[U-Boot-Users] [PATCH 1/2][SH] Hitachi MS7750SE Support
6 May
2007
6 May
'07
10:15 p.m.
Hi , all.
I had MS7750SE[0] that was one of the reference boards of SH correspond to u-boot.
Now , 0 . Serial 1 . SDRAM 2 . Flash working.
As for this board, NIC that is called STNIC is installed. However, This has not been ported for u-boot yet. I plan to support this NIC in the future.
[0] : http://www.hitachi-ul.co.jp/e/SH-SE/index.html
Nobuhiro Iwamatsu
E-Mail : iwamatsu@nigauri.org
GPG ID : 3170EBE9
Signed-off-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
diff --git a/Makefile b/Makefile
index 1a9b3d2..6001d1d 100644
--- a/Makefile
+++ b/Makefile
@@ -2408,6 +2408,18 @@ atstk1002_config : unconfig
+## sh4 (Renesas SuperH)
+ms7750se_config: unconfig
+ @ >include/config.h
+ @echo "#define CONFIG_MS7750SE 1" >> include/config.h
+ @./mkconfig -a $(@:_config=) sh sh4 ms7750se
clean:
find $(OBJTREE) -type f \
( -name 'core' -o -name '*.bak' -o -name '*~' \
diff --git a/board/ms7750se/Makefile b/board/ms7750se/Makefile
new file mode 100644
index 0000000..f81d56c
--- /dev/null
+++ b/board/ms7750se/Makefile
@@ -0,0 +1,43 @@
+# Copyright (C) 2007
+# Nobuhiro Iwamatsu iwamatsu@nigauri.org
+# This program is free software; you can redistribute it and/or
+# modify it under the terms of the GNU General Public License as
+# published by the Free Software Foundation; either version 2 of
+# the License, or (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+# MA 02111-1307 USA
+include $(TOPDIR)/config.mk
+LIB = lib$(BOARD).a
+OBJS := ms7750se.o
+SOBJS := lowlevel_init.o
+$(LIB): $(OBJS) $(SOBJS)
+ $(AR) crv $@ $(OBJS) $(SOBJS)
+clean:
+ rm -f $(SOBJS) $(OBJS)
+distclean: clean
+ rm -f $(LIB) core *.bak .depend
+.depend: Makefile $(SOBJS:.o=.S) $(OBJS:.o=.c)
+ $(CC) -M $(CPPFLAGS) $(SOBJS:.o=.S) $(OBJS:.o=.c) > $@
+-include .depend
diff --git a/board/ms7750se/config.mk b/board/ms7750se/config.mk
index 0000000..1eed580
--- /dev/null
+++ b/board/ms7750se/config.mk
@@ -0,0 +1,23 @@
+# NOTE: Must match value used in u-boot.lds (in this directory).
+TEXT_BASE = 0x8FFC0000
diff --git a/board/ms7750se/lowlevel_init.S b/board/ms7750se/lowlevel_init.S
index 0000000..056c691
--- /dev/null
+++ b/board/ms7750se/lowlevel_init.S
@@ -0,0 +1,169 @@
+ modified from SH-IPL+g
+ Renesaso SuperH Solution Enginge MS775x BSC setting
+ Coyright (c) 2007 Nobuhiro Iwamatsu
+#include <config.h>
+#include <version.h>
+#include <asm/processor.h>
+#ifdef CONFIG_CPU_SUBTYPE_SH7751
+#define BCR2_D_VALUE 0x2FFC /* Area 1-6 width: 32/32/32/32/32/16 */
+#define WCR1_D_VALUE 0x02770771 /* DMA:0 A6:2 A3:0 A0:1 Others:15 */
+#ifdef CONFIG_MRSHPC
+#define WCR2_D_VALUE 0xFFFE4FE7 /* A6:15 A6B:7 A5:15 A5B:7 A4:15
+ A3:2 A2:15 A1:15 A0:6 A0B:7 */
+#else /* CONFIG_MRSHPC*/
+#define WCR2_D_VALUE 0x7FFE4FE7 /* A6:3 A6B:7 A5:15 A5B:7 A4:15
+#endif /* CONFIG_MRSHPC */
+#define WCR3_D_VALUE 0x01777771 /* A6: 0-1 A5: 1-3 A4: 1-3 A3: 1-3
+ A2: 1-3 A1: 1-3 A0: 0-1 */
+#define LED_ADDRESS 0xBA000000 /* Address of LED register */
+#define RTCOR_D_VALUE 0xA50D /* Write code A5, data 0D (~15us?) */
+#define SDMR3_ADDRESS 0xFF940088 /* SDMR3 address on 32-bit bus */
+#define MCR_D1_VALUE 0x100901B4 /* SDRAM 32-bit, CAS/RAS Refresh, ... */
+#define MCR_D2_VALUE 0x500901B4 /* Same w/MRSET now 1 (mode reg cmd) */
+#define SWITCH_ADDR 0xB9000000 /* Address of DIP switches */
+#else /* CONFIG_CPU_SUBTYPE_SH7751 */
+#define BCR2_D_VALUE 0x2E3C /* Area 1-6 width: 32/32/64/16/32/16 */
+#define WCR1_D_VALUE 0x02720777 /* DMA:0 A6:2 A4:2 A3:0 Others:15 */
+#define WCR2_D_VALUE 0xFFFE4FFF /* A6:15 A6B:7 A5:15 A5B:7 A4:15
+ A3:2 A2:15 A1:15 A0:15 A0B:7 */
+#define WCR3_D_VALUE 0x01717771 /* A6: 0-1 A5: 1-3 A4: 0-1 A3: 1-3
+#define LED_ADDRESS 0xB0C00000 /* Address of LED register */
+#define RTCOR_D_VALUE 0xA510 /* Write code A5, data 10 (~15us?) */
+#define SDMR3_ADDRESS 0xFF940110 /* SDMR3 address on 64-bit bus */
+#define MCR_D1_VALUE 0x8801001C /* SDRAM 64-bit, CAS/RAS Refresh, ... */
+#define MCR_D2_VALUE 0xC801001C /* Same w/MRSET now 1 (mode reg cmd) */
+#define SWITCH_ADDR 0xb0800000 /* Address of DIP switches */
+#endif /* CONFIG_CPU_SUBTYPE_SH7751 */
+ .global lowlevel_init
+ .text
+ .align 2
+lowlevel_init:
+ mov.l L_CCR, r1 ! CCR Address
+ mov.l L_CCR_DISABLE, r0 ! CCR Data
+ mov.l r0, @r1
+init_bsc:
+ mov.l FRQCR_A,r1 /* FRQCR Address */
+ mov.l FRQCR_D,r0 /* FRQCR Data */
+ mov.w r0,@r1
+ mov.l BCR1_A,r1 /* BCR1 Address */
+ mov.l BCR1_D,r0 /* BCR1 Data */
+ mov.l r0,@r1
+ mov.l BCR2_A,r1 /* BCR2 Address */
+ mov.l BCR2_D,r0 /* BCR2 Data */
+ mov.w r0,@r1
+ mov.l WCR1_A,r1 /* WCR1 Address */
+ mov.l WCR1_D,r0 /* WCR1 Data */
+ mov.l r0,@r1
+ mov.l WCR2_A,r1 /* WCR2 Address */
+ mov.l WCR2_D,r0 /* WCR2 Data */
+ mov.l r0,@r1
+ mov.l WCR3_A,r1 /* WCR3 Address */
+ mov.l WCR3_D,r0 /* WCR3 Data */
+ mov.l r0,@r1
+ mov.l LED_A,r1 /* LED Address */
+ mov #0xff,r0 /* LED ALL 'on' */
+ shll8 r0
+ mov.w r0,@r1
+ mov.l MCR_A,r1 /* MCR Address */
+ mov.l MCR_D1,r0 /* MCR Data1 */
+ mov.l r0,@r1
+ mov.l SDMR3_A,r1 /* Set SDRAM mode */
+ mov #0,r0
+ mov.b r0,@r1
+ ! Do you need PCMCIA setting?
+ ! If so, please add the lines here...
+ mov.l RTCNT_A,r1 /* RTCNT Address */
+ mov.l RTCNT_D,r0 /* RTCNT Data */
+ mov.w r0,@r1
+ mov.l RTCOR_A,r1 /* RTCOR Address */
+ mov.l RTCOR_D,r0 /* RTCOR Data */
+ mov.w r0,@r1
+ mov.l RTCSR_A,r1 /* RTCSR Address */
+ mov.l RTCSR_D,r0 /* RTCSR Data */
+ mov.w r0,@r1
+ mov.l RFCR_A,r1 /* RFCR Address */
+ mov.l RFCR_D,r0 /* RFCR Data */
+ mov.w r0,@r1 /* Clear reflesh counter */
+ /* Wait DRAM refresh 30 times */
+ mov #30,r3
+1:
+ mov.w @r1,r0
+ extu.w r0,r2
+ cmp/hi r3,r2
+ bf 1b
+ mov.l MCR_D2,r0 /* MCR Data2 */
+ mov.l r0,@r1
+ mov #0,r0
+ mov.b r0,@r1
+ rts
+ nop
+ .align 2
+L_CCR: .long CCR
+L_CCR_DISABLE: .long 0x0808
+FRQCR_A: .long FRQCR
+FRQCR_D:
+#ifdef CONFIG_CPU_SUBTYPE_SH_R
+ .long 0x00000e1a /* 12:3:3 */
+#else
+#ifdef CONFIG_GOOD_SESH4
+ .long 0x00000e13 /* 6:2:1 */
+#else
+ .long 0x00000e23 /* 6:1:1 */
+#endif /* CONFIG_CPU_SUBTYPE_SH_R */
+BCR1_A: .long BCR1
+BCR1_D: .long 0x00000008 /* Area 3 SDRAM */
+BCR2_A: .long BCR2
+BCR2_D: .long BCR2_D_VALUE /* Bus width settings */
+WCR1_A: .long WCR1
+WCR1_D: .long WCR1_D_VALUE /* Inter-area or turnaround wait states */
+WCR2_A: .long WCR2
+WCR2_D: .long WCR2_D_VALUE /* Per-area access and burst wait states */
+WCR3_A: .long WCR3
+WCR3_D: .long WCR3_D_VALUE /* Address setup and data hold cycles */
+LED_A: .long LED_ADDRESS /* LED Address */
+RTCSR_A: .long RTCSR
+RTCSR_D: .long 0xA518 /* RTCSR Write Code A5h Data 18h */
+RTCNT_A: .long RTCNT
+RTCNT_D: .long 0xA500 /* RTCNT Write Code A5h Data 00h */
+RTCOR_A: .long RTCOR
+RTCOR_D: .long RTCOR_D_VALUE /* Set refresh time (about 15us) */
+SDMR3_A: .long SDMR3_ADDRESS
+MCR_A: .long MCR
+MCR_D1: .long MCR_D1_VALUE
+MCR_D2: .long MCR_D2_VALUE
+RFCR_A: .long RFCR
+RFCR_D: .long 0xA400 /* RFCR Write Code A4h Data 00h */
10:51 p.m.
Hi , Mark.
On Mon, 7 May 2007 09:58:39 +0200 "Jonas Mark (ST-FIR/ENG1)" Mark.Jonas@de.bosch.com wrote:
Hi Iwamatsu,
Is there also a SH3 or SH3-DSP based board in the pipe?
Yes , I can support SH3 and SH3-DSP board and, I plan to support it.
regards, Nobuhiro
Nobuhiro Iwamatsu
GPG ID : 3170EBE9
6574
2 comments
2 participants
Nobuhiro Iwamatsu
