[U-Boot] [PATCH 1/7] Moved SC520 Files (fix commit 407976185e0dda2c90e89027121a1071b9c77bfb)
Fixes commit 407976185e0dda2c90e89027121a1071b9c77bfb
Signed-off-by: Graeme Russ <graeme.russ at gmail.com> --- For some reason, the following patch posted on the mailing list did not apply completely: [PATCH 04/15] Moved sc520 specific code into new cpu/i386/sc520 folder --- cpu/i386/Makefile | 3 +-- cpu/i386/sc520/Makefile | 52 ++++++++++++++++++++++++++++++++++++++++++++ cpu/i386/sc520/sc520.c | 0 cpu/i386/sc520/sc520_asm.S | 3 --- 4 files changed, 53 insertions(+), 5 deletions(-) create mode 100644 cpu/i386/sc520/Makefile rename cpu/i386/{sc520.c => sc520/sc520.c} (100%) rename cpu/i386/{sc520_asm.S => sc520/sc520_asm.S} (99%)
diff --git a/cpu/i386/Makefile b/cpu/i386/Makefile index f20675a..761c4f6 100644 --- a/cpu/i386/Makefile +++ b/cpu/i386/Makefile @@ -29,8 +29,7 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o start16.o resetvec.o -COBJS = serial.o interrupts.o cpu.o timer.o sc520.o -SOBJS = sc520_asm.o +COBJS = serial.o interrupts.o cpu.o timer.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/i386/sc520/Makefile b/cpu/i386/sc520/Makefile new file mode 100644 index 0000000..ddfec23 --- /dev/null +++ b/cpu/i386/sc520/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2008 +# Graeme Russ, graeme.russ@gmail.com. +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2002 +# Daniel Engström, Omicron Ceti AB, daniel@omicron.se. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB := $(obj)lib$(SOC).a + +COBJS-$(CONFIG_SYS_SC520) += sc520.o +SOBJS-$(CONFIG_SYS_SC520) += sc520_asm.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### \ No newline at end of file diff --git a/cpu/i386/sc520.c b/cpu/i386/sc520/sc520.c similarity index 100% rename from cpu/i386/sc520.c rename to cpu/i386/sc520/sc520.c diff --git a/cpu/i386/sc520_asm.S b/cpu/i386/sc520/sc520_asm.S similarity index 99% rename from cpu/i386/sc520_asm.S rename to cpu/i386/sc520/sc520_asm.S index 59ed2b8..2042d9b 100644 --- a/cpu/i386/sc520_asm.S +++ b/cpu/i386/sc520/sc520_asm.S @@ -105,7 +105,6 @@ */
#include <config.h> -#ifdef CONFIG_SC520
.section .text .equ DRCCTL, 0x0fffef010 /* DRAM control register */ @@ -580,5 +579,3 @@ set_ecc: out: movl %ebx, %eax jmp *%ebp - -#endif /* CONFIG_SC520 */
Dear Graeme Russ,
In message 49A3C7CC.4090608@gmail.com you wrote:
Fixes commit 407976185e0dda2c90e89027121a1071b9c77bfb =
For some reason, the following patch posted on the mailing list did not app= ly completely: [PATCH 04/15] Moved sc520 specific code into new cpu/i386/sc520 folder
cpu/i386/Makefile | 3 +-- cpu/i386/sc520/Makefile | 52 ++++++++++++++++++++++++++++++++++++++++= ++++ cpu/i386/sc520/sc520.c | 0 =
cpu/i386/sc520/sc520_asm.S | 3 --- 4 files changed, 53 insertions(+), 5 deletions(-) create mode 100644 cpu/i386/sc520/Makefile rename cpu/i386/{sc520.c =3D> sc520/sc520.c} (100%) rename cpu/i386/{sc520_asm.S =3D> sc520/sc520_asm.S} (99%)
Applied to "next" branch. Thanks.
On Wed, Feb 25, 2009 at 9:27 AM, Wolfgang Denk wd@denx.de wrote:
Dear Graeme Russ,
Wolfgang,
Can this one be applied to master considering in fixes a broken build?
Regards,
Graeme
Dear Graeme Russ,
In message d66caabb0902250218k6a6acf91ie0a3223ca4380577@mail.gmail.com you wrote:
Dear Graeme Russ,
Wolfgang,
Sure. Done.
Graeme Russ
