Pull request: u-boot-rockchip-20220630
Hi Tom,
Sorry for lat sending this bunch of fix on rockchip platform. Please pull the rockchip fixes if possible: - Fix for rk3328 nonopi-r2s boot env; - Fix for rk8xx pmic boot on power plug-in; - Fix for tee.bin support in fit image; - rk3288 board dts update or fix; - Some rk3399 board fix;
Gitlab ci: https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip/pipelines/12562
Thanks, - Kever
The following changes since commit a063429c17616007f6c48aaa293683402ae6ea56:
Merge branch '2022-06-28-assorted-fixes' (2022-06-28 17:02:25 -0400)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20220630
for you to fetch changes up to fce1e9bba263fb5e3e589fdc5c2321f733e3de81:
rockchip: pinebook-pro: sync PBP dtb to 5.18 (2022-06-29 11:43:05 +0800)
---------------------------------------------------------------- Chris Morgan (2): power: pmic: rk8xx: Support sysreset shutdown method rockchip: Add option to prevent booting on power plug-in
Emmanuel Vadot (1): rockchip: rk3328: nanopi-r2s: Use the sdcard for the env
Jerome Forissier (1): mach-rockchip: make_fit_atf.py: support OP-TEE tee.bin v1 format
Johan Jonker (7): rockchip: include: configs: remove unused configs for tag and size rockchip: usb: phy: add rk3066/rk3188 support rockchip: board: change condition board_usb_init() in function arm: dts: rockchip: remove usb-phy fallback string for rk3188 arm: dts: rockchip: rk3288: bulk convert gpios to their constant counterparts arm: dts: rockchip: rk3288: sort mipi hdmi lvds and dp nodes arm: dts: rockchip: rk3288: move dma-controller nodes
Paweł Jarosz (1): rockchip: usb: gadget: add rk3066 product id
Peter Robinson (3): rockchip: pinebook-pro: minor SPI flash fixes rockchip: rockpro64: enable leds rockchip: pinebook-pro: sync PBP dtb to 5.18
Simon Glass (1): phycore-rk3288: Avoid enabling partition support in SPL
arch/arm/dts/rk3188.dtsi | 3 +- arch/arm/dts/rk3288-evb.dtsi | 2 +- arch/arm/dts/rk3288.dtsi | 460 ++++++++++++++++----------------- arch/arm/dts/rk3399-pinebook-pro.dts | 11 +- arch/arm/mach-rockchip/Kconfig | 10 + arch/arm/mach-rockchip/board.c | 2 +- arch/arm/mach-rockchip/make_fit_atf.py | 43 ++- configs/nanopi-r2s-rk3328_defconfig | 1 + configs/phycore-rk3288_defconfig | 1 + configs/pinebook-pro-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 + drivers/power/pmic/rk8xx.c | 84 +++++- drivers/usb/gadget/Kconfig | 1 + drivers/usb/phy/rockchip_usb2_phy.c | 8 + include/configs/rk3036_common.h | 3 - include/configs/rk3188_common.h | 2 - include/configs/rk322x_common.h | 2 - include/power/rk8xx_pmic.h | 3 + 18 files changed, 378 insertions(+), 262 deletions(-)
On Fri, Jul 01, 2022 at 10:05:55AM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
