[U-Boot] [PATCH] usb: eth: smsc95xx: add LAN9500A device ID
Add LAN9500A product ID (0x9e00) in order to support LAN9500A based dongles. Tested on cm_t335.
Signed-off-by: Ilya Ledvich ilya@compulab.co.il --- drivers/usb/eth/smsc95xx.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/eth/smsc95xx.c b/drivers/usb/eth/smsc95xx.c index 7bf0a34..7a7a676 100644 --- a/drivers/usb/eth/smsc95xx.c +++ b/drivers/usb/eth/smsc95xx.c @@ -799,6 +799,7 @@ static const struct smsc95xx_dongle smsc95xx_dongles[] = { { 0x0424, 0x9500 }, /* LAN9500 Ethernet */ { 0x0424, 0x9730 }, /* LAN9730 Ethernet (HSIC) */ { 0x0424, 0x9900 }, /* SMSC9500 USB Ethernet Device (SAL10) */ + { 0x0424, 0x9e00 }, /* LAN9500A Ethernet */ { 0x0000, 0x0000 } /* END - Do not remove */ };
- { 0x0424, 0x9e00 }, /* LAN9500A Ethernet */ { 0x0000, 0x0000 } /* END - Do not remove */
Acked-by: Marek Vasut marex@denx.de
Shall I start picking this stuff up via USB tree or will you do this Tom ?
Best regards, Marek Vasut
I probably put this on you in Patchwork already so pick it up or hand it back please, either works, thanks!
Ilya Ledvich
