[PATCH v1 0/2] TPS65219 U-Boot Driver Clean-Up
This clean-up series is sent in preparation to add 2 PMIC devices to the TPS65219 Driver. The changes involve replacing magic numbers with macros and replacing printf() instances with pr_err(). The intention is to remove unnecessary noise from the new PMIC device patches added to this driver.
Test Log (AM62B-P1 + TPS65219 EVM): https://gist.github.com/ramamoorthyhs/8c81e33cf6d46c8b5fc135424a5f224b
Kernel baseline used in test log: Reg: https://lore.kernel.org/all/20241217204526.1010989-1-s-ramamoorthy@ti.com/ GPIO: https://lore.kernel.org/all/20241217204755.1011731-1-s-ramamoorthy@ti.com/ MFD: https://lore.kernel.org/all/20241217204935.1012106-1-s-ramamoorthy@ti.com/
Shree Ramamoorthy (2): power: regulator: replace printf() with pr_err() power: replace magic numbers with macros
drivers/power/regulator/tps65219_regulator.c | 30 ++++++++++---------- include/power/tps65219.h | 14 +++++++-- 2 files changed, 27 insertions(+), 17 deletions(-)
Replace printf() with pr_err() because pr_err() has a uniform print format and takes into consideration the log levels supported.
Signed-off-by: Shree Ramamoorthy s-ramamoorthy@ti.com --- drivers/power/regulator/tps65219_regulator.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/tps65219_regulator.c b/drivers/power/regulator/tps65219_regulator.c index b7124fed0245..4b0fb205909a 100644 --- a/drivers/power/regulator/tps65219_regulator.c +++ b/drivers/power/regulator/tps65219_regulator.c @@ -250,7 +250,7 @@ static int tps65219_ldo_probe(struct udevice *dev) /* idx must be in 1..TPS65219_LDO_NUM */ idx = dev->driver_data; if (idx < 1 || idx > TPS65219_LDO_NUM) { - printf("Wrong ID for regulator\n"); + pr_err("Wrong ID for regulator\n"); return -EINVAL; }
@@ -271,7 +271,7 @@ static int tps65219_buck_probe(struct udevice *dev) /* idx must be in 1..TPS65219_BUCK_NUM */ idx = dev->driver_data; if (idx < 1 || idx > TPS65219_BUCK_NUM) { - printf("Wrong ID for regulator\n"); + pr_err("Wrong ID for regulator\n"); return -EINVAL; }
-----Original Message----- From: Shree Ramamoorthy s-ramamoorthy@ti.com Sent: Thursday, December 19, 2024 2:13 AM
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
return -EINVAL; }pr_err("Wrong ID for regulator\n");
-- 2.34.1
Replace magic numbers in buckval2votl() & buckvolt2val() with macros to help with clarity and correlate what the numbers correspond to in the TPS65219 datasheet.
Signed-off-by: Shree Ramamoorthy s-ramamoorthy@ti.com --- drivers/power/regulator/tps65219_regulator.c | 26 ++++++++++---------- include/power/tps65219.h | 14 +++++++++-- 2 files changed, 25 insertions(+), 15 deletions(-)
diff --git a/drivers/power/regulator/tps65219_regulator.c b/drivers/power/regulator/tps65219_regulator.c index 4b0fb205909a..88abc896b3a2 100644 --- a/drivers/power/regulator/tps65219_regulator.c +++ b/drivers/power/regulator/tps65219_regulator.c @@ -72,12 +72,12 @@ static int tps65219_buck_enable(struct udevice *dev, int op, bool *enable)
static int tps65219_buck_volt2val(int uV) { - if (uV > TPS65219_BUCK_VOLT_MAX) + if (uV > TPS65219_BUCK_3V4) return -EINVAL; - else if (uV >= 1400000) - return (uV - 1400000) / 100000 + 0x20; - else if (uV >= 600000) - return (uV - 600000) / 25000 + 0x00; + else if (uV >= TPS65219_BUCK_1V4) + return (uV - TPS65219_BUCK_1V4) / TPS65219_VOLT_STEP_100MV + TPS65219_BUCK_REG_1V4; + else if (uV >= TPS65219_BUCK_0V6) + return (uV - TPS65219_BUCK_0V6) / TPS65219_VOLT_STEP_25MV + TPS65219_BUCK_REG_0V6; else return -EINVAL; } @@ -86,12 +86,12 @@ static int tps65219_buck_val2volt(int val) { if (val > TPS65219_VOLT_MASK) return -EINVAL; - else if (val > 0x34) - return TPS65219_BUCK_VOLT_MAX; - else if (val > 0x20) - return 1400000 + (val - 0x20) * 100000; - else if (val >= 0) - return 600000 + val * 25000; + else if (val > TPS65219_BUCK_REG_3V4) + return TPS65219_BUCK_3V4; + else if (val > TPS65219_BUCK_REG_1V4) + return TPS65219_BUCK_1V4 + (val - TPS65219_BUCK_REG_1V4) * TPS65219_VOLT_STEP_100MV; + else if (val >= TPS65219_BUCK_REG_0V6) + return TPS65219_BUCK_0V6 + val * TPS65219_VOLT_STEP_25MV; else return -EINVAL; } @@ -161,7 +161,7 @@ static int tps65219_ldo_volt2val(int idx, int uV) if (uV > max) return -EINVAL; else if (uV >= base) - return (uV - TPS65219_LDO12_VOLT_MIN) / 50000; + return (uV - TPS65219_LDO12_VOLT_MIN) / TPS65219_VOLT_STEP_50MV; else return -EINVAL; } @@ -187,7 +187,7 @@ static int tps65219_ldo_val2volt(int idx, int val) else if (val <= reg_base) return base; else if (val >= 0) - return TPS65219_LDO12_VOLT_MIN + (50000 * val); + return TPS65219_LDO12_VOLT_MIN + (TPS65219_VOLT_STEP_50MV * val); else return -EINVAL; } diff --git a/include/power/tps65219.h b/include/power/tps65219.h index aa81b92266fd..e8780af2d811 100644 --- a/include/power/tps65219.h +++ b/include/power/tps65219.h @@ -17,10 +17,20 @@ #define TPS65219_BUCK_DRIVER "tps65219_buck"
#define TPS65219_VOLT_MASK 0x3F -#define TPS65219_BUCK_VOLT_MAX 3400000 - #define TPS65219_ENABLE_CTRL_REG 0x2
+#define TPS65219_VOLT_STEP_25MV 25000 +#define TPS65219_VOLT_STEP_50MV 50000 +#define TPS65219_VOLT_STEP_100MV 100000 + +#define TPS65219_BUCK_0V6 600000 +#define TPS65219_BUCK_1V4 1400000 +#define TPS65219_BUCK_3V4 3400000 + +#define TPS65219_BUCK_REG_0V6 0x00 +#define TPS65219_BUCK_REG_1V4 0x20 +#define TPS65219_BUCK_REG_3V4 0x34 + #define TPS65219_BUCK1_VOUT_REG 0xa #define TPS65219_BUCK2_VOUT_REG 0x9 #define TPS65219_BUCK3_VOUT_REG 0x8
- if (uV > TPS65219_BUCK_3V4) return -EINVAL;
- else if (uV >= TPS65219_BUCK_1V4)
Even though Not relevant to this subject. If uV is 340000, the return value is correct?
- else if (uV >= TPS65219_BUCK_0V6)
else return -EINVAL;return (uV - TPS65219_BUCK_0V6) / TPS65219_VOLT_STEP_25MV + TPS65219_BUCK_REG_0V6;
- else if (val > TPS65219_BUCK_REG_3V4)
- else if (val > TPS65219_BUCK_REG_1V4)
- else if (val >= TPS65219_BUCK_REG_0V6)
else return -EINVAL;return TPS65219_BUCK_0V6 + val * TPS65219_VOLT_STEP_25MV;
else return -EINVAL;return (uV - TPS65219_LDO12_VOLT_MIN) / TPS65219_VOLT_STEP_50MV;
else return -EINVAL;return TPS65219_LDO12_VOLT_MIN + (TPS65219_VOLT_STEP_50MV * val);
2.34.1
Hi.
Thank you for reviewing! The allowed max uV is 3.4V inclusive. If 340000 uV is detected, the first 'else if' statement should be taken.
Best, Shree
else return -EINVAL; }return (uV - TPS65219_BUCK_0V6) / TPS65219_VOLT_STEP_25MV + TPS65219_BUCK_REG_0V6;
else return -EINVAL; }return TPS65219_BUCK_0V6 + val * TPS65219_VOLT_STEP_25MV;
else return -EINVAL; }return (uV - TPS65219_LDO12_VOLT_MIN) / TPS65219_VOLT_STEP_50MV;
else return -EINVAL; }return TPS65219_LDO12_VOLT_MIN + (TPS65219_VOLT_STEP_50MV * val);
- #define TPS65219_BUCK1_VOUT_REG 0xa #define TPS65219_BUCK2_VOUT_REG 0x9 #define TPS65219_BUCK3_VOUT_REG 0x8
-- 2.34.1
-----Original Message----- From: Shree Ramamoorthy s-ramamoorthy@ti.com Sent: Thursday, December 19, 2024 7:55 AM
Hi.
Ah, I missed wrong read. Thanks for checking. If you can do, other tpsXXX can also be changed to readable macro.
Best, Shree
-- 2.34.1
-- Best, Shree Ramamoorthy PMIC Software Engineer
Hi.
Absolutely, I will make a note to work on this. Besides tps6594, are there any specific tpsXXX drivers you had in mind? Or work on patches for any TI PMIC tpsXXX U-Boot drivers that include magic numbers?
Best, Shree
-- 2.34.1
-----Original Message----- From: Shree Ramamoorthy s-ramamoorthy@ti.com Sent: Friday, December 20, 2024 2:47 AM
Hi.
readable macro.
I didn't check the entire tpsXXX drivers in more detail. But I don't like using magic numbers. :) It's a difficult to know what purpose its value is.
Best, Shree
-- 2.34.1
Jaehoon Chung
Shree Ramamoorthy
