[PATCH] bloblist: Fix bloblist convention checking.
According to recently firmware handsoff spec [1]'s "Register usage at handoff boundary", Transfer List's signature value was changed from 0x40_b10b (3 bytes) to 4a0f_b10b (4 bytes).
As updating of TL's signature, register value of x1/r1 should be:
In aarch32's r1 value should be R1[23:0]: TL signature (4a0f_b10b->masked range value: 0f_b10b) R1[31:24]: version of the register convention == 1
and
In aarch64's x1 value should be X1[31:0]: TL signature (4a0f_b10b) X1[39:32]: version of the register convention == 1 X1[63:40]: MBZ (See the [2] and [3]).
Also, according to architecture, the convention is slight different:
In aarch32: R0: MBZ R1: see above R2: Compatibility location for passing a platform description devicetree R3: tl_base_pa
In aarch64: X0: Compatibility location for passing a platform description devicetree X1: see above X2: MBZ X3: tl_base_pa
This patch fix problems: 1. breaking X1 value with updated specification in aarch64 - change of length of signature field.
2. previous error value set in R1 in arm32. - length of signature should be 24, but it uses 32bit signature.
3. according to architecture, check register convetion differently.
[1] https://github.com/FirmwareHandoff/firmware_handoff [2] https://github.com/FirmwareHandoff/firmware_handoff/issues/32 [3] https://github.com/FirmwareHandoff/firmware_handoff/commit/5aa7aa1d3a1db7521...
Signed-off-by: Levi Yun yeoreum.yun@arm.com --- arch/arm/lib/xferlist.c | 8 +++++--- common/bloblist.c | 11 ++++++++++- include/bloblist.h | 5 ++++- 3 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/arch/arm/lib/xferlist.c b/arch/arm/lib/xferlist.c index f9c5d88bd4..a6349293bd 100644 --- a/arch/arm/lib/xferlist.c +++ b/arch/arm/lib/xferlist.c @@ -12,12 +12,14 @@ int xferlist_from_boot_arg(ulong addr, ulong size) { int ret;
- ret = bloblist_check(saved_args[3], size); + if (IS_ENABLED(CONFIG_64BIT)) + ret = bloblist_check_reg_conv(saved_args[0], saved_args[2], saved_args[1]); + else + ret = bloblist_check_reg_conv(saved_args[2], saved_args[0], saved_args[1]); if (ret) return ret;
- ret = bloblist_check_reg_conv(saved_args[0], saved_args[2], - saved_args[1]); + ret = bloblist_check(saved_args[3], size); if (ret) return ret;
diff --git a/common/bloblist.c b/common/bloblist.c index 11d6422b69..2008ab4d25 100644 --- a/common/bloblist.c +++ b/common/bloblist.c @@ -576,7 +576,16 @@ int bloblist_maybe_init(void)
int bloblist_check_reg_conv(ulong rfdt, ulong rzero, ulong rsig) { - if (rzero || rsig != (BLOBLIST_MAGIC | BLOBLIST_REGCONV_VER) || + ulong version = BLOBLIST_REGCONV_VER; + ulong sigval; + + sigval = (IS_ENABLED(CONFIG_64BIT)) ? + ((BLOBLIST_MAGIC & ((1UL << BLOBLIST_REGCONV_SHIFT_64) - 1)) | + ((version & BLOBLIST_REGCONV_MASK) << BLOBLIST_REGCONV_SHIFT_64)) : + ((BLOBLIST_MAGIC & ((1UL << BLOBLIST_REGCONV_SHIFT_32) - 1)) | + ((version & BLOBLIST_REGCONV_MASK) << BLOBLIST_REGCONV_SHIFT_32)); + + if (rzero || rsig != sigval || rfdt != (ulong)bloblist_find(BLOBLISTT_CONTROL_FDT, 0)) { gd->bloblist = NULL; /* Reset the gd bloblist pointer */ return -EIO; diff --git a/include/bloblist.h b/include/bloblist.h index 7fbdd622bc..f4849f22a0 100644 --- a/include/bloblist.h +++ b/include/bloblist.h @@ -83,7 +83,10 @@ enum { * Register convention version should be placed into a higher byte * https://github.com/FirmwareHandoff/firmware_handoff/issues/32 */ - BLOBLIST_REGCONV_VER = 1 << 24, + BLOBLIST_REGCONV_SHIFT_64 = 32, + BLOBLIST_REGCONV_SHIFT_32 = 24, + BLOBLIST_REGCONV_MASK = 0xff, + BLOBLIST_REGCONV_VER = 1,
BLOBLIST_BLOB_ALIGN_LOG2 = 3, BLOBLIST_BLOB_ALIGN = 1 << BLOBLIST_BLOB_ALIGN_LOG2, -- LEVI:{C3F47F37-75D8-414A-A8BA-3980EC8A46D7}
Hi Levi,
and
else
The handoff of armv7 will break if you swap arg[0] and arg[2] here. The args are already aligned in the correct order via the assembly code. Please see the 'save_boot_params' function in start.S of armv7.
Regards, Raymond
Hi Raymond!
Thanks to let me know. I couldn't see that code. But I think before checking transfer_list, It would be good to check convention first.
So, I'll change order only.
Thanks! IMPORTANT NOTICE: The contents of this email and any attachments are confidential and may also be privileged. If you are not the intended recipient, please notify the sender immediately and do not disclose the contents to any other person, use it for any purpose, or store or copy the information in any medium. Thank you.
Hi Levi,
On Tue, 9 Jul 2024 at 13:16, Yeo Reum Yun YeoReum.Yun@arm.com wrote:
Hi Raymond!
I think you don't even need to change the order.
The FW handoff must fulfill two conditions at the same time (A valid TL plus and proper register conventions). Both conditions are essential with the same priority and which one should be proceeded first is fully arbitrary.
Regards, Raymond
Hi. Raymond.
I think you don't even need to change the order. The FW handoff must fulfill two conditions at the same time (A valid TL plus and proper register conventions). Both conditions are essential with the same priority and which one should be proceeded first is fully arbitrary.
okay. then I'll restore xferlist.c.
and send patch v3. Please ignore patch v2.
Thanks!
________________________________________ From: Raymond Mao raymond.mao@linaro.org Sent: 09 July 2024 20:26 To: Yeo Reum Yun Cc: trini@konsulko.com; sjg@chromium.org; ilias.apalodimas; n-jain1@ti.com; bmeng.cn@gmail.com; u-boot@lists.denx.de Subject: Re: [PATCH] bloblist: Fix bloblist convention checking.
Hi Levi,
On Tue, 9 Jul 2024 at 13:16, Yeo Reum Yun <YeoReum.Yun@arm.commailto:YeoReum.Yun@arm.com> wrote: Hi Raymond!
Regards, Raymond IMPORTANT NOTICE: The contents of this email and any attachments are confidential and may also be privileged. If you are not the intended recipient, please notify the sender immediately and do not disclose the contents to any other person, use it for any purpose, or store or copy the information in any medium. Thank you.
Levi Yun
Raymond Mao
Yeo Reum Yun
