[PATCH v2] common: memtop: Fix the return type for find_ram_top
As the return type is "int" for find_ram_top() function and returning the "base" which is of phys_addr_t is breaking when the "base" address is 64-bit. So fix this by updating the return type as phys_addr_t.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com Reviewed-by: Michal Simek michal.simek@amd.com --- Changes in v2: - Fixed the check patch warning. --- common/memtop.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/memtop.c b/common/memtop.c index 841d89e0799..bff27d8211e 100644 --- a/common/memtop.c +++ b/common/memtop.c @@ -121,8 +121,8 @@ static long region_overlap_check(struct mem_region *mem_rgn, phys_addr_t base, return (i < mem_rgn->count) ? i : -1; }
-static int find_ram_top(struct mem_region *free_mem, - struct mem_region *reserved_mem, phys_size_t size) +static phys_addr_t find_ram_top(struct mem_region *free_mem, + struct mem_region *reserved_mem, phys_size_t size) { long i, rgn; phys_addr_t base = 0;
On Fri, 20 Dec 2024 at 08:38, Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com wrote:
Acked-by: Sughosh Ganu sughosh.ganu@linaro.org
-sughosh
Changes in v2:
{ long i, rgn; phys_addr_t base = 0; -- 2.34.1
Changes in v2:
{ long i, rgn; phys_addr_t base = 0;struct mem_region *reserved_mem, phys_size_t size)
Applied. M
Michal Simek
Sughosh Ganu
