_HOST_BASE -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91rm9200" -#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 - -#undef CONFIG_HARD_I2C - -#ifdef CONFIG_HARD_I2C -#define CONFIG_SYS_I2C_SPEED 0 /* not used */ -#define CONFIG_SYS_I2C_SLAVE 0 /* not used */ -#define CONFIG_RTC_RS5C372A /* RICOH I2C RTC */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x32 -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 -#define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW -#endif -/* still about 20 kB free with this defined */ -#define CONFIG_SYS_LONGHELP - -#define CONFIG_BOOTDELAY 3 - -#if !defined(CONFIG_HARD_I2C) -#define CONFIG_TIMESTAMP -#endif - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#if defined(CONFIG_HARD_I2C) - - #define CONFIG_CMD_DATE - #define CONFIG_CMD_EEPROM - #define CONFIG_CMD_I2C - #define CONFIG_CMD_MISC - -#else - - #define CONFIG_CMD_CACHE - #define CONFIG_CMD_USB - - #undef CONFIG_CMD_BDI - #undef CONFIG_CMD_FPGA - #undef CONFIG_CMD_IMI - #undef CONFIG_CMD_LOADS - #undef CONFIG_CMD_MISC - #undef CONFIG_CMD_SOURCE - -#endif - - -#define CONFIG_SYS_LONGHELP - -#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 -#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ - -#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 262144 - -#define CONFIG_NET_MULTI 1 -#ifdef CONFIG_NET_MULTI -#define CONFIG_DRIVER_AT91EMAC 1 -#define CONFIG_SYS_RX_ETH_BUFFER 8 -#else -#define CONFIG_DRIVER_ETHER 1 -#endif -#define CONFIG_NET_RETRY_COUNT 20 -#undef CONFIG_AT91C_USE_RMII - -#define PHYS_FLASH_1 0x10000000 -#define PHYS_FLASH_SIZE 0x1000000 /* 16 megs main flash */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_MAX_FLASH_SECT 256 -#define CONFIG_SYS_FLASH_ERASE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ -#define CONFIG_SYS_FLASH_WRITE_TOUT (2 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ -#define CONFIG_SYS_FLASH_LOCK_TOUT (10*CONFIG_SYS_HZ) /* Timeout for Flash Set Lock Bit */ -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (10*CONFIG_SYS_HZ) /* Timeout for Flash Clear Lock Bits */ -#define CONFIG_SYS_FLASH_PROTECTION /* "Real" (hardware) sectors protection */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x20000 /* after u-boot.bin */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE+CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x20000 - -#define CONFIG_SYS_LOAD_ADDR 0x21000000 /* default load address */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 115200, 57600, 38400, 19200, 9600 } - -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#define CONFIG_SYS_MAXARGS 32 /* max number of command args */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ - -#define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ - -#define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK/2) /* AT91C_TC0_CMR is implicitly set to */ - /* AT91C_TC_TIMER_DIV1_CLOCK */ - -#define CONFIG_STACKSIZE (32*1024) /* regular stack */ - -#ifdef CONFIG_USE_IRQ -#error CONFIG_USE_IRQ not supported -#endif - -#define CONFIG_SYS_DEVICE_NULLDEV 1 /* enble null device */ -#undef CONFIG_SILENT_CONSOLE /* enable silent startup */ - -#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT \ - "Press SPACE to abort autoboot in %d seconds\n", bootdelay -#define CONFIG_AUTOBOOT_STOP_STR " " -#define CONFIG_AUTOBOOT_DELAY_STR "d" - -#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ - -#endif /* __CONFIG_H */
- update to new relocation code - switch to boards.cfg - get rid of LEGACY (still a little hack in .h to compile) - add nand boot configuration - boot tested for the following configurations : 9260 (64MB RAM & nor boot) 9260_nand (64MB RAM & nand boot) 9G20_128M (128MB RAM & nor boot) 9G20_nand_128M (128MB RAM & nand boot) (nor boot is using lowlevel init)
Signed-off-by: Eric Bénard eric@eukrea.com --- board/eukrea/cpu9260/config.mk | 1 - board/eukrea/cpu9260/cpu9260.c | 161 +++++++++++-------------- board/eukrea/cpu9260/led.c | 36 +++--- boards.cfg | 8 ++ include/configs/cpu9260.h | 265 +++++++++++++++++++++++++--------------- 5 files changed, 263 insertions(+), 208 deletions(-) delete mode 100644 board/eukrea/cpu9260/config.mk
diff --git a/board/eukrea/cpu9260/config.mk b/board/eukrea/cpu9260/config.mk deleted file mode 100644 index 2077692..0000000 --- a/board/eukrea/cpu9260/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x21f00000 diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c index 61b6c33..9ec48a0 100644 --- a/board/eukrea/cpu9260/cpu9260.c +++ b/board/eukrea/cpu9260/cpu9260.c @@ -29,12 +29,13 @@ #include <common.h> #include <asm/sizes.h> #include <asm/arch/at91sam9260.h> -#include <asm/arch/at91sam9_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> -#include <asm/arch/gpio.h> +#include <asm/arch/at91_matrix.h> +#include <asm/arch/at91_pio.h> +#include <asm/arch/clk.h> #include <asm/arch/io.h> #include <asm/arch/hardware.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) @@ -53,116 +54,103 @@ DECLARE_GLOBAL_DATA_PTR; static void cpu9260_nand_hw_init(void) { unsigned long csa; + at91_smc_t *smc = (at91_smc_t *) AT91_SMC_BASE; + at91_matrix_t *matrix = (at91_matrix_t *) AT91_MATRIX_BASE; + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE;
/* Enable CS3 */ - csa = at91_sys_read(AT91_MATRIX_EBICSA); - at91_sys_write(AT91_MATRIX_EBICSA, - csa | AT91_MATRIX_CS3A_SMC_SMARTMEDIA); + csa = readl(&matrix->csa) | AT91_MATRIX_CSA_EBI_CS3A; + writel(csa, &matrix->csa);
/* Configure SMC CS3 for NAND/SmartMedia */ #if defined(CONFIG_CPU9G20) - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(2) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(2) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(4) | AT91_SMC_NCS_WRPULSE_(4) | - AT91_SMC_NRDPULSE_(4) | AT91_SMC_NCS_RDPULSE_(4)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(7) | AT91_SMC_NRDCYCLE_(7)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | - AT91_SMC_TDF_(3)); + writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(4) | + AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(4), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(7) | AT91_SMC_CYCLE_NRD(7), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(3), + &smc->cs[3].mode); #elif defined(CONFIG_CPU9260) - at91_sys_write(AT91_SMC_SETUP(3), - AT91_SMC_NWESETUP_(1) | AT91_SMC_NCS_WRSETUP_(0) | - AT91_SMC_NRDSETUP_(1) | AT91_SMC_NCS_RDSETUP_(0)); - at91_sys_write(AT91_SMC_PULSE(3), - AT91_SMC_NWEPULSE_(3) | AT91_SMC_NCS_WRPULSE_(3) | - AT91_SMC_NRDPULSE_(3) | AT91_SMC_NCS_RDPULSE_(3)); - at91_sys_write(AT91_SMC_CYCLE(3), - AT91_SMC_NWECYCLE_(5) | AT91_SMC_NRDCYCLE_(5)); - at91_sys_write(AT91_SMC_MODE(3), - AT91_SMC_READMODE | AT91_SMC_WRITEMODE | - AT91_SMC_EXNWMODE_DISABLE | - AT91_SMC_DBW_8 | - AT91_SMC_TDF_(2)); + writel(AT91_SMC_SETUP_NWE(1) | AT91_SMC_SETUP_NCS_WR(0) | + AT91_SMC_SETUP_NRD(1) | AT91_SMC_SETUP_NCS_RD(0), + &smc->cs[3].setup); + writel(AT91_SMC_PULSE_NWE(3) | AT91_SMC_PULSE_NCS_WR(3) | + AT91_SMC_PULSE_NRD(3) | AT91_SMC_PULSE_NCS_RD(3), + &smc->cs[3].pulse); + writel(AT91_SMC_CYCLE_NWE(5) | AT91_SMC_CYCLE_NRD(5), + &smc->cs[3].cycle); + writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | + AT91_SMC_MODE_EXNW_DISABLE | + AT91_SMC_MODE_DBW_8 | + AT91_SMC_MODE_TDF_CYCLE(2), + &smc->cs[3].mode); #endif
- at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + writel(1 << AT91SAM9260_ID_PIOC, &pmc->pcer);
/* Configure RDY/BSY */ - at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); + at91_set_pio_input(CONFIG_SYS_NAND_READY_PIN, 1);
/* Enable NandFlash */ - at91_set_gpio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); + at91_set_pio_output(CONFIG_SYS_NAND_ENABLE_PIN, 1); } #endif
#ifdef CONFIG_MACB static void cpu9260_macb_hw_init(void) { - unsigned long rstc; + unsigned long rstcmr; + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + at91_rstc_t *rstc = (at91_rstc_t *) AT91_RSTC_BASE;
/* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_EMAC); - - /* - * Disable pull-up on: - * RXDV (PA17) => PHY normal mode (not Test mode) - * ERX0 (PA14) => PHY ADDR0 - * ERX1 (PA15) => PHY ADDR1 - * ERX2 (PA25) => PHY ADDR2 - * ERX3 (PA26) => PHY ADDR3 - * ECRS (PA28) => PHY ADDR4 => PHYADDR = 0x0 - * - * PHY has internal pull-down - */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - pin_to_controller(AT91_PIN_PA0) + PIO_PUDR); - - rstc = at91_sys_read(AT91_RSTC_MR) & AT91_RSTC_ERSTL; + writel(1 << AT91SAM9260_ID_EMAC, &pmc->pcer); + + at91_set_pio_pullup(AT91_PIO_PORTA, 17, 1); + + rstcmr = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK;
/* Need to reset PHY -> 500ms reset */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (AT91_RSTC_ERSTL & (0x0D << 8)) | - AT91_RSTC_URSTEN); + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0xD) | + AT91_RSTC_MR_URSTEN, &rstc->mr);
- at91_sys_write(AT91_RSTC_CR, AT91_RSTC_KEY | AT91_RSTC_EXTRST); + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr);
/* Wait for end hardware reset */ - while (!(at91_sys_read(AT91_RSTC_SR) & AT91_RSTC_NRSTL)) + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) ;
/* Restore NRST value */ - at91_sys_write(AT91_RSTC_MR, AT91_RSTC_KEY | - (rstc) | - AT91_RSTC_URSTEN); - - /* Re-enable pull-up */ - writel(pin_to_mask(AT91_PIN_PA14) | - pin_to_mask(AT91_PIN_PA15) | - pin_to_mask(AT91_PIN_PA17) | - pin_to_mask(AT91_PIN_PA25) | - pin_to_mask(AT91_PIN_PA26) | - pin_to_mask(AT91_PIN_PA28), - pin_to_controller(AT91_PIN_PA0) + PIO_PUER); + writel(AT91_RSTC_KEY | rstcmr | AT91_RSTC_MR_URSTEN, &rstc->mr);
at91_macb_hw_init(); } #endif
-int board_init(void) +int board_early_init_f(void) { - /* Enable Ctrlc */ - console_init_f(); + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + + writel((1 << AT91SAM9260_ID_PIOA) | + (1 << AT91SAM9260_ID_PIOC) | + (1 << AT91SAM9260_ID_PIOB), + &pmc->pcer); + + at91_serial_hw_init(); + + return 0; +}
+ +int board_init(void) +{ /* arch number of the board */ #if defined(CONFIG_CPU9G20) gd->bd->bi_arch_number = MACH_TYPE_CPUAT9G20; @@ -171,9 +159,8 @@ int board_init(void) #endif
/* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
- at91_serial_hw_init(); #ifdef CONFIG_CMD_NAND cpu9260_nand_hw_init(); #endif @@ -188,26 +175,16 @@ int board_init(void)
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM; - if (get_ram_size((long *) PHYS_SDRAM, PHYS_SDRAM_SIZE) != - PHYS_SDRAM_SIZE) - return -1; - - gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); return 0; }
-#ifdef CONFIG_RESET_PHY_R -void reset_phy(void) -{ -} -#endif - int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x00); + rc = macb_eth_initialize(0, (void *)AT91_EMAC_BASE, 0); #endif return rc; } diff --git a/board/eukrea/cpu9260/led.c b/board/eukrea/cpu9260/led.c index e73543b..d0906bc 100644 --- a/board/eukrea/cpu9260/led.c +++ b/board/eukrea/cpu9260/led.c @@ -35,65 +35,67 @@ static unsigned int saved_state[4] = {STATUS_LED_OFF, STATUS_LED_OFF,
void coloured_LED_init(void) { + at91_pmc_t *pmc = (at91_pmc_t *) AT91_PMC_BASE; + /* Enable clock */ - at91_sys_write(AT91_PMC_PCER, 1 << AT91SAM9260_ID_PIOC); + writel(1 << AT91SAM9260_ID_PIOC, &pmc->pcer);
- at91_set_gpio_output(CONFIG_RED_LED, 1); - at91_set_gpio_output(CONFIG_GREEN_LED, 1); - at91_set_gpio_output(CONFIG_YELLOW_LED, 1); - at91_set_gpio_output(CONFIG_BLUE_LED, 1); + at91_set_pio_output(CONFIG_RED_LED, 1); + at91_set_pio_output(CONFIG_GREEN_LED, 1); + at91_set_pio_output(CONFIG_YELLOW_LED, 1); + at91_set_pio_output(CONFIG_BLUE_LED, 1);
- at91_set_gpio_value(CONFIG_RED_LED, 1); - at91_set_gpio_value(CONFIG_GREEN_LED, 1); - at91_set_gpio_value(CONFIG_YELLOW_LED, 1); - at91_set_gpio_value(CONFIG_BLUE_LED, 1); + at91_set_pio_value(CONFIG_RED_LED, 1); + at91_set_pio_value(CONFIG_GREEN_LED, 1); + at91_set_pio_value(CONFIG_YELLOW_LED, 1); + at91_set_pio_value(CONFIG_BLUE_LED, 1); }
void red_LED_off(void) { - at91_set_gpio_value(CONFIG_RED_LED, 1); + at91_set_pio_value(CONFIG_RED_LED, 1); saved_state[STATUS_LED_RED] = STATUS_LED_OFF; }
void green_LED_off(void) { - at91_set_gpio_value(CONFIG_GREEN_LED, 1); + at91_set_pio_value(CONFIG_GREEN_LED, 1); saved_state[STATUS_LED_GREEN] = STATUS_LED_OFF; }
void yellow_LED_off(void) { - at91_set_gpio_value(CONFIG_YELLOW_LED, 1); + at91_set_pio_value(CONFIG_YELLOW_LED, 1); saved_state[STATUS_LED_YELLOW] = STATUS_LED_OFF; }
void blue_LED_off(void) { - at91_set_gpio_value(CONFIG_BLUE_LED, 1); + at91_set_pio_value(CONFIG_BLUE_LED, 1); saved_state[STATUS_LED_BLUE] = STATUS_LED_OFF; }
void red_LED_on(void) { - at91_set_gpio_value(CONFIG_RED_LED, 0); + at91_set_pio_value(CONFIG_RED_LED, 0); saved_state[STATUS_LED_RED] = STATUS_LED_ON; }
void green_LED_on(void) { - at91_set_gpio_value(CONFIG_GREEN_LED, 0); + at91_set_pio_value(CONFIG_GREEN_LED, 0); saved_state[STATUS_LED_GREEN] = STATUS_LED_ON; }
void yellow_LED_on(void) { - at91_set_gpio_value(CONFIG_YELLOW_LED, 0); + at91_set_pio_value(CONFIG_YELLOW_LED, 0); saved_state[STATUS_LED_YELLOW] = STATUS_LED_ON; }
void blue_LED_on(void) { - at91_set_gpio_value(CONFIG_BLUE_LED, 0); + at91_set_pio_value(CONFIG_BLUE_LED, 0); saved_state[STATUS_LED_BLUE] = STATUS_LED_ON; }
diff --git a/boards.cfg b/boards.cfg index 105c748..2f0d1df 100644 --- a/boards.cfg +++ b/boards.cfg @@ -72,6 +72,14 @@ omap1510inn arm arm925t - ti aspenite arm arm926ejs - Marvell armada100 afeb9260 arm arm926ejs - - at91 at91cap9adk arm arm926ejs - atmel at91 +cpu9260 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260 +cpu9260_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,NANDBOOT +cpu9260_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M +cpu9260_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9260,CPU9260_128M,NANDBOOT +cpu9G20 arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20 +cpu9G20_nand arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,NANDBOOT +cpu9G20_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M +cpu9G20_nand_128M arm arm926ejs cpu9260 eukrea at91 cpu9260:CPU9G20,CPU9G20_128M,NANDBOOT top9000eval_xe arm arm926ejs top9000 emk at91 top9000:EVAL9000 top9000su_xe arm arm926ejs top9000 emk at91 top9000:SU9000 meesc arm arm926ejs - esd at91 diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index d239423..a8ada2d 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -31,35 +31,39 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_AT91_LEGACY - -#define CONFIG_DISPLAY_CPUINFO 1 +/* to be removed once maemory-map.h is fixed */ +#define AT91_BASE_SYS 0xffffe800 +#define AT91_DBGU (0xfffff200 - AT91_BASE_SYS)
#define CONFIG_SYS_AT91_MAIN_CLOCK 18432000 #define CONFIG_SYS_HZ 1000
-#define CONFIG_ARM926EJS 1 - -#if defined(CONFIG_CPU9260_128M) || defined(CONFIG_CPU9260) -#define CONFIG_CPU9260 1 -#elif defined(CONFIG_CPU9G20_128M) || defined(CONFIG_CPU9G20) -#define CONFIG_CPU9G20 1 -#endif +#define CONFIG_ARM926EJS
#if defined(CONFIG_CPU9G20) -#define CONFIG_AT91SAM9G20 1 +#define CONFIG_AT91SAM9G20 #elif defined(CONFIG_CPU9260) -#define CONFIG_AT91SAM9260 1 +#define CONFIG_AT91SAM9260 #else #error "Unknown board" #endif
+#define CONFIG_AT91FAMILY #define CONFIG_ARCH_CPU_INIT #undef CONFIG_USE_IRQ +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_BOARD_EARLY_INIT_F
-#define CONFIG_CMDLINE_TAG 1 -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +#if defined(CONFIG_NANDBOOT) +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0x23f00000 +#else +#define CONFIG_SYS_TEXT_BASE 0x00000000 +#endif
/* clocks */ #if defined(CONFIG_CPU9G20) @@ -113,8 +117,8 @@
/* EBI_CSA, 3.3V, no pull-ups for D[15:0], CS1 SDRAM, CS3 NAND Flash */ #define CONFIG_SYS_MATRIX_EBICSA_VAL \ - (AT91_MATRIX_DBPUC | AT91_MATRIX_CS1A_SDRAMC |\ - AT91_MATRIX_CS3A_SMC_SMARTMEDIA | AT91_MATRIX_VDDIOMSEL) + (AT91_MATRIX_CSA_DBPUC | AT91_MATRIX_CSA_EBI_CS1A | \ + AT91_MATRIX_CSA_EBI_CS3A | AT91_MATRIX_CSA_VDDIOMSEL_3_3V)
/* SDRAM */ /* SDRAMC_MR Mode register */ @@ -199,67 +203,68 @@ /* setup SMC0, CS0 (NOR Flash) - 16-bit */ #if defined(CONFIG_CPU9G20) #define CONFIG_SYS_SMC0_SETUP0_VAL \ - (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ - AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) + (AT91_SMC_SETUP_NWE(0) | AT91_SMC_SETUP_NCS_WR(0) | \ + AT91_SMC_SETUP_NRD(0) | AT91_SMC_SETUP_NCS_RD(0)) #define CONFIG_SYS_SMC0_PULSE0_VAL \ - (AT91_SMC_NWEPULSE_(8) | AT91_SMC_NCS_WRPULSE_(8) | \ - AT91_SMC_NRDPULSE_(14) | AT91_SMC_NCS_RDPULSE_(14)) + (AT91_SMC_PULSE_NWE(8) | AT91_SMC_PULSE_NCS_WR(8) | \ + AT91_SMC_PULSE_NRD(14) | AT91_SMC_PULSE_NCS_RD(14)) #define CONFIG_SYS_SMC0_CYCLE0_VAL \ - (AT91_SMC_NWECYCLE_(8) | AT91_SMC_NRDCYCLE_(14)) + (AT91_SMC_CYCLE_NWE(8) | AT91_SMC_CYCLE_NRD(14)) #define CONFIG_SYS_SMC0_MODE0_VAL \ - (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ - AT91_SMC_DBW_16 | \ - AT91_SMC_TDFMODE | \ - AT91_SMC_TDF_(3)) + (AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | \ + AT91_SMC_MODE_DBW_16 | \ + AT91_SMC_MODE_TDF | \ + AT91_SMC_MODE_TDF_CYCLE(3)) #elif defined(CONFIG_CPU9260) #define CONFIG_SYS_SMC0_SETUP0_VAL \ - (AT91_SMC_NWESETUP_(0) | AT91_SMC_NCS_WRSETUP_(0) | \ - AT91_SMC_NRDSETUP_(0) | AT91_SMC_NCS_RDSETUP_(0)) + (AT91_SMC_SETUP_NWE(0) | AT91_SMC_SETUP_NCS_WR(0) | \ + AT91_SMC_SETUP_NRD(0) | AT91_SMC_SETUP_NCS_RD(0)) #define CONFIG_SYS_SMC0_PULSE0_VAL \ - (AT91_SMC_NWEPULSE_(6) | AT91_SMC_NCS_WRPULSE_(6) | \ - AT91_SMC_NRDPULSE_(10) | AT91_SMC_NCS_RDPULSE_(10)) + (AT91_SMC_PULSE_NWE(6) | AT91_SMC_PULSE_NCS_WR(6) | \ + AT91_SMC_PULSE_NRD(10) | AT91_SMC_PULSE_NCS_RD(10)) #define CONFIG_SYS_SMC0_CYCLE0_VAL \ - (AT91_SMC_NWECYCLE_(6) | AT91_SMC_NRDCYCLE_(10)) + (AT91_SMC_CYCLE_NWE(6) | AT91_SMC_CYCLE_NRD(10)) #define CONFIG_SYS_SMC0_MODE0_VAL \ - (AT91_SMC_READMODE | AT91_SMC_WRITEMODE | \ - AT91_SMC_DBW_16 | \ - AT91_SMC_TDFMODE | \ - AT91_SMC_TDF_(2)) + (AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | \ + AT91_SMC_MODE_DBW_16 | \ + AT91_SMC_MODE_TDF | \ + AT91_SMC_MODE_TDF_CYCLE(2)) #endif
/* user reset enable */ #define CONFIG_SYS_RSTC_RMR_VAL \ (AT91_RSTC_KEY | \ - AT91_RSTC_PROCRST | \ - AT91_RSTC_RSTTYP_WAKEUP | \ - AT91_RSTC_RSTTYP_WATCHDOG) + AT91_RSTC_CR_PROCRST | \ + AT91_RSTC_MR_ERSTL(1) | \ + AT91_RSTC_MR_ERSTL(2))
/* Disable Watchdog */ #define CONFIG_SYS_WDTC_WDMR_VAL \ - (AT91_WDT_WDIDLEHLT | AT91_WDT_WDDBGHLT | \ - AT91_WDT_WDV | \ - AT91_WDT_WDDIS | \ - AT91_WDT_WDD) + (AT91_WDT_MR_WDIDLEHLT | AT91_WDT_MR_WDDBGHLT | \ + AT91_WDT_MR_WDV(0xfff) | \ + AT91_WDT_MR_WDDIS | \ + AT91_WDT_MR_WDD(0xfff))
/* * Hardware drivers */ -#define CONFIG_AT91_GPIO 1 -#define CONFIG_ATMEL_USART 1 +#define CONFIG_AT91SAM9_WATCHDOG +#define CONFIG_AT91_GPIO +#define CONFIG_ATMEL_USART #undef CONFIG_USART0 #undef CONFIG_USART1 #undef CONFIG_USART2 -#define CONFIG_USART3 1 /* USART 3 is DBGU */ +#define CONFIG_USART3
/* * BOOTP options */ -#define CONFIG_BOOTP_BOOTFILESIZE 1 -#define CONFIG_BOOTP_BOOTPATH 1 -#define CONFIG_BOOTP_GATEWAY 1 -#define CONFIG_BOOTP_HOSTNAME 1 +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME
/* * Command line configuration. @@ -271,37 +276,41 @@ #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_IMLS
-#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 -#define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1 -#define CONFIG_CMD_FAT 1 +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NAND +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_CMD_MII
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 #if defined(CONFIG_CPU9260_128M) || defined(CONFIG_CPU9G20_128M) -#define PHYS_SDRAM_SIZE 0x08000000 /* 128 MB */ +#define CONFIG_SYS_SDRAM_SIZE (128 * 1024 * 1024) #define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_128MB #else -#define PHYS_SDRAM_SIZE 0x04000000 /* 64 MB */ +#define CONFIG_SYS_SDRAM_SIZE (64 * 1024 * 1024) #define CONFIG_SYS_SDRC_CR_VAL CONFIG_SYS_SDRC_CR_VAL_64MB #endif
/* NAND flash */ -#define CONFIG_NAND_ATMEL 1 +#define CONFIG_NAND_ATMEL #define NAND_MAX_CHIPS 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE 0x40000000 #define CONFIG_SYS_NAND_DBW_8 1 -#define CONFIG_SYS_NAND_READY_PIN AT91_PIN_PC13 -#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIN_PC14 +#define CONFIG_SYS_NAND_READY_PIN AT91_PIO_PORTC, 13 +#define CONFIG_SYS_NAND_ENABLE_PIN AT91_PIO_PORTC, 14 #define CONFIG_SYS_NAND_MASK_ALE (1 << 21) #define CONFIG_SYS_NAND_MASK_CLE (1 << 22)
/* NOR flash */ -#define CONFIG_SYS_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 +#if defined(CONFIG_NANDBOOT) +#define CONFIG_SYS_NO_FLASH +#else +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER #define PHYS_FLASH_1 0x10000000 #define PHYS_FLASH_2 0x12000000 #define CONFIG_SYS_FLASH_BANKS_LIST \ @@ -310,23 +319,23 @@ #define CONFIG_SYS_MAX_FLASH_SECT (255+4) #define CONFIG_SYS_MAX_FLASH_BANKS 2 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT -#define CONFIG_SYS_FLASH_EMPTY_INFO 1 -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#define CONFIG_SYS_FLASH_PROTECTION #define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 +#endif
/* Ethernet */ -#define CONFIG_MACB 1 -#define CONFIG_RMII 1 -#define CONFIG_RESET_PHY_R 1 -#define CONFIG_NET_MULTI 1 +#define CONFIG_MACB +#define CONFIG_RMII +#define CONFIG_NET_MULTI #define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_MACB_SEARCH_PHY 1 +#define CONFIG_MACB_SEARCH_PHY
/* LEDS */ /* Status LED */ -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ -#define CONFIG_BOARD_SPECIFIC_LED 1 +#define CONFIG_STATUS_LED +#define CONFIG_BOARD_SPECIFIC_LED #define STATUS_LED_RED 0 #define STATUS_LED_GREEN 1 #define STATUS_LED_YELLOW 2 @@ -350,39 +359,56 @@ /* Optional value */ #define STATUS_LED_BOOT STATUS_LED_BIT
-#define CONFIG_RED_LED AT91_PIN_PC11 -#define CONFIG_GREEN_LED AT91_PIN_PC12 -#define CONFIG_YELLOW_LED AT91_PIN_PC7 -#define CONFIG_BLUE_LED AT91_PIN_PC9 +#define CONFIG_RED_LED AT91_PIO_PORTC, 11 +#define CONFIG_GREEN_LED AT91_PIO_PORTC, 12 +#define CONFIG_YELLOW_LED AT91_PIO_PORTC, 7 +#define CONFIG_BLUE_LED AT91_PIO_PORTC, 9
/* USB */ -#define CONFIG_USB_ATMEL 1 -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW +#define CONFIG_DOS_PARTITION +#define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 +#if defined(CONFIG_CPU9G20) +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9g20" +#elif defined(CONFIG_CPU9260) #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9260" +#endif #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 -#define CONFIG_USB_STORAGE 1 +#define CONFIG_USB_STORAGE
#define CONFIG_SYS_LOAD_ADDR 0x21000000 +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR
-#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM -#define CONFIG_SYS_MEMTEST_END 0x21e00000 +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END \ + (CONFIG_SYS_MEMTEST_START + CONFIG_SYS_SDRAM_SIZE - 512 * 1024)
+#if defined(CONFIG_NANDBOOT) +#define CONFIG_SYS_USE_NANDFLASH +#undef CONFIG_SYS_USE_FLASH +#else +#define CONFIG_SYS_USE_FLASH #undef CONFIG_SYS_USE_NANDFLASH -#define CONFIG_SYS_USE_FLASH 1 +#endif + +#if defined(CONFIG_CPU9G20) +#define CONFIG_SYS_BASEDIR "cpu9G20" +#elif defined(CONFIG_CPU9260) +#define CONFIG_SYS_BASEDIR "cpu9260" +#endif
#if defined(CONFIG_SYS_USE_FLASH) -#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_OVERWRITE
#define CONFIG_BOOTCOMMAND "run flashboot"
-#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=atmel_nand" +#define MTDIDS_DEFAULT "nor0=physmap-flash.0,nand0=atmel_nand" #define MTDPARTS_DEFAULT \ "mtdparts=physmap-flash.0:" \ "256k(u-boot)ro," \ @@ -393,18 +419,12 @@
#define CONFIG_BOOTARGS "root=/dev/mtdblock3 rootfstype=jffs2 "
-#if defined(CONFIG_CPU9G20) -#define CONFIG_SYS_BASEDIR "cpu9G20" -#elif defined(CONFIG_CPU9260) -#define CONFIG_SYS_BASEDIR "cpu9260" -#endif - #define CONFIG_EXTRA_ENV_SETTINGS \ "mtdids=" MTDIDS_DEFAULT "\0" \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "partition=nand0,0\0" \ "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ - "ramboot=tftpboot 0x22000000 cpu9260/uImage;" \ + "ramboot=tftpboot 0x22000000 $(basedir)/uImage;" \ "run ramargs;bootm 22000000\0" \ "flashboot=run ramargs;bootm 0x10060000\0" \ "basedir=" CONFIG_SYS_BASEDIR "\0" \ @@ -421,6 +441,52 @@ "0x10220000 0x13ffffff;cp.b 0x24000000 " \ "0x10220000 $(filesize)\0" \ "" +#elif defined(CONFIG_NANDBOOT) +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_OFFSET_REDUND 0x80000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_SIZE 0x20000 +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) +#define CONFIG_ENV_OVERWRITE + +#define CONFIG_BOOTCOMMAND "run flashboot" + +#define MTDIDS_DEFAULT "nand0=atmel_nand" +#define MTDPARTS_DEFAULT \ + "mtdparts=atmel_nand:" \ + "128k(bootstrap)ro," \ + "256k(u-boot)ro," \ + "128k(u-boot-env)ro," \ + "128k(u-boot-env2)ro," \ + "2M(kernel)," \ + "-(rootfs)" + +#define CONFIG_BOOTARGS "root=ubi0:eukrea-cpu9260-rootfs " \ + "ubi.mtd=5 rootfstype=ubifs at91sam9_wdt.heartbeat=60" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "partition=nand0,5\0" \ + "ramargs=setenv bootargs $(bootargs) $(mtdparts)\0" \ + "ramboot=tftpboot 0x22000000 $(basedir)/uImage;" \ + "run ramargs;bootm 22000000\0" \ + "flashboot=run ramargs; nand read 0x22000000 0xA0000 " \ + "0x200000; bootm 0x22000000\0" \ + "basedir=" CONFIG_SYS_BASEDIR "\0" \ + "u-boot=u-boot-eukrea-cpu9260.bin\0" \ + "kernel=uImage-eukrea-cpu9260.bin\0" \ + "rootfs=image-eukrea-cpu9260.ubi\0" \ + "updtub=tftp ${loadaddr} $(basedir)/${u-boot}; " \ + "nand erase 20000 40000; " \ + "nand write ${loadaddr} 20000 40000\0" \ + "updtui=tftp ${loadaddr} $(basedir)/${kernel}; " \ + "nand erase a0000 200000; " \ + "nand write ${loadaddr} a0000 200000\0" \ + "updtrfs=tftp ${loadaddr} $(basedir)/${rootfs}; " \ + "nand erase 2a0000 fd60000; " \ + "nand write ${loadaddr} 2a0000 ${filesize}\0" #endif
#define CONFIG_BAUDRATE 115200 @@ -435,10 +501,10 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_LONGHELP 1 -#define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_SILENT_CONSOLE 1 -#define CONFIG_NETCONSOLE 1 +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_SILENT_CONSOLE +#define CONFIG_NETCONSOLE
/* * Size of malloc() pool @@ -446,6 +512,9 @@ #define CONFIG_SYS_MALLOC_LEN \ ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 0x1000)
+#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - \ + GENERATED_GBL_DATA_SIZE) + #define CONFIG_STACKSIZE (32 * 1024)
#if defined(CONFIG_USE_IRQ)
- boot tested for the following configurations : 9260 (64MB RAM& nor boot) 9260_nand (64MB RAM& nand boot) 9G20_128M (128MB RAM& nor boot) 9G20_nand_128M (128MB RAM& nand boot) (nor boot is using lowlevel init)
Signed-off-by: Eric Bénarderic@eukrea.com
any news concerning this patch ? http://patchwork.ozlabs.org/patch/89540/
Thanks, Eric
PHYS_SDRAM_SIZE)
return -1;
- gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE,
Checkpatch warns about the volatile here.
I know the get_ram_size() prototype calls for the volatile attribute, but what is the rationale here for this? get_ram_size() just needs the RAM base address *value*; if it requires volatile accesses to it, it can arrange for these inside its definition. Besides, throughout the code base there are 19 instances of get_ram_size() callw where the argument is cast to volatile, against 130 where it is not.
Wolfgang et al.: how about removing the 'volatile' qualifier from the get_ram_size() prototype?
Eric: if your patch does not cause a warning without the volatile in the call, can you update and repost it as V2?
Checkpatch considers these errors. This is again a case where we'd want it to ignore it... or reconsider this type of macro, which intends to expand to several function arguments.
For now I'll ignore these 6 checkpatch errors.
Amicalement,
PHYS_SDRAM_SIZE)
return -1;
Amicalement,
Applied to u-boot-arm/master, thanks.
Amicalement,
- fix board support following relocation changes - switch to boards.cfg - disable i2c to keep size under 128kiB (1 sector)
Signed-off-by: Eric Bénard eric@eukrea.com --- Makefile | 10 --- board/eukrea/cpuat91/Makefile | 4 +- board/eukrea/cpuat91/config.mk | 1 - board/eukrea/cpuat91/cpuat91.c | 11 ++-- boards.cfg | 2 + include/configs/cpuat91.h | 141 ++++++++++++++++++++++------------------ 6 files changed, 87 insertions(+), 82 deletions(-) delete mode 100644 board/eukrea/cpuat91/config.mk
diff --git a/Makefile b/Makefile index 10a856a..aeb6e7c 100644 --- a/Makefile +++ b/Makefile @@ -749,16 +749,6 @@ M5485HFE_config : unconfig #========================================================================
######################################################################### -## Atmel AT91RM9200 Systems -######################################################################### - -CPUAT91_RAM_config \ -CPUAT91_config : unconfig - @mkdir -p $(obj)include - @echo "#define CONFIG_$(@:_config=) 1" >$(obj)include/config.h - @$(MKCONFIG) -n $@ -a cpuat91 arm arm920t cpuat91 eukrea at91 - -######################################################################### ## ARM926EJ-S Systems #########################################################################
diff --git a/board/eukrea/cpuat91/Makefile b/board/eukrea/cpuat91/Makefile index 15da3d8..1d62b13 100644 --- a/board/eukrea/cpuat91/Makefile +++ b/board/eukrea/cpuat91/Makefile @@ -25,7 +25,7 @@ include $(TOPDIR)/config.mk
-COBJS := cpuat91.o +COBJS := $(BOARD).o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) @@ -38,7 +38,7 @@ clean: rm -f $(SOBJS) $(OBJS)
distclean: clean - rm -f $(LIB) core *.bak .depend + rm -f $(LIB) core *.bak $(obj).depend
diff --git a/board/eukrea/cpuat91/config.mk b/board/eukrea/cpuat91/config.mk deleted file mode 100644 index 463f46b..0000000 --- a/board/eukrea/cpuat91/config.mk +++ /dev/null @@ -1 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0x21F00000 diff --git a/board/eukrea/cpuat91/cpuat91.c b/board/eukrea/cpuat91/cpuat91.c index cd4d42c..4c4dad6 100644 --- a/board/eukrea/cpuat91/cpuat91.c +++ b/board/eukrea/cpuat91/cpuat91.c @@ -47,24 +47,23 @@ int board_init(void) /* arch number of CPUAT91-Board */ gd->bd->bi_arch_number = MACH_TYPE_CPUAT91; /* adress of boot parameters */ - gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
return 0; }
int dram_init(void) { - gd->bd->bi_dram[0].start = PHYS_SDRAM; - gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((volatile long *)CONFIG_SYS_SDRAM_BASE, + CONFIG_SYS_SDRAM_SIZE); return 0; }
#ifdef CONFIG_DRIVER_AT91EMAC int board_eth_init(bd_t *bis) { - int rc = 0; - rc = at91emac_register(bis, 0); - return rc; + return at91emac_register(bis, (u32) AT91_EMAC_BASE); } #endif
diff --git a/boards.cfg b/boards.cfg index 2f0d1df..64b5f95 100644 --- a/boards.cfg +++ b/boards.cfg @@ -52,6 +52,8 @@ a320evb arm arm920t - faraday at91rm9200ek arm arm920t at91rm9200ek atmel at91 at91rm9200ek at91rm9200ek_ram arm arm920t at91rm9200ek atmel at91 at91rm9200ek:RAMBOOT eb_cpux9k2 arm arm920t - BuS at91 +cpuat91 arm arm920t cpuat91 eukrea at91 cpuat91 +cpuat91_ram arm arm920t cpuat91 eukrea at91 cpuat91:RAMBOOT cmc_pu2 arm arm920t - - at91rm9200 csb637 arm arm920t - - at91rm9200 kb9202 arm arm920t - - at91rm9200 diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index f31081d..cfaef15 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -26,30 +26,36 @@ #ifndef _CONFIG_CPUAT91_H #define _CONFIG_CPUAT91_H
-#ifdef CONFIG_CPUAT91_RAM -#define CONFIG_SKIP_LOWLEVEL_INIT 1 +#include <asm/sizes.h> + +#ifdef CONFIG_RAMBOOT +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0x21F00000 #else #define CONFIG_BOOTDELAY 1 +#define CONFIG_SYS_TEXT_BASE 0 #endif
-#define AT91C_MAIN_CLOCK 179712000 -#define AT91C_MASTER_CLOCK 59904000 - -#define AT91_SLOW_CLOCK 32768 +#define AT91C_XTAL_CLOCK 18432000 +#define AT91C_MAIN_CLOCK ((AT91C_XTAL_CLOCK / 4) * 39) +#define AT91C_MASTER_CLOCK (AT91C_MAIN_CLOCK / 3) +#define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2) +#define CONFIG_SYS_HZ 1000
-#define CONFIG_ARM920T 1 -#define CONFIG_AT91RM9200 1 -#define CONFIG_CPUAT91 1 +#define CONFIG_ARM920T +#define CONFIG_AT91RM9200 +#define CONFIG_CPUAT91 +#define CONFIG_AT91FAMILY
#undef CONFIG_USE_IRQ -#define USE_920T_MMU 1 +#define USE_920T_MMU
#ifndef CONFIG_SKIP_LOWLEVEL_INIT -#define CONFIG_SYS_USE_MAIN_OSCILLATOR 1 +#define CONFIG_SYS_USE_MAIN_OSCILLATOR /* flash */ #define CONFIG_SYS_MC_PUIA_VAL 0x00000000 #define CONFIG_SYS_MC_PUP_VAL 0x00000000 @@ -81,17 +87,15 @@ #endif /* CONFIG_SKIP_LOWLEVEL_INIT */
/* define one of these to choose the DBGU, USART0 or USART1 as console */ -#define CONFIG_AT91RM9200_USART 1 -#define CONFIG_DBGU 1 -#undef CONFIG_USART0 -#undef CONFIG_USART1 +#define CONFIG_AT91RM9200_USART +#define CONFIG_DBGU
#undef CONFIG_HARD_I2C -#define CONFIG_SOFT_I2C 1 +#undef CONFIG_SOFT_I2C #define AT91_PIN_SDA (1<<25) #define AT91_PIN_SCL (1<<26)
-#define CONFIG_SYS_I2C_INIT_BOARD 1 +#define CONFIG_SYS_I2C_INIT_BOARD #define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0
@@ -117,70 +121,77 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW 1 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10
-#define CONFIG_CMD_DHCP 1 -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_MII 1 -#define CONFIG_CMD_CACHE 1 +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_CMD_CACHE #undef CONFIG_CMD_USB #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_IMI #undef CONFIG_CMD_LOADS #undef CONFIG_CMD_NFS +#undef CONFIG_CMD_DHCP
-#define CONFIG_CMD_EEPROM 1 -#define CONFIG_CMD_I2C 1 +#ifdef CONFIG_SOFT_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_I2C +#endif
#define CONFIG_NR_DRAM_BANKS 1 -#define PHYS_SDRAM 0x20000000 -#define PHYS_SDRAM_SIZE 0x02000000 +#define CONFIG_SYS_SDRAM_BASE 0x20000000 +#define CONFIG_SYS_SDRAM_SIZE (32 * 1024 * 1024)
-#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END \ - (CONFIG_SYS_MEMTEST_START + PHYS_SDRAM_SIZE - 512 * 1024) + (CONFIG_SYS_MEMTEST_START + CONFIG_SYS_SDRAM_SIZE - 512 * 1024)
-#define CONFIG_NET_MULTI 1 -#define CONFIG_DRIVER_AT91EMAC 1 -#define CONFIG_SYS_RX_ETH_BUFFER 8 -#define CONFIG_RMII 1 -#define CONFIG_MII 1 +#define CONFIG_NET_MULTI +#define CONFIG_DRIVER_AT91EMAC +#define CONFIG_SYS_RX_ETH_BUFFER 16 +#define CONFIG_RMII +#define CONFIG_MII #define CONFIG_DRIVER_AT91EMAC_PHYADDR 1 #define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_KS8721_PHY 1 +#define CONFIG_KS8721_PHY
-#define CONFIG_SYS_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_EMPTY_INFO 1 -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE #define CONFIG_SYS_MAX_FLASH_BANKS 1 -#define CONFIG_SYS_FLASH_PROTECTION 1 +#define CONFIG_SYS_FLASH_PROTECTION #define PHYS_FLASH_1 0x10000000 #define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 #define CONFIG_SYS_MAX_FLASH_SECT 128 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 +#define PHYS_FLASH_SIZE (16 * 1024 * 1024) +#define CONFIG_SYS_FLASH_BANKS_LIST \ + { PHYS_FLASH_1 }
#if defined(CONFIG_CMD_USB) -#define CONFIG_USB_OHCI_NEW 1 -#define CONFIG_USB_STORAGE 1 -#define CONFIG_DOS_PARTITION 1 -#define CONFIG_AT91C_PQFP_UHPBU 1 +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION +#define CONFIG_AT91C_PQFP_UHPBU #undef CONFIG_SYS_USB_OHCI_BOARD_INIT -#define CONFIG_SYS_USB_OHCI_CPU_INIT 1 +#define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE AT91_USB_HOST_BASE #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91rm9200" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 15 #endif
-#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + 0x20000) -#define CONFIG_ENV_SIZE 0x20000 -#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + 128 * 1024) +#define CONFIG_ENV_SIZE (128 * 1024) +#define CONFIG_ENV_SECT_SIZE (128 * 1024)
@@ -192,29 +203,33 @@ #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING
-#define CONFIG_SYS_HZ 1000 -#define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK / 2) +#define CONFIG_SYS_MALLOC_LEN \ + ROUND(3 * CONFIG_ENV_SIZE + 128 * 1024, 4 * 1024) + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - \ + GENERATED_GBL_DATA_SIZE)
-#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024) #define CONFIG_STACKSIZE (32 * 1024) +#define CONFIG_STACKSIZE_IRQ (4 * 1024) +#define CONFIG_STACKSIZE_FIQ (4 * 1024) +
#if defined(CONFIG_USE_IRQ) #error CONFIG_USE_IRQ not supported #endif
-#define CONFIG_DEVICE_NULLDEV 1 -#define CONFIG_SILENT_CONSOLE 1 +#define CONFIG_DEVICE_NULLDEV +#define CONFIG_SILENT_CONSOLE
-#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_KEYED #define CONFIG_AUTOBOOT_PROMPT \ "Press SPACE to abort autoboot\n" #define CONFIG_AUTOBOOT_STOP_STR " " #define CONFIG_AUTOBOOT_DELAY_STR "d"
-#define CONFIG_VERSION_VARIABLE 1 +#define CONFIG_VERSION_VARIABLE
#define MTDIDS_DEFAULT "nor0=physmap-flash.0" #define MTDPARTS_DEFAULT \
any news concerning this patch ? http://patchwork.ozlabs.org/patch/89536/
Thanks, Eric
Reinhard: this was delegated to you in patchwork, but since this is only board support, not arch, and I have applied other at91-related patches in the series, I took the liberty of assigning it to myself.
Amicalement,
Dear Eric,
In message 1301848555-14404-1-git-send-email-eric@eukrea.com you wrote:
this board was cancelled long time ago so remove it as it won't be maintained anymore
board/mp2usb/Makefile | 50 ----- board/mp2usb/config.mk | 3 - board/mp2usb/flash.c | 552 ---------------------------------------------- board/mp2usb/mp2usb.c | 98 -------- boards.cfg | 1 - include/configs/mp2usb.h | 242 -------------------- 6 files changed, 0 insertions(+), 946 deletions(-) delete mode 100644 board/mp2usb/Makefile delete mode 100644 board/mp2usb/config.mk delete mode 100644 board/mp2usb/flash.c delete mode 100644 board/mp2usb/mp2usb.c delete mode 100644 include/configs/mp2usb.h
This does not apply cleanly. Can you please rebase and resubmit?
Please also make an entry about the removal in doc/README.scrapyard - thanks!
Hi Wolfgang,
in fact you already applied it ee986e2a7d1fd38568e2e5f83563b7bc4f607963 but took the 1st version which didn't remove boards.cfg (I forget to add v2 btw).
a patch finishing to work follows.
Thanks, Eric
- remove from boards.cfg - add to doc/README.scrapyard
Signed-off-by: Eric Bénard eric@eukrea.com --- boards.cfg | 1 - doc/README.scrapyard | 1 + 2 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/boards.cfg b/boards.cfg index d4cbb06..916414a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -56,7 +56,6 @@ cmc_pu2 arm arm920t - - csb637 arm arm920t - - at91rm9200 kb9202 arm arm920t - - at91rm9200 m501sk arm arm920t - - at91rm9200 -mp2usb arm arm920t - - at91rm9200 at91rm9200dk arm arm920t - atmel at91rm9200 mx1ads arm arm920t - - imx mx1fs2 arm arm920t - - imx diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 8f98b60..5cdf151 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -11,6 +11,7 @@ easily if here is something they might want to dig for...
Board Arch CPU removed Commit last known maintainer/contact ============================================================================= +mp2usb ARM AT91RM2900 ee986e2 2011-01-25 Eric Bénard eric@eukrea.com barco powerpc MPC8245 - 2010-11-23 Marc Leeman marc.leeman@barco.com ERIC powerpc 405GP d9ba451 2010-11-21 Swen Anderson sand@peppercon.de VoVPN-GW_100MHz powerpc MPC8260 26fe3d2 2010-10-24 Juergen Selent j.selent@elmeg.de
Dear =?UTF-8?q?Eric=20B=C3=A9nard?=,
Applied, thanks.
Albert ARIBAUD
Eric Bénard
