Fwd: New Defects reported by Coverity Scan for Das U-Boot
Here's the latest report
---------- Forwarded message --------- From: scan-admin@coverity.com Date: Mon, Nov 21, 2022 at 12:44 PM Subject: New Defects reported by Coverity Scan for Das U-Boot To: tom.rini@gmail.com
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
2 new defect(s) introduced to Das U-Boot found with Coverity Scan. 3 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 2 of 2 defect(s)
** CID 376996: Error handling issues (CHECKED_RETURN) /drivers/net/sandbox-raw-bus.c: 40 in eth_raw_bus_post_bind()
________________________________________________________________________________________________________ *** CID 376996: Error handling issues (CHECKED_RETURN) /drivers/net/sandbox-raw-bus.c: 40 in eth_raw_bus_post_bind() 34 if (skip_localhost && local) 35 continue; 36 37 ub_ifname = calloc(IFNAMSIZ + sizeof(ub_ifname_pfx), 1); 38 strcpy(ub_ifname, ub_ifname_pfx); 39 strncat(ub_ifname, i->if_name, IFNAMSIZ);
CID 376996: Error handling issues (CHECKED_RETURN) Calling "device_bind_driver" without checking return value (as is done elsewhere 12 out of 15 times).
40 device_bind_driver(dev, "eth_sandbox_raw", ub_ifname, &child); 41 42 device_set_name_alloced(child); 43 device_probe(child); 44 priv = dev_get_priv(child); 45 if (priv) {
** CID 376995: Null pointer dereferences (FORWARD_NULL) /test/test-main.c: 518 in ut_run_tests()
________________________________________________________________________________________________________ *** CID 376995: Null pointer dereferences (FORWARD_NULL) /test/test-main.c: 518 in ut_run_tests() 512 pos = dectoul(test_insert, NULL); 513 p = strchr(test_insert, ':'); 514 if (p) 515 p++; 516 517 for (test = tests; test < tests + count; test++) {
CID 376995: Null pointer dereferences (FORWARD_NULL) Passing null pointer "p" to "strcmp", which dereferences it. [Note: The source code implementation of the function has been overridden by a builtin model.]
518 if (!strcmp(p, test->name)) 519 one = test; 520 } 521 } 522 523 for (upto = 0, test = tests; test < tests + count; test++, upto++) {
