[U-Boot] [PATCH] fastboot: nand: fix compile error
Error info " common/fb_nand.c: In function 'fb_nand_lookup': common/fb_nand.c:65:3: error: 'mtd' undeclared (first use in this function) *mtd = nand_info[dev->id->num]; ^ "
Correct fb_nand_lookup parameter name to fix this issue.
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Maxime Ripard maxime.ripard@free-electrons.com Cc: Scott Wood oss@buserror.net Cc: Tom Rini trini@konsulko.com --- common/fb_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/fb_nand.c b/common/fb_nand.c index e55ea38..ae34f48 100644 --- a/common/fb_nand.c +++ b/common/fb_nand.c @@ -34,7 +34,7 @@ __weak int board_fastboot_write_partition_setup(char *name) }
static int fb_nand_lookup(const char *partname, char *response, - struct mtd_info **nand, + struct mtd_info **mtd, struct part_info **part) { struct mtd_device *dev;
I've already received and applied a patch for this.
-Scott
I worked this patch based on upstream tree and not checked your tree.
Drop this patch, since there is already a fix.
Thanks, Peng.
-Scott
Peng Fan
Scott Wood
