[U-Boot] [PATCH 0/2] usb: 2 keyboard fixes for v2015.07
Hi Marek,
While working on enabling the musb device-model support on more sunxi boards, I noticed a problem with usb-keyboards when plugged into an usb-2 hub and thus connected via the ehci code.
In the scenario of a usb-kbd connected to an ehci controller, combined with using CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE (*), an ehci code bug triggers which causes every other usb interrupt packet to get lost due to a data toggle mismatch. We've had this bug for a long time, loosing the key release packets most of the time, which did not matter, until my recent usb-kbd keyrepeat changes.
The first patch in this series fixes this, the second patch is a better safe then sorry patch I wrote while working on this.
Can you please queue both of these up for merging into v2015.07 ?
Thanks & Regards,
Hans
*) Which AFAIK sofar is only used by sunxi...
Without this we loose every other interrupt packet. We never noticed this because with keyboards the packets which we were loosing would normally be key release packets.
But now that we do keyrepeat in software instead of relying on the hid idle functionality, missing a release will result in key repeat triggering.
This commit fixes this.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- drivers/usb/host/ehci-hcd.c | 26 +++++++++++++++++++------- 1 file changed, 19 insertions(+), 7 deletions(-)
diff --git a/drivers/usb/host/ehci-hcd.c b/drivers/usb/host/ehci-hcd.c index 1e5a6e2..bf02221 100644 --- a/drivers/usb/host/ehci-hcd.c +++ b/drivers/usb/host/ehci-hcd.c @@ -1214,6 +1214,7 @@ static int _ehci_submit_control_msg(struct usb_device *dev, unsigned long pipe,
struct int_queue { int elementsize; + unsigned long pipe; struct QH *first; struct QH *current; struct QH *last; @@ -1269,7 +1270,7 @@ static struct int_queue *_ehci_create_int_queue(struct usb_device *dev, { struct ehci_ctrl *ctrl = ehci_get_ctrl(dev); struct int_queue *result = NULL; - int i; + uint32_t i, toggle;
/* * Interrupt transfers requiring several transactions are not supported @@ -1309,6 +1310,7 @@ static struct int_queue *_ehci_create_int_queue(struct usb_device *dev, goto fail1; } result->elementsize = elementsize; + result->pipe = pipe; result->first = memalign(USB_DMA_MINALIGN, sizeof(struct QH) * queuesize); if (!result->first) { @@ -1326,6 +1328,8 @@ static struct int_queue *_ehci_create_int_queue(struct usb_device *dev, memset(result->first, 0, sizeof(struct QH) * queuesize); memset(result->tds, 0, sizeof(struct qTD) * queuesize);
+ toggle = usb_gettoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe)); + for (i = 0; i < queuesize; i++) { struct QH *qh = result->first + i; struct qTD *td = result->tds + i; @@ -1357,7 +1361,9 @@ static struct int_queue *_ehci_create_int_queue(struct usb_device *dev, td->qt_altnext = cpu_to_hc32(QT_NEXT_TERMINATE); debug("communication direction is '%s'\n", usb_pipein(pipe) ? "in" : "out"); - td->qt_token = cpu_to_hc32((elementsize << 16) | + td->qt_token = cpu_to_hc32( + QT_TOKEN_DT(toggle) | + (elementsize << 16) | ((usb_pipein(pipe) ? 1 : 0) << 8) | /* IN/OUT token */ 0x80); /* active */ td->qt_buffer[0] = @@ -1372,6 +1378,7 @@ static struct int_queue *_ehci_create_int_queue(struct usb_device *dev, cpu_to_hc32((td->qt_buffer[0] + 0x4000) & ~0xfff);
*buf = buffer + i * elementsize; + toggle ^= 1; }
flush_dcache_range((unsigned long)buffer, @@ -1426,6 +1433,8 @@ static void *_ehci_poll_int_queue(struct usb_device *dev, { struct QH *cur = queue->current; struct qTD *cur_td; + uint32_t token, toggle; + unsigned long pipe = queue->pipe;
/* depleted queue */ if (cur == NULL) { @@ -1436,12 +1445,15 @@ static void *_ehci_poll_int_queue(struct usb_device *dev, cur_td = &queue->tds[queue->current - queue->first]; invalidate_dcache_range((unsigned long)cur_td, ALIGN_END_ADDR(struct qTD, cur_td, 1)); - if (QT_TOKEN_GET_STATUS(hc32_to_cpu(cur_td->qt_token)) & - QT_TOKEN_STATUS_ACTIVE) { - debug("Exit poll_int_queue with no completed intr transfer. token is %x\n", - hc32_to_cpu(cur_td->qt_token)); + token = hc32_to_cpu(cur_td->qt_token); + if (QT_TOKEN_GET_STATUS(token) & QT_TOKEN_STATUS_ACTIVE) { + debug("Exit poll_int_queue with no completed intr transfer. token is %x\n", token); return NULL; } + + toggle = QT_TOKEN_GET_DT(token); + usb_settoggle(dev, usb_pipeendpoint(pipe), usb_pipeout(pipe), toggle); + if (!(cur->qh_link & QH_LINK_TERMINATE)) queue->current++; else @@ -1452,7 +1464,7 @@ static void *_ehci_poll_int_queue(struct usb_device *dev, queue->elementsize));
debug("Exit poll_int_queue with completed intr transfer. token is %x at %p (first at %p)\n", - hc32_to_cpu(cur_td->qt_token), cur, queue->first); + token, cur, queue->first); return cur->buffer; }
When we're polling and thus handling key-repeat in software, make sure to disable idle reports, some keyboards may have these enabled by default messing up our software keyrepeat.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- common/usb_kbd.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index 49bfc09..e2af67d 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -460,10 +460,12 @@ static int usb_kbd_probe(struct usb_device *dev, unsigned int ifnum) /* We found a USB Keyboard, install it. */ usb_set_protocol(dev, iface->desc.bInterfaceNumber, 0);
+ debug("USB KBD: found set idle...\n"); #if !defined(CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP) && \ !defined(CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE) - debug("USB KBD: found set idle...\n"); usb_set_idle(dev, iface->desc.bInterfaceNumber, REPEAT_RATE / 4, 0); +#else + usb_set_idle(dev, iface->desc.bInterfaceNumber, 0, 0); #endif
debug("USB KBD: enable interrupt pipe...\n");
On Thursday, June 18, 2015 at 10:34:32 PM, Hans de Goede wrote:
Hi Marek,
Hi Hans,
Applied both, thanks!
Best regards, Marek Vasut
Hans de Goede
