[U-Boot] [PATCH] net: Fix emaclite driver to support little-endian microblaze
Support New emaclite AXI IP.
Signed-off-by: Michal Simek monstr@monstr.eu CC: Ben Warren biggerbadderben@gmail.com --- drivers/net/xilinx_emaclite.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 455ce0c..76af939 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -309,7 +309,7 @@ static int emaclite_recv(struct eth_device *dev) #endif } /* Get the length of the frame that arrived */ - switch(((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC)) & + switch(((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC))) & 0xFFFF0000 ) >> 16) { case 0x806: length = 42 + 20; /* FIXME size of ARP */ @@ -317,7 +317,7 @@ static int emaclite_recv(struct eth_device *dev) break; case 0x800: length = 14 + 14 + - (((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10)) & + (((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10))) & 0xFFFF0000) >> 16); /* FIXME size of IP packet */ debug ("IP Packet\n"); break;
Emaclite was using old net api that's why this patch move emaclite to NET_MULTI api.
v2: Pass base_addr as parameter
v1: Initial version --- drivers/net/xilinx_emaclite.c | 84 +++++++++++++++++++++++------------------ include/netdev.h | 1 + 2 files changed, 48 insertions(+), 37 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 0820daa..455ce0c 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -26,6 +26,7 @@ #include <common.h> #include <net.h> #include <config.h> +#include <malloc.h> #include <asm/io.h>
#undef DEBUG @@ -63,26 +64,19 @@ #define XEL_RSR_RECV_IE_MASK 0x00000008UL
typedef struct { - unsigned int baseaddress; /* Base address for device (IPIF) */ - unsigned int nexttxbuffertouse; /* Next TX buffer to write to */ - unsigned int nextrxbuffertouse; /* Next RX buffer to read from */ - unsigned char deviceid; /* Unique ID of device - for future */ + u32 baseaddress; /* Base address for device (IPIF) */ + u32 nexttxbuffertouse; /* Next TX buffer to write to */ + u32 nextrxbuffertouse; /* Next RX buffer to read from */ + uchar deviceid; /* Unique ID of device - for future */ } xemaclite;
static xemaclite emaclite;
static u32 etherrxbuff[PKTSIZE_ALIGN/4]; /* Receive buffer */
-/* hardcoded MAC address for the Xilinx EMAC Core when env is nowhere*/ -#ifdef CONFIG_ENV_IS_NOWHERE -static u8 emacaddr[ENET_ADDR_LENGTH] = { 0x00, 0x0a, 0x35, 0x00, 0x22, 0x01 }; -#else -static u8 emacaddr[ENET_ADDR_LENGTH]; -#endif - -void xemaclite_alignedread (u32 * srcptr, void *destptr, unsigned bytecount) +static void xemaclite_alignedread (u32 *srcptr, void *destptr, u32 bytecount) { - unsigned int i; + u32 i; u32 alignbuffer; u32 *to32ptr; u32 *from32ptr; @@ -107,9 +101,9 @@ void xemaclite_alignedread (u32 * srcptr, void *destptr, unsigned bytecount) } }
-void xemaclite_alignedwrite (void *srcptr, u32 destptr, unsigned bytecount) +static void xemaclite_alignedwrite (void *srcptr, u32 destptr, u32 bytecount) { - unsigned i; + u32 i; u32 alignbuffer; u32 *to32ptr = (u32 *) destptr; u32 *from32ptr; @@ -134,23 +128,16 @@ void xemaclite_alignedwrite (void *srcptr, u32 destptr, unsigned bytecount) *to32ptr++ = alignbuffer; }
-void eth_halt (void) +static void emaclite_halt(struct eth_device *dev) { debug ("eth_halt\n"); }
-int eth_init (bd_t * bis) +static int emaclite_init(struct eth_device *dev, bd_t *bis) { - uchar enetaddr[6]; - debug ("EmacLite Initialization Started\n"); memset (&emaclite, 0, sizeof (xemaclite)); - emaclite.baseaddress = XILINX_EMACLITE_BASEADDR; - - if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { - memcpy(enetaddr, emacaddr, ENET_ADDR_LENGTH); - eth_setenv_enetaddr("ethaddr", enetaddr); - } + emaclite.baseaddress = dev->iobase;
/* * TX - TX_PING & TX_PONG initialization @@ -158,7 +145,7 @@ int eth_init (bd_t * bis) /* Restart PING TX */ out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET, 0); /* Copy MAC address */ - xemaclite_alignedwrite (enetaddr, + xemaclite_alignedwrite (dev->enetaddr, emaclite.baseaddress, ENET_ADDR_LENGTH); /* Set the length */ out_be32 (emaclite.baseaddress + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); @@ -171,7 +158,7 @@ int eth_init (bd_t * bis) #ifdef CONFIG_XILINX_EMACLITE_TX_PING_PONG /* The same operation with PONG TX */ out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, 0); - xemaclite_alignedwrite (enetaddr, emaclite.baseaddress + + xemaclite_alignedwrite (dev->enetaddr, emaclite.baseaddress + XEL_BUFFER_OFFSET, ENET_ADDR_LENGTH); out_be32 (emaclite.baseaddress + XEL_TPLR_OFFSET, ENET_ADDR_LENGTH); out_be32 (emaclite.baseaddress + XEL_TSR_OFFSET + XEL_BUFFER_OFFSET, @@ -194,7 +181,7 @@ int eth_init (bd_t * bis) return 0; }
-int xemaclite_txbufferavailable (xemaclite * instanceptr) +static int xemaclite_txbufferavailable (xemaclite *instanceptr) { u32 reg; u32 txpingbusy; @@ -216,12 +203,12 @@ int xemaclite_txbufferavailable (xemaclite * instanceptr) return (!(txpingbusy && txpongbusy)); }
-int eth_send (volatile void *ptr, int len) { - - unsigned int reg; - unsigned int baseaddress; +static int emaclite_send (struct eth_device *dev, volatile void *ptr, int len) +{ + u32 reg; + u32 baseaddress;
- unsigned maxtry = 1000; + u32 maxtry = 1000;
if (len > ENET_MAX_MTU) len = ENET_MAX_MTU; @@ -293,11 +280,11 @@ int eth_send (volatile void *ptr, int len) { return 0; }
-int eth_rx (void) +static int emaclite_recv(struct eth_device *dev) { - unsigned int length; - unsigned int reg; - unsigned int baseaddress; + u32 length; + u32 reg; + u32 baseaddress;
baseaddress = emaclite.baseaddress + emaclite.nextrxbuffertouse; reg = in_be32 (baseaddress + XEL_RSR_OFFSET); @@ -353,3 +340,26 @@ int eth_rx (void) return 1;
} + +int xilinx_emaclite_initialize (bd_t *bis, int base_addr) +{ + struct eth_device *dev; + + dev = malloc(sizeof(*dev)); + if (dev == NULL) + hang(); + + memset(dev, 0, sizeof(*dev)); + sprintf(dev->name, "Xilinx_Emaclite"); + + dev->iobase = base_addr; + dev->priv = 0; + dev->init = emaclite_init; + dev->halt = emaclite_halt; + dev->send = emaclite_send; + dev->recv = emaclite_recv; + + eth_register(dev); + + return 0; +} diff --git a/include/netdev.h b/include/netdev.h index 94eedfe..64bdf7b 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -88,6 +88,7 @@ int tsi108_eth_initialize(bd_t *bis); int uec_initialize(int index); int uec_standard_init(bd_t *bis); int uli526x_initialize(bd_t *bis); +int xilinx_emaclite_initialize (bd_t *bis, int base_addr); int sh_eth_initialize(bd_t *bis); int dm9000_initialize(bd_t *bis);
Hi Michal,
Signed-off-by: Michal Simekmonstr@monstr.eu CC: Ben Warrenbiggerbadderben@gmail.com
v1: Initial version
Applied to net repo.
thanks, Ben
Hi Michal,
- switch(((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC))&
- switch(((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC)))& 0xFFFF0000 )>> 16) { case 0x806: length = 42 + 20; /* FIXME size of ARP */
(((in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10))&
(((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0x10)))& 0xFFFF0000)>> 16); /* FIXME size of IP packet */ debug ("IP Packet\n"); break;
thanks, Ben
Hello.
- switch(((ntohl(in_be32 (baseaddress + XEL_RXBUFF_OFFSET + 0xC))) &
This wouldn't pass checkpatch.pl -- spaces before ( not allowed.
Same here.
WBR, Sergei
Ben Warren
Michal Simek
Sergei Shtylyov
